admin 你好,
用ai-express v2.9.0里video box sample,打开大华球机的rtsp流,但解码stream失败。请教下,可能是什么原因导致的。谢谢!
板子:x3dvbx3-hynix1G-2666
[URL:“rtsp://192.168.1.70:554/cam/realmonitor?channel=1&subtype=0/”]: Started playing session…
Stream “rtsp://192.168.1.70:554/cam/realmonitor?channel=1&subtype=0/”; video/H264: Received 3 bytes. Presentation time: 234000
wen recv h264 grp 0 data: 00 00 00 00 00 00 00 00 00 00
(H264Sink.cpp:250): channel:0 recv stream
(H264Sink.cpp:254): wen sps[0].sPropLength:44, hex:674d40288d8d403c113f2
(H264Sink.cpp:273): wen channel:0 recv nal type1:7
(H264Sink.cpp:275): wen channel:0 to analytics sps info
(SPSInfoMgr.cpp:55): sps anlytics get width:1920 height:1088
(H264Sink.cpp:280): wen width, height:1920, 1088
enType = 96 ctx->encoder = 0
============reorder_enable:1, skip_mode:0, bandwidth_Opt:1
(vdecmodule.cpp:81): Vdec module init done.
(mediapipeline.cpp:51): Vps module init done.
(vdecmodule.cpp:92): Vdec module start done.
(mediapipeline.cpp:67): Vps module start done.
Stream “rtsp://192.168.1.70:554/cam/realmonitor?channel=1&subtype=0/”; video/H264: Received 44 bytes. Presentation time: 234000
wen recv h264 grp 0 data: 00 00 00 01 67 4d 40 28 8d 8d
Stream “rtsp://192.168.1.70:554/cam/realmonitor?channel=1&subtype=0/”; video/H264: Received 5 bytes. Presentation time: 234000
wen recv h264 grp 0 data: 00 00 00 01 68 ee 38 80 00 00
(H264Sink.cpp:178): batch_send_
wen vdec recv data: 00 00 00 01 67
wen vdec recv data: 00 00 00 01 68
Stream “rtsp://192.168.1.70:554/cam/realmonitor?channel=1&subtype=0/”; video/H264: Received 29 bytes. Presentation time: 234000
wen recv h264 grp 0 data: 00 00 00 01 06 00 0d 80 c5 c1
wen vdec recv data: 00 00 00 01 06
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][154065.25094][4721:4877][VideoDecoder] DecodeHeader:1413 FAILED TO DEC_PIC_HDR: ret(1), SEQERR(00005000)
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][154065.25104][4721:4877][COMPONENT] Component wave_decoder will be terminated.
[ERROR][video/src/hb_vdec.c:663] [154065.252143]HB_VDEC_SendStream[663] E: [HB_VDEC] HB_VDEC_SendStream:663 Failed VeChn = 0 s32Ret = -269024256
(vdecmodule.cpp:114): HB_VDEC_SendStream Failed. ret = 4025943040
Stream “rtsp://192.168.1.70:554/cam/realmonitor?channel=1&subtype=0/”; video/H264: Received 22186 bytes. Presentation time: 234000
wen recv h264 grp 0 data: 00 00 00 01 65 b8 00 02 00 00
wen vdec recv data: 00 00 00 01 65
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][154065.25336][4721:4870][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][video/src/hb_vdec.c:663] [154065.253404]HB_VDEC_SendStream[663] E: [HB_VDEC] HB_VDEC_SendStream:663 Failed VeChn = 0 s32Ret = -269024256
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][154065.33169][4721:4872][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][video/src/hb_vdec.c:740] [154065.331764]HB_VDEC_GetFrame[740] E: [HB_VDEC] HB_VDEC_GetFrame:740 Failed VdChn = 0 s32Ret = -269024256
(vdecmodule.cpp:135): HB_VDEC_GetFrame Failed. ret = 4025943040
[ERROR][MM][src/vdi/linux/vdi_osal.c:173] [ERROR][154065.33186][4721:4872][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][video/src/hb_vdec.c:740] [154065.331903]HB_VDEC_GetFrame[740] E: [HB_VDEC] HB_VDEC_GetFrame:740 Failed VdChn = 0 s32Ret = -269024256
