我修改的步骤:
1. 替换掉app文件夹里面test_yolov3.py的模型与模型加载代码
我把官方ppyolo帖子里面的ppyolo_trashdet_416x416_nv12.bin文件放到/app/ai_inference/models中,
并修改/app/ai_inference/06_yolov3_sample/test_yolov3.py里面的模型加载,把它改成加载ppyolo_trashdet_416x416_nv12.bin
2. 修改分类文件里面的分类和后处理代码里面的分类数
修改了postpress.py里面的num_classes = 80改为num_classes = 1,以及coco_classes.names里面的类别也全删了,就写了一个trash
自己运行原本正常程序与修改后程序的对比结果:
原本程序执行推理返回的元组大小是3,修改后推理后返回的元组大小却为2
其他的尝试:
使用tros运行成功,而且配置文件后处理配置写的也是yolov3
运行使用的指令:ros2 launch dnn_node_example hobot_dnn_node_example.launch.py config_file:=config/ppyoloworkconfig.json msg_pub_topic_name:=ai_msg_mono2d_trash_detection image_width:=1920 image_height:=1080
未修改前正常程序运行信息
[C][5496][03-04][17:01:47:590][configuration.cpp:51][EasyDNN]EasyDNN version: 0.1.1
[BPU_PLAT]BPU Platform Version(1.3.3)!
[HBRT] set log level as 0. version = 3.14.5
[DNN] Runtime version = 1.9.7_(3.14.5 HBRT)
tensor type: NV12_SEPARATE
data type: uint8
layout: NCHW
shape: (1, 3, 416, 416)
3
tensor type: float32
data type: float32
layout: NHWC
shape: (1, 13, 13, 255)
data type: float32
layout: NHWC
shape: (1, 26, 26, 255)
data type: float32
layout: NHWC
shape: (1, 52, 52, 255)
<class ‘tuple’>
3
(1, 52, 52, 255)
detected item num: 16
person is in the picture with confidence:0.9898
person is in the picture with confidence:0.9867
person is in the picture with confidence:0.9297
person is in the picture with confidence:0.9114
person is in the picture with confidence:0.8958
person is in the picture with confidence:0.8801
person is in the picture with confidence:0.8213
person is in the picture with confidence:0.7038
person is in the picture with confidence:0.5001
person is in the picture with confidence:0.4798
kite is in the picture with confidence:0.9792
kite is in the picture with confidence:0.7745
kite is in the picture with confidence:0.6520
kite is in the picture with confidence:0.5453
kite is in the picture with confidence:0.5256
kite is in the picture with confidence:0.4490
[array([109.97397964, 609.3799464 , 165.59845765, 768.23997301,
0.98983681, 0. ]), array([212.993 , 697.4619933 , 273.82313922, 849.52617116,
0.98665556, 0. ]), array([ 78.63372576, 507.68010446, 108.26859891, 568.40274138,
0.92970676, 0. ]), array([176.88269225, 540.27909615, 197.19433603, 573.25273544,
0.91135648, 0. ]), array([345.48917175, 486.14568209, 357.63510727, 505.59590181,
0.89577639, 0. ]), array([520.85178416, 504.50164454, 535.68336446, 527.79051608,
0.88014819, 0. ]), array([ 26.21890852, 524.41786036, 45.83317021, 556.99691989,
0.82129945, 0. ]), array([541.99734285, 515.08086873, 556.98230192, 534.88092561,
0.70380589, 0. ]), array([5.24318668e+02, 5.17251076e+02, 5.42762714e+02, 5.30034187e+02,
5.00111708e-01, 0.00000000e+00]), array([3.02657943e+01, 5.14510368e+02, 5.16450562e+01, 5.50474636e+02,
4.79826691e-01, 0.00000000e+00]), array([593.15143204, 79.84221712, 674.67715836, 150.61631756,
0.97919091, 33. ]), array([279.39018098, 234.82780816, 307.23055419, 281.00842336,
0.77447677, 33. ]), array([306.41312492, 374.88221513, 325.55392754, 405.03702039,
0.65199802, 33. ]), array([5.79715805e+02, 3.45468275e+02, 5.98832008e+02, 3.66825490e+02,
5.45296997e-01, 3.30000000e+01]), array([1.08276234e+03, 3.93677806e+02, 1.10494449e+03, 4.24567473e+02,
5.25616331e-01, 3.30000000e+01]), array([4.68791874e+02, 3.37578726e+02, 4.86844799e+02, 3.60711761e+02,
4.48973435e-01, 3.30000000e+01])]
【INFO】: Offload model “yolov3_darknet53_416x416_nv12” Successfully.
修改后报错信息
[C][5349][03-04][16:43:16:619][configuration.cpp:51][EasyDNN]EasyDNN version: 0.1.1
data type: uint8
layout: NCHW
2
data type: float32
layout: NHWC
shape: (1, 13, 13, 18)
data type: float32
layout: NHWC
shape: (1, 26, 26, 18)
<class ‘tuple’>
2
File “test_yolov3.py”, line 55, in
prediction_bbox = postprocess(outputs, model_hw_shape=(416, 416), origin_image=img_file)
File “/app/ai_inference/06_yolov3_sample/postprocess.py”, line 37, in postprocess
print(model_output[2].properties.shape)
IndexError: tuple index out of range
【INFO】: Offload model “ppyolo_trashdet_416x416_nv12” Successfully.
双横杠里面为我自己查看信息的代码输出的内容
config文件夹的百度链接
链接:百度网盘-链接不存在
提取码:1234
这个config里面有ppyolo_trashdet_416x416_nv12.bin文件
