J3开发板调试AI Express问题
目前对开发板进行了刷机操作,刷机版本是disk_xj3_emmc20201023_1GB&2GB.img,AI Express按照github上的交叉编译进行编译,生成deploy文件夹后,拷贝到开发板/userdata目录下,后,运行sh run.sh,无法展示正确的demo,log如下:
ssh root@10.33.10.60
root@j3dvbj3-hynix2G-2666:~# cd /userdata/deploy/
root@j3dvbj3-hynix2G-2666:/userdata/deploy# sh run.sh d
/userdata/deploy
log_level: d
run_mode:
Choose lunch solution menu…pick a combo:
1. face
2. face_recog
3. body
4. xbox
5. behavior
7. video_box
8. tv_uvc
9. face_body_multisource
10. apa
11. multi_input_hapi
12. apa_test
13. ssd_test
14. vio_test
15. multi_input_hapi_ipm
16. matting
17. yolov3_mobilenetv3_example
18. matting_trimapfree
Which would you like?
You choose 1:face
pass_viotype_ck is
Choose lunch platform menu…pick a combo:
1. x2_96board
2. x2_2610
3. x3_sdb
4. x3_dev
5. j3_dev
5
You choose 5:j3dev
Choose lunch j3 vio type menu…pick a combo:
1. single cam
2. single feedback
3. multi cam sync
4. multi cam async
5. multi feedback sync
2
You choose 2:single_fb
Choose lunch fb resolution menu…pick a combo:
1. 1080p feedback
2. 2160p feedback
You choose 1:1080p_feedback
Choose lunch feedback source mode menu…pick a combo:
1. cached feedback source
2. jpeg feedback source
3. nv12 feedback source
2
You choose 2:jpeg
fb_mode: jpeg_image_list
vio_pipe_file: configs/vio/j3dev/1080_fb.json
platform is j3dev
fb_res is 1080_fb
vio_cfg_file is ./configs/vio_config.json.j3dev.fb
vio_pipe_file is configs/vio/j3dev/1080_fb.json
sh: write error: No such device
/usr/bin/adbd is not runnning
Detecting platform:
board : Hobot J3 SOC MP DVB
udc : b2000000.usb
usb-gadget is already running
resolution 1080P feedback start, 1080P X3 JPEG Codec…
cp: can’t stat ‘vehicle_solution/configs/vehicle_multitask_2M.json’: No such file or directory
cp: can’t stat ‘vehicle_solution/configs/config_match_2M.json’: No such file or directory
turn on mallopt
use bpu native engine
(xpluginasync.cpp:119): XPluginAsync() cons
(smartplugin.cpp:2551): smart config file:./face_solution/configs/face_solution.json
(smartplugin.cpp:2572): xstream_workflow_file:./face_solution/configs/face_snapshot.json
(smartplugin.cpp:2573): enable_profile:0, profile_log_path:
(smartplugin.cpp:2623): gesture_mute_outside:20 palm_move_dist_thr:5 valid_palm_for_palmpat_thr:150 dynamic_gesture_vanish_thr:50 static_gesture_vanish_thr:25 static_dynamic_dist_thr:5 conflict_gesture_thr:25 gesture_direction_activate_thr:0.005 gesture_direction_cal_N_pts:15
(smartplugin.cpp:2642): dist_calibration_w:0 dist_fit_factor:0 dist_fit_impower:0 dist_smooth:1
(main.cpp:151): create WebSocket plugin
(websocketplugin.cpp:43): UwsPlugin smart config file:./configs/visualplugin_face.json
(websocketplugin.cpp:86): Reset!!!
(viopipemanager.cpp:29): get vio pipe_id value: 0
(viopipeconfig.cpp:37): Open config file configs/vio/j3dev/1080_fb.json success
(viopipeconfig.cpp:52): Open config file1 configs/vio/j3dev/1080_fb.json
(viopipeconfig.cpp:300): ******** iot vio config: 0 start *********
(viopipeconfig.cpp:302): cam_en: 0
(viopipeconfig.cpp:303): vin_vps_mode: 0
(viopipeconfig.cpp:305): vin_fd_en: 0
(viopipeconfig.cpp:307): sensor_id: 1
(viopipeconfig.cpp:308): sensor_port: 0
(viopipeconfig.cpp:309): i2c_bus: 5
(viopipeconfig.cpp:310): extra_mode: 0
(viopipeconfig.cpp:311): need_clk: 0
(viopipeconfig.cpp:312): serdes_index: 0
(viopipeconfig.cpp:313): serdes_port: 0
(viopipeconfig.cpp:314): gpio_num: 0
(viopipeconfig.cpp:315): gpio_pin: 0
(viopipeconfig.cpp:316): gpio_level: 0
(viopipeconfig.cpp:318): mipi_index: 1
(viopipeconfig.cpp:319): vc_index: 0
(viopipeconfig.cpp:320): dol2_vc_index: 1
(viopipeconfig.cpp:322): need_md: 0
(viopipeconfig.cpp:323): sif_out_buf_num: 8
(viopipeconfig.cpp:325): temper_mode: 2
(viopipeconfig.cpp:326): isp_out_buf_num: 5
(viopipeconfig.cpp:327): isp_3a_en: 1
(viopipeconfig.cpp:329): ldc_en: 0
(viopipeconfig.cpp:330): dis_en: 0
(viopipeconfig.cpp:332): vps_dump_num: 0
(viopipeconfig.cpp:333): vps_layer_dump: 4
(viopipeconfig.cpp:334): vps_fd_en: 0
(viopipeconfig.cpp:336): fb_width: 1920
(viopipeconfig.cpp:337): fb_height: 1080
(viopipeconfig.cpp:338): fb_buf_num: 8
(viopipeconfig.cpp:339): fb_inner_buf_en: 0
(viopipeconfig.cpp:340): fb_inner_buf_type: 0
(viopipeconfig.cpp:341): fb_bind_pipe_id: -1
(viopipeconfig.cpp:344): gdc_0_en: 0
(viopipeconfig.cpp:346): gdc_0_frame_depth: 2
(viopipeconfig.cpp:348): gdc_0_src_type: 1
(viopipeconfig.cpp:350): gdc_0_rotate: 0
(viopipeconfig.cpp:352): gdc_0_bid_ipu_chn: -1
(viopipeconfig.cpp:354): gdc_0_file_path:
(viopipeconfig.cpp:344): gdc_1_en: 0
(viopipeconfig.cpp:346): gdc_1_frame_depth: 2
(viopipeconfig.cpp:348): gdc_1_src_type: 2
(viopipeconfig.cpp:350): gdc_1_rotate: 0
(viopipeconfig.cpp:352): gdc_1_bid_ipu_chn: -1
(viopipeconfig.cpp:354): gdc_1_file_path:
(viopipeconfig.cpp:358): vps_chn_num: 7
(viopipeconfig.cpp:360): chn_index: 0 ipu_chn_en: 0
(viopipeconfig.cpp:362): chn_index: 0 pym_chn_en: 0
(viopipeconfig.cpp:364): chn_index: 0 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 0 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 0 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 0 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 0 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 0 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 0 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 0 roi_w: 1920
(viopipeconfig.cpp:382): chn_index: 0 roi_h: 1080
(viopipeconfig.cpp:360): chn_index: 1 ipu_chn_en: 0
(viopipeconfig.cpp:362): chn_index: 1 pym_chn_en: 0
(viopipeconfig.cpp:364): chn_index: 1 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 1 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 1 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 1 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 1 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 1 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 1 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 1 roi_w: 1920
(viopipeconfig.cpp:382): chn_index: 1 roi_h: 1080
(viopipeconfig.cpp:360): chn_index: 2 ipu_chn_en: 0
(viopipeconfig.cpp:362): chn_index: 2 pym_chn_en: 0
(viopipeconfig.cpp:364): chn_index: 2 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 2 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 2 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 2 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 2 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 2 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 2 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 2 roi_w: 1920
(viopipeconfig.cpp:382): chn_index: 2 roi_h: 1080
(viopipeconfig.cpp:360): chn_index: 3 ipu_chn_en: 0
(viopipeconfig.cpp:362): chn_index: 3 pym_chn_en: 0
(viopipeconfig.cpp:364): chn_index: 3 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 3 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 3 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 3 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 3 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 3 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 3 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 3 roi_w: 1920
(viopipeconfig.cpp:382): chn_index: 3 roi_h: 1080
(viopipeconfig.cpp:360): chn_index: 4 ipu_chn_en: 0
(viopipeconfig.cpp:362): chn_index: 4 pym_chn_en: 0
(viopipeconfig.cpp:364): chn_index: 4 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 4 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 4 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 4 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 4 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 4 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 4 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 4 roi_w: 1920
(viopipeconfig.cpp:382): chn_index: 4 roi_h: 1080
(viopipeconfig.cpp:360): chn_index: 5 ipu_chn_en: 0
(viopipeconfig.cpp:362): chn_index: 5 pym_chn_en: 0
(viopipeconfig.cpp:364): chn_index: 5 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 5 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 5 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 5 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 5 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 5 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 5 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 5 roi_w: 1920
(viopipeconfig.cpp:382): chn_index: 5 roi_h: 1080
(viopipeconfig.cpp:360): chn_index: 6 ipu_chn_en: 1
(viopipeconfig.cpp:362): chn_index: 6 pym_chn_en: 1
(viopipeconfig.cpp:364): chn_index: 6 ipu_frame_depth: 8
(viopipeconfig.cpp:366): chn_index: 6 ipu_frame_timeout: 2000
(viopipeconfig.cpp:369): chn_index: 6 scale_w: 1920
(viopipeconfig.cpp:371): chn_index: 6 scale_h: 1080
(viopipeconfig.cpp:374): chn_index: 6 roi_en: 0
(viopipeconfig.cpp:376): chn_index: 6 roi_x: 0
(viopipeconfig.cpp:378): chn_index: 6 roi_y: 0
(viopipeconfig.cpp:380): chn_index: 6 roi_w: 0
(viopipeconfig.cpp:382): chn_index: 6 roi_h: 0
(viopipeconfig.cpp:386): --------chn:6 pym config start---------
(viopipeconfig.cpp:387): chn_index: 6 frame_id: 1
(viopipeconfig.cpp:389): chn_index: 6 ds_layer_en: 23
(viopipeconfig.cpp:391): chn_index: 6 ds_uv_bypass: 0
(viopipeconfig.cpp:393): chn_index: 6 us_layer_en: 0
(viopipeconfig.cpp:395): chn_index: 6 us_uv_bypass: 0
(viopipeconfig.cpp:397): chn_index: 6 frameDepth: 5
(viopipeconfig.cpp:399): chn_index: 6 timeout: 2000
(viopipeconfig.cpp:404): ds_pym_layer: 1 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 1 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 1 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 1 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 1 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 2 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 2 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 2 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 2 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 2 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 3 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 3 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 3 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 3 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 3 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 5 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 5 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 5 ds roi_width: 900
(viopipeconfig.cpp:410): ds_pym_layer: 5 ds roi_height: 540
(viopipeconfig.cpp:412): ds_pym_layer: 5 ds factor: 8
(viopipeconfig.cpp:404): ds_pym_layer: 6 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 6 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 6 ds roi_width: 960
(viopipeconfig.cpp:410): ds_pym_layer: 6 ds roi_height: 540
(viopipeconfig.cpp:412): ds_pym_layer: 6 ds factor: 32
(viopipeconfig.cpp:404): ds_pym_layer: 7 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 7 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 7 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 7 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 7 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 9 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 9 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 9 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 9 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 9 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 10 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 10 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 10 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 10 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 10 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 11 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 11 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 11 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 11 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 11 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 13 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 13 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 13 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 13 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 13 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 14 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 14 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 14 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 14 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 14 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 15 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 15 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 15 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 15 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 15 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 17 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 17 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 17 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 17 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 17 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 18 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 18 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 18 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 18 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 18 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 19 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 19 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 19 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 19 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 19 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 21 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 21 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 21 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 21 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 21 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 22 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 22 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 22 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 22 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 22 ds factor: 0
(viopipeconfig.cpp:404): ds_pym_layer: 23 ds roi_x: 0
(viopipeconfig.cpp:406): ds_pym_layer: 23 ds roi_y: 0
(viopipeconfig.cpp:408): ds_pym_layer: 23 ds roi_width: 0
(viopipeconfig.cpp:410): ds_pym_layer: 23 ds roi_height: 0
(viopipeconfig.cpp:412): ds_pym_layer: 23 ds factor: 0
(viopipeconfig.cpp:417): us_pym_layer: 0 us roi_x: 0
(viopipeconfig.cpp:419): us_pym_layer: 0 us roi_y: 0
(viopipeconfig.cpp:421): us_pym_layer: 0 us roi_width: 0
(viopipeconfig.cpp:423): us_pym_layer: 0 us roi_height: 0
(viopipeconfig.cpp:425): us_pym_layer: 0 us factor: 0
(viopipeconfig.cpp:417): us_pym_layer: 1 us roi_x: 0
(viopipeconfig.cpp:419): us_pym_layer: 1 us roi_y: 0
(viopipeconfig.cpp:421): us_pym_layer: 1 us roi_width: 0
(viopipeconfig.cpp:423): us_pym_layer: 1 us roi_height: 0
(viopipeconfig.cpp:425): us_pym_layer: 1 us factor: 0
(viopipeconfig.cpp:417): us_pym_layer: 2 us roi_x: 0
(viopipeconfig.cpp:419): us_pym_layer: 2 us roi_y: 0
(viopipeconfig.cpp:421): us_pym_layer: 2 us roi_width: 0
(viopipeconfig.cpp:423): us_pym_layer: 2 us roi_height: 0
(viopipeconfig.cpp:425): us_pym_layer: 2 us factor: 0
(viopipeconfig.cpp:417): us_pym_layer: 3 us roi_x: 0
(viopipeconfig.cpp:419): us_pym_layer: 3 us roi_y: 0
(viopipeconfig.cpp:421): us_pym_layer: 3 us roi_width: 0
(viopipeconfig.cpp:423): us_pym_layer: 3 us roi_height: 0
(viopipeconfig.cpp:425): us_pym_layer: 3 us factor: 0
(viopipeconfig.cpp:417): us_pym_layer: 4 us roi_x: 0
(viopipeconfig.cpp:419): us_pym_layer: 4 us roi_y: 0
(viopipeconfig.cpp:421): us_pym_layer: 4 us roi_width: 0
(viopipeconfig.cpp:423): us_pym_layer: 4 us roi_height: 0
(viopipeconfig.cpp:425): us_pym_layer: 4 us factor: 0
(viopipeconfig.cpp:417): us_pym_layer: 5 us roi_x: 0
(viopipeconfig.cpp:419): us_pym_layer: 5 us roi_y: 0
(viopipeconfig.cpp:421): us_pym_layer: 5 us roi_width: 0
(viopipeconfig.cpp:423): us_pym_layer: 5 us roi_height: 0
(viopipeconfig.cpp:425): us_pym_layer: 5 us factor: 0
(viopipeconfig.cpp:428): ---------pym_chn:6 config end----------
(viopipeconfig.cpp:431): ******** iot vio config: 0 end *********
(viopipeline.cpp:40): Enter viopipeline init, pipe_id: 0 pipe_sync_num: 1
(vpsmodule.cpp:70): Enter FbInit fb_buf_num: 8 fb_width: 1920 fb_height: 1080
ion allocator open success m_ionClient :5 !
(viopipemanager.cpp:69): viopipemanager vb init success…
(vpsmodule.cpp:909): pipe_id: 0 pym_chn_index: 0 pym_chn_valid: 6
(vpsmodule.cpp:163): vps create group, grp_w: 1920 grp_h: 1080 grp_depth: 0
(vpsmodule.cpp:170): created a group ok:GrpId: 0
(vpsmodule.cpp:291): vps set ipu chn Attr ok: GrpId: 0 chn_id: 6
(vpsmodule.cpp:362): vps set pym chn Attr ok: GrpId: 0 chn_id: 6
(vpsmodule.cpp:366): ds5 factor: roi_x: 0 roi_y: 0 roi_width: 900 roi_height: 540
(vpsmodule.cpp:372): ds6 factor: roi_x: 0 roi_y: 0 roi_width: 960 roi_height: 540
(msg_manager.h:55): try to register invalid msg type:XPLUGIN_HBIPC_MESSAGE, for plugin VioPlugin
(xpluginasync.cpp:28): XPluginAsync::Init
(scheduler.cpp:31): Scheduler Init
(scheduler.cpp:526): CreateSlot
(node.cpp:32): Node Init
(method_manager.cpp:32): MethodManager Init
(MultitaskPredictMethod.cpp:34): MultitaskPredictMethod Init
(DnnPredictMethod.cpp:29): DnnPredictMethod Init
[1970-01-01 08:11:41 INFO 548527648784 hr_api.cpp:467] HorizonRT version = 1.2.2
[1970-01-01 08:11:41 INFO 548527648784 hr_api.cpp:472] hbrt version = 3.10.4
[HBRT] set log level as 0. version = 3.10.4
bpu engine_type is naive.
[BPU_PLAT]Makesure BPU Core Opened!!!)
[BPU_PLAT]BPU Platform Version(1.1.1)!
naive engine use core-engine type is naive.
[BPU_PLAT]Makesure BPU Core(1) Opened!!!
(MultitaskPredictMethod.cpp:47): pyramid layer: 6, model input width: 640, model input height: 360
(MultitaskPostProcessMethod.cpp:42): MultitaskPostProcessMethod Init
(DnnPostProcessMethod.cpp:25): DnnPostProcessMethod Init
(MultitaskPostProcessMethod.cpp:50): rcnn branch out type:
(MultitaskPostProcessMethod.cpp:54): _
(MultitaskPostProcessMethod.cpp:54): bbox
(MultitaskPostProcessMethod.cpp:54): lmks2_label
(MultitaskPostProcessMethod.cpp:54): lmks2_offset
(MultitaskPostProcessMethod.cpp:54): lmks1
(MultitaskPostProcessMethod.cpp:54): 3d_pose
(MOTMethod.cpp:34): MOTMethod::Init ./face_solution/configs/iou_method_param.json
(MOTMethod.cpp:49): tracker_type IOU
(IOU.cpp:32): IOU Mot::Init ./face_solution/configs/iou_method_param.json
(CNNMethod.cpp:34): CNNMethod Init
(Predictor.cpp:47): model_file_path:./face_solution/configs/../../models/faceAgeGender.hbm
bpu_config_path:./face_solution/configs/../configs/bpu_config.json
parent path./face_solution/configs/
(ModelInfo.cpp:81): data_type: 7
(vote_method.cpp:45): Init ./face_solution/configs/age_voting.json
(vote_method.cpp:54): type:age
(vote_method.cpp:45): Init ./face_solution/configs/gender_voting.json
(vote_method.cpp:54): type:gender
(Predictor.cpp:47): model_file_path:./face_solution/configs/../../models/faceQuality.hbm
(ModelInfo.cpp:81): data_type: -1
(FilterMethod.cpp:28): FilterMethod::Init ./face_solution/configs/filter_config.json
用户您好,问题是系统镜像和ai-express不匹配,老版本镜像没有新版本ai-express运行的库,需要同步更新镜像,请下载最新镜像与安装工具,传送门:https://developer.horizon.ai/resource
由于有字数限制,在评论中给出后续log
(filter_data_type.cpp:30): show_bound_rect: 1
(filter_data_type.cpp:31): image_width: 1920
(filter_data_type.cpp:32): image_height: 1080
(filter_data_type.cpp:33): face_size_thr: 15
(filter_data_type.cpp:34): head_size_thr: 15
(filter_data_type.cpp:35): body_size_thr: 42
(filter_data_type.cpp:36): hand_size_thr: 15
(filter_data_type.cpp:37): frontal_pitch_thr: 30
(filter_data_type.cpp:38): frontal_yaw_thr: 40
(filter_data_type.cpp:39): frontal_roll_thr: 20
(filter_data_type.cpp:40): frontal_thr: 1000
(filter_data_type.cpp:41): filter_with_frontal_thr: 0
(filter_data_type.cpp:42): face_pv_thr: 0.9
(filter_data_type.cpp:43): head_pv_thr: 0.9
(filter_data_type.cpp:44): body_pv_thr: 0.9
(filter_data_type.cpp:45): hand_pv_thr: 0.9
(filter_data_type.cpp:46): quality_thr: 0.9
(filter_data_type.cpp:47): lmk_thr: 0.6
(filter_data_type.cpp:48): lmk_filter_num: 10
(filter_data_type.cpp:49): bound_thr_w: 10
(filter_data_type.cpp:50): bound_thr_h: 10
(filter_data_type.cpp:51): max_face_box_counts: 0
(filter_data_type.cpp:52): brightness_min: 0
(filter_data_type.cpp:53): brightness_max: 4
(filter_data_type.cpp:54): abnormal_thr: 1
(filter_data_type.cpp:55): face_expand_scale: 1.2
(filter_data_type.cpp:56): head_expand_scale: 1
(filter_data_type.cpp:57): body_expand_scale: 1
(filter_data_type.cpp:58): hand_expand_scale: 1
(filter_data_type.cpp:59): filter_status: 4
(filter_data_type.cpp:60): age_min: 0
(filter_data_type.cpp:61): age_max: 100
(filter_data_type.cpp:62): age_thr: 0.5
(filter_data_type.cpp:66): pose filter with pitch: 30 yaw: 40 roll: 20
(filter_data_type.cpp:88): left_eye_occluded_thr: 0.5
(filter_data_type.cpp:89): right_eye_occluded_thr: 0.5
(filter_data_type.cpp:90): left_brow_occluded_thr: 0.5
(filter_data_type.cpp:91): right_brow_occluded_thr: 0.5
(filter_data_type.cpp:92): forehead_occluded_thr: 0.5
(filter_data_type.cpp:93): left_cheek_occluded_thr: 0.5
(filter_data_type.cpp:94): right_cheek_occluded_thr: 0.5
(filter_data_type.cpp:95): nose_occluded_thr: 0.5
(filter_data_type.cpp:96): mouth_occluded_thr: 0.5
(filter_data_type.cpp:97): jaw_occluded_thr: 0.5
(filter_data_type.cpp:73): norm_method: norm_by_lside_square
(filter_data_type.cpp:84): norm_method:norm_by_lside_square
(filter_data_type.cpp:102): passed_err_code: 0
(filter_data_type.cpp:103): snap_area_err_code: -1
(filter_data_type.cpp:104): snap_size_thr_err_code: -2
(filter_data_type.cpp:105): expand_thr_err_code: -3
(filter_data_type.cpp:106): frontal_thr_err_code: -4
(filter_data_type.cpp:107): pv_thr_err_code: -5
(filter_data_type.cpp:108): quality_thr_err_code: -6
(filter_data_type.cpp:109): lmk_thr_err_code: -7
(filter_data_type.cpp:110): black_list_err_code: -8
(filter_data_type.cpp:111): white_list_err_code: -9
(filter_data_type.cpp:112): big_face_err_code: -10
(filter_data_type.cpp:113): age_err_code: -11
(filter_data_type.cpp:114): stop_id_err_code: -12
(filter_data_type.cpp:115): brightness_err_code: -21
(filter_data_type.cpp:116): abnormal_thr_err_code: -22
(filter_data_type.cpp:121): left_eye_occluded_thr_err_code: -23
(filter_data_type.cpp:122): right_eye_occluded_thr_err_code: -24
(filter_data_type.cpp:123): left_brow_occluded_thr_err_code: -25
(filter_data_type.cpp:124): right_brow_occluded_thr_err_code: -26
(filter_data_type.cpp:125): forehead_occluded_thr_err_code: -27
(filter_data_type.cpp:126): left_cheek_occluded_thr_err_code: -28
(filter_data_type.cpp:127): right_cheek_occluded_thr_err_code: -29
(filter_data_type.cpp:128): nose_occluded_thr_err_code: -30
(filter_data_type.cpp:129): mouth_occluded_thr_err_code: -31
(filter_data_type.cpp:130): jaw_occluded_thr_err_code: -32
(filter_data_type.cpp:189): stop_id: -1
(filter_data_type.cpp:196): start_id: -1
(filter_data_type.cpp:246): merge_method: head_body
(filter_data_type.cpp:247): head_enable: 1
(filter_data_type.cpp:248): face_enable: 1
(filter_data_type.cpp:249): body_enable: 1
(filter_data_type.cpp:250): hand_enable: 1
(GradingMethod.cpp:25): GradingMethod::Init ./face_solution/configs/grading.json
(WeightGrading.cpp:55): GradingMethod::GradingInit ./face_solution/configs/grading.json
(SnapShotMethod.cpp:30): SnapShotMethod::Init ./face_solution/configs/snapshot.json
(first_num_best.cpp:478): FirstNumBestParam update config: 0x48fba50
(snapshot_data_type.cpp:34): SnapShotParam update config: 0x48fba50
(snapshot_data_type.cpp:51): scale_rate: 0
(snapshot_data_type.cpp:52): need_resize: 1
(snapshot_data_type.cpp:53): output_width: 0
(snapshot_data_type.cpp:54): output_height: 0
(snapshot_data_type.cpp:55): save_original_image_frame: 1
(snapshot_data_type.cpp:51): scale_rate: 1.6
(snapshot_data_type.cpp:52): need_resize: 0
(snapshot_data_type.cpp:53): output_width: 128
(snapshot_data_type.cpp:54): output_height: 128
(snapshot_data_type.cpp:55): save_original_image_frame: 0
(first_num_best.cpp:501): update_steps: 0
(first_num_best.cpp:502): snaps_per_track: 1
(first_num_best.cpp:503): max_tracks: 256
(first_num_best.cpp:504): max_crop_num_per_frame: 20
(first_num_best.cpp:505): smoothing_frame_range: 10
(first_num_best.cpp:506): avg_crop_num_per_frame: 2
(first_num_best.cpp:507): begin_post_frame_thr: 1
(first_num_best.cpp:508): resnap_value: 3
(first_num_best.cpp:509): report_flushed_track_flag: 1
(first_num_best.cpp:510): out_date_target_post_flag: 1
(first_num_best.cpp:511): repeat_post_flag: 1
(first_num_best.cpp:512): allow_empty_snapshot: 0
(first_num_best.cpp:478): FirstNumBestParam update config: 0x48fb2d0
(snapshot_data_type.cpp:34): SnapShotParam update config: 0x48fb2d0
(websocketplugin.cpp:54): WebsocketPlugin::Init
(websocketplugin.cpp:66): attribute_description_path: configs/websocketplugin_attribute.json
(uws_server.cpp:48): UwsServer::StartServer
(uws_server.cpp:72): UwsServer begin to run
(viopipeline.cpp:141): Enter viopipeline start, pipe_id: 0 pipe_sync_num: 1
(vpsmodule.cpp:497): Enter Vps Start, pipe_id: 0
(vpsmodule.cpp:452): Enter VpsCreatePymThread, pipe_id: 0 start_flag: 0
(vpsmodule.cpp:1344): Enter Get PYM Data Thread, pipe_id: 0 start_flag: 1 max_pym_buffer is: 5
(ring_queue.h:32): Try to construct empty RingQueue
(executor.cpp:92): task_queue_size: 1 thread_count: 1
(smartplugin.cpp:2770): SmartPlugin Start
(vioproduce.cpp:1499): Finish importing images
[ERROR][vps/hb_vps_api.c:397] [701.827255]HB_VPS_SendFrame[397]: bad paddr
(vpsmodule.cpp:1200): info_type: IOT_VIO_FEEDBACK_PYM_PROCESS HB_VPS_SendFrame error, ret: -9
(viopipeline.cpp:242): vps module set info failed, pipe_id: 0
(vioproduce.cpp:627): vio pipeline set feedback pym process info failed
(vioproduce.cpp:1561): fill vio image failed, ret: 0
[ERROR][vps/hb_vps_api.c:397] [702.071657]HB_VPS_SendFrame[397]: bad paddr
[ERROR][vps/hb_vps_api.c:397] [702.315609]HB_VPS_SendFrame[397]: bad paddr
[ERROR][vps/hb_vps_api.c:1714] [703.577724]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
(vpsmodule.cpp:1368): pipe_id: 0 HB_VPS_GetChnFrame error, ret: -13
[ERROR][vps/hb_vps_api.c:1714] [705.577977]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [707.578194]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [709.578461]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [711.578677]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [713.578882]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [715.579082]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [717.579230]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [719.579437]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
(uws_server.cpp:52): UwsServer Connection with PC success
(uws_server.cpp:59): UwsServer onMessage: {“filter_prefix”:“null/null/null”}>D�connection: Upgrade
pragma: no-cache
cache-control: no-cache
upgrade: websocket
origin: http://10.33.10.60
sec-websocket-version: 13
user-agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/75.0.3770.80 Safari/537.36
accept-encoding: gzip, deflate
accept-language: zh-CN,zh;q=0.9,en;q=0.8
cookie: path_num=1
sec-websocket-key: GXuMXi+l8hsCgLgXJZnSLg==
sec-websocket-extensions: permessage-deflate; client_max_window_bits
[ERROR][vps/hb_vps_api.c:1714] [721.579630]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
[ERROR][vps/hb_vps_api.c:1714] [723.579839]HB_VPS_GetChnFrame[1714]: VPS error get chn6 frame timeout
