工具连软件安装报错:
1: 下载文件 wget -c ftp://xj3ftp@vrftp.horizon.ai/ai\_toolchain/ai\_toolchain.tar.gz --ftp-password=xj3ftp@123$%
wget -c ftp://xj3ftp@vrftp.horizon.ai/model\_convert\_sample/yolov5s\_v2.0.tar.gz --ftp-password=xj3ftp@123$%
2: 解压
3: 创建并激活
4: 安装 工具连软件
pip install ai_toolchain/h* -i https://mirrors.aliyun.com/pypi/simple
报错如下:
Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 (from requests==2.22.0->horizon-tc-ui==1.17.4)
Using cached https://mirrors.aliyun.com/pypi/packages/56/aa/4ef5aa67a9a62505db124a5cb5262332d1d4153462eb8fd89c9fa41e5d92/urllib3-1.25.11-py2.py3-none-any.whl (127 kB)
Collecting certifi>=2017.4.17 (from requests==2.22.0->horizon-tc-ui==1.17.4)
Using cached https://mirrors.aliyun.com/pypi/packages/4c/dd/2234eab22353ffc7d94e8d13177aaa050113286e93e7b40eae01fbf7c3d9/certifi-2023.7.22-py3-none-any.whl (158 kB)
Collecting contextlib2>=0.5.5 (from schema==0.7.2->horizon-tc-ui==1.17.4)
Using cached https://mirrors.aliyun.com/pypi/packages/76/56/6d6872f79d14c0cb02f1646cbb4592eef935857c0951a105874b7b62a0c3/contextlib2-21.6.0-py2.py3-none-any.whl (13 kB)
Requirement already satisfied: fonttools>=4.22.0 in /home/zmc/miniconda3/envs/horizon_bpu/lib/python3.8/site-packages (from matplotlib<=3.5.2->horizon-nn==0.18.2) (4.42.0)
Requirement already satisfied: packaging>=20.0 in /home/zmc/miniconda3/envs/horizon_bpu/lib/python3.8/site-packages (from matplotlib<=3.5.2->horizon-nn==0.18.2) (23.1)
Requirement already satisfied: pycparser in /home/zmc/miniconda3/envs/horizon_bpu/lib/python3.8/site-packages (from cffi>=1.12->cryptography==3.4.8->horizon-tc-ui==1.17.4) (2.21)
Building wheels for collected packages: pycocotools
Building wheel for pycocotools (setup.py) … error
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [43 lines of output]
/tmp/pip-install-fp48g10f/pycocotools_90fef4fece9947788d47dbfebcae73ed/setup.py:12: _DeprecatedInstaller: setuptools.installer and fetch_build_eggs are deprecated.
Requirements should be satisfied by a PEP 517 installer.
If you are using pip, you can try `pip install --use-pep517`.
dist.Distribution().fetch_build_eggs(setup_requires)
/home/zmc/miniconda3/envs/horizon_bpu/lib/python3.8/site-packages/setuptools/__init__.py:84: _DeprecatedInstaller: setuptools.installer and fetch_build_eggs are deprecated.
dist.fetch_build_eggs(dist.setup_requires)
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-cpython-38
creating build/lib.linux-x86_64-cpython-38/pycocotools
copying pycocotools/__init__.py → build/lib.linux-x86_64-cpython-38/pycocotools
copying pycocotools/cocoeval.py → build/lib.linux-x86_64-cpython-38/pycocotools
copying pycocotools/mask.py → build/lib.linux-x86_64-cpython-38/pycocotools
copying pycocotools/coco.py → build/lib.linux-x86_64-cpython-38/pycocotools
running build_ext
Compiling pycocotools/_mask.pyx because it changed.
[1/1] Cythonizing pycocotools/_mask.pyx
/home/zmc/miniconda3/envs/horizon_bpu/lib/python3.8/site-packages/Cython/Compiler/Main.py:381: FutureWarning: Cython directive ‘language_level’ not set, using ‘3str’ for now (Py3). This has changed from earlier releases! File: /tmp/pip-install-fp48g10f/pycocotools_90fef4fece9947788d47dbfebcae73ed/pycocotools/_mask.pyx
tree = Parsing.p_module(s, pxd, full_module_name)
building ‘pycocotools._mask’ extension
creating build/common
creating build/temp.linux-x86_64-cpython-38
creating build/temp.linux-x86_64-cpython-38/common
creating build/temp.linux-x86_64-cpython-38/pycocotools
gcc -pthread -B /home/zmc/miniconda3/envs/horizon_bpu/compiler_compat -Wl,–sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -I/home/zmc/miniconda3/envs/horizon_bpu/lib/python3.8/site-packages/numpy/core/include -I./common -I/home/zmc/miniconda3/envs/horizon_bpu/include/python3.8 -c ../common/maskApi.c -o build/temp.linux-x86_64-cpython-38/../common/maskApi.o -Wno-cpp -Wno-unused-function -std=c99
gcc: error: ../common/maskApi.c: No such file or directory
error: command ‘/usr/bin/gcc’ failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for pycocotools
Running setup.py clean for pycocotools
Failed to build pycocotools
