X3上使用MJEPG格式采集USB摄像头图像,调用HB_VDEC_SendStream时失败
我需要采集USB摄像头上的视频,视频分辨率1920x1080,手头上这个摄像头当采用YUYV格式时采集帧率在5fps左右,不满足要求,然后我试着用MJPEG格式采集视频,帧率能到30帧,我使用从网上找到的V4L2例子代码打开摄像头,读摄像头视频,图像保存为文件显示正常。当我试着用开发包里面的API解码时出错,程序打印如下信息:-
root@x3sdbx3-samsung2G-3200:/userdata/cam_test# ./camera_capture
1920 1080
ion allocator open success m_ionClient :7 !
HorizonVideoDecoder Decode, BufferSize=4147200
[ERROR][video/src/hb_vdec.c:671] [68.803874]HB_VDEC_SendStream[671]: bitstream buffer too large
[ERROR][video/src/hb_vdec.c:671] [68.838882]HB_VDEC_SendStream[671]: bitstream buffer too large
[ERROR][video/src/hb_vdec.c:671] [68.870596]HB_VDEC_SendStream[671]: bitstream buffer too large
[ERROR][video/src/hb_vdec.c:671] [68.903056]HB_VDEC_SendStream[671]: bitstream buffer too large
[ERROR][MM][src/vdi/linux/vdi_osal.c:174] [ERROR][69.17948][1692:1695][JPUAPIFUNC] hit end of stream
[ERROR][MM][src/vdi/linux/vdi_osal.c:174] [ERROR][69.17960][1692:1695][JPGDecoder] JPU_DecGetInitialInfo failed. ret(0x1)
[ERROR][MM][src/vdi/linux/vdi_osal.c:174] [ERROR][69.17962][1692:1695][COMPONENT] Component jpg_decoder will be terminated.
[ERROR][video/src/hb_vdec.c:666] [69.180674]HB_VDEC_SendStream[666]: [HB_VDEC] HB_VDEC_SendStream:666 Failed VeChn = 0 s32Ret = -269024256
[ERROR][MM][src/vdi/linux/vdi_osal.c:174] [ERROR][69.18309][1692:1692][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][video/src/hb_vdec.c:666] [69.183137]HB_VDEC_SendStream[666]: [HB_VDEC] HB_VDEC_SendStream:666 Failed VeChn = 0 s32Ret = -269024256
[ERROR][MM][src/vdi/linux/vdi_osal.c:174] [ERROR][69.18527][1692:1692][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][video/src/hb_vdec.c:666] [69.185330]HB_VDEC_SendStream[666]: [HB_VDEC] HB_VDEC_SendStream:666 Failed VeChn = 0 s32Ret = -269024256
已经解决了,参数传递错误导致,-
int StreamBufSize = VideoWidth * VideoHeight * 3 / 2;换成-
int StreamBufSize = VideoWidth * VideoHeight * 2;就对了。
板子固件:xj3_1.1.20g
程序调用顺序如下:
#define DECODE_MEMORY_BLOCK_NUMBER 4-
HB_SYS_Init();
VP_CONFIG_S struVpConf;
memset(&struVpConf, 0x00, sizeof(VP_CONFIG_S));
struVpConf.u32MaxPoolCnt = DECODE_MEMORY_BLOCK_NUMBER;
HB_VP_SetConfig(&struVpConf);
HB_VP_Init();
HB_VDEC_Module_Init();
int ret = 0;
int VideoWidth = 1920;
int VideoHeight = 1080;
for (int32_t i = 0; i < DECODE_MEMORY_BLOCK_NUMBER; ++i)
if (0 != (ret = HB_SYS_Alloc(&PhyAddr[i], reinterpret_cast<void **>(&VirAddr[i]), StreamBufSize)))
return -1;
VDEC_CHN_ATTR_S VDecChnAttr;
memset(&VDecChnAttr, 0, sizeof(VDEC_CHN_ATTR_S));
VDecChnAttr.enType = PT_MJPEG;
VDecChnAttr.enMode = VIDEO_MODE_FRAME;
VDecChnAttr.enPixelFormat = HB_PIXEL_FORMAT_YUV420P;
VDecChnAttr.u32FrameBufCnt = m_FrameBufferNumber;
VDecChnAttr.u32StreamBufCnt = m_FrameBufferNumber;
VDecChnAttr.u32StreamBufSize = StreamBufSize;
VDecChnAttr.bExternalBitStreamBuf = HB_TRUE;
VDecChnAttr.stAttrMjpeg.enRotation = CODEC_ROTATION_0;
VDecChnAttr.stAttrMjpeg.enMirrorFlip = DIRECTION_NONE;
VDecChnAttr.stAttrMjpeg.stCropCfg.bEnable = HB_FALSE;
HB_VDEC_CreateChn(0, &VDecChnAttr);
HB_VDEC_SetChnAttr(0, &VDecChnAttr);
HB_VDEC_StartRecvStream(0);
int FrameNumber = 0;
VIDEO_STREAM_S PstStream;
memset(&PstStream, 0, sizeof(VIDEO_STREAM_S));
uint64_t MemoryIndex = FrameNumber % DECODE_MEMORY_BLOCK_NUMBER;
memcpy(m_VirAddr[MemoryIndex], BufferIn, BufferSize);
PstStream.pstPack.phy_ptr = PhyAddr[MemoryIndex];
PstStream.pstPack.vir_ptr = VirAddr[MemoryIndex];
PstStream.pstPack.pts = FrameNumber;
PstStream.pstPack.src_idx = MemoryIndex;
PstStream.pstPack.size = BufferSize;
PstStream.pstPack.stream_end = HB_FALSE;
if (0 != HB_VDEC_SendStream(0, &PstStream, -1))
printf(“decode, HB_VDEC_SendStream fail, errno=%d\n”, errno);
return -1;
++FrameNumber;
