编解码问题
  1. 系统软件版本: x3pi_ubuntu_v1.0.2 — x3pi_ubuntu_server_disk_20220718195941
  2. 问题涉及的技术领域: 解码
  3. 问题描述: 当出现一次HB_VPS_SendFrame Failed 后,后面的这个group 6全部内部失败,并有Please check the task state 6这种报错。
  4. 复现概率:(必现):
2022-08-30 23:53:31.100 E HbVps.cpp:151 input | HB_VPS_SendFrame Failed. group:6 ret = -268696584
2022-08-30 23:53:31.101 E HbVdec.cpp:310 free | HB_VDEC_ReleaseFrame Failed6 ret = -269024256
2022-08-30 23:53:31.151 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.252 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.352 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.453 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.553 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.567 E HbVdec.cpp:237 input | HB_VDEC_SendStream Failed. group:6 ret = -269024256
2022-08-30 23:53:31.654 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.718 E HbVdec.cpp:237 input | HB_VDEC_SendStream Failed. group:6 ret = -269024256
2022-08-30 23:53:31.754 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.855 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:31.868 E HbVdec.cpp:237 input | HB_VDEC_SendStream Failed. group:6 ret = -269024256
2022-08-30 23:53:31.919 E HbVdec.cpp:237 input | HB_VDEC_SendStream Failed. group:6 ret = -269024256
2022-08-30 23:53:31.955 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:32.055 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:32.069 E HbVdec.cpp:237 input | HB_VDEC_SendStream Failed. group:6 ret = -269024256
2022-08-30 23:53:32.156 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
2022-08-30 23:53:32.221 E HbVdec.cpp:237 input | HB_VDEC_SendStream Failed. group:6 ret = -269024256
2022-08-30 23:53:32.257 E HbVdec.cpp:283 output | HB_VDEC_GetFrame Failed. group:6 ret = -269024256
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][76176.77104][64157:3079602][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“vdec”][video/src/hb_vdec.c:742] [76176.771110]HB_VDEC_GetFrame[742]: [HB_VDEC] HB_VDEC_GetFrame:742 Failed VdChn = 6 s32Ret = -269024256
[ERROR][“vdec”][video/src/hb_vdec.c:437] [76176.851956]HB_VDEC_QueryStatus[437]: [HB_VDEC] HB_VDEC_QueryStatus:437 Failed to hb_mm_mc_release VeChn = 6 s32Ret = -269024256
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][76176.85206][64157:3079600][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“vdec”][video/src/hb_vdec.c:665] [76176.852104]HB_VDEC_SendStream[665]: [HB_VDEC] HB_VDEC_SendStream:665 Failed VeChn = 6 s32Ret = -269024256
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][76176.87139][64157:3079602][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“vdec”][video/src/hb_vdec.c:742] [76176.871488]HB_VDEC_GetFrame[742]: [HB_VDEC] HB_VDEC_GetFrame:742 Failed VdChn = 6 s32Ret = -269024256
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][76176.97182][64157:3079602][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“vdec”][video/src/hb_vdec.c:742] [76176.971913]HB_VDEC_GetFrame[742]: [HB_VDEC] HB_VDEC_GetFrame:742 Failed VdChn = 6 s32Ret = -269024256
[ERROR][“vdec”][video/src/hb_vdec.c:437] [76177.002491]HB_VDEC_QueryStatus[437]: [HB_VDEC] HB_VDEC_QueryStatus:437 Failed to hb_mm_mc_release VeChn = 6 s32Ret = -269024256
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][76177.00256][64157:3079600][TASK] It’s not allowd to do this operation. Please check the task state 6.
并且 报错是vdChn,但是从解码信息看却是通道0停止了,这是啥问题
-—decode param----
dec_idx dec_id feed_mode pix_fmt bitstream_buf_size bitstream_buf_count frame_buf_count
0 h264 1 1 3110912 1 1
1 h264 1 1 3110912 1 1
2 h264 1 1 3110912 1 1
3 h264 1 1 3110912 1 1
4 h264 1 1 3110912 1 1
5 h264 1 1 3110912 1 1
6 h264 1 1 3110912 1 1
7 h264 1 1 3110912 1 1
-—h264 decode param----
dec_idx dec_id reorder_enable skip_mode bandwidth_Opt
0 h264 1 0 1
1 h264 1 0 1
2 h264 1 0 1
3 h264 1 0 1
4 h264 1 0 1
5 h264 1 0 1
6 h264 1 0 1
7 h264 1 0 1
-—decode frameinfo----
dec_idx dec_id display_width display_height
0 h264 0 0
1 h264 1920 1080
2 h264 1920 1080
3 h264 1920 1080
4 h264 1920 1080
5 h264 1920 1080
6 h264 1920 1080
7 h264 1920 1080
-—decode status----
dec_idx dec_id cur_input_buf_cnt cur_output_buf_cnt total_input_buf_cnt total_output_buf_cnt
0 h264 1 1 1 1
1 h264 0 1 216287 216287
2 h264 0 1 216230 216230
3 h264 0 1 216258 216258
4 h264 0 1 216281 216279
5 h264 0 1 216305 216302
6 h264 0 1 216293 216293
7 h264 0 1 216270 216270
您好,该问题可以请利尔达协助解决,利尔达有问题也可以一起在这里反馈
