【服务机器人】先从机械臂搞起吧 (二) 究极缝合怪
功能是识别并抓取一个橘子或者苹果-
缝合了前面机械臂运动学逆解与双目相机测距的代码
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import rospy, sys
import moveit_commander
import math
from moveit_commander import MoveGroupCommander
from geometry_msgs.msg import Pose
from copy import deepcopy
import os
from bputools.format_convert import imequalresize, bgr2nv12_opencv
import lib.pyyolotools as yolotools
import stereoconfig_040_2 #导入相机内参
# P = 6.7
pi = math.pi
A1 = 10.5
A2 = 10.5
A3 = 10.5
A4 = 17.5
MAX_LEN = A2+A3+A4
MAX_HIGH = A1+A2+A3+A4
euler_alter = [[1,0,0], [0,-0.8660254,-0.5 ], [0, 0.5,-0.8660254]]
def transform_xyz(x_o,y_o,z_o):
    m = [x_o,y_o,z_o]
    real = np.matmul(m, euler_alter)
    real[0] = format(real[0], '.2f')
    real[1] = format(real[1], '.2f')
    real[2] = format(real[2], '.2f')
    if real[0]<0:
        real_alter = [real[0]-4.7,real[1]+13.5,real[2]+ 29]
        real_alter = [real[0]-3.7,real[1]+13.5,real[2]+ 29]
    return real_alter
def cos(degree):
    return math.cos(math.radians(degree))
def sin(degree):
    return math.sin(math.radians(degree))
def atan2(v1,v2):
    rad=math.atan2(v1,v2)
    return math.degrees(rad)
def backward_kinematics(x, y, z,alpha):
    # len = math.sqrt(x*x + (P+y)*(P+y))
    j1 = math.atan2( x, y)
    x = abs(x)
    y = abs(y)
    len = math.sqrt(x*x + y*y)
    # print (len)
    high = z
    if len > MAX_LEN or high > MAX_HIGH:
        print ('超出范围')
        return 0,0,0,0
    L = len - A4*sin(alpha)
    H = high - A4*cos(alpha) - A1
    # print('L',L)
    # print('H',H)
    # print ((L*L + H*H - A2*A2 - A3*A3 )/(2 * A2 * A3))
    try:
        j3 = math.acos((L*L + H*H - A2*A2 - A3*A3 )/(2 * A2 * A3))
    except:
        return -pi,-pi,-pi,-pi
    K1 = A2 + A3*math.cos(j3)
    # print('K1',K1)
    K2 = A3*math.sin(j3)
    # print('K2',K2)
    W = math.atan2(K2, K1)
    # print('W',W)
    # print('math.atan(L/H)',math.atan(L/H))
    j2 = math.atan2(L,H) - W
    # print (math.radians(alpha))
    j4 = math.radians(alpha) - j2 - j3
    return j1,j2,j3,j4
def test_ok(x,y,z):
    for alpha in range(1,90):
        alpha_alter = 180 - alpha
        deg1, deg2, deg3, deg4 = backward_kinematics(x, y, z, alpha_alter)
        if (deg1 < (0-pi/2)) or (deg1 > pi/2) or (deg2 < 0) or (deg2 > pi/2) or (deg3 < 0) or (deg3 > pi/2) or (deg4 < (0 - pi/4)) or (deg4 > pi/2):
            # print (deg1, deg2, deg3, deg4)
            alpha = alpha + 1
            print (alpha_alter)
            print ([deg1, -deg2, -deg3, -deg4,0])
            return [deg1, 0, 0, 0, 0], [deg1, -deg2, -deg3, -deg4, 0]
# 识别测距包
def get_hw(pro):
    if pro.layout == "NCHW":
        return pro.shape[2], pro.shape[3]
        return pro.shape[1], pro.shape[2]
def format_yolov5(frame):
    row, col, _ = frame.shape
    _max = max(col, row)
    result = np.zeros((_max, _max, 3), np.uint8)
    result[0:row, 0:col] = frame
    return result
def undistortion(image, camera_matrix, dist_coeff):
    undistortion_image = cv2.undistort(image, camera_matrix, dist_coeff)
    return undistortion_image
def getRectifyTransform(height, width, config):
    # 读取内参和外参
    left_K = config.cam_matrix_left
    right_K = config.cam_matrix_right
    left_distortion = config.distortion_l
    right_distortion = config.distortion_r
    R = config.R
    T = config.T
    # 计算校正变换
    R1, R2, P1, P2, Q, roi1, roi2 = cv2.stereoRectify(left_K, left_distortion, right_K, right_distortion,
                                                    (width, height), R, T, alpha=0)
    map1x, map1y = cv2.initUndistortRectifyMap(left_K, left_distortion, R1, P1, (width, height), cv2.CV_32FC1)
    map2x, map2y = cv2.initUndistortRectifyMap(right_K, right_distortion, R2, P2, (width, height), cv2.CV_32FC1)
    return map1x, map1y, map2x, map2y, Q
# 畸变校正和立体校正
def rectifyImage(image1, image2, map1x, map1y, map2x, map2y):
    rectifyed_img1 = cv2.remap(image1, map1x, map1y, cv2.INTER_AREA)
    rectifyed_img2 = cv2.remap(image2, map2x, map2y, cv2.INTER_AREA)
    return rectifyed_img1, rectifyed_img2
# 立体校正检验----画线
def draw_line(image1, image2):
    # 建立输出图像
    height = max(image1.shape[0], image2.shape[0])
    width = image1.shape[1] + image2.shape[1]
    output = np.zeros((height, width, 3), dtype=np.uint8)
    output[0:image1.shape[0], 0:image1.shape[1]] = image1
    output[0:image2.shape[0], image1.shape[1]:] = image2
    # 绘制等间距平行线
    line_interval = 50  # 直线间隔:50
    for k in range(height // line_interval):
        cv2.line(output, (0, line_interval * (k + 1)), (2 * width, line_interval * (k + 1)), (0, 255, 0), thickness=2, lineType=cv2.LINE_AA)
    return output
# 视差计算
def stereoMatchSGBM(left_image, right_image, down_scale=False):
    # SGBM匹配参数设置
    if left_image.ndim == 2:
        img_channels = 1
        img_channels = 3
    blockSize = 3
    paraml = {'minDisparity': 0,
             'numDisparities': 128,
             'blockSize': blockSize,
             'P1': 8 * img_channels * blockSize ** 2,
             'P2': 32 * img_channels * blockSize ** 2,
             'disp12MaxDiff': 1,
             'preFilterCap': 63,
             'uniquenessRatio': 15,
             'speckleWindowSize': 100,
             'speckleRange': 1,
             'mode': cv2.STEREO_SGBM_MODE_SGBM_3WAY
    # 构建SGBM对象
    left_matcher = cv2.StereoSGBM_create(**paraml)
    paramr = paraml
    paramr['minDisparity'] = -paraml['numDisparities']
    right_matcher = cv2.StereoSGBM_create(**paramr)
    # 计算视差图
    size = (left_image.shape[1], left_image.shape[0])
    if down_scale == False:
        disparity_left = left_matcher.compute(left_image, right_image)
        disparity_right = right_matcher.compute(right_image, left_image)
        left_image_down = cv2.pyrDown(left_image)
        right_image_down = cv2.pyrDown(right_image)
        factor = left_image.shape[1] / left_image_down.shape[1]
        disparity_left_half = left_matcher.compute(left_image_down, right_image_down)
        disparity_right_half = right_matcher.compute(right_image_down, left_image_down)
        disparity_left = cv2.resize(disparity_left_half, size, interpolation=cv2.INTER_AREA)
        disparity_right = cv2.resize(disparity_right_half, size, interpolation=cv2.INTER_AREA)
        disparity_left = factor * disparity_left
        disparity_right = factor * disparity_right
    # 真实视差(因为SGBM算法得到的视差是×16的)
    trueDisp_left = disparity_left.astype(np.float32) / 16.
    trueDisp_right = disparity_right.astype(np.float32) / 16.
    return trueDisp_left, trueDisp_right
    # 拍照识别函数
def photograph_and_det():
    model_path = '/home/sunrise/codes/test_yolov5/yolov5s.bin'
    classes_name_path = '/home/sunrise/codes/test_yolov5/coco_classes.names'
    thre_confidence = 0.4
    thre_score = 0.25
    thre_nms = 0.45
    colors = [(255, 255, 0), (0, 255, 0), (0, 255, 255), (255, 0, 0)]
    models = dnn.load(model_path)
    model_h, model_w = get_hw(models[0].inputs[0].properties)
    print(model_h, model_w)
    camera = cv2.VideoCapture(10)
    print(camera.isOpened())
    camera.set(cv2.CAP_PROP_FRAME_WIDTH,2560)
    camera.set(cv2.CAP_PROP_FRAME_HEIGHT,720)
    ret, imgOri = camera.read()
    inputImage = format_yolov5(imgOri[0:720, 0:1280])
    img = imequalresize(inputImage, (model_w, model_h))
    nv12 = bgr2nv12_opencv(img)
    # 3 模型推理
    t1 = cv2.getTickCount()
    outputs = models[0].forward(nv12)
    t2 = cv2.getTickCount()
    outputs = outputs[0].buffer # 25200x85x1
    print('time consumption {0} ms'.format((t2-t1)*1000/cv2.getTickFrequency()))
    # 4 后处理
    image_width, image_height, _ = inputImage.shape
    fx, fy = image_width / model_w, image_height / model_h
    class_ids, confidences, boxes = yolotools.pypostprocess_yolov5(outputs[0][:, :, 0], fx, fy,
        thre_confidence, thre_score, thre_nms)
    print('post consumption {0} ms'.format((t2-t1)*1000/cv2.getTickFrequency()))
    #xmd  vvvvvvvvvv
    i = 3
    string = 're'
    image_left = imgOri[0:720, 0:1280] #左图
    image_right = imgOri[0:720, 1280:2560]  #右图
    height, width = image_left.shape[0:2]
    print("width = %d \n"  % width)
    print("height = %d \n" % height)
    #读取相机内参
    config = stereoconfig_040_2.stereoCamera()
    #立体校正
    map1x, map1y, map2x, map2y, Q = getRectifyTransform(height, width, config)  # 获取用于畸变校正和立体校正的映射矩阵以及用于计算像素空间坐标的重投影矩阵
    # print('Q',Q)
    iml_rectified, imr_rectified = rectifyImage(image_left, image_right, map1x, map1y, map2x, map2y)
    line = draw_line(iml_rectified, imr_rectified)
    # print('./%s检验%d.png' %(string,i), line)
    cv2.imwrite('./%s检验%d.png' %(string,i), line)
    iml = undistortion(image_left, config.cam_matrix_left, config.distortion_l)
    imr = undistortion(image_right, config.cam_matrix_right, config.distortion_r)
    iml_rectified_l, imr_rectified_r = rectifyImage(iml, imr, map1x, map1y, map2x, map2y)
    disp, _ = stereoMatchSGBM(iml_rectified_l, imr_rectified_r, True)
    # print('./%s视差%d.png' %(string,i), disp)
    cv2.imwrite('./%s视差%d.png' %(string,i), disp)
    # 计算像素点的3D坐标(左相机坐标系下)
    points_3d = cv2.reprojectImageTo3D(disp, Q)  # 可以使用上文的stereo_config.py给出的参数
    #xmd  ^^^^^^^^^^
    # 5 绘制检测框
    with open(classes_name_path, "r") as f:
        class_list = [cname.strip() for cname in f.readlines()]
    list = []
    for (classid, confidence, box) in zip(class_ids, confidences, boxes):
        color = colors[int(classid) % len(colors)]
        cv2.rectangle(imgOri, box, color, 2)
        # cv2.rectangle(img, (xmin, ymin), (xmax, ymax), (0,0,255), 2)
        # xmin = box[0],ymin = box[1] - 20
        cv2.rectangle(imgOri, (box[0], box[1] - 20), (box[0] + box[2], box[1]), color, -1)
        cv2.putText(imgOri, class_list[classid], (box[0], box[1] - 10), cv2.FONT_HERSHEY_SIMPLEX, .5, (0,0,0))
        print("box[0]",box[0],"box[1]",box[1],"box[2]",box[2],"class_list[classid]",class_list[classid])
        x = int((box[0]+box[2]+box[0])/2)
        y = int((box[1]+box[3]+box[1])/2)
        print('点 (%d, %d) 的三维坐标 (%f, %f, %f)' % (x, y, points_3d[y, x, 0]/10, points_3d[y, x, 1]/10, points_3d[y, x, 2]/10))
        dis = ( (points_3d[y, x, 0] ** 2 + points_3d[y, x, 1] ** 2 + points_3d[y, x, 2] **2) ** 0.5) / 1000
        print('点 (%d, %d) 距离左摄像头的相对距离为 %0.3f m' %(x, y, dis) )
        if dis <= 0.4:
            print(classid+1)
            print(round(points_3d[y, x, 0]/10,2))
            print(round(points_3d[y, x, 1]/10,2))
            print(round(points_3d[y, x, 2]/10,2))
            list.append([classid+1,round(points_3d[y, x, 0]/10,2),round(points_3d[y, x, 1]/10,2),round(points_3d[y, x, 2]/10,2),round(dis,2)])
    print('draw rect consumption {0} ms'.format((t2-t1)*1000/cv2.getTickFrequency()))
    cv2.imwrite('res.png', imgOri)
    return list
# 机械臂类
class MoveItFkDemo:
    def __init__(self):
        # 初始化move_group的API,出现roscpp是因为底层是通过C++进行实现的
        moveit_commander.roscpp_initialize(sys.argv)
        # 初始化ROS节点,节点名为'moveit_fk_demo'
        rospy.init_node('moveit_fk_demo', anonymous=True)
        # 初始化需要使用move group控制的机械臂中的arm group
        arm = moveit_commander.MoveGroupCommander('arm')
        hand = moveit_commander.MoveGroupCommander('hand')
        # 设置机械臂运动的允许误差值,单位弧度
        arm.set_goal_joint_tolerance(0.01)
        # 设置允许的最大速度和加速度,范围0~1
        arm.set_max_acceleration_scaling_factor(0.5)
        arm.set_max_velocity_scaling_factor(0.5)
        # 控制机械臂先回到初始化位置,home是setup assistant中设置的
        arm.set_named_target('arm_home')
        arm.go()  #让机械臂先规划,再运动,阻塞指令,直到机械臂到达home后再向下执行
        arm.set_named_target('arm_look')
        arm.go()
        get_flag = 0
        while get_flag == 0:
            arm_post_list = photograph_and_det()
            for i in range(len(arm_post_list)):
                class_ID = arm_post_list[i][0]
                if( class_ID == 48) or (class_ID == 50 ): #48-apple  50-orange
                    get_flag =1
                    x_origin = arm_post_list[i][1]
                    y_origin = arm_post_list[i][2]
                    z_origin = arm_post_list[i][3]
                    print(x_origin,y_origin,z_origin)
                    x, y, z = transform_xyz(x_origin,y_origin,z_origin)
                    print(x,y,z)
                    joint_positions1, joint_positions2 = test_ok(x,y,z)
                    hand.set_named_target('hand_open')
                    hand.go()
                    arm.set_joint_value_target(joint_positions1)  #设置关节值作为目标值
                    arm.go()
                    arm.set_joint_value_target(joint_positions2)
                    arm.go()   # 规划+执行
                    rospy.sleep(1)
                    hand.set_named_target('hand_close')
                    hand.go()
                    arm.go()
        # 关闭并退出moveit
        moveit_commander.roscpp_shutdown()
        moveit_commander.os._exit(0)
if __name__ == "__main__":
    try:
        MoveItFkDemo()
    except rospy.ROSInterruptException:
        pass
先点个赞
