系统软件版本:2.0.0
问题涉及的技术领域: 驱动
问题描述:
你好! 我正在尝试运行官方的python demo来调用Encoder进行H265编码,但是当我运行后前30帧是没有报错的,30帧之后开始出现了如下报错。
我所使用的是这里的参考代码:https://developer.horizon.ai/api/v1/fileData/documents\_pi/Python\_Develop/python\_vio.html#encoder,我将其中的output.img 改为了本地的一张nv12格式文件。
我所运行的代码及完整log在附件中。
复现概率:必现
提供必要的问题日志:
encode write image success count: 27
Encoder encode_file return:0
encode write image success count: 28
encode write image success count: 29
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][6498.46839][6461:6466][VideoEncoder] Bitstream buffer is too small!
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][6498.46845][6461:6466][COMPONENT] Component wave_encoder will be terminated.
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][6498.46858][6461:6461][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“venc”][video/src/hb_venc.c:102] [6498.468615]MCErrC_2_HBVencErrC[102]: [HB_VENC] MCErrC_2_HBVencErrC:102 Not Support Venc Error Code(-268435438)!
[ERROR][“venc”][video/src/hb_venc.c:1192] [6498.468658]HB_VENC_ReleaseStream[1192]: [HB_VENC] HB_VENC_ReleaseStream:1192 Failed VeChn = 0 s32Ret = -268958728
2023/08/04 23:37:54.743 ERROR [x3_venc_put_frame][0692]HB_VENC_ReleaseStream error!!!
encode write image success count: 30
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][6498.47036][6461:6461][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“venc”][video/src/hb_venc.c:102] [6498.470445]MCErrC_2_HBVencErrC[102]: [HB_VENC] MCErrC_2_HBVencErrC:102 Not Support Venc Error Code(-268435438)!
[ERROR][“venc”][video/src/hb_venc.c:1253] [6498.470475]HB_VENC_SendFrame[1253]: [HB_VENC] HB_VENC_SendFrame:1253 Failed VeChn = 0 s32Ret = -268958728
2023/08/04 23:37:54.745 ERROR [x3_venc_file][0641]HB_VENC_SendFrame error!!!
hb_vp_deinit success
Encoder encode_file return:-1
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][6498.47132][6461:6461][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“venc”][video/src/hb_venc.c:102] [6498.471374]MCErrC_2_HBVencErrC[102]: [HB_VENC] MCErrC_2_HBVencErrC:102 Not Support Venc Error Code(-268435438)!
[ERROR][“venc”][video/src/hb_venc.c:982] [6498.471392]HB_VENC_GetStream[982]: [HB_VENC] HB_VENC_GetStream:982 Failed VeChn = 0 s32Ret = -268958728
2023/08/04 23:37:54.746 ERROR [x3_venc_get_frame][0668]HB_VENC_GetStream error!!!
encode write image failed count: 31
[ERROR][“multimedia”][src/vdi/linux/vdi_osal.c:174] [ERROR][6498.47498][6461:6461][TASK] It’s not allowd to do this operation. Please check the task state 6.
[ERROR][“venc”][video/src/hb_venc.c:102] [6498.475051]MCErrC_2_HBVencErrC[102]: [HB_VENC] MCErrC_2_HBVencErrC:102 Not Support Venc Error Code(-268435438)!
[ERROR][“venc”][video/src/hb_venc.c:1253] [6498.475073]HB_VENC_SendFrame[1253]: [HB_VENC] HB_VENC_SendFrame:1253 Failed VeChn = 0 s32Ret = -268958728
2023/08/04 23:37:54.750 ERROR [x3_venc_file][0641]HB_VENC_SendFrame error!!!
- 软件上是否有做自定义修改:无
