我使用X3派开发板,系统是2.0的系统,然后程序长时间运行或高温运行大半个小时,就会出现系统崩溃重启,错误如下:
[ERROR][“vio_devop”][utils/dev_ioctl.c:121] [10943.089245]dev_node_dqbuf_ispoll[121]: failed to ioctl: dq (14 - Bad address)
[ERROR][“vio_devop”][utils/dev_ioctl.c:189] [10943.089325]entity_node_dqbuf_ispoll[189]: dev type(9) dq failed
[ERROR][“vio_core”][commom_grp/binding_main.c:1032] [10943.089342]comm_dq_no_data[1032]: G0 MIPI_SIF_MODULE module chn0 dq failed! maybe framedrop error_detail -14
[ERROR][“vio_devop”][utils/dev_ioctl.c:121] [10943.181571]dev_node_dqbuf_ispoll[121]: failed to ioctl: dq (14 - Bad address)
[ERROR][“vio_devop”][utils/dev_ioctl.c:189] [10943.181628]entity_node_dqbuf_ispoll[189]: dev type(9) dq failed
[ERROR][“vio_core”][commom_grp/binding_main.c:1032] [10943.181649]comm_dq_no_data[1032]: G0 MIPI_SIF_MODULE module chn0 dq failed! maybe framedrop error_detail -14
[ERROR][“vio_devop”][utils/dev_ioctl.c:121] [10943.246616]dev_node_dqbuf_ispoll[121]: failed to ioctl: dq (14 - Bad address)
[ERROR][“vio_devop”][utils/dev_ioctl.c:189] [10943.246668]entity_node_dqbuf_ispoll[189]: dev type(9) dq failed
[ERROR][“vio_core”][commom_grp/binding_main.c:1032] [10943.246689]comm_dq_no_data[1032]: G0 MIPI_SIF_MODULE module chn0 dq failed! maybe framedrop error_detail -14
[ERROR][“vio_devop”][utils/dev_ioctl.c:121] [224.636069]dev_node_dqbuf_ispoll[121]: failed to ioctl: dq (14 - Bad address)
[ERROR][“vio_devop”][utils/dev_ioctl.c:189] [224.636192]entity_node_dqbuf_ispoll[189]: dev type(9) dq failed
[ERROR][“vio_core”][commom_grp/binding_main.c:1032] [224.636208]comm_dq_no_data[1032]: G0 MIPI_SIF_MODULE module chn0 dq failed! maybe framedrop error_detail -14
[ERROR][“vio_devop”][utils/dev_ioctl.c:121] [10943.338906]dev_node_dqbuf_ispoll[121]: failed to ioctl: dq (14 - Bad address)
[ERROR][“vio_devop”][utils/dev_ioctl.c:189] [10943.338962]entity_node_dqbuf_ispoll[189]: dev type(9) dq failed
[ERROR][“vio_core”][commom_grp/binding_main.c:1032] [10943.338988]comm_dq_no_data[1032]: G0 MIPI_SIF_MODULE module chn0 dq failed! maybe framedrop error_detail -14
[ERROR][“vio_devop”][utils/dev_ioctl.c:121] [10943.403950]dev_node_dqbuf_ispoll[121]: failed to ioctl: dq (14 - Bad address)
[ERROR][“vio_devop”][utils/dev_ioctl.c:189] [10943.404018]entity_node_dqbuf_ispoll[189]: dev type(9) dq failed
一直都是这种错误,不知道能否帮助解决,非常感谢!,附件是完整的错误日志。
系统软件版本: (通过 cat /etc/version 获得)
问题涉及的技术领域: (硬件、操作系统、驱动、其他)
硬件问题先排查供电和时钟
驱动问题先排查外设的供电、复位和时钟
功能异常,先排查一下是不是运行的代码和demo存在差异,修改不多的情况下直接用对比软件先对比
提供必要的问题日志:
软件上是否有做自定义修改:
