root@ubuntu:~# source /opt/tros/local_setup.bash
root@ubuntu:~# ros2 launch websocket hobot_websocket.launch.py
[INFO] [launch]: All log files can be found below /root/.ros/log/2022-08-28-01-54-06-840120-ubuntu-3169
[INFO] [mipi_cam-1]: process started with pid [3179]
[INFO] [hobot_codec_republish-2]: process started with pid [3181]
[INFO] [mono2d_body_detection-3]: process started with pid [3183]
[INFO] [websocket-4]: process started with pid [3185]
[websocket-4] [INFO] [1661622848.318705824] [websocket]:
[websocket-4] Parameter:
[websocket-4] image_topic: /image_jpeg
[websocket-4] smart_topic: /hobot_mono2d_body_detection
[websocket-4] output_fps: 10
[websocket-4] [INFO] [1661622848.319796693] [websocket]: Websocket using image mjpeg
[mono2d_body_detection-3] (MOTMethod.cpp:34): MOTMethod::Init config/iou2_euclid_method_param.json
[mono2d_body_detection-3] (IOU2.cpp:29): IOU2 Mot::Init config/iou2_euclid_method_param.json
[mono2d_body_detection-3] (MOTMethod.cpp:34): MOTMethod::Init config/iou2_method_param.json
[mono2d_body_detection-3] (IOU2.cpp:29): IOU2 Mot::Init config/iou2_method_param.json
[mipi_cam-1] [ERROR] [1661622848.684096286] [mipi_cam]: Cannot open ‘F37’: 121, Remote I/O error
[mipi_cam-1] [ERROR] [1661622848.685219861] [mipi_node]: video dev ‘F37’ config err
[mipi_cam-1] what(): could not create publisher: rcl node’s context is invalid, at /home/kairui/cc_ws_release/tros_ws/src/tros/rcl/rcl/src/rcl/node.c:441
[ERROR] [mipi_cam-1]: process has died [pid 3179, exit code -6, cmd ‘/opt/tros/lib/mipi_cam/mipi_cam --ros-args --log-level error --ros-args --params-file /tmp/launch_params_lvl59h05 --params-file /tmp/launch_params_vx6ayou_ --params-file /tmp/launch_params_0wrrky0j --params-file /tmp/launch_params_e0_5b2_t --params-file /tmp/launch_params_vmc5hwrr’].
