基于Ubuntu20.04虚拟机的Docker安装与配置
测试环境为VMWare虚拟机下的Ubuntu 20.04
安装方法参考https://docs.docker.com/engine/install/ubuntu/,选择直接通过apt包管理工具安装
  • 首先更新apt索引,安装必要依赖:
$ sudo apt-get update
$ sudo apt-get install \
    ca-certificates \
    curl \
    gnupg \
    lsb-release
  • 然后添加Docker仓库的GPG公钥:
$ sudo mkdir -p /etc/apt/keyrings
$ curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
  • 将Docker仓库添加到apt源中:
$ echo \
  "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu \
  $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
  • 安装最新版Docker:
$ sudo apt-get install docker-ce docker-ce-cli containerd.io docker-compose-plugin
  • 为了测试安装是否成功,运行一个简单镜像:
$ sudo docker run hello-world
镜像正常运行,安装成功!
