旭日x3派
安装hhp有错误
root@ubuntu:/userdata/dev_ws# sudo apt install hhp
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following NEW packages will be installed:
hhp
0 upgraded, 1 newly installed, 0 to remove and 7 not upgraded.
Need to get 0 B/696 MB of archives.
After this operation, 512 MB of additional disk space will be used.
(Reading database … 131869 files and directories currently installed.)
Preparing to unpack …/archives/hhp_1.0.5_arm64.deb …
Unpacking hhp (1.0.5) …
dpkg: error processing archive /var/cache/apt/archives/hhp_1.0.5_arm64.deb (–unpack):
trying to overwrite ‘/opt/tros/.colcon_install_layout’, which is also in package tros 1.1.3
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
旭日x3 按照教程安装TogetherROS后,在
创建工作空间时colcon build时出错
Starting >>> cpp_dnn_demo
Starting >>> hbmem_pubsub
Starting >>> hobot_cv
Starting >>> learning_action_cpp
-– stderr: cpp_dnn_demo
CMake Error at CMakeLists.txt:19 (find_package):
By not providing “Findament_cmake.cmake” in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
“ament_cmake”, but CMake did not find one.
Could not find a package configuration file provided by “ament_cmake” with
any of the following names:
ament_cmakeConfig.cmake
ament_cmake-config.cmake
Add the installation prefix of “ament_cmake” to CMAKE_PREFIX_PATH or set
“ament_cmake_DIR” to a directory containing one of the above files. If
“ament_cmake” provides a separate development package or SDK, be sure it
has been installed.
Failed <<< cpp_dnn_demo [5.60s, exited with code 1]
Aborted <<< hobot_cv [5.50s]
Aborted <<< hbmem_pubsub [5.53s]
Aborted <<< learning_action_cpp [5.46s]
Summary: 0 packages finished [6.87s]
1 package failed: cpp_dnn_demo
3 packages aborted: hbmem_pubsub hobot_cv learning_action_cpp
4 packages had stderr output: cpp_dnn_demo hbmem_pubsub hobot_cv learning_action_cpp
2 packages not processed
opt目录下都已安装好ros 和tros
root@ubuntu:/opt# ls
ros tros
root@ubuntu:/userdata/dev_ws# ls
build install log src
试过桌面版和服务版都是一样的问题,步骤都是按照教程一步一步来的
