- 系统软件版本:RDK X3 Module V2.0.0
- 问题描述:开发板连接到 HDMI 时,桌面是能正常使用的。执行 /app/pydev_demo/08_decode_rtsp_stream/ 目录下的多媒体例程时,HDMI 上显示 “输入不支持”?请问是什么原因。
推理服务已经启动,通过工具是能查看到的。
旧版本的XJ3 SDB板子如何开启HDMI支持?
您好,按照示例4.3 图像多媒体示例 | RDK X3用户手册 (horizon.cc)运行是没有问题的,您看看是否按照该教程正确操作。另外请提供一下显示器分辨率以及帧率
显示器是 1920x1080 60
执行的打印信息
./live555MediaServer &
LIVE555 Media Server
version 1.01 (LIVE555 Streaming Media library version 2020.07.09).
Play streams from this server using the URL
rtsp://192.168.1.10/
where is a file present in the current directory.
Each file’s type is inferred from its name suffix:
“.264” => a H.264 Video Elementary Stream file
“.265” => a H.265 Video Elementary Stream file
“.aac” => an AAC Audio (ADTS format) file
“.ac3” => an AC-3 Audio file
“.amr” => an AMR Audio file
“.dv” => a DV Video file
“.m4e” => a MPEG-4 Video Elementary Stream file
“.mkv” => a Matroska audio+video+(optional)subtitles file
“.mp3” => a MPEG-1 or 2 Audio file
“.mpg” => a MPEG-1 or 2 Program Stream (audio+video) file
“.ogg” or “.ogv” or “.opus” => an Ogg audio and/or video file
“.ts” => a MPEG Transport Stream file
(a “.tsx” index file - if present - provides server ‘trick play’ support)
“.vob” => a VOB (MPEG-2 video with AC-3 audio) file
“.wav” => a WAV Audio file
“.webm” => a WebM audio(Vorbis)+video(VP8) file
See http://www.live555.com/mediaServer/ for additional documentation.
(We use port 80 for optional RTSP-over-HTTP tunneling, or for HTTP live streaming (for indexed Transport Stream files only).)
root@ubuntu:/app/pydev_demo/08_decode_rtsp_stream# ./decode_rtsp_stream.py
[‘rtsp://127.0.0.1/1080P_test.h264’]
RTSP stream frame_width:1920, frame_height:1080
Decoder(0, 1) return:0 frame count: 0
libiar: hb_disp_set_timing done!
Camera vps return:0
Decode CHAN: 0 FPS: 30.65
Display FPS: 31.03
Decode CHAN: 0 FPS: 25.00
Display FPS: 25.01
你好,SDB已经停止维护,社区上也不提供相关内容,仅对签订nda的商业用户开放,需要和采购的代理商要一下资料
您好,安装一下这两个包再尝试一下。链接:百度网盘-链接不存在
提取码:9sx2
安装了,不行
您给个邮箱,这边发一个新的镜像您刷一下
您好,邮件已发送,请注意查收
已收到,该镜像能够正常使用,谢谢。
两年前淘宝买的,可以刷RDK手册上的ubuntu镜像嘛,(LNX_PL2.2_WB_20221207 debug,Linux x3sdbx3-samsung2G-3200 4.14.87 #1 SMP PREEMPT Wed Dec 7 22:50:19 CST 2022 aarch64 GNU/Linux)
额,目前来看X3 SDB刷不了X3派的Ubuntu镜像,您找一下您的淘宝客服问问您HDMI相关的问题吧。
OK
