显示如下
无法进入系统
不知道什么原因
求助
go addr
## Starting application at 0x00000ADD …
“Synchronous Abort” handler, esr 0x8a000000
elr: 0000000000000add lr : 0000000004004e74 (reloc)
x0 : 0000000000000001 x1 : 0000000004fefc08
x2 : 0000000004fefc08 x3 : 0000000000000020
x4 : 00000000ffffffff x5 : 0000000004fdad18
x6 : 0000000000000044 x7 : 000000000000000f
x8 : 0000000004fdb398 x9 : 0000000000000004
x10: 00000000ffffffd0 x11: 0000000004fe4b30
x12: 0000000000000000 x13: 0000000000000004
x14: 00000000040c64c0 x15: 0000000000000001
x16: 0000000000000add x17: 0000000000000000
x18: 0000000004fdb670 x19: 0000000004fefc08
x20: 0000000000000add x21: 0000000000000002
x22: 0000000004fefc00 x23: 00000000040e2adc
x24: 0000000000000002 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000004fefc60 x29: 0000000004fdb3d0
Resetting CPU …
resetting …
NOTICE: fast_boot:0
S
F
L
O
NOTICE: efuse cpu_cfg = 0
W
NOTICE: boot src: 0
NOTICE: eMMC : 0xd6
NOTICE: BL1: Booting BL2
Auth pass
NOTICE: bl1_main exit
SPL normal reset flow
check_reset_state (2): wakeup address = 0x0, hw wakeup status = 0x3, wakeup src=0x100
SFLOW_INIT
CHIP ID:PCC839/WAFER: W13/ X: X39/ Y: Y31
SFLOW_FIN_HW_A
U-Boot SPL 2018.09-g5f69d1b69c (Mar 28 2022 - 20:37:01 +0800)
SPACC Init - ID: (00000061)
SPL emmc boot mode (from strap)
emmc: width = 4, mclk = 48000000, sclk = 24000000
ddr_type = 1 (LPDDR4)
hb_chip_package_type:3
ddr_hdr.ecc_gran: 0x0
ddr_hdr.ecc_map: 0x0
ddr_hdr.sbr_pattern0: 0x0
ddr_hdr.sbr_pattern1: 0x0
ddr_freq = 05
board id = 31520024
ddr datarate: 3200
### SAMSUNG DDR ###
no ddr pin set
detect part number: 108
detect ddr freq: c80
board id alternative:0x2
index is 12
index is 15
hb_ddr_index: 15
dram_pll_init
sscg disabled
control load ddrc src_addr: b3000, load_addr: 802caa20, src_len: 920
[DDR INFO] VERSION: develop
[DDR INFO] BUILD: 2022-03-28-20:36
[DDR INFO] GIT COMMIT: 5f69d1b69cf2ed7dfe9d5b6ab3c9c44595b0c2fa
[DDR INFO] GIT TIME: Mon, 28 Mar 2022 20:29:30 +0800
[DDR INFO] ==ddr_features==
[DDR INFO] RDBI: 0
[DDR INFO] WDBI: 1
[DDR INFO] InlineECC: 0
[DDR INFO] DM: 1
[DDR INFO] DDC: 1
[DDR INFO] SSCG: 0
[DDR INFO] BOARD: XS_ENABLE
load ddr phy src_addr: b3c00, load_addr: 802caa20, src_len: 420
ATxSlewRate : 15f
ATxImpedance : 7f
TxSlewRate : 19f
TxOdtDrvStren : 600
TxImpedanceCtrl : e3f
CalDrvStr0 : 11
VrefInGlobal : 104
load dqmap src addr: c2600, load_addr: 802caa20, src_len: 20
magic = 544f4248
load imem1 src_addr: 81e00, load_addr: 802caa20, src_len: 8000
load dmem1 src_addr: b2200, load_addr: 802caa20, src_len: 684
executing 1D fw
load imem2 src_addr: 89e00, load_addr: 802caa20, src_len: 8000
load dmem2 src_addr: b2a00, load_addr: 802caa20, src_len: 564
p_dmem_lpddr4_2d_16b->MR11_A0:43
p_dmem_lpddr4_2d_16b->MR14_A0:5c
p_dmem_lpddr4_2d_16b->MR12_A0:54
p_dmem_lpddr4_2d_16b->MR22_A0:14
p_dmem_lpddr4_2d_16b->MR3_A0:b3
p_dmem_lpddr4_2d_16b->Reserved00:40
p_dmem_lpddr4_2d_16b->Reserved0E:4
p_dmem_lpddr4_2d_16b->Delay_Weight2D:20
p_dmem_lpddr4_2d_16b->Voltage_Weight2D:80
executing 2D fw
load pie src_addr: b4400, load_addr: 802caa20, src_len: 11f0
Set QoS.
get_ddr_mr_info:cs_num=1, mr5=0x1, mr8=0x10
no magic in efuse file,bypass efuse
total_sz = 2048
SPL_VERSION:7
boot reason: normal
ota check count:25
uboot partition is uboot_A
load u-boot: src_addr=0x100000, dest_addr=0x4000000, len=2097152
load warm boot spl: addr=0x45000, dest_addr=0x80000000, len=31232
load bl31: addr=0xe7000, dest_addr=0x0, len=102400
SFLOW_AUTH_BL31
bypass bpu image
clear keybank!!!
SFLOW_DBG_EN
Trying to boot from RAM
SFLOW_CLR_KEY
SFLOW_REG_LD
install_portal copy portal
hb som type: 3
U-Boot 2018.09-g7c0f066f (Apr 24 2022 - 10:47:32 +0800)
Model: Hobot XJ3 Soc Board
DRAM: system DDR size: 0x7fe00000
2 GiB
MMC: dwmmc@A5010000 clock set: 52000000.
dwmmc@A5010000: 0 (eMMC), dwmmc@A5011000: 1, dwmmc@A5012000: 2
Loading Environment from MMC… *** Warning - bad CRC, using default environment
In: serial@a5000000
Out: serial@a5000000
Err: serial@a5000000
Net:
Warning: ethernet@A5014000 (eth0) using random MAC address - ee:cc:e7:18:0d:c5
eth0: ethernet@A5014000
Disable cnn cores ..
dtb_name:hobot-x3-sdb.dtb
base board type: X3 SDB
bootmode: EMMC
board_id = 31520124
uboot: normal boot
boot partition: boot, system partition: system
enable watchdog success !
switch to partitions #0, OK
mmc0(part 0) is current device
** Unrecognized filesystem type **
disable watchdog success !
Hobot>boot
Hobot>NOTICE: fast_boot:0
S
F
L
O
W
NOTICE: boot src: 0
NOTICE: eMMC : 0xd6
Auth pass
*** SPL abnormal reset flow (do not re-init ddr) ***
check_reset_state (3): wakeup address = 0x0, hw wakeup status = 0x3, wakeup src=0x100
SFLOW_INIT
SFLOW_FIN_HW_A
ddr_freq = 05
board id = 31520024
ddr datarate: 3200
### SAMSUNG DDR ###
no ddr pin set
index is 12
index is 15
hb_ddr_index: 15
dram_pll_init
sscg disabled
[DDR INFO] RDBI: 0
[DDR INFO] WDBI: 1
[DDR INFO] DM: 1
[DDR INFO] DDC: 1
[DDR INFO] SSCG: 0
ATxSlewRate : 15f
ATxImpedance : 7f
TxSlewRate : 19f
TxOdtDrvStren : 600
CalDrvStr0 : 11
VrefInGlobal : 104
magic = 544f4248
executing 1D fw
executing 2D fw
Set QoS.
total_sz = 2048
SPL_VERSION:7
boot reason: normal
ota check count:25
SFLOW_AUTH_BL31
bypass bpu image
clear keybank!!!
SFLOW_DBG_EN
SFLOW_CLR_KEY
SFLOW_REG_LD
hb som type: 3
2 GiB
In: serial@a5000000
Net:
Warning: ethernet@A5014000 (eth0) using random MAC address - 72:70:f8:23:4a:dd
bootmode: EMMC
board_id = 31520124
uboot: normal boot
