第一次用`dmesg`不太会用,如果用法错了请指正
第 15 行开始报误
第 19 行执行dmesg
[TCP] Lset drive: 100 -100[TCP] Sset drive: 0 0[TCP] Fset drive: 100 100[TCP] Sset drive: 0 0[TCP] Fset drive: 100 100[TCP] Sset drive: 0 0[TCP] Fset drive: 100 100[ERROR]["vps"][vps/hb_vps_api.c:2438] [136.318407]HB_VPS_GetChnFrame[2438]: G0 VPS error get chn1 frame timeout[ERROR]["vio_bufmgr"][utils/hb_vio_buffer_mgr.c:2011] [136.318526]buf_mgr_print_qcount[2011]: Mgr(1)state:Total(5)Avail(2)Process(3)Done(0)Repro(0)User(0).HB_VPS_GetChnFrame Failed. ret = -268696588[TCP] Sset drive: 0 0[ERROR]["vio_core"][commom_grp/binding_main.c:1541] [138.808085]comm_channel_bump_thread[1541]: G0 IPU_MODULE select too much timeout, retry[ERROR]["vio_core"][commom_grp/binding_main.c:1541] [139.308346]comm_channel_bump_thread[1541]: G0 IPU_MODULE select too much timeout, retry[ERROR]["vio_core"][commom_grp/binding_main.c:1541] [139.808567]comm_channel_bump_thread[1541]: G0 IPU_MODULE select too much timeout, retry[ERROR]["vio_core"][commom_grp/binding_main.c:1541] [140.308839]comm_channel_bump_thread[1541]: G0 IPU_MODULE select too much timeout, retry[ERROR]["vio_core"][commom_grp/binding_main.c:1541] [140.809100]comm_channel_bump_thread[1541]: G0 IPU_MODULE select too much timeout, retry^CException ignored in: <module 'threading' from '/usr/lib/python3.8/threading.py'>Traceback (most recent call last): File "/usr/lib/python3.8/threading.py", line 1388, in _shutdown lock.acquire()KeyboardInterrupt: [ERROR]["vio_core"][commom_grp/binding_main.c:1541] [141.309303]comm_channel_bump_thread[1541]: G0 IPU_MODULE select too much timeout, retrysunrise@ubuntu:~$ dmesg[ 0.000000] Booting Linux on physical CPU 0x0[ 0.000000] Linux version 4.14.87 (root@horizon-sz-server) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #1 SMP PREEMPT Thu Dec 1 19:06:42 CST 2022[ 0.000000] Boot CPU: AArch64 Processor [410fd034][ 0.000000] Machine model: Hobot X3 PI[ 0.000000] earlycon: hobot0 at MMIO 0x00000000a5000000 (options '')[ 0.000000] bootconsole [hobot0] enabled[ 0.000000] OF: reserved mem: OVERLAP DETECTED! image_r5_mem (0x0000000080000000--0x0000000080010000) overlaps with msg_r5_mem (0x000000008000f000--0x0000000080010000)[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000004000000, size 672 MiB[ 0.000000] OF: reserved mem: initialized node ion_cma, compatible id shared-dma-pool[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000[ 0.000000] On node 0 totalpages: 1047808[ 0.000000] DMA zone: 8180 pages used for memmap[ 0.000000] DMA zone: 0 pages reserved[ 0.000000] DMA zone: 523520 pages, LIFO batch:31[ 0.000000] Normal zone: 8192 pages used for memmap[ 0.000000] Normal zone: 524288 pages, LIFO batch:31[ 0.000000] psci: probing for conduit method from DT.[ 0.000000] psci: PSCIv1.1 detected in firmware.[ 0.000000] psci: Using standard PSCI v0.2 function IDs[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.[ 0.000000] psci: SMC Calling Convention v1.1[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc17ff2a000 s65176 r8192 d29032 u102400[ 0.000000] pcpu-alloc: s65176 r8192 d29032 u102400 alloc=25*4096[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0[ 0.000000] CPU features: enabling workaround for ARM erratum 845719[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1031436[ 0.000000] Kernel command line: earlycon loglevel=8 kgdboc=ttyS0 video=hobot:x3sdb-hdmi console=ttyS0,921600 raid=noautodetect hobotboot.reson=POWER_RESET rootfstype=ext4 rw rootwait ubi.mtd=2,2048 "mtdparts=hr_nand.0:6291456@0x0(miniboot),2097152@0x600000(env),26214400@0x800000(boot),57671680@0x2000000(system),-@0x5700000(userdata)" root=/dev/mmcblk2p1[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)[ 0.000000] software IO TLB [mem 0x7afff000-0x7efff000] (64MB) mapped at [ffffffc07afff000-ffffffc07effefff][ 0.000000] Memory: 3319644K/4191232K available (10494K kernel code, 1304K rwdata, 5748K rodata, 1088K init, 9555K bss, 167076K reserved, 704512K cma-reserved)[ 0.000000] Virtual kernel memory layout:[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)[ 0.000000] .text : 0xffffff8008000000 - 0xffffff8008a40000 ( 10496 KB)[ 0.000000] .rodata : 0xffffff8008a40000 - 0xffffff8008fe0000 ( 5760 KB)[ 0.000000] .init : 0xffffff8008fe0000 - 0xffffff80090f0000 ( 1088 KB)[ 0.000000] .data : 0xffffff80090f0000 - 0xffffff8009236008 ( 1305 KB)[ 0.000000] .bss : 0xffffff8009236008 - 0xffffff8009b8aed8 ( 9556 KB)[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)[ 0.000000] 0xffffffbf00008000 - 0xffffffbf06000000 ( 95 MB actual)[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc180000000 ( 6142 MB)[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1[ 0.000000] ftrace: allocating 36255 entries in 142 pages[ 0.000000] Preemptible hierarchical RCU implementation.[ 0.000000] Tasks RCU enabled.[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0[ 0.000000] parent_rate: 0, dclk->rate:2666000000, pre_ddr_rate:0, res.a0:139716584[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns[ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns[ 0.001193] clocksource: hobot_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns[ 0.002965] Console: colour dummy device 80x25[ 0.003535] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)[ 0.004841] pid_max: default: 32768 minimum: 301[ 0.005496] Security Framework initialized[ 0.006014] AppArmor: AppArmor disabled by boot time parameter[ 0.006857] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)[ 0.007726] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)[ 0.023769] ASID allocator initialised with 65536 entries[ 0.031766] Hierarchical SRCU implementation.[ 0.063826] smp: Bringing up secondary CPUs ...[ 0.100035] Detected VIPT I-cache on CPU1[ 0.100070] CPU1: Booted secondary processor [410fd034][ 0.136084] Detected VIPT I-cache on CPU2[ 0.136105] CPU2: Booted secondary processor [410fd034][ 0.172144] Detected VIPT I-cache on CPU3[ 0.172164] CPU3: Booted secondary processor [410fd034][ 0.172217] smp: Brought up 1 node, 4 CPUs[ 0.176280] SMP: Total of 4 processors activated.[ 0.176874] CPU features: detected feature: 32-bit EL0 Support[ 0.177692] CPU: All CPU(s) started at EL1[ 0.178220] alternatives: patching kernel code[ 0.179815] devtmpfs: initialized[ 0.189065] random: get_random_u32 called from bucket_table_alloc+0x108/0x270 with crng_init=0[ 0.190701] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns[ 0.191946] futex hash table entries: 1024 (order: 5, 131072 bytes)[ 0.208566] xor: automatically using best checksumming function 32regs [ 0.209504] pinctrl core: initialized pinctrl subsystem[ 0.210730] NET: Registered protocol family 16[ 0.212163] vdso: 2 pages (1 code @ ffffff8008a46000, 1 data @ ffffff80090f4000)[ 0.213108] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.[ 0.214701] DMA: preallocated 256 KiB pool for atomic allocations[ 0.215773] pstore: using zlib compression[ 0.216566] console [pstore-1] enabled[ 0.217161] pstore: Registered ramoops as persistent store backend[ 0.217946] ramoops: attached 0x40000@0x3fc0000, ecc: 0/0[ 0.222924] hobot_dma a1005000.dma: Hobot DMA Engine Driver Probed!![ 0.236830] SCSI subsystem initialized[ 0.237451] media: Linux media interface: v0.10[ 0.238043] Linux video capture interface: v2.00[ 0.238672] pps_core: LinuxPPS API ver. 1 registered[ 0.239299] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>[ 0.240632] PTP clock support registered[ 0.241784] ion_dummy: not reserve carveout memory, try to alloc from cma[ 0.378199] Advanced Linux Sound Architecture Driver Initialized.[ 0.379359] usbcore: registered new interface driver usbfs[ 0.380085] usbcore: registered new interface driver hub[ 0.380838] usbcore: registered new device driver usb[ 0.381838] clocksource: Switched to clocksource arch_sys_counter[ 0.429358] VFS: Disk quotas dquot_6.6.0[ 0.429934] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)[ 0.430868] FS-Cache: Loaded[ 0.431351] CacheFiles: Loaded[ 0.436552] NET: Registered protocol family 2[ 0.437473] TCP established hash table entries: 32768 (order: 6, 262144 bytes)[ 0.438618] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)[ 0.439845] TCP: Hash tables configured (established 32768 bind 32768)[ 0.440756] UDP hash table entries: 2048 (order: 4, 65536 bytes)[ 0.441586] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)[ 0.442614] NET: Registered protocol family 1[ 0.443443] RPC: Registered named UNIX socket transport module.[ 0.444194] RPC: Registered udp transport module.[ 0.444791] RPC: Registered tcp transport module.[ 0.445390] RPC: Registered tcp NFSv4.1 backchannel transport module.[ 0.446959] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available[ 0.449164] audit: initializing netlink subsys (disabled)[ 0.449975] audit: type=2000 audit(0.448:1): state=initialized audit_enabled=0 res=1[ 0.450283] Initialise system trusted keyrings[ 0.450360] workingset: timestamp_bits=46 max_order=20 bucket_order=0[ 0.454260] zbud: loaded[ 0.455807] squashfs: version 4.0 (2009/01/31) Phillip Lougher[ 0.456666] exFAT: Version 1.2.9[ 0.457145] FS-Cache: Netfs 'nfs' registered for caching[ 0.458394] NFS: Registering the id_resolver key type[ 0.459046] Key type id_resolver registered[ 0.459574] Key type id_legacy registered[ 0.460089] nfs4filelayout_init: NFSv4 File Layout Driver Registering...[ 0.460942] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).[ 0.465104] NET: Registered protocol family 38[ 0.465675] async_tx: api initialized (async)[ 0.466282] Key type asymmetric registered[ 0.466799] Asymmetric key parser 'x509' registered[ 0.467480] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)[ 0.468495] io scheduler noop registered[ 0.469142] io scheduler cfq registered (default)[ 0.469737] io scheduler mq-deadline registered[ 0.470336] io scheduler kyber registered[ 0.471513] pinctrl-single a6003170.pinctrl_voltag: 64 pins at pa ffffff8009c3d170 size 8[ 0.472848] pinctrl-single a6004000.pinctrl: 128 pins at pa ffffff8009c51000 size 512[ 0.474073] pinctrl_cdev soc:pinctrl_cdev@0xA6004000: start probe[ 0.474961] pinctrl_cdev soc:pinctrl_cdev@0xA6004000: probe ok[ 0.475825] gpio-x3 a6003000.gpio: x3 gpio probe start!!![ 0.476515] gpio-x3 a6003000.gpio: x3 gpio add gpiochip start!!![ 0.477440] gpio-x3 a6003000.gpio: diable all gpio irq[ 0.479826] gpio-x3 a6003000.gpio: irqbase:57[ 0.480378] gpio-x3 a6003000.gpio: x3 irq add start!!![ 0.481035] irq: Cannot allocate irq_descs @ IRQ57, assuming pre-allocated[ 0.482081] gpio-x3 a6003000.gpio: x3 irq add ok!!![ 0.482734] gpio-x3 a6003000.gpio: x3 irqchip ops add ok!!![ 0.483439] gpio-x3 a6003000.gpio: x3 gpio probe ok!!![ 0.484530] hobot-pwm: hobot-pwmchip0 registered[ 0.485282] hobot-pwm: hobot-pwmchip1 registered[ 0.486644] diag dev [ver:1.1] init done[ 0.487539] hobot_ddr_monitor: LPDDR4 detected[ 0.488300] hobot_ddr_monitor: ddr monitor init finished.[ 0.488689] [vcam] init start[ 0.489749] vcam probe start[ 0.490225] vcam probe end successful[ 0.490686] [vcam] init end[ 0.491603] a5000000.serial: ttyS0 at MMIO 0xa5000000 (irq = 10, base_baud = 12000000) is a hobot-uart[ 0.492814] console [ttyS0] enabled[ 0.493698] bootconsole [hobot0] disabled[ 0.495044] hobot-uart a5001000.serial: Failed to create debugfs root directory[ 0.496048] a5001000.serial: ttyS1 at MMIO 0xa5001000 (irq = 11, base_baud = 12000000) is a hobot-uart[ 0.497496] hobot-uart a5003000.serial: Failed to create debugfs root directory[ 0.498678] a5003000.serial: ttyS3 at MMIO 0xa5003000 (irq = 12, base_baud = 12000000) is a hobot-uart[ 0.500220] KGDB: Registered I/O driver kgdboc[ 0.501061] cacheinfo: Unable to detect cache hierarchy for CPU 0[ 0.506475] brd: module loaded[ 0.511060] loop: module loaded[ 0.512565] spi-nand hr_nand.0: GigaDevice SPI NAND was found.[ 0.513325] spi-nand hr_nand.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64[ 0.514527] 5 cmdlinepart partitions found on MTD device hr_nand.0[ 0.515322] Creating 5 MTD partitions on "hr_nand.0":[ 0.515975] 0x000000000000-0x000000600000 : "miniboot"[ 0.520876] 0x000000600000-0x000000800000 : "env"[ 0.523215] 0x000000800000-0x000002100000 : "boot"[ 0.539549] 0x000002000000-0x000005700000 : "system"[ 0.572936] 0x000005700000-0x000008000000 : "userdata"[ 0.600525] hobot_spi a5006000.spi: ver: HOBOT-spi_V20.200330 master[ 0.601569] libphy: Fixed MDIO Bus: probed[ 0.602800] st_gmac a5014000.ethernet: found phy-handle subnode[ 0.603636] st_gmac a5014000.ethernet: xj3_mtl_setup, plat->rx-queues-to-use:4, and tx:4[ 0.604820] st_gmac a5014000.ethernet: xj3_probe_config_dt, clk_ptp_rate:250000000[ 0.605821] set mac address 00:11:22:17:28:59:[ 0.605824] (using random mac adress)[ 0.606895] (NULL device *): xj3_get_hw_features, tx_fifo_size:16384[ 0.607712] (NULL device *): xj3_get_hw_features, rx_fifo_size:16384[ 0.608529] st_gmac a5014000.ethernet: TSO supported[ 0.609169] st_gmac a5014000.ethernet: TSO feature enabled[ 0.609891] st_gmac a5014000.ethernet: Enable Rx Mitigation via HW Watchdog Timer[ 0.730950] libphy: hobot-mac-mdio: probed[ 0.732467] st_gmac a5014000.ethernet: hobot_eth_probe: probe sucessfully[ 0.733663] dwc3-of-simple b2000000.usb: b2000000.usb supply usb_0v8 not found, using dummy regulator[ 0.734906] dwc3-of-simple b2000000.usb: usb regulator 0v8 enable succeed[ 0.735783] dwc3-of-simple b2000000.usb: b2000000.usb supply usb_3v3 not found, using dummy regulator[ 0.736986] dwc3-of-simple b2000000.usb: usb regulator 3v3 enable succeed[ 0.738519] dwc3 b2000000.dwc3: Configuration mismatch. user dr_mode(otg) not equal with hardware default mode(peripheral). still use otg mode[ 0.740176] dwc3 b2000000.dwc3: found 6 IN and 3 OUT endpoints[ 0.741585] usbcore: registered new interface driver cdc_acm[ 0.742335] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters[ 0.743391] usbcore: registered new interface driver uas[ 0.744107] usbcore: registered new interface driver usb-storage[ 0.744931] usbcore: registered new interface driver usbserial[ 0.745702] usbcore: registered new interface driver usbserial_generic[ 0.746581] usbserial: USB Serial support registered for generic[ 0.747376] usbcore: registered new interface driver usb_serial_simple[ 0.748236] usbserial: USB Serial support registered for carelink[ 0.749036] usbserial: USB Serial support registered for zio[ 0.749781] usbserial: USB Serial support registered for funsoft[ 0.750588] usbserial: USB Serial support registered for flashloader[ 0.751424] usbserial: USB Serial support registered for google[ 0.752203] usbserial: USB Serial support registered for libtransistor[ 0.753058] usbserial: USB Serial support registered for vivopay[ 0.753867] usbserial: USB Serial support registered for moto_modem[ 0.754691] usbserial: USB Serial support registered for motorola_tetra[ 0.755558] usbserial: USB Serial support registered for novatel_gps[ 0.756393] usbserial: USB Serial support registered for hp4x[ 0.757150] usbserial: USB Serial support registered for suunto[ 0.757937] usbserial: USB Serial support registered for siemens_mpi[ 0.758781] usbcore: registered new interface driver rio500[ 0.759615] mousedev: PS/2 mouse device common for all mice[ 0.770666] hobot-rtc a6002000.rtc: rtc core: registered hobot-rtc as rtc0[ 0.771659] i2c /dev entries driver[ 0.772261] hobot-i2c a5009000.i2c: hobot i2c probe start[ 0.773027] hobot-i2c a5009000.i2c: round_rate:96000000[ 0.773705] hobot-i2c a5009000.i2c: I2C bus speed is 400000[ 0.774442] hobot-i2c a5009000.i2c: clkdiv = 0x1d[ 0.775049] hobot-i2c a5009000.i2c: i2c0 diag register....[ 0.776142] hobot-i2c a5009000.i2c: hobot_i2c_0 probe done[ 0.776942] hobot-i2c a500a000.i2c: hobot i2c probe start[ 0.777696] hobot-i2c a500a000.i2c: round_rate:96000000[ 0.778395] hobot-i2c a500a000.i2c: I2C bus speed is 400000[ 0.779113] hobot-i2c a500a000.i2c: clkdiv = 0x1d[ 0.779720] hobot-i2c a500a000.i2c: i2c1 diag register....[ 0.780746] hobot-i2c a500a000.i2c: hobot_i2c_1 probe done[ 0.781712] lirc_dev: IR Remote Control driver registered, major 239[ 0.782552] IR LIRC bridge handler initialized[ 0.783310] sif_mclk clock frequence is 544000000[ 0.783946] mipi_rx0_ipi clock frequence is 544000000[ 0.784634] mipi_rx1_ipi clock frequence is 544000000[ 0.785332] mipi_rx2_ipi clock frequence is 544000000[ 0.786061] mipi_rx3_ipi clock frequence is 544000000[ 0.786782] mipi_tx_ipi clock frequence is 544000000[ 0.787501] mipi_cfg_host clock frequence is 102000000[ 0.788254] pym_mclk clock frequence is 1188000000[ 0.788974] mipi_dev_ref clock frequence is 24000000[ 0.789726] mipi_host_ref clock frequence is 24000000[ 0.790520] sensor0_mclk clock frequence is 37125000[ 0.791295] sensor1_mclk clock frequence is 37125000[ 0.792084] sensor2_mclk clock frequence is 37125000[ 0.792886] sensor3_mclk clock frequence is 37125000[ 0.793525] [FRT:D] x3_ips_probe(0)[ 0.794553] hobot swinfo sel reg ro=0x1 boot dump[ 0.795467] pvt a1009000.pvt: SCRATCH test: 1234abcd, pvt is alive.[ 0.796389] pvt a1009000.pvt: VM Calibrated data detected[ 0.797579] hobot_wdt a1002000.watchdog: watchdog setting [pet:6s bark:11s bite:15s][ 0.798924] hobot_wdt a1002000.watchdog: Hobot Watchdog Timer at ffffff8009da3000 with timeout 15s[ 0.800271] device-mapper: uevent: version 1.0.3[ 0.801029] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com[ 0.802215] device-mapper: verity-avb: AVB error handler initialized with vbmeta device: [ 0.804623] Synopsys Designware Multimedia Card Interface Driver[ 0.805620] dwmmc_hobot a5010000.dwmmc: ver: HOBOT-mmc_V20.200402[ 0.806484] dwmmc_hobot a5010000.dwmmc: card-detect-delay not found.[ 0.807303] dwmmc_hobot a5010000.dwmmc: data-addr not found.[ 0.808350] mmc_host mmc0: card is non-removable.[ 0.847051] dwmmc_hobot a5011000.dwmmc: ver: HOBOT-mmc_V20.200402[ 0.849889] dwmmc_hobot a5011000.dwmmc: card-detect-delay not found.[ 0.850709] dwmmc_hobot a5011000.dwmmc: data-addr not found.[ 0.855477] dwmmc_hobot a5011000.dwmmc: mmc set to fixed voltage 1800[ 0.856544] mmc_host mmc1: card is non-removable.[ 0.954050] dwmmc_hobot a5012000.dwmmc: ver: HOBOT-mmc_V20.200402[ 0.954879] dwmmc_hobot a5012000.dwmmc: card-detect-delay not found.[ 0.955716] dwmmc_hobot a5012000.dwmmc: data-addr not found.[ 0.956683] dwmmc_hobot a5012000.dwmmc: Got CD GPIO[ 1.067584] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)[ 1.069770] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)[ 1.071965] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)[ 1.075330] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)[ 1.079284] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)[ 1.146149] ledtrig-cpu: registered to indicate activity on CPUs[ 1.146977] hidraw: raw HID events driver (C) Jiri Kosina[ 1.147815] usbcore: registered new interface driver usbhid[ 1.148531] usbhid: USB HID core driver[ 1.149114] logger: created 256K log 'log_main'[ 1.149763] logger: created 256K log 'log_events'[ 1.150452] logger: created 256K log 'log_radio'[ 1.151114] logger: created 256K log 'log_system'[ 1.152173] set dmc devfreq governor to performance[ 1.152816] hobot_dmcfreq_target: dmcfreq->rate:2666000000, target_rate:2666000000[ 1.153797] buf:, powersave_rate:2666000000, dmcfreq->pre_state:0[ 1.160672] usbcore: registered new interface driver snd-usb-audio[ 1.161855] Netfilter messages via NETLINK v0.30.[ 1.162490] ip_set: protocol 6[ 1.162981] ipip: IPv4 and MPLS over IPv4 tunneling driver[ 1.164002] ip_tables: (C) 2000-2006 Netfilter Core Team[ 1.164966] arp_tables: arp_tables: (C) 2002 David S. Miller[ 1.165777] Initializing XFRM netlink socket[ 1.166747] NET: Registered protocol family 10[ 1.167984] Segment Routing with IPv6[ 1.168498] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver[ 1.169611] NET: Registered protocol family 17[ 1.170279] Key type dns_resolver registered[ 1.171974] Loading compiled-in X.509 certificates[ 1.175485] Loaded X.509 cert 'Build time autogenerated kernel key: 81cb0ef77db2fac76e9588c2120c82422367d268'[ 1.176818] zswap: loaded using pool lzo/zbud[ 1.188159] dwc3 b2000000.dwc3: Configuration mismatch. user dr_mode(otg) not equal with hardware default mode(peripheral). still use otg mode[ 1.189821] dwc3 b2000000.dwc3: found 6 IN and 3 OUT endpoints[ 1.190798] ubi0: attaching mtd2[ 1.272613] ubi0: scanning is finished[ 1.278068] ubi0: attached mtd2 (name "boot", size 25 MiB)[ 1.278778] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes[ 1.279661] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048[ 1.280533] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096[ 1.281427] ubi0: good PEBs: 200, bad PEBs: 0, corrupted PEBs: 0[ 1.282218] ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128[ 1.283146] ubi0: max/mean erase counter: 1/1, WL threshold: 4096, image sequence number: 0[ 1.284218] ubi0: available PEBs: 176, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20[ 1.285420] ubi0: background thread "ubi_bgt0d" started, PID 1138[ 1.286235] console [netcon0] enabled[ 1.286708] netconsole: network logging started[ 1.287499] hobot-rtc a6002000.rtc: setting system clock to 1970-01-01 00:00:00 UTC (0)[ 1.288705] vps mipi_dphy: probe with x3vio done[ 1.289422] hobot_wdt_test: wdt_test_init: wdt test init[ 1.292146] VCC_CNN0: disabling[ 1.292555] VCC_CNN1: disabling[ 1.293523] vps mipi_host0: ver 140* port0(0:0)[ 1.294465] vps mipi_host1: ver 140* port1(1:0)[ 1.295361] vps mipi_host2: ver 140* port2(0:1)[ 1.296151] vps mipi_host3: ver 140* port3(1:1)[ 1.296987] ALSA device list:[ 1.297372] No soundcards found.[ 1.298045] md: Skipping autodetection of RAID arrays. (raid=autodetect will force)[ 1.299098] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller[ 1.299144] Waiting for root device /dev/mmcblk2p1...[ 1.300463] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1[ 1.301927] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x0000000000010010[ 1.303160] xhci-hcd xhci-hcd.0.auto: irq 178, io mem 0xb2000000[ 1.305159] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.14[ 1.306236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.307165] usb usb1: Product: xHCI Host Controller[ 1.307793] usb usb1: Manufacturer: Linux 4.14.87 xhci-hcd[ 1.308500] usb usb1: SerialNumber: xhci-hcd.0.auto[ 1.309438] hub 1-0:1.0: USB hub found[ 1.309967] hub 1-0:1.0: 1 port detected[ 1.310661] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller[ 1.311375] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2[ 1.312363] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed[ 1.313238] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.[ 1.314362] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.14[ 1.315092] mmc1: new HSSDIO card at address 0001[ 1.316029] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1[ 1.316957] usb usb2: Product: xHCI Host Controller[ 1.317586] usb usb2: Manufacturer: Linux 4.14.87 xhci-hcd[ 1.318308] usb usb2: SerialNumber: xhci-hcd.0.auto[ 1.319224] hub 2-0:1.0: USB hub found[ 1.319726] hub 2-0:1.0: 1 port detected[ 1.565854] usb 1-1: new high-speed USB device number 2 using xhci-hcd[ 1.714040] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11[ 1.715093] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0[ 1.716010] usb 1-1: Product: USB 2.0 Hub[ 1.761411] hub 1-1:1.0: USB hub found[ 1.761948] hub 1-1:1.0: 4 ports detected[ 2.106175] mmc2: new UHS SDR104 SDXC card at address 0001[ 2.107181] mmcblk2: mmc2:0001 USD 59.5 GiB [ 2.108506] mmcblk2: p1[ 2.126321] EXT4-fs (mmcblk2p1): mounted filesystem with ordered data mode. Opts: (null)[ 2.127395] VFS: Mounted root (ext4 filesystem) on device 179:1.[ 2.128879] devtmpfs: mounted[ 2.130483] Freeing unused kernel memory: 1088K[ 2.416335] systemd[1]: System time before build time, advancing clock.[ 2.434079] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)[ 2.437316] systemd[1]: Detected architecture arm64.[ 2.447704] systemd[1]: Set hostname to <ubuntu>.[ 2.639697] random: lvmconfig: uninitialized urandom read (4 bytes read)[ 2.949579] random: systemd: uninitialized urandom read (16 bytes read)[ 2.952802] systemd[1]: Created slice system-modprobe.slice.[ 2.954641] random: systemd: uninitialized urandom read (16 bytes read)[ 2.956313] systemd[1]: Created slice system-serial\x2dgetty.slice.[ 2.958834] systemd[1]: Created slice User and Session Slice.[ 2.960707] systemd[1]: Started Forward Password Requests to Wall Directory Watch.[ 2.963513] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.[ 2.966144] systemd[1]: Reached target User and Group Name Lookups.[ 2.967993] systemd[1]: Reached target Slices.[ 2.969342] systemd[1]: Reached target Swap.[ 2.970867] systemd[1]: Listening on Device-mapper event daemon FIFOs.[ 2.973017] systemd[1]: Listening on LVM2 poll daemon socket.[ 2.987197] systemd[1]: Listening on RPCbind Server Activation Socket.[ 2.989567] systemd[1]: Listening on Syslog Socket.[ 2.991320] systemd[1]: Listening on initctl Compatibility Named Pipe.[ 2.993776] systemd[1]: Listening on Journal Audit Socket.[ 2.995731] systemd[1]: Listening on Journal Socket (/dev/log).[ 2.997809] systemd[1]: Listening on Journal Socket.[ 2.999674] systemd[1]: Listening on udev Control Socket.[ 3.001460] systemd[1]: Listening on udev Kernel Socket.[ 3.003403] systemd[1]: Condition check resulted in Huge Pages File System being skipped.[ 3.007246] systemd[1]: Mounting POSIX Message Queue File System...[ 3.011921] systemd[1]: Mounting RPC Pipe File System...[ 3.017043] systemd[1]: Mounting Kernel Debug File System...[ 3.021944] systemd[1]: Mounting Kernel Trace File System...[ 3.027715] systemd[1]: Starting Journal Service...[ 3.032722] systemd[1]: Starting Availability of block devices...[ 3.039013] systemd[1]: Starting Restore / save the current clock...[ 3.044295] systemd[1]: Starting Set the console keyboard layout...[ 3.061029] systemd[1]: Starting Create list of static device nodes for the current kernel...[ 3.067233] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...[ 3.075131] systemd[1]: Starting Load Kernel Module chromeos_pstore...[ 3.077521] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.[ 3.083075] systemd[1]: Starting Load Kernel Module efi_pstore...[ 3.093006] systemd[1]: Starting Load Kernel Module pstore_blk...[ 3.098718] systemd[1]: Starting Load Kernel Module pstore_zone...[ 3.100771] systemd[1]: Condition check resulted in Load Kernel Module ramoops being skipped.[ 3.106804] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.[ 3.113679] systemd[1]: Starting Load Kernel Modules...[ 3.118806] systemd[1]: Starting Remount Root and Kernel File Systems...[ 3.126497] systemd[1]: Starting udev Coldplug all Devices...[ 3.138484] systemd[1]: Mounted POSIX Message Queue File System.[ 3.141009] systemd[1]: Mounted RPC Pipe File System.[ 3.143206] systemd[1]: Mounted Kernel Debug File System.[ 3.145374] systemd[1]: Mounted Kernel Trace File System.[ 3.148933] systemd[1]: Finished Availability of block devices.[ 3.153082] systemd[1]: Finished Restore / save the current clock.[ 3.159990] systemd[1]: Finished Create list of static device nodes for the current kernel.[ 3.163838] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.[ 3.166336] systemd[1]: Finished Load Kernel Module chromeos_pstore.[ 3.169894] systemd[1]: modprobe@efi_pstore.service: Succeeded.[ 3.172185] systemd[1]: Finished Load Kernel Module efi_pstore.[ 3.175318] systemd[1]: modprobe@pstore_blk.service: Succeeded.[ 3.177556] systemd[1]: Finished Load Kernel Module pstore_blk.[ 3.180777] systemd[1]: modprobe@pstore_zone.service: Succeeded.[ 3.182902] systemd[1]: Finished Load Kernel Module pstore_zone.[ 3.186834] systemd[1]: Finished Remount Root and Kernel File Systems.[ 3.223687] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.[ 3.224923] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.[ 3.229009] systemd[1]: Starting Load/Save Random Seed...[ 3.239728] systemd[1]: Starting Create System Users...[ 3.251762] systemd[1]: Started Journal Service.[ 3.276051] systemd-journald[1207]: Received client request to flush runtime journal.[ 3.314844] systemd-journald[1207]: File /var/log/journal/42d2df982fe74fe4a4f15c0bb10c907d/system.journal corrupted or uncleanly shut down, renaming and replacing.[ 3.321562] Bluetooth: Core ver 2.22[ 3.322099] NET: Registered protocol family 31[ 3.322675] Bluetooth: HCI device and connection manager initialized[ 3.323500] Bluetooth: HCI socket layer initialized[ 3.324132] Bluetooth: L2CAP socket layer initialized[ 3.324803] Bluetooth: SCO socket layer initialized[ 3.363184] Bluetooth: HCI UART driver ver 2.2.3634cd9.20220519-142433[ 3.364033] Bluetooth: HCI H4 protocol initialized[ 3.364650] Bluetooth: HCI Realtek H5 protocol initialized[ 3.365355] rtk_btcoex: rtk_btcoex_init: version: 1.2[ 3.366346] rtk_btcoex: create workqueue[ 3.366982] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2[ 3.456327] bpu_cores: module license 'Proprietary' taints kernel.[ 3.457147] Disabling lock debugging due to kernel taint[ 3.468107] hobot_efuse probe success[ 4.363127] es8156_i2c_probe start[ 4.363668] es8156_i2c_probe end[ 4.562862] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001[ 4.657973] [dhd] _dhd_module_init: in Dongle Host Driver, version 101.10.361.17 (wlan=r892223-20220414-2)(20220708-01) drivers/net/wireless/bcmdhd compiled on Dec 1 2022 at 19:08:32[ 4.660461] [dhd] ======== dhd_wlan_init_plat_data ========[ 4.661184] [dhd] dhd_wlan_init_gpio: gpio_request(16) for WL_REG_ON failed[ 4.662280] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1[ 4.662907] [dhd] dhd_wifi_platform_load: Enter[ 4.663500] [dhd] Power-up adapter 'DHD generic adapter'[ 4.664395] [dhd] wifi_platform_set_power = 1, delay: 200 msec[ 4.665162] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========[ 4.728296] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Nov 25 2016 15:06:56 version 7.46.57.5.apsta.r4.o12 (Station/Softap) FWID 01-64fb9fe8 es6.c5.n4.a3[ 4.973857] [dhd] wifi_platform_bus_enumerate device present 1[ 4.974617] [dhd] ======== Card detection to detect SDIO card! ========[ 5.230690] iar probe begin!!![ 5.231586] hobot-iar a4301000.iar: bt656_func get error -19[ 5.232324] hobot-iar a4301000.iar: mipi_dsi_func get error -19[ 5.233213] error get bt656 output pin group config, use low 8bit default!![ 5.234164] error get bt1120 clk invert config, use normal as default!![ 5.250119] read edid failed: no ack[ 5.250314] can't find timing for 1280*720, use default!![ 5.251725] can't find timing for 800*480, use default!![ 5.252411] can't find timing for 1080*1920, use default!![ 5.253119] can't find timing for 704*576 touch, use default!![ 5.253932] can't find timing for 720*480 touch, use default!![ 5.254720] hobot_iar_probe: panel type is HDMI_TYPE[ 5.275176] iar probe end success!!![ 5.327839] hb_vpu a8000000.vpu: vpu_aclk clock is 750000000[ 5.328789] hb_vpu a8000000.vpu: vpu_bclk clock is 544000000[ 5.329585] hb_vpu a8000000.vpu: vpu_cclk clock is 544000000[ 5.376985] hb_jpu a8010000.jpu: jpg_aclk clock is 750000000[ 5.377923] hb_jpu a8010000.jpu: jpg_cclk clock is 544000000[ 5.391421] [FRT:D] x3_sif_probe(0)[ 5.494468] acamera_loglist_init [ 5.519292] [isp_drv]: camera_subdev_probe: register v4l2 lens device. result0[ 5.520756] sensor_ctrl register success ![ 5.594707] [isp_drv]: acamera_camera_async_complete: complete done, rc: 0.[ 5.601958] Hobot fb probe!!![ 5.602896] channel id is 0, enable is 1, reg value is 0x1e40000.[ 5.602902] channel id is 2, enable is 1, reg value is 0x5c4f004.[ 6.102352] Console: switching to colour frame buffer device 240x67[ 6.105904] fb0: x2-fb frame buffer at 0x15000000-0x157e8fff[ 6.106656] fb1: hobot-fb1 frame buffer at 0x157e9000-0x15fd1fff[ 6.123142] hdmi: add sii902xA driver[ 6.168946] hobot_dev_ipu: [FRT:D] x3_ipu_probe(0)[ 6.181180] hobot_dev_pym: [FRT:D] x3_pym_probe(0)[ 6.189972] [FRT:D] x3_gdc_probe(0)[ 6.190734] [FRT:D] x3_gdc_probe(0)[ 6.201388] hobot_dev_osd: [FRT:D] x3_osd_probe(0)[ 6.219536] usbcore: registered new interface driver uvcvideo[ 6.220290] USB Video Class driver (1.1.1)[ 6.233381] usbcore: registered new interface driver ch341[ 6.234231] usbserial: USB Serial support registered for ch341-uart[ 6.283621] usbcore: registered new interface driver cp210x[ 6.284424] usbserial: USB Serial support registered for cp210x[ 6.295375] usbcore: registered new interface driver ftdi_sio[ 6.296196] usbserial: USB Serial support registered for FTDI USB Serial Device[ 7.005874] [dhd] failed to power up DHD generic adapter, 0 retry left[ 7.021970] [dhd] wifi_platform_set_power = 0, delay: 0 msec[ 7.021977] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========[ 7.021981] [dhd] wifi_platform_bus_enumerate device present 0[ 7.021983] [dhd] ======== Card detection to remove SDIO card! ========[ 7.021986] [dhd] failed to power up DHD generic adapter, max retry reached**[ 7.021989] [dhd] unregister wifi platform drivers[ 7.021992] [dhd] wifi_platform_bus_enumerate device present 0[ 7.021994] [dhd] ======== Card detection to remove SDIO card! ========[ 7.021997] [dhd] ======== dhd_wlan_deinit_plat_data ========[ 7.022001] [dhd] _dhd_module_init: Failed to load the driver, try cnt 0[ 7.022026] [dhd] _dhd_module_init: Failed to load driver max retry reached**[ 7.022029] [dhd] _dhd_module_init: Exit err=-19[ 7.084115] [dhd] _dhd_module_init: in Dongle Host Driver, version 101.10.361.17 (wlan=r892223-20220414-2)(20220708-01) drivers/net/wireless/bcmdhd compiled on Dec 1 2022 at 19:08:32[ 7.086643] [dhd] ======== dhd_wlan_init_plat_data ========[ 7.086650] [dhd] dhd_wlan_init_gpio: gpio_request(16) for WL_REG_ON failed[ 7.086653] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1[ 7.086656] [dhd] dhd_wifi_platform_load: Enter[ 7.086659] [dhd] Power-up adapter 'DHD generic adapter'[ 7.086734] [dhd] wifi_platform_set_power = 1, delay: 200 msec[ 7.086738] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========[ 7.253597] LT8618_GET_EDID_RESOLUTION_RATIO[ 7.270189] read edid failed: no ack[ 7.393906] [dhd] wifi_platform_bus_enumerate device present 1[ 7.393912] [dhd] ======== Card detection to detect SDIO card! ========[ 7.543279] channel id is 0, enable is 1, reg value is 0x572300f.[ 7.543290] channel id is 1, enable is 0, reg value is 0x542f00f.[ 7.543297] channel id is 2, enable is 1, reg value is 0x542f00f.[ 7.543302] channel id is 3, enable is 0, reg value is 0x542f00f.[ 7.601222] iar start......[ 7.601386] disable channel 0[ 7.622922] UDC core: couldn't find an available UDC - added [g_ether] to list of pending drivers[ 7.838703] RTL8211F Gigabit Ethernet hobot-mac-mdio-a5014000:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=hobot-mac-mdio-a5014000:00, irq=POLL)[ 7.853125] st_gmac a5014000.ethernet: IEEE 1588-2008 Advanced Timestamp [ 7.853132] st_gmac a5014000.ethernet: supported by Hobot Ethernet Network Card[ 7.853324] st_gmac a5014000.ethernet: registered PTP clock by hobot successfully[ 7.853358] st_gmac a5014000.ethernet: xj3_open: successfully[ 7.857245] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready[ 8.015807] file system registered[ 8.051229] read descriptors[ 8.051239] read strings[ 8.268255] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready[ 8.298374] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready[ 8.581466] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready[ 9.405858] [dhd] failed to power up DHD generic adapter, 0 retry left[ 9.421944] [dhd] wifi_platform_set_power = 0, delay: 0 msec[ 9.421951] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========[ 9.421954] [dhd] wifi_platform_bus_enumerate device present 0[ 9.421957] [dhd] ======== Card detection to remove SDIO card! ========[ 9.421959] [dhd] failed to power up DHD generic adapter, max retry reached**[ 9.421962] [dhd] unregister wifi platform drivers[ 9.421965] [dhd] wifi_platform_bus_enumerate device present 0[ 9.421967] [dhd] ======== Card detection to remove SDIO card! ========[ 9.421970] [dhd] ======== dhd_wlan_deinit_plat_data ========[ 9.421974] [dhd] _dhd_module_init: Failed to load the driver, try cnt 0[ 9.422010] [dhd] Error creating socket.[ 9.422013] [dhd] _dhd_module_init: Failed to load driver max retry reached**[ 9.422015] [dhd] _dhd_module_init: Exit err=-19[ 9.481060] [dhd] _dhd_module_init: in Dongle Host Driver, version 101.10.361.17 (wlan=r892223-20220414-2)(20220708-01) drivers/net/wireless/bcmdhd compiled on Dec 1 2022 at 19:08:32[ 9.484492] [dhd] ======== dhd_wlan_init_plat_data ========[ 9.484500] [dhd] dhd_wlan_init_gpio: gpio_request(16) for WL_REG_ON failed[ 9.484503] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1[ 9.484506] [dhd] dhd_wifi_platform_load: Enter[ 9.484509] [dhd] Power-up adapter 'DHD generic adapter'[ 9.484588] [dhd] wifi_platform_set_power = 1, delay: 200 msec[ 9.484592] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========[ 9.789913] [dhd] wifi_platform_bus_enumerate device present 1[ 9.789921] [dhd] ======== Card detection to detect SDIO card! ========[ 9.809054] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready[ 10.017749] set ubuntu desktop mode!![ 10.026190] ubi10: attaching mtd1[ 10.032724] ubi10: scanning is finished[ 10.038183] ubi10 warning: ubi_eba_init: cannot reserve enough PEBs for bad PEB handling, reserved 1, need 20[ 10.039256] ubi10: attached mtd1 (name "env", size 2 MiB)[ 10.039264] ubi10: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes[ 10.039267] ubi10: min./max. I/O unit sizes: 2048/2048, sub-page size 2048[ 10.039271] ubi10: VID header offset: 2048 (aligned 2048), data offset: 4096[ 10.039275] ubi10: good PEBs: 16, bad PEBs: 0, corrupted PEBs: 0[ 10.039278] ubi10: user volume: 4, internal volumes: 1, max. volumes count: 128[ 10.039283] ubi10: max/mean erase counter: 27/16, WL threshold: 4096, image sequence number: 1334872891[ 10.039286] ubi10: available PEBs: 0, total reserved PEBs: 16, PEBs reserved for bad PEB handling: 1[ 10.047088] ubi10: background thread "ubi_bgt10d" started, PID 2591[ 11.135871] hobot mmap end!:15000000[ 11.136378] hbfb_check_var begin.[ 11.805916] [dhd] failed to power up DHD generic adapter, 0 retry left[ 11.822101] [dhd] wifi_platform_set_power = 0, delay: 0 msec[ 11.822116] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========[ 11.822123] [dhd] wifi_platform_bus_enumerate device present 0[ 11.822129] [dhd] ======== Card detection to remove SDIO card! ========[ 11.822135] [dhd] failed to power up DHD generic adapter, max retry reached**[ 11.822142] [dhd] unregister wifi platform drivers[ 11.822148] [dhd] wifi_platform_bus_enumerate device present 0[ 11.822153] [dhd] ======== Card detection to remove SDIO card! ========[ 11.822159] [dhd] ======== dhd_wlan_deinit_plat_data ========[ 11.822167] [dhd] _dhd_module_init: Failed to load the driver, try cnt 0[ 11.822253] [dhd] Error creating socket.[ 11.822260] [dhd] _dhd_module_init: Failed to load driver max retry reached**[ 11.822267] [dhd] _dhd_module_init: Exit err=-19[ 20.782291] Bluetooth: BNEP (Ethernet Emulation) ver 1.3[ 20.782299] Bluetooth: BNEP filters: protocol multicast[ 20.782316] Bluetooth: BNEP socket layer initialized[ 31.409391] vps mipi_host0: snrclk set enable[ 31.409417] vps mipi_host0: sensor0_mclk set(1) 37125000 as 37125000[ 35.616686] vps mipi_host0: sensor0_mclk set(2) 24000000 as 24000000[ 46.155542] vps mipi_host0: mipi_cfg_host = 24000000[ 46.155567] vps mipi_host0: snrclk set en cmd[ 46.155573] vps mipi_host0: snrclk set enable[ 46.155607] vps mipi_host1: snrclk set en cmd[ 46.155612] vps mipi_host1: snrclk set enable[ 46.155632] vps mipi_host1: sensor1_mclk set(1) 24000000 as 24000000[ 46.175103] [isp_drv:cam]: camera_fop_open: camera_fop_open begin 51 [ 46.175109] [isp_drv:cam]: camera_fop_open: dev_port 0 is open ![ 46.175111] [isp_drv:cam]: camera_fop_open: user_mutex init ![ 46.175114] [isp_drv:cam]: camera_fop_open: line 78 user_num 1[ 46.196114] camera_i2c_open come in port 0[ 46.196125] camera_i2c_open come in sensor_name gc4663 sensor_addr 0x29[ 46.196137] the is open success ![ 46.196149] [isp_drv]: camera_sys_printk_disturing: sensor_addr 0x29, bus_type 0, reg_width 16[ 46.196156] [isp_drv]: camera_sys_printk_disturing: sensor_mode 1 [ 46.196163] [isp_drv]: camera_sys_printk_disturing: s_line 0x0 s_line_length 0 [ 46.196170] [isp_drv]: camera_sys_printk_disturing: sensor_addr 0x29, bus_type 0, reg_width 16[ 46.196177] [isp_drv]: camera_sys_printk_disturing: line 0x0 line_length 0 [ 46.196185] [isp_drv]: camera_sys_printk_disturing: active_height 1440 active_width 2560 [ 46.196191] [isp_drv]: camera_sys_printk_disturing: normal param_hold 0x0 param_hold_length 0 [ 46.196198] [isp_drv]: camera_sys_printk_disturing: dol2 param_hold 0x0 param_hold_length 0 [ 46.196468] [isp_drv:cam]: camera_fop_ioctl: ioctl set init cnt 201 init_num 1[ 46.196541] vps mipi_host0: init cmd: 0 real[ 46.196554] vps mipi_host0: init begin[ 46.196567] vps mipi_host0: 2 lane 2560x1440 30fps datatype 0x2b[ 46.196588] vps mipi_host0: sensor0_mclk set(3) 24000000 as 24000000[ 46.196597] vps mipi_host0: snrclk set enable[ 46.196609] vps mipi_host0: ipiclk limit 40800000 up to 102000000[ 46.196659] vps mipi_host0: ipiclk set 102000000 get 102000000[ 46.197715] vps mipi_host0: linelenth: 2720, framelenth: 1500, fps: 30, bits_per_pixel: 10, pixclk: 102000000, rx_bit_clk: 1224000000[ 46.197725] vps mipi_host0: time to transmit last pixel in ppi: 22222[ 46.197734] vps mipi_host0: minium hsdtime: 1404[ 46.197743] vps mipi_host0: time to transmit last pixel in ipi: 22215[ 46.197761] vps mipi_host0: config 1/1 ipi done[ 46.197770] vps mipi_host0: init end[ 46.202473] vio mp dev open.[ 46.202495] vio_mp_bind_chain_group mp 0 bind done, refcount(1)[ 46.209280] hobot_dmcfreq_target: dmcfreq->rate:2666000000, target_rate:2666000000[ 46.209288] buf:performance , powersave_rate:2666000000, dmcfreq->pre_state:0[ 46.210356] [S0][V0] sif_bind_chain_group done, ctx_index(0) refcount(1)[ 46.210371] yuv_format 0 mipi_rx_index 0 [ 46.210379] sif_set_mipi_rx: vc_index[0] = 0[ 46.210385] mux_index = 0, ipi_index = 0 lines 1 [ 46.210397] [S0] sif_mux_init mux_index 0 ddr_mux_index = 0[ 46.210400] [S0][V0] sif_video_init done[ 46.210412] vio_group_api: Stream0 path: G0[ 46.215865] [isp_drv]: acamera_isp_init_context: +[ 46.215874] [isp_drv]: acamera_init_context: ctx_id 0 +[ 46.215878] [isp_drv]: acamera_init_context: copy data from isp hw to sram 0[ 46.217371] [isp_drv]: acamera_init_context: side sram, chn 0, paddr ffffff8011e00000[ 46.224861] [isp_drv]: acamera_init_context: ctx_id 0 -[ 46.224876] [isp_drv]: acamera_isp_init_context: context-0 copy to isp ping/pong[ 46.224888] [isp_drv]: acamera_isp_init_context: -[ 46.224974] [isp_drv]: fw_intf_stream_set_resolution: w 2560, h 1440, exposures 1, bits 10, preset idx = 1[ 46.281332] vio_group_api: vio_dwe_clk_enable done[ 46.288100] hobot_dev_ipu: [S0][V3] ipu_bind_chain_group done[ 46.288125] hobot_dev_ipu: [S0][V3] ipu_set_group_leader[ 46.288132] hobot_dev_ipu: ipu_video_init group->leader:0[ 46.288332] hobot_dev_ipu: [S0][V3]ipu_video_init done[ 46.288369] hobot_dev_ipu: [S0][V3]ipu_video_reqbufs buffer number 5 first index 0[ 46.297211] hobot_dev_ipu: [S0][V4] ipu_bind_chain_group done[ 46.297228] hobot_dev_ipu: ipu_video_init group->leader:0[ 46.297233] hobot_dev_ipu: [S0][V4]ipu_video_init done[ 46.297249] hobot_dev_ipu: [S0][V4]ipu_video_reqbufs buffer number 5 first index 0[ 46.312606] vio bind info dev open.[ 46.312626] vio bind info dev close.[ 46.312822] hobot_dev_ipu: [S0][V0] ipu_bind_chain_group done[ 46.312827] hobot_dev_ipu: reuse_shadow0_count = 1[ 46.312864] hobot_dev_ipu: ipu_video_init group->leader:0[ 46.312867] hobot_dev_ipu: [S0][V0]ipu_video_init done[ 46.312893] vio_group_api: change group 2 to leader[ 46.312895] vio_group_api: [S0]G1->G2 case[ 46.312898] vio_group_api: Stream0 path: G0->G2[ 46.312901] hobot_dev_ipu: [S0][V0] ipu_init_end done[ 46.321853] hobot_dev_ipu: [S0][V0] ipu_video_streamon[ 46.321876] hobot_dev_ipu: [S0][V3] ipu_video_streamon[ 46.321882] hobot_dev_ipu: [S0][V4] ipu_video_streamon[ 46.322155] [isp_drv]: isp_v4l2_streamon: ctx_id 0+[ 46.322202] [isp_drv]: acamera_fw_isp_start: done.[ 46.322210] [isp_drv]: isp_v4l2_streamon: ctx_id 0-[ 46.327209] [S0][V0]sif_video_streamon mux_index 0 [ 46.327243] sif_start_pattern_gen: open stream instances: 1, open_cnt: 1[ 46.327936] [S0][V0]sif_video_streamon isp_init_cnt 1 rsccount 1 [ 46.338284] [isp_drv:cam]: camera_fop_ioctl: ioctl set start cnt 180 start_num 1[ 46.338309] vps mipi_host0: start cmd: 0 real[ 46.338316] vps mipi_host0: check phy stop state[ 46.338323] vps mipi_host0: check hs reception[ 46.361336] vps mipi_host0: entry hs reception[ 81.632790] vps mipi_host0: irq status 0x20[ 81.633345] vps mipi_host0: pld_crc_fatal: 0x1[ 81.654105] vps mipi_host0: irq status 0x10[ 81.654710] vps mipi_host0: crc_frm_fatal: 0x1[ 82.118900] vps mipi_host0: irq status 0x20[ 82.119512] vps mipi_host0: pld_crc_fatal: 0x1[ 82.123689] vps mipi_host0: irq status 0x20[ 82.124257] vps mipi_host0: pld_crc_fatal: 0x1[ 82.125113] vps mipi_host0: irq status 0x10[ 82.125681] vps mipi_host0: crc_frm_fatal: 0x1[ 82.128096] vps mipi_host0: irq status 0x20[ 82.128674] vps mipi_host0: pld_crc_fatal: 0x1[ 82.132068] vps mipi_host0: irq status 0x20[ 82.132642] vps mipi_host0: pld_crc_fatal: 0x1[ 82.146460] vps mipi_host0: irq status 0x20[ 82.147021] vps mipi_host0: pld_crc_fatal: 0x1[ 82.158759] vps mipi_host0: irq status 0x10[ 82.159333] vps mipi_host0: crc_frm_fatal: 0x1[ 83.293044] vps mipi_host0: irq status 0x20[ 83.293619] vps mipi_host0: pld_crc_fatal: 0x1[ 83.302684] vps mipi_host0: irq status 0x10[ 83.303258] vps mipi_host0: crc_frm_fatal: 0x1[ 141.479581] hobot_dev_ipu: [S0][V0]ipu_video_streamoff:proc 0, fst_ind 0, num:0[ 141.479595] hobot_dev_ipu: [S0]IPU close node V0 proc 0[ 141.479622] hobot_dev_ipu: [S0][V4]ipu_video_streamoff:proc 0, fst_ind 0, num:5[ 141.479653] hobot_dev_ipu: [S0]IPU close node V4 proc 0[ 141.483690] hobot_dev_ipu: [S0][V3]ipu_video_streamoff:proc 0, fst_ind 0, num:5[ 141.483711] vio_framemgr: cancel by gstop1[ 141.485805] [S0] ipu last process close disable channels[ 141.486399] [S1] ipu last process close disable channels[ 141.486405] [S2] ipu last process close disable channels[ 141.486412] [S3] ipu last process close disable channels[ 141.486422] hobot_dev_ipu: [S0]IPU close node V3 proc 0[ 141.487472] vio_group_api: vio_dwe_clk_disable done[ 141.487535] [isp_drv]: _v4l2_stream_off: ctx_id 0+[ 141.596992] stop fsm_mgr failed, timeout: 102000.[ 141.597042] [isp_drv]: _v4l2_stream_off: ctx_id 0-[ 141.706665] stop fsm_mgr failed, timeout: 102000.[ 141.706780] [isp_drv]: acamera_deinit_context: ctx_id 0 +[ 141.707552] [isp_drv]: acamera_deinit_context: ctx_id 0 -[ 141.707641] [S0][V0]sif_video_streamoff SIF last process stream off [ 141.707656] [S0][V0]sif_video_streamoff[ 141.708731] hobot_dmcfreq_target: dmcfreq->rate:2666000000, target_rate:2666000000[ 141.708752] buf:performance , powersave_rate:2666000000, dmcfreq->pre_state:0[ 141.708776] [S0][V0]x3_sif_close SIF last process close [ 141.708787] SIF close node 0[ 141.708811] vio mp close instance 0[ 141.708840] instance 0 sif_wait_frame_done come in[ 141.709089] [isp_drv]: camera_sys_stream_off: camera_sys_stream_off success line 1552 dev_name port_0[ 141.709121] [isp_drv:cam]: camera_fop_release: line 118 port 0 user_num 0 camera_cdev->start_num 0 [ 141.709182] vps mipi_host1: close as 0[ 141.709214] vps mipi_host1: sensor1_mclk set(0) 0 as 24000000[ 141.709243] vps mipi_host0: close as 0[ 141.709282] vps mipi_host0: sensor0_mclk set(2) 0 as 24000000[ 141.709308] vps mipi_host0: sensor0_mclk set(1) 0 as 24000000sunrise@ubuntu:~$
