运行MIPI GC4663摄像头Web展示例程报错,与其他提问问题不一样
  1. 系统软件版本:x3_ubuntu_v1.0.4
  2. 问题涉及的技术领域:例程启动不正常, MIPI相机: 官方指定的400W, GC4663
  3. 问题描述:脚本:start_nginx.sh和 例程:mipi_camera_web.py 先后启动nginx和python例程,均无报错,然后点击web页面1路后报错,详情附后
  4. 复现概率:每次必现,重启依旧
  5. 提供必要的问题日志:
相机查询: 0x29
sunrise@ubuntu:~$ sudo i2cdetect -y -r 1
[sudo] password for sunrise:
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
70: -- -- -- -- -- -- -- --
启动python程序报错:
sunrise@ubuntu:/app/ai_inference/05_web_display_camera_sample$ clear
sunrise@ubuntu:/app/ai_inference/05_web_display_camera_sample$ sudo python3 ./mipi_camera_web.py
[C][3429][09-01][09:58:21:825][configuration.cpp:51][EasyDNN]EasyDNN version: 0.1.1
[BPU_PLAT]BPU Platform Version(1.3.1)!
[HBRT] set log level as 0. version = 3.14.5
[DNN] Runtime version = 1.9.7_(3.14.5 HBRT)
start ptf 547721327072
Error: no vps chn can be get
[x3_venc_file]:[593]:Invalid image address!
connection handler failed
TypeError: expected bytes, NoneType found
  File "/usr/local/lib/python3.8/dist-packages/websockets/legacy/server.py", line 232, in handler
    await self.ws_handler(self)
  File "/usr/local/lib/python3.8/dist-packages/websockets/legacy/server.py", line 1146, in _ws_handler
    return await cast(
  File "./mipi_camera_web.py", line 249, in web_service
    enc.encode_file(origin_image)
SystemError: <method 'encode_file' of 'libsrcampy.Encoder' objects> returned a result with an error set
    return await cast(
^A^CTraceback (most recent call last):
  File "./mipi_camera_web.py", line 262, in <module>
    asyncio.get_event_loop().run_forever()
  File "/usr/lib/python3.8/asyncio/base_events.py", line 570, in run_forever
    self._run_once()
  File "/usr/lib/python3.8/asyncio/base_events.py", line 1823, in _run_once
    event_list = self._selector.select(timeout)
  File "/usr/lib/python3.8/selectors.py", line 468, in select
    fd_event_list = self._selector.poll(timeout, max_ev)
KeyboardInterrupt
【INFO】: Offload model "fcos_512x512_nv12" Successfully.
  1. 软件上是否有做自定义修改: 没有修改,原装程序
mipi不带web的可以正常启动.
想咨询下该如何排查?
你用的是什么浏览器打开的?
谷歌浏览器, 版本 104.0.5112.81(正式版本) (64 位)
我刚在tros下跑用edge(版本 104.0.1293.54 (正式版本) (64 位))可以web浏览实时图像,稍后回头看下这个实例在edge下的情况
只有tros上运行对应例程是可以, 访问点击web页面后就出错
