enable watchdog success !
switch to partitions #0, OK
mmc2 is current device
Scanning mmc 2:2…
Found U-Boot script /boot/boot.scr
664 bytes read in 1 ms (648.4 KiB/s)
## Executing script at 03c10000
Boot script loaded from devtype:mmc devnum:2 devplist:2
bootargs = console=ttyS0,921600 raid=noautodetect hobotboot.reson=PANIC_RESET rootfstype=ext4 root=/dev/mmcblk2p2
Loading fdt file: /boot/hobot/hobot-x3-pi.dtb
69676 bytes read in 6 ms (11.1 MiB/s)
Loading kernel: /boot/Image
19097608 bytes read in 847 ms (21.5 MiB/s)
## Flattened Device Tree blob at 03c00000
Booting using the fdt blob at 0x3c00000
Loading Device Tree to 0000000003c00000, end 0000000003c1ffff … OK
chip_id: ab36300
The address of the fdt is 0x3c00000
Changed status Done
Can’t get fdt_addr !!!Orign(MAX) bpu model Reserve Mem Size to 64M!!
Starting kernel …
[ 0.000000] OF: reserved mem: OVERLAP DETECTED!
[ 0.000000] image_r5_mem (0x0000000080000000–0x0000000080010000) overlaps with msg_r5_mem (0x000000008000f000–0x0000000080010000)
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000004000000, size 672 MiB
[ 0.000000] OF: reserved mem: initialized node ion_cma, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[ 0.000000] On node 0 totalpages: 1047808
[ 0.000000] DMA zone: 8180 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523520 pages, LIFO batch:31
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc17ff2a000 s65176 r8192 d29032 u102400
[ 0.000000] pcpu-alloc: s65176 r8192 d29032 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1031436
[ 0.000000] Kernel command line: earlycon loglevel=8 kgdboc=ttyS0 video=hobot:x3sdb-hdmi console=ttyS0,921600 raid=noautodetect hobotboot.reson=PANIC_RESET rootfstype=ext4 root=/dev/mmcblk2p2
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB [mem 0x7afff000-0x7efff000] (64MB) mapped at [ffffffc07afff000-ffffffc07effefff]
[ 0.000000] Memory: 3319644K/4191232K available (10494K kernel code, 1306K rwdata, 5748K rodata, 1088K init, 9553K bss, 167076K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008000000 - 0xffffff8008a40000 ( 10496 KB)
[ 0.000000] .rodata : 0xffffff8008a40000 - 0xffffff8008fe0000 ( 5760 KB)
[ 0.000000] .init : 0xffffff8008fe0000 - 0xffffff80090f0000 ( 1088 KB)
[ 0.000000] .data : 0xffffff80090f0000 - 0xffffff8009236808 ( 1307 KB)
[ 0.000000] .bss : 0xffffff8009236808 - 0xffffff8009b8aed8 ( 9554 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00008000 - 0xffffffbf06000000 ( 95 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc180000000 ( 6142 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 36277 entries in 142 pages
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] parent_rate: 0, dclk->rate:2666000000, pre_ddr_rate:0, res.a0:139713232
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001210] clocksource: hobot_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
[ 0.003008] Console: colour dummy device 80x25
[ 0.003579] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.004885] pid_max: default: 32768 minimum: 301
[ 0.005542] Security Framework initialized
[ 0.006060] AppArmor: AppArmor disabled by boot time parameter
[ 0.006902] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.007769] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023811] ASID allocator initialised with 65536 entries
[ 0.031809] Hierarchical SRCU implementation.
[ 0.063870] smp: Bringing up secondary CPUs …
[ 0.100077] Detected VIPT I-cache on CPU1
[ 0.100112] CPU1: Booted secondary processor [410fd034]
[ 0.136129] Detected VIPT I-cache on CPU2
[ 0.136150] CPU2: Booted secondary processor [410fd034]
[ 0.172188] Detected VIPT I-cache on CPU3
[ 0.172208] CPU3: Booted secondary processor [410fd034]
[ 0.172263] smp: Brought up 1 node, 4 CPUs
[ 0.176326] SMP: Total of 4 processors activated.
[ 0.176920] CPU features: detected feature: 32-bit EL0 Support
[ 0.177739] CPU: All CPU(s) started at EL1
[ 0.178268] alternatives: patching kernel code
[ 0.179859] devtmpfs: initialized
[ 0.188791] random: get_random_u32 called from bucket_table_alloc+0x108/0x270 with crng_init=0
[ 0.190360] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.191606] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.208138] xor: automatically using best checksumming function 32regs
[ 0.209059] pinctrl core: initialized pinctrl subsystem
[ 0.210300] NET: Registered protocol family 16
[ 0.211617] vdso: 2 pages (1 code @ ffffff8008a46000, 1 data @ ffffff80090f4000)
[ 0.212563] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.214153] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.218978] pstore: using zlib compression
[ 0.219770] console [pstore-1] enabled
[ 0.220370] pstore: Registered ramoops as persistent store backend
[ 0.221155] ramoops: attached 0x40000@0x3fc0000, ecc: 0/0
[ 0.226164] hobot_dma a1005000.dma: Hobot DMA Engine Driver Probed!!
[ 0.240246] SCSI subsystem initialized
[ 0.241035] media: Linux media interface: v0.10
[ 0.241631] Linux video capture interface: v2.00
[ 0.242263] pps_core: LinuxPPS API ver. 1 registered
[ 0.242891] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.244067] PTP clock support registered
[ 0.245217] ion_dummy: not reserve carveout memory, try to alloc from cma
[ 0.381889] Advanced Linux Sound Architecture Driver Initialized.
[ 0.383054] usbcore: registered new interface driver usbfs
[ 0.383780] usbcore: registered new interface driver hub
[ 0.384506] usbcore: registered new device driver usb
[ 0.385478] clocksource: Switched to clocksource arch_sys_counter
[ 0.433205] VFS: Disk quotas dquot_6.6.0
[ 0.433784] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.434721] FS-Cache: Loaded
[ 0.435208] CacheFiles: Loaded
[ 0.440581] NET: Registered protocol family 2
[ 0.441555] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.442673] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.443916] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.444827] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.445685] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.446683] NET: Registered protocol family 1
[ 0.447516] RPC: Registered named UNIX socket transport module.
[ 0.448267] RPC: Registered udp transport module.
[ 0.448864] RPC: Registered tcp transport module.
[ 0.449462] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.450995] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.453222] audit: initializing netlink subsys (disabled)
[ 0.454031] audit: type=2000 audit(0.452:1): state=initialized audit_enabled=0 res=1
[ 0.454312] Initialise system trusted keyrings
[ 0.455635] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.460089] zbud: loaded
[ 0.461718] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.462580] exFAT: Version 1.2.9
[ 0.463061] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.464165] NFS: Registering the id_resolver key type
[ 0.464817] Key type id_resolver registered
[ 0.465344] Key type id_legacy registered
[ 0.465873] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.466727] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.471002] NET: Registered protocol family 38
[ 0.471573] async_tx: api initialized (async)
[ 0.472125] Key type asymmetric registered
[ 0.472644] Asymmetric key parser ‘x509’ registered
[ 0.473329] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.474367] io scheduler noop registered
[ 0.475029] io scheduler cfq registered (default)
[ 0.475624] io scheduler mq-deadline registered
[ 0.476200] io scheduler kyber registered
[ 0.477420] pinctrl-single a6003170.pinctrl_voltag: 64 pins at pa ffffff8009c3d170 size 8
[ 0.478938] pinctrl-single a6004000.pinctrl: 128 pins at pa ffffff8009c51000 size 512
[ 0.480161] pinctrl_cdev soc:pinctrl_cdev@0xA6004000: start probe
[ 0.481054] pinctrl_cdev soc:pinctrl_cdev@0xA6004000: probe ok
[ 0.481955] gpio-x3 a6003000.gpio: x3 gpio probe start!!!
[ 0.482646] gpio-x3 a6003000.gpio: x3 gpio add gpiochip start!!!
[ 0.483583] gpio-x3 a6003000.gpio: diable all gpio irq
[ 0.485825] gpio-x3 a6003000.gpio: irqbase:57
[ 0.486377] gpio-x3 a6003000.gpio: x3 irq add start!!!
[ 0.487033] irq: Cannot allocate irq_descs @ IRQ57, assuming pre-allocated
[ 0.488069] gpio-x3 a6003000.gpio: x3 irq add ok!!!
[ 0.488723] gpio-x3 a6003000.gpio: x3 irqchip ops add ok!!!
[ 0.489428] gpio-x3 a6003000.gpio: x3 gpio probe ok!!!
[ 0.490669] hobot-pwm: hobot-pwmchip0 registered
[ 0.491421] hobot-pwm: hobot-pwmchip1 registered
[ 0.492757] diag dev [ver:1.1] init done
[ 0.493755] hobot_ddr_monitor: LPDDR4 detected
[ 0.494533] hobot_ddr_monitor: ddr monitor init finished.
[ 0.494967] [vcam] init start
[ 0.496026] vcam probe start
[ 0.496478] vcam probe end successful
[ 0.496939] [vcam] init end
[ 0.497930] a5000000.serial: ttyS0 at MMIO 0xa5000000 (irq = 10, base_baud = 12000000) is a hobot-uart
[ 0.499143] console [ttyS0] enabled
[ 0.500027] bootconsole [hobot0] disabled
[ 0.501348] hobot-uart a5001000.serial: Failed to create debugfs root directory
[ 0.502417] a5001000.serial: ttyS1 at MMIO 0xa5001000 (irq = 11, base_baud = 12000000) is a hobot-uart
[ 0.503890] hobot-uart a5003000.serial: Failed to create debugfs root directory
[ 0.504882] a5003000.serial: ttyS3 at MMIO 0xa5003000 (irq = 12, base_baud = 12000000) is a hobot-uart
[ 0.506452] KGDB: Registered I/O driver kgdboc
[ 0.507303] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.512752] brd: module loaded
[ 0.517323] loop: module loaded
[ 0.518959] spi-nand hr_nand.0: GigaDevice SPI NAND was found.
[ 0.519720] spi-nand hr_nand.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.522367] hobot_spi a5006000.spi: ver: HOBOT-spi_V20.200330 master
[ 0.523421] libphy: Fixed MDIO Bus: probed
[ 0.524649] st_gmac a5014000.ethernet: found phy-handle subnode
[ 0.525529] st_gmac a5014000.ethernet: xj3_mtl_setup, plat->rx-queues-to-use:4, and tx:4
[ 0.526721] st_gmac a5014000.ethernet: xj3_probe_config_dt, clk_ptp_rate:250000000
[ 0.527727] set mac address 00:11:22:21:08:7a:
[ 0.527730] (using random mac adress)
[ 0.528773] (NULL device *): xj3_get_hw_features, tx_fifo_size:16384
[ 0.529619] (NULL device *): xj3_get_hw_features, rx_fifo_size:16384
[ 0.530438] st_gmac a5014000.ethernet: TSO supported
[ 0.531078] st_gmac a5014000.ethernet: TSO feature enabled
[ 0.531784] st_gmac a5014000.ethernet: Enable Rx Mitigation via HW Watchdog Timer
[ 0.652847] libphy: hobot-mac-mdio: probed
[ 0.654422] st_gmac a5014000.ethernet: hobot_eth_probe: probe sucessfully
[ 0.655636] dwc3-of-simple b2000000.usb: b2000000.usb supply usb_0v8 not found, using dummy regulator
[ 0.656854] dwc3-of-simple b2000000.usb: usb regulator 0v8 enable succeed
[ 0.657756] dwc3-of-simple b2000000.usb: b2000000.usb supply usb_3v3 not found, using dummy regulator
[ 0.658971] dwc3-of-simple b2000000.usb: usb regulator 3v3 enable succeed
[ 0.660499] dwc3 b2000000.dwc3: Configuration mismatch. user dr_mode(otg) not equal with hardware default mode(peripheral). still use otg mode
[ 0.662177] dwc3 b2000000.dwc3: found 6 IN and 3 OUT endpoints
[ 0.663681] usbcore: registered new interface driver cdc_acm
[ 0.664410] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.665465] usbcore: registered new interface driver uas
[ 0.666192] usbcore: registered new interface driver usb-storage
[ 0.667019] usbcore: registered new interface driver usbserial
[ 0.667790] usbcore: registered new interface driver usbserial_generic
[ 0.668650] usbserial: USB Serial support registered for generic
[ 0.669444] usbcore: registered new interface driver usb_serial_simple
[ 0.670322] usbserial: USB Serial support registered for carelink
[ 0.671124] usbserial: USB Serial support registered for zio
[ 0.671869] usbserial: USB Serial support registered for funsoft
[ 0.672659] usbserial: USB Serial support registered for flashloader
[ 0.673511] usbserial: USB Serial support registered for google
[ 0.674292] usbserial: USB Serial support registered for libtransistor
[ 0.675148] usbserial: USB Serial support registered for vivopay
[ 0.675937] usbserial: USB Serial support registered for moto_modem
[ 0.676760] usbserial: USB Serial support registered for motorola_tetra
[ 0.677644] usbserial: USB Serial support registered for novatel_gps
[ 0.678478] usbserial: USB Serial support registered for hp4x
[ 0.679237] usbserial: USB Serial support registered for suunto
[ 0.680015] usbserial: USB Serial support registered for siemens_mpi
[ 0.680859] usbcore: registered new interface driver rio500
[ 0.681709] mousedev: PS/2 mouse device common for all mice
[ 0.692763] hobot-rtc a6002000.rtc: rtc core: registered hobot-rtc as rtc0
[ 0.693779] i2c /dev entries driver
[ 0.694387] hobot-i2c a5009000.i2c: hobot i2c probe start
[ 0.695152] hobot-i2c a5009000.i2c: round_rate:96000000
[ 0.695829] hobot-i2c a5009000.i2c: I2C bus speed is 400000
[ 0.696546] hobot-i2c a5009000.i2c: clkdiv = 0x1d
[ 0.697153] hobot-i2c a5009000.i2c: i2c0 diag register…
[ 0.698276] hobot-i2c a5009000.i2c: hobot_i2c_0 probe done
[ 0.699078] hobot-i2c a500a000.i2c: hobot i2c probe start
[ 0.699835] hobot-i2c a500a000.i2c: round_rate:96000000
[ 0.700512] hobot-i2c a500a000.i2c: I2C bus speed is 400000
[ 0.701229] hobot-i2c a500a000.i2c: clkdiv = 0x1d
[ 0.701857] hobot-i2c a500a000.i2c: i2c1 diag register…
[ 0.702868] hobot-i2c a500a000.i2c: hobot_i2c_1 probe done
[ 0.703833] lirc_dev: IR Remote Control driver registered, major 239
[ 0.704650] IR LIRC bridge handler initialized
[ 0.705403] sif_mclk clock frequence is 544000000
[ 0.706074] mipi_rx0_ipi clock frequence is 544000000
[ 0.706763] mipi_rx1_ipi clock frequence is 544000000
[ 0.707461] mipi_rx2_ipi clock frequence is 544000000
[ 0.708170] mipi_rx3_ipi clock frequence is 544000000
[ 0.708889] mipi_tx_ipi clock frequence is 544000000
[ 0.709627] mipi_cfg_host clock frequence is 102000000
[ 0.710381] pym_mclk clock frequence is 1188000000
[ 0.711101] mipi_dev_ref clock frequence is 24000000
[ 0.711854] mipi_host_ref clock frequence is 24000000
[ 0.712630] sensor0_mclk clock frequence is 37125000
[ 0.713405] sensor1_mclk clock frequence is 37125000
[ 0.714213] sensor2_mclk clock frequence is 37125000
[ 0.715014] sensor3_mclk clock frequence is 37125000
[ 0.715653] [FRT:D] x3_ips_probe(0)
[ 0.716674] hobot swinfo sel reg ro=0x1 boot dump
[ 0.717628] pvt a1009000.pvt: SCRATCH test: 1234abcd, pvt is alive.
[ 0.718556] pvt a1009000.pvt: VM Calibrated data detected
[ 0.719766] hobot_wdt a1002000.watchdog: watchdog setting [pet:6s bark:11s bite:15s]
[ 0.721074] hobot_wdt a1002000.watchdog: Hobot Watchdog Timer at ffffff8009da3000 with timeout 15s
[ 0.722487] device-mapper: uevent: version 1.0.3
[ 0.723253] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 0.724411] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 0.726851] Synopsys Designware Multimedia Card Interface Driver
[ 0.727866] dwmmc_hobot a5010000.dwmmc: ver: HOBOT-mmc_V20.200402
[ 0.728691] dwmmc_hobot a5010000.dwmmc: card-detect-delay not found.
[ 0.729535] dwmmc_hobot a5010000.dwmmc: data-addr not found.
[ 0.730573] mmc_host mmc0: card is non-removable.
[ 0.770692] dwmmc_hobot a5011000.dwmmc: ver: HOBOT-mmc_V20.200402
[ 0.773530] dwmmc_hobot a5011000.dwmmc: card-detect-delay not found.
[ 0.774349] dwmmc_hobot a5011000.dwmmc: data-addr not found.
[ 0.779118] dwmmc_hobot a5011000.dwmmc: mmc set to fixed voltage 1800
[ 0.780181] mmc_host mmc1: card is non-removable.
[ 0.877674] dwmmc_hobot a5012000.dwmmc: ver: HOBOT-mmc_V20.200402
[ 0.878492] dwmmc_hobot a5012000.dwmmc: card-detect-delay not found.
[ 0.879322] dwmmc_hobot a5012000.dwmmc: data-addr not found.
[ 0.880288] dwmmc_hobot a5012000.dwmmc: Got CD GPIO
[ 0.991196] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.993379] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.995572] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.998938] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.002892] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.069799] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.070627] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.071484] usbcore: registered new interface driver usbhid
[ 1.072201] usbhid: USB HID core driver
[ 1.072783] logger: created 256K log ‘log_main’
[ 1.073426] logger: created 256K log ‘log_events’
[ 1.074110] logger: created 256K log ‘log_radio’
[ 1.074765] logger: created 256K log ‘log_system’
[ 1.075793] set dmc devfreq governor to performance
[ 1.076427] hobot_dmcfreq_target: dmcfreq->rate:2666000000, target_rate:2666000000
[ 1.077399] buf:, powersave_rate:2666000000, dmcfreq->pre_state:0
[ 1.084229] usbcore: registered new interface driver snd-usb-audio
[ 1.085390] Netfilter messages via NETLINK v0.30.
[ 1.086040] ip_set: protocol 6
[ 1.086522] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 1.087522] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.088441] arp_tables: arp_tables: (C) 2002 David S. Miller
[ 1.089231] Initializing XFRM netlink socket
[ 1.090114] NET: Registered protocol family 10
[ 1.091346] Segment Routing with IPv6
[ 1.091857] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.092948] NET: Registered protocol family 17
[ 1.093642] Key type dns_resolver registered
[ 1.095264] Loading compiled-in X.509 certificates
[ 1.098778] Loaded X.509 cert ‘Build time autogenerated kernel key: 81cb0ef77db2fac76e9588c2120c82422367d268’
[ 1.100109] zswap: loaded using pool lzo/zbud
[ 1.111350] dwc3 b2000000.dwc3: Configuration mismatch. user dr_mode(otg) not equal with hardware default mode(peripheral). still use otg mode
[ 1.113013] dwc3 b2000000.dwc3: found 6 IN and 3 OUT endpoints
[ 1.114028] console [netcon0] enabled
[ 1.114502] netconsole: network logging started
[ 1.115287] hobot-rtc a6002000.rtc: setting system clock to 1970-01-01 00:00:00 UTC (0)
[ 1.116478] vps mipi_dphy: probe with x3vio done
[ 1.117187] hobot_wdt_test: wdt_test_init: wdt test init
[ 1.119953] VCC_CNN0: disabling
[ 1.120363] VCC_CNN1: disabling
[ 1.121326] vps mipi_host0: ver 140* port0(0:0)
[ 1.122259] vps mipi_host1: ver 140* port1(1:0)
[ 1.123154] vps mipi_host2: ver 140* port2(0:1)
[ 1.123937] vps mipi_host3: ver 140* port3(1:1)
[ 1.124782] ALSA device list:
[ 1.125167] No soundcards found.
[ 1.125860] md: Skipping autodetection of RAID arrays. (raid=autodetect will force)
[ 1.126994] VFS: Cannot open root device “mmcblk2p2” or unknown-block(0,0): error -6
[ 1.127988] Please append a correct “root=” boot option; here are the available partitions:
[ 1.129062] 0100 102400 ram0
[ 1.129065] (driver?)
[ 1.129874] 0101 102400 ram1
[ 1.129876] (driver?)
[ 1.130665] 0102 102400 ram2
[ 1.130666] (driver?)
[ 1.131454] 0103 102400 ram3
[ 1.131456] (driver?)
[ 1.132244] 0104 102400 ram4
[ 1.132246] (driver?)
[ 1.133034] 0105 102400 ram5
[ 1.133036] (driver?)
[ 1.133864] 0106 102400 ram6
[ 1.133866] (driver?)
[ 1.134655] 0107 102400 ram7
[ 1.134656] (driver?)
[ 1.135444] 0108 102400 ram8
[ 1.135446] (driver?)
[ 1.136234] 0109 102400 ram9
[ 1.136236] (driver?)
[ 1.137024] 010a 102400 ram10
[ 1.137026] (driver?)
[ 1.137841] 010b 102400 ram11
[ 1.137843] (driver?)
[ 1.138642] 010c 102400 ram12
[ 1.138644] (driver?)
[ 1.139443] 010d 102400 ram13
[ 1.139445] (driver?)
[ 1.140244] 010e 102400 ram14
[ 1.140246] (driver?)
[ 1.141045] 010f 102400 ram15
[ 1.141047] (driver?)
[ 1.141870] 1f00 131072 mtdblock0
[ 1.141872] (driver?)
[ 1.142716] hobot_fusa: set_fusa_error_pin:75 set error pin to 1
[ 1.143487] hobot_fusa: fusa errpin not ready
[ 1.143490] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.145109] Kernel Offset: disabled
[ 1.145560] CPU features: 0x0002004
[ 1.146010] Memory Limit: none
[ 1.150579] Rebooting in 1 seconds..
[ 1.185481] dwmmc_hobot a5012000.dwmmc: Unexpected interrupt latency
[ 1.201475] dwmmc_hobot a5011000.dwmmc: Unexpected interrupt latency
[ 1.221715] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.222433] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.223890] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6d hci version 0x110 quirks 0x0000000000010010
[ 1.225125] xhci-hcd xhci-hcd.0.auto: irq 178, io mem 0xb2000000
[ 1.226094] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.14
[ 1.227157] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.228086] usb usb1: Product: xHCI Host Controller
[ 1.228715] usb usb1: Manufacturer: Linux 4.14.87 xhci-hcd
[ 1.229421] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.230365] hub 1-0:1.0: USB hub found
[ 1.230870] hub 1-0:1.0: 1 port detected
[ 1.231560] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.232274] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.233262] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 1.234148] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.235256] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.14
[ 1.236319] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.237247] usb usb2: Product: xHCI Host Controller
[ 1.237885] usb usb2: Manufacturer: Linux 4.14.87 xhci-hcd
[ 1.238592] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.239484] hub 2-0:1.0: USB hub found
[ 1.239984] hub 2-0:1.0: 1 port detected
[ 2.151091] SMP: stopping secondary CPUs
[ 2.151598] psci: psci_sys_reset(reboot_mode=0)
NOTICE: fast_boot:0
S
F
L
O
NOTICE: efuse cpu_cfg = 0
W
NOTICE: boot src: 2
NOTICE: GigaDev SPI NAND was found.
NOTICE: Block size: 128 KiB, page size: 2048
NOTICE: BL1: Booting BL2
Auth pass
NOTICE: bl1_main exit
SPL normal reset flow
check_reset_state (2): wakeup address = 0x0, hw wakeup status = 0x3, wakeup src=0x100
SFLOW_INIT
CHIP ID:PCB941/WAFER: W04/ X: X23/ Y: Y17
SFLOW_FIN_HW_A
U-Boot SPL 2018.09-g4ca851534c-dirty (May 11 2022 - 20:09:50 +0800)
SPACC Init - ID: (00000061)
SPL nand boot mode (from strap)
ddr_type = 1 (LPDDR4)
hb_chip_package_type:3
load ddr header src_addr: 100000, load_addr: 802ca020, src_len: a00
find valid ddr image
ddr_hdr.ecc_gran: 0x0
ddr_hdr.ecc_map: 0x0
ddr_hdr.sbr_pattern0: 0x0
ddr_hdr.sbr_pattern1: 0x0
ddr_freq = 05
board id = 31540334
ddr datarate: 3200
### SAMSUNG DDR ###
no ddr pin set
detect part number: 108
detect ddr freq: c80
board id alternative:0x3
index is 12
index is 15
index is 19
hb_ddr_index: 19
dram_pll_init
sscg disabled
control load ddrc src_addr: 15ae00, load_addr: 802caa20, src_len: 920
[DDR INFO] VERSION: develop
[DDR INFO] BUILD: 2022-05-11-20:09
[DDR INFO] GIT COMMIT: 4ca851534c1616ace920fdaa000c6fb717c1fb74
[DDR INFO] GIT TIME: Wed, 20 Apr 2022 18:28:49 +0800
[DDR INFO] ==ddr_features==
[DDR INFO] RDBI: 0
[DDR INFO] WDBI: 1
[DDR INFO] InlineECC: 0
[DDR INFO] DM: 1
[DDR INFO] DDC: 1
[DDR INFO] SSCG: 0
[DDR INFO] BOARD: XS_ENABLE
load ddr phy src_addr: 15b800, load_addr: 802caa20, src_len: 420
ATxSlewRate : 15f
ATxImpedance : 7f
TxSlewRate : 19f
TxOdtDrvStren : 600
TxImpedanceCtrl : e3f
CalDrvStr0 : 11
VrefInGlobal : 104
load dqmap src addr: 15d600, load_addr: 802caa20, src_len: 20
magic = 544f4248
load imem1 src_addr: 11ce00, load_addr: 802caa20, src_len: 8000
load dmem1 src_addr: 15a000, load_addr: 802caa20, src_len: 684
executing 1D fw
load imem2 src_addr: 124e00, load_addr: 802caa20, src_len: 8000
load dmem2 src_addr: 15a800, load_addr: 802caa20, src_len: 564
p_dmem_lpddr4_2d_16b->MR11_A0:54
p_dmem_lpddr4_2d_16b->MR14_A0:54
p_dmem_lpddr4_2d_16b->MR12_A0:51
p_dmem_lpddr4_2d_16b->MR22_A0:14
p_dmem_lpddr4_2d_16b->MR3_A0:b3
p_dmem_lpddr4_2d_16b->Reserved00:40
p_dmem_lpddr4_2d_16b->Reserved0E:4
p_dmem_lpddr4_2d_16b->Delay_Weight2D:20
p_dmem_lpddr4_2d_16b->Voltage_Weight2D:80
executing 2D fw
load pie src_addr: 15be00, load_addr: 802caa20, src_len: 11f0
Set QoS.
get_ddr_mr_info:cs_num=1, mr5=0x1, mr8=0x10
no magic in efuse file,bypass efuse
total_sz = 4096
SPL_VERSION:7
uboot partition is uboot_A
load u-boot: src_addr=0x380000, dest_addr=0x4000000, len=2097152
load warm boot spl: addr=0x800, dest_addr=0x80000000, len=31232
load bl31: addr=0x300000, dest_addr=0x0, len=524288
SFLOW_AUTH_BL31
bypass bpu image
clear keybank!!!
SFLOW_DBG_EN
Trying to boot from RAM
SFLOW_CLR_KEY
SFLOW_REG_LD
install_portal copy portal
hb som type: 5
X3 PI reset VDD_SD done
U-Boot 2018.09-g40785bca (May 27 2022 - 16:30:48 +0800)
Model: Hobot XJ3 Soc Board
DRAM: system DDR size: 0xffe00000
4 GiB
MMC: dwmmc@A5010000: 0, dwmmc@A5011000: 1, dwmmc@A5012000: 2 (SD)
Loading Environment from UBI… GigaDevice SPI NAND was found.
In: serial@a5000000
Out: serial@a5000000
Err: serial@a5000000
Net: x3 sdb reset eth phy done
Warning: ethernet@A5014000 (eth0) using random MAC address - 22:7b:04:b7:60:ea
eth0: ethernet@A5014000
Disable cnn cores ..
dtb_name:hobot-x3-pi.dtb
base board type: X3 SDB
bootmode: NAND
board_id = 31540334
damaged volume, update marker is setdamaged volume, update marker is setdamaged volume, update marker is sethb_boot_args_cmd_set custom_bootargs 0 ubuntu_boot 0
Scanning mmc 2:2…
