旭日x3派无法启动操作系统求助
  1. 系统软件版本:x3pi_ubuntu_desktop_disk_20230225032350
  2. 问题涉及的技术领域: 操作系统
  3. 问题描述:系统无法正常启动,已烧录系统到tf卡,并已多次重复烧录后仍然无法重启(64g tf卡),已尝试通过升级工具1.3升级到最新的固件(disk_nand_minimum_boot_4GB_20220913141512.img)
  4. 复现概率:必现
  5. 提供必要的问题日志:
U-Boot 2018.09-gafbe43f7 (Sep 01 2022 - 16:21:36 +0800)
Model: Hobot XJ3 Soc Board
DRAM: system DDR size: 0xffe00000
4 GiB
MMC: dwmmc@A5010000: 0, dwmmc@A5011000: 1, dwmmc@A5012000: 2 (SD)
Loading Environment from UBI… GigaDevice SPI NAND was found.
In: serial@a5000000
Out: serial@a5000000
Err: serial@a5000000
Net: x3 sdb reset eth phy done
Warning: ethernet@A5014000 (eth0) using random MAC address - e2:10:8e:30:be:a6
eth0: ethernet@A5014000
Disable cnn cores ..
dtb_name:hobot-x3-pi.dtb
base board type: X3 SDB
bootmode: NAND
board_id = 31540334
enable watchdog success !
switch to partitions #0, OK
mmc2 is current device
Scanning mmc 2:1…
Found U-Boot script /boot/boot.scr
674 bytes read in 1 ms (658.2 KiB/s)
## Executing script at 03c10000
Boot script loaded from devtype:mmc devnum:2 devplist:1
bootargs = console=ttyS0,921600 raid=noautodetect hobotboot.reson=POWER_RESET rootfstype=ext4 rw rootwait ubi.mtd=2,2048 mtdparts=hr_nand.0:6291456@0x0(miniboot),2097152@0x600000(env),26214400@0x800000(boot),57671680@0x2000000(system),-@0x5700000(userdata) root=/dev/mmcblk2p1
Loading fdt file: /boot/hobot/hobot-x3-pi.dtb
69633 bytes read in 6 ms (11.1 MiB/s)
Loading kernel: /boot/vmlinuz-4.14.87
19163144 bytes read in 844 ms (21.7 MiB/s)
## Flattened Device Tree blob at 03c00000
Booting using the fdt blob at 0x3c00000
Loading Device Tree to 0000000003c00000, end 0000000003c1ffff … OK
chip_id: ab36300
The address of the fdt is 0x3c00000
Changed status Done
Can’t get fdt_addr !!!Orign(MAX) bpu model Reserve Mem Size to 64M!!
Starting kernel …
[ 0.000000] OF: reserved mem: OVERLAP DETECTED!
[ 0.000000] image_r5_mem (0x0000000080000000–0x0000000080010000) overlaps with msg_r5_mem (0x000000008000f000–0x0000000080010000)
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000004000000, size 672 MiB
[ 0.000000] OF: reserved mem: initialized node ion_cma, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[ 0.000000] On node 0 totalpages: 1047808
[ 0.000000] DMA zone: 8180 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523520 pages, LIFO batch:31
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc17ff2a000 s65176 r8192 d29032 u102400
[ 0.000000] pcpu-alloc: s65176 r8192 d29032 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1031436
[ 0.000000] Kernel command line: earlycon loglevel=8 kgdboc=ttyS0 video=hobot:x3sdb-hdmi console=ttyS0,921600 raid=noautodetect hobotboot.reson=POWER_RESET rootfstype=ext4 rw rootwait ubi.mtd=2,2048 “mtdparts=hr_nand.0:6291456@0x0(miniboot),2097152@0x600000(env),26214400@0x800000(boot),57671680@0x2000000(system),-@0x5700000(userdata)” root=/dev/mmcblk2p1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB [mem 0x7afff000-0x7efff000] (64MB) mapped at [ffffffc07afff000-ffffffc07effefff]
[ 0.000000] Memory: 3319580K/4191232K available (10494K kernel code, 1306K rwdata, 5756K rodata, 1088K init, 9553K bss, 167140K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008000000 - 0xffffff8008a40000 ( 10496 KB)
[ 0.000000] .rodata : 0xffffff8008a40000 - 0xffffff8008ff0000 ( 5824 KB)
[ 0.000000] .init : 0xffffff8008ff0000 - 0xffffff8009100000 ( 1088 KB)
[ 0.000000] .data : 0xffffff8009100000 - 0xffffff8009246808 ( 1307 KB)
[ 0.000000] .bss : 0xffffff8009246808 - 0xffffff8009b9aed8 ( 9554 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00008000 - 0xffffffbf06000000 ( 95 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc180000000 ( 6142 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 36277 entries in 142 pages
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] parent_rate: 0, dclk->rate:2666000000, pre_ddr_rate:0, res.a0:139716584
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001195] clocksource: hobot_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
[ 0.002969] Console: colour dummy device 80x25
[ 0.003539] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.004845] pid_max: default: 32768 minimum: 301
[ 0.005499] Security Framework initialized
[ 0.006017] AppArmor: AppArmor disabled by boot time parameter
[ 0.006861] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.007730] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023772] ASID allocator initialised with 65536 entries
[ 0.031770] Hierarchical SRCU implementation.
[ 0.063829] smp: Bringing up secondary CPUs …
[ 0.100038] Detected VIPT I-cache on CPU1
[ 0.100072] CPU1: Booted secondary processor [410fd034]
[ 0.136087] Detected VIPT I-cache on CPU2
[ 0.136108] CPU2: Booted secondary processor [410fd034]
[ 0.172148] Detected VIPT I-cache on CPU3
[ 0.172167] CPU3: Booted secondary processor [410fd034]
[ 0.172220] smp: Brought up 1 node, 4 CPUs
[ 0.176283] SMP: Total of 4 processors activated.
[ 0.176878] CPU features: detected feature: 32-bit EL0 Support
[ 0.177698] CPU: All CPU(s) started at EL1
[ 0.178225] alternatives: patching kernel code
[ 0.179817] devtmpfs: initialized
[ 0.188984] random: get_random_u32 called from bucket_table_alloc+0x108/0x270 with crng_init=0
[ 0.190624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.191869] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.208477] xor: automatically using best checksumming function 32regs
[ 0.209398] pinctrl core: initialized pinctrl subsystem
[ 0.210634] NET: Registered protocol family 16
[ 0.212077] vdso: 2 pages (1 code @ ffffff8008a46000, 1 data @ ffffff8009104000)
[ 0.213023] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.214616] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.217527] pstore: using zlib compression
[ 0.218353] console [pstore-1] enabled
[ 0.218949] pstore: Registered ramoops as persistent store backend
[ 0.219734] ramoops: attached 0x40000@0x3fc0000, ecc: 0/0
[ 0.224725] hobot_dma a1005000.dma: Hobot DMA Engine Driver Probed!!
[ 0.238597] SCSI subsystem initialized
[ 0.239217] media: Linux media interface: v0.10
[ 0.239810] Linux video capture interface: v2.00
[ 0.240469] pps_core: LinuxPPS API ver. 1 registered
[ 0.241097] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.242271] PTP clock support registered
[ 0.243402] ion_dummy: not reserve carveout memory, try to alloc from cma
NOTICE: fast_boot:0
S
F
L
O
NOTICE: efuse cpu_cfg = 0
W
NOTICE: Waiting connect …
NOTICE: boot src: 2
NOTICE: GigaDev SPI NAND was found.
NOTICE: Block size: 128 KiB, page size: 2048
NOTICE: BL1: Booting BL2
Auth pass
NOTICE: bl1_main exit
SPL cold boot flow
check_reset_state (0): wakeup address = 0x0, hw wakeup status = 0x0, wakeup src=0x100
SFLOW_INIT
CHIP ID:PCC835/WAFER: W17/ X: X34/ Y: Y20
SFLOW_FIN_HW_A
U-Boot SPL 2018.09-g685ea0924d (Jul 07 2022 - 16:15:50 +0800)
SPACC Init - ID: (00000061)
SPL nand boot mode (from strap)
ddr_type = 1 (LPDDR4)
hb_chip_package_type:3
load ddr header src_addr: 100000, load_addr: 802ca020, src_len: a00
find valid ddr image
ddr_hdr.ecc_gran: 0x0
ddr_hdr.ecc_map: 0x0
ddr_hdr.sbr_pattern0: 0x0
ddr_hdr.sbr_pattern1: 0x0
ddr_freq = 05
board id = 31540334
ddr datarate: 3200
### SAMSUNG DDR ###
no ddr pin set
detect part number: 108
detect ddr freq: c80
board id alternative:0x3
index is 12
index is 15
index is 19
hb_ddr_index: 19
dram_pll_init
sscg disabled
control load ddrc src_addr: 15a800, load_addr: 802caa20, src_len: 920
[DDR INFO] VERSION: develop
[DDR INFO] BUILD: 2022-07-07-16:15
[DDR INFO] GIT COMMIT: 685ea0924d581ca988bce42c579b18c25bd53c4c
[DDR INFO] GIT TIME: Thu, 7 Jul 2022 16:14:13 +0800
[DDR INFO] ==ddr_features==
[DDR INFO] RDBI: 0
[DDR INFO] WDBI: 1
[DDR INFO] InlineECC: 0
[DDR INFO] DM: 1
[DDR INFO] DDC: 1
[DDR INFO] SSCG: 0
[DDR INFO] BOARD: XS_ENABLE
load ddr phy src_addr: 15b200, load_addr: 802caa20, src_len: 420
ATxSlewRate : 15f
ATxImpedance : 7f
TxSlewRate : 19f
TxOdtDrvStren : 600
TxImpedanceCtrl : e3f
CalDrvStr0 : 11
VrefInGlobal : 104
load dqmap src addr: 15d000, load_addr: 802caa20, src_len: 20
magic = 544f4248
load imem1 src_addr: 11ce00, load_addr: 802caa20, src_len: 8000
load dmem1 src_addr: 159a00, load_addr: 802caa20, src_len: 684
executing 1D fw
load imem2 src_addr: 124e00, load_addr: 802caa20, src_len: 8000
load dmem2 src_addr: 15a200, load_addr: 802caa20, src_len: 564
p_dmem_lpddr4_2d_16b->MR11_A0:54
p_dmem_lpddr4_2d_16b->MR14_A0:54
p_dmem_lpddr4_2d_16b->MR12_A0:51
p_dmem_lpddr4_2d_16b->MR22_A0:14
p_dmem_lpddr4_2d_16b->MR3_A0:b3
p_dmem_lpddr4_2d_16b->Reserved00:40
p_dmem_lpddr4_2d_16b->Reserved0E:4
p_dmem_lpddr4_2d_16b->Delay_Weight2D:20
p_dmem_lpddr4_2d_16b->Voltage_Weight2D:80
executing 2D fw
load pie src_addr: 15b800, load_addr: 802caa20, src_len: 11f0
Set QoS.
get_ddr_mr_info:cs_num=1, mr5=0x1, mr8=0x10
no magic in efuse file,bypass efuse
total_sz = 4096
SPL_VERSION:7
uboot partition is uboot_A
load u-boot: src_addr=0x380000, dest_addr=0x4000000, len=2097152
load warm boot spl: addr=0x800, dest_addr=0x80000000, len=31232
load bl31: addr=0x300000, dest_addr=0x0, len=524288
SFLOW_AUTH_BL31
bypass bpu image
clear keybank!!!
SFLOW_DBG_EN
Trying to boot from RAM
SFLOW_CLR_KEY
SFLOW_REG_LD
install_portal copy portal
hb som type: 5
X3 PI reset VDD_SD done
软件上是否有做自定义修改:未作修改
log3_20230405232548.txt
换个好一点的充电器试试 最好10W以上
感谢回复,已解决。用的5V2.1A的不行,用了手机的有5V3A的输出规格就可以正常启动了。
