系统启动问题
  2. 问题涉及的技术领域: (硬件、操作系统)
  3. 问题描述:无法读出tf卡中的系统。
  4. 复现概率:(必现) 已进行的排查措施 ,日志中出现:
mmc fail to send set blkcnt cmd
fs_devread read outside partition 542819616
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
disable watchdog success !
系统类型问题么? 该如何修复呢?
5.日志如下:
bypass bpu image
clear keybank!!!
SFLOW_DBG_EN
Trying to boot from RAM
SFLOW_CLR_KEY
SFLOW_REG_LD
install_portal copy portal
hb som type: 5
X3 PI reset VDD_SD done
U-Boot 2018.09-g40785bca (May 27 2022 - 16:30:48 +0800)
Model: Hobot XJ3 Soc Board
DRAM: system DDR size: 0xffe00000
4 GiB
MMC: dwmmc@A5010000: 0, dwmmc@A5011000: 1, dwmmc@A5012000: 2 (SD)
Loading Environment from UBI… GigaDevice SPI NAND was found.
In: serial@a5000000
Out: serial@a5000000
Err: serial@a5000000
Net: x3 sdb reset eth phy done
Warning: ethernet@A5014000 (eth0) using random MAC address - 1e:9c:db:09:a8:2a
eth0: ethernet@A5014000
Disable cnn cores ..
dtb_name:hobot-x3-pi.dtb
base board type: X3 SDB
bootmode: NAND
board_id = 31540334
enable watchdog success !
switch to partitions #0, OK
mmc2 is current device
您好,
你这个看上去emmc没有挂载上来的
您好,循环重启需要更换大功率的电源,5V3A以上即可
无法进入系统您需要换一张sd卡进行烧录,c10 以上大厂的新卡即可,如闪迪等
您好,您的问题我们已收到,技术同事稍后将会为您解答~
您好,麻烦问下,日志中的这个是什么意思呢?
