上板运行提示json错误
根据大神“Ethanyyy”提供的上板教程把yolov5编译成功并部署到开发板上,运行"run_example.sh"脚本进行1080P的视频推理出现以下错误:
fb_cfg_func::platform is x3
fb_cfg_func::fb_res is 1080_fb
fb_cfg_func::vio_cfg_file is ./configs/x3_video_source.json.fb
sh: write error: No such device
/usr/bin/adbd is not runnning
Detecting platform:
board : Hobot XJ3 SOC SDB
udc : b2000000.dwc3
usb-gadget is already running
after start uvc
resolution 1080P feedback start, 1080P X3 JPEG Codec…
vio_cfg_file: ./configs/x3_video_source.json.fb
(video_source.cc:286): log level has been set, log_level: 4
(vps_manager.cc:375): create vps manager fifo success, this is main process
(vps_manager.cc:436): write input group id to fifo success, write_bytes_num: 32 fifo_fd: 5
(video_source_produce.cc:99): log level has been set, log_level: 4
(inferencer.cc:107): [ERROR] Not Support model_post_process-class_name: yolov5_postprocess
(method_manager.cc:112): methods init failed
错误日志已上传至附件
1642071604857.txt
您好,后处理出错了,需要对应好输入输出接口
后处理这里已经处理过了,但是不知道为什么提示找不到class_name
代码是以库的形式提供的,需要对源码进行编译,生成库替换现有的库
代码是编译过的,生成的"libmodel_inference.so"也替换了到部署生成的deploy/lib目录了
需要内部加一些log 判断下,是否使用的是自己编译的库文件
问题已处理,手动拷贝model_inference.so/build目录下的libmodel_inference.so替换到生成的部署deploy/lib下,model_inference的make.sh 里面cp命令可能路径不对还是其他问题
现在新的问题是提示找不到模型了
[000:000] (packed_model.cpp:440): Model not exists: yolov5
(inference_engine_dnn.cc:203): not found model: yolov5
(inferencer.cc:128): LoadModelHandle failed.
日志的最后输出:
[61971.364385] x3sdbx3-samsung2G-3200:unkown: Untracked pid 4420 killed by signal 9
[61971.364731] x3sdbx3-samsung2G-3200:unkown: Untracked pid 4421 killed by signal 9
[61979.829420] alloc_contig_range: [7f070, 7f080) PFNs busy
[61979.829729] module id: 4, event id: 1 register err[had registed]
[61979.834162] alloc_contig_range: [7f070, 7f080) PFNs busy
[61979.834286] module id: 4, event id: 2 register err[had registed]
[62533.646948] x3sdbx3-samsung2G-3200:unkown: Untracked pid 4495 killed by signal 9
[62533.647294] x3sdbx3-samsung2G-3200:unkown: Untracked pid 4496 killed by signal 9
[62542.287638] module id: 4, event id: 1 register err[had registed]
[62542.292030] alloc_contig_range: [7f080, 7f090) PFNs busy
[62542.292267] module id: 4, event id: 2 register err[had registed]
[62610.358053] x3sdbx3-samsung2G-3200:unkown: Untracked pid 4589 killed by signal 9
[62610.358389] x3sdbx3-samsung2G-3200:unkown: Untracked pid 4590 killed by signal 9
[62622.538675] alloc_contig_range: [7f070, 7f080) PFNs busy
[62622.538817] module id: 4, event id: 1 register err[had registed]
[62622.543416] alloc_contig_range: [7f070, 7f080) PFNs busy
[62622.543669] module id: 4, event id: 2 register err[had registed]
infer_yolov5_config.json配置如下:
“mode”: “run_model”,-
“with_postprocess”: true,-
“model_preprocess”:{-
“class_name”: “pyramid_preprocess”,-
“pyramid_layer”: 8,-
“config”: {-
“image_process_pipeline”: [-
“pad(960, 960)”,-
“resize(672, 672)”-
“model_predict”: {-
“model_file_path”: “/userdata/deploy/yolov5_mobilenetv2_example/models/yolov5_672x672_nv12.bin”,-
“is_packed_model”: false,-
“model_name”: “yolov5”,-
“run_mode”: {-
“bpu_core”:2-
“model_post_process”: {-
“class_name”: “yolov5_postprocess”,-
“score_threshold”: 0.3,-
“nms_threshold”: 0.45,-
“nms_top_k”: 500,-
“basic_pyramid_image_height”: 540,-
“basic_pyramid_image_width”: 960,-
“src_image_height”: 2160,-
“src_image_width”: 3840-
反复测试过,模型的文件路径是没有问题的,提示
