1、前言
在x3开发者手册里面的利用bpu进行resize的操作,便在板端上进行了测试,对比了一下bpu-resize与opencv-resize的时间差异,而且还能在裁剪的同时对裁剪的区域进行缩放。而且之前一直是在docker环境下进行编译的,稍显麻烦,而cpp编译只依赖交叉编译工具和依赖文件,交叉编译工具在docker下的/opt/gcc-ubuntu-9.3.0-2020.03-x86_64-aarch64-linux-gnu下,将它复制出来到主机上,就可以在不依赖docker进行编译了,如果编译起来有问题,也可以从本文的百度云链接获得完整的依赖文件以及源代码。-
本文测试代码:https://github.com/Rex-LK/ai_arm_learning-
百度云完整依赖文件以及源代码:https://pan.baidu.com/s/1x34kaRseh8YXMJ-vmFhxEg?pwd=c6cn 提取码: c6cn
2、简化cpp编译环境
在本机中export交叉编译工具的路径
export LD_LIBRARY_PATH=..../ai_arm_learning/x3/datagcc-ubuntu-9.3.0-2020. 03-x86_64-aarch64-linux-gnu/lib/x86_64-linux-gnu ## ....为实际路径
如果不使用交叉编译工具时,即 注释掉# SET(tar x3),在主机运行yolo_demo时会出现
./yolo_demo: error while loading shared libraries: libhbdk_sim_x86.so: cannot open shared object file: No such file or directory
同样的export对应的库路径即可
export LD_LIBRARY_PATH=..../ai_arm_learning/x3/data/deps/x86/dnn_x86/lib ## ....为实际路径
有了上面的过程,就可以愉快的不依赖docker进行交叉编译了,下面就开始本文的正题吧。
3、使用bpu进行resize
在x3_inference/sample/resize_demo.cpp中实现了三种不同图片格式的resize方法,yuv420、rgb、bgr,最终调用的api接口为 hbDNNResize
string image_path = "../../data/images/kite.jpg";
string test_case = argv[1];
int oimg_w = 1920;
int oimg_h = 1080;
auto bgrImg = imread(image_path);
int resized_w = 640;
int resized_h = 640;
resize(bgrImg,bgrImg,Size(oimg_w,oimg_h));
if(test_case == "YUV420"){
Mat yuvImg;
cvtColor(bgrImg, yuvImg, COLOR_BGR2YUV_I420);
BpuResize* resizer = new BpuResize(oimg_w,oimg_h,resized_w,resized_h,imageType::YUV420);
long t1 = tools::get_current_time();
float* res = resizer->Resize(yuvImg);
long t2 = tools::get_current_time();
cout <<"bpu resize:" <<t2 - t1 << endl;
Mat ResizedYuvMat(resized_h * 1.5, resized_w, CV_8UC1);
memcpy(ResizedYuvMat.data,res,resized_w * resized_h * 1.5);
Mat ResizedBgrMat;
cvtColor(ResizedYuvMat,ResizedBgrMat, COLOR_YUV2BGR_I420);
imwrite("test_resized_yuv.png", ResizedBgrMat);
else if (test_case == "BGR"){
BpuResize* resizer = new BpuResize(oimg_w,oimg_h,resized_w,resized_h,imageType::BGR);
float* res = resizer->Resize(bgrImg);
Mat ResizedBgrMat(resized_h , resized_w, CV_8UC3);
memcpy(ResizedBgrMat.data,res,resized_w * resized_h * 3);
imwrite("test_resized_bgr.png", ResizedBgrMat);
else if (test_case == "RGB"){
Mat rgbImg;
cvtColor(bgrImg, rgbImg, COLOR_BGR2RGB);
BpuResize* resizer = new BpuResize(oimg_w,oimg_h,resized_w,resized_h,imageType::RGB);
float* res = resizer->Resize(rgbImg,{0,0,2000,2000});
Mat ResizedRgbMat(resized_h , resized_w, CV_8UC3);
memcpy(ResizedRgbMat.data,res,resized_w * resized_h * 3);
Mat ResizedBgrMat;
cvtColor(ResizedRgbMat,ResizedBgrMat, COLOR_RGB2BGR);
imwrite("test_resized_rgb.png", ResizedBgrMat);
实现bpu-resize的头文件 bpu_resize.hpp,对裁剪的区域进行缩放有利于給后续的模型进行预测,当然这个步骤可以采用官方的 roiInfer接口来进行,但是roiInfer 有一些限制条件,比如对裁剪区域的高宽必须小于256。
class BpuResize{
public:
BpuResize(const BpuResize& other) = delete;
BpuResize& operator = (const BpuResize& other) = delete;
explicit BpuResize(const int input_w, const int input_h, const int output_w, const int output_h, const imageType imgType);
~BpuResize();
void copy_image_2_input_tensor(uint8_t *image_data,hbDNNTensor *tensor);
float *Resize(Mat ori_img, const std::initializer_list<int> crop);
int32_t prepare_input_tensor();
int32_t prepare_output_tensor();
4、总结
本次测试简化了cpp遍历流程,为后续的上板测试省略的一定的步骤,同时对bpu的resize的接口进行了测试,并且测试了裁剪缩放的功能,发现如果原图为1920*1080,resize后的图片大小为640*640时,opencv的resize需要40+ms,而bpu接口的时间只需要25+ms,但目前从小图放大时,opencv的resize更快一些,不知道这是否属于正常现象。
