自己编程打开摄像头的时候,报错,请问是什么原因呢?
stop sensor_name f37, setting_size = 1
[ERROR][][vps/hb_vps_api.c:2303] [4763.495218]HB_VPS_GetChnFrame[2303]: VPS error get chn2 frame timeout
代码如下:
#include <ostream>#include <iostream>#include <memory>#include <sstream>#include <string>#include <thread>#include "video_source/video_source.h"#include "video_source/video_source_type.h"using std::chrono::milliseconds;using videosource::VideoSource;using videosource::VideoSourceLogLevel;using videosource::VideoSourceErrorCode;using videosource::ImageFrame;using videosource::PyramidFrame;using videosource::HorizonVisionPixelFormat;int main(int argc, char **argv) {    std::cout << "main" << std::endl;    int ret = -1;    std::string config_file;    config_file= "./configs/video_source/x3dev/mipi_cam/x3_mipi_cam_f37_1080p_chn0.json";    int channel_id = 0;    auto video_sorce = std::make_shared<VideoSource>(channel_id, config_file);    video_sorce->Init();    std::cout << "init" << std::endl;    video_sorce->Start();    std::cout << "start" << std::endl;    bool is_sync_mode = video_sorce->GetSyncMode(); //0    std::cout << "sync: " << is_sync_mode << std::endl;    bool vin_out_en = video_sorce->GetVinOutEnable(); //0    std::cout << "vin_out_en: " << vin_out_en << std::endl;    bool vps_en = video_sorce->GetVpsEnable();//1    std::cout << "vps_en: " << vps_en << std::endl;    int time = 25;    if(time>0){        std::vector<std::shared_ptr<videosource::ImageFrame>> ipu_image_list;        ret = video_sorce->GetVpsImageFrame(ipu_image_list);        std::cout << ret << std::endl;       // std::cout << ipu_image_list.size() << std::endl;        ret = video_sorce->FreeVpsImageFrame(ipu_image_list);        std::cout << ret << std::endl;        std::this_thread::sleep_for(std::chrono::milliseconds(40));        std::cout << time << std::endl;        time = time - 1;    }    video_sorce->Stop();    std::cout << "stop" << std::endl;    video_sorce->DeInit();    std::cout << "deinit" << std::endl;    std::cout << "end!!!" << std::endl;    if(ret!=0)    {        std::cout << "end" << std::endl;    }    return 0;}
谢谢!
您好 报的错是?为什么不直接使用ai-express呢
另外 f37的库需要下载的
因为没有找到可以单独build AI_EXPRESS例程中的方法,每次都要重新build,太慢,太复杂了
请问AI-EXPRESS-master\source\solution_zoo\face项目有没有可以单独编译的build
