报错日志:
##function camera_show_format succeed
##function camera_set_params in
V4L2: Setting format to: MJPG 1920x1080
##function camera_set_params succeed
##function camera_start_streaming in
/dev/video8: 4 buffers requested.
/dev/video8: buffer 0 mapped at address 0x7f2f02b000.
/dev/video8: buffer 1 mapped at address 0x7f2ec36000.
/dev/video8: buffer 2 mapped at address 0x7f2e841000.
/dev/video8: buffer 3 mapped at address 0x7f2e44c000.
##function streaming_loop in
##function camera_start_streaming succeed
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][462.85078][10811:10861][JPUAPIFUNC] hit end of stream
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][462.85098][10811:10861][JPGDecoder] JPU_DecGetInitialInfo failed. ret(0x1)
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][462.85102][10811:10861][COMPONENT] Component jpg_decoder will be terminated.
[ERROR][video/src/hb_vdec.c:663] [462.852240]HB_VDEC_SendStream[663] E: [HB_VDEC] HB_VDEC_SendStream:663 Failed VeChn = 0 s32Ret = -269024256
(vioproduce.cpp:381): send stream to decoder fail
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][462.85341][10811:10880][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][video/src/hb_vdec.c:663] [462.853506]HB_VDEC_SendStream[663] E: [HB_VDEC] HB_VDEC_SendStream:663 Failed VeChn = 0 s32Ret = -269024256
