ros2 run usb_cam usb_cam_node_exe
[INFO] [1672317097.868193768] [usb_cam]: camera_name value: default_cam
[WARN] [1672317097.868701993] [usb_cam]: framerate: 10.000000
[INFO] [1672317097.882498675] [usb_cam]: using default calibration URL
[INFO] [1672317097.882686396] [usb_cam]: camera calibration URL: file:///root/.ros/camera_info/default_cam.yaml
[ERROR] [1672317097.883022644] [camera_calibration_parsers]: Unable to open camera calibration file [/root/.ros/camera_info/default_cam.yaml]
[WARN] [1672317097.883111569] [usb_cam]: Camera calibration file /root/.ros/camera_info/default_cam.yaml not found
[INFO] [1672317097.883251058] [usb_cam]: Starting ‘default_cam’ (/dev/video0) at 640x480 via mmap (yuyv) at 10 FPS
[ERROR] [1672317097.892144336] [usb_cam]: /dev/video0 is no video capture device
[INFO] [1672317097.892349133] [usb_cam]: This Cameras Supported Formats:
[INFO] [1672317097.892615741] [usb_cam]: starting timer 100
