ddr频率与容量
  1. 系统软件版本:LNX_PL2.0_WB_20210508 release
  2. 问题涉及的技术领域: 驱动
  3. 问题描述: DDR型号是K4F6E3S4HM-MGCJ,应该16Gbit但是free命令只看到1GB
  4. 第二个问题, 如何调整ddr频率, 看log应该是3200Mbps,如果想调整到2133Mbps, 该怎么操作
root@x3sdbx3-samsung1G-3200:~# free
total used free shared buffers cached
Mem: 1015764 366064 649700 80 1820 12408
-/+ buffers/cache: 351836 663928
Swap: 0 0 0
开机的部分log如下:
NOTICE: efuse cpu_cfg = 0
W
NOTICE: boot src: 0
NOTICE: eMMC : 0xd6
NOTICE: BL1: Booting BL2
Auth pass
NOTICE: bl1_main exit
SPL normal reset flow
check_reset_state (2): wakeup address = 0x0, hw wakeup status = 0x3, wakeup src=0x100
SFLOW_INIT
CHIP ID:P0U706/WAFER: W04/ X: X15/ Y: Y35
SFLOW_FIN_HW_A
U-Boot SPL 2018.09-00846-g37c759ce5c (May 07 2021 - 16:02:44 +0800)
SPACC Init - ID: (00000061)
SPL emmc boot mode (from strap)
emmc: width = 4, mclk = 48000000, sclk = 24000000
ddr_type = 1 (LPDDR4)
ddr_hdr.ecc_gran: 0x0
ddr_hdr.ecc_map: 0x0
ddr_hdr.sbr_pattern0: 0x0
ddr_hdr.sbr_pattern1: 0x0
ddr_freq = 00
board id = 31000004
ddr datarate: 3200
### SAMSUNG DDR ###
no ddr pin set
detect part number: 108
detect ddr freq: c80
board id alternative:0x0
hb_ddr_index: 12
dram_pll_init
sscg disabled
control load ddrc src_addr: c9600, load_addr: 802caa20, src_len: 920
[DDR INFO] VERSION: develop
[DDR INFO] BUILD: 2021-05-07-16:02
[DDR INFO] GIT COMMIT: 37c759ce5cd816a6919e54d16a65555efd94b983
[DDR INFO] GIT TIME: Fri, 7 May 2021 16:00:26 +0800
[DDR INFO] ==ddr_features==
[DDR INFO] RDBI: 0
[DDR INFO] WDBI: 1
[DDR INFO] InlineECC: 0
[DDR INFO] DM: 1
[DDR INFO] DDC: 1
[DDR INFO] SSCG: 0
[DDR INFO] BOARD: XS_ENABLE
load ddr phy src_addr: ca200, load_addr: 802caa20, src_len: 420
ATxSlewRate : 15f
ATxImpedance : 7f
TxSlewRate : 19f
TxOdtDrvStren : 600
TxImpedanceCtrl : e3f
CalDrvStr0 : 11
VrefInGlobal : 104
load dqmap src addr: dc000, load_addr: 802caa20, src_len: 20
magic = 544f4248
load imem1 src_addr: 9ca00, load_addr: 802caa20, src_len: 8000
load dmem1 src_addr: c8800, load_addr: 802caa20, src_len: 684
executing 1D fw
load imem2 src_addr: a4a00, load_addr: 802caa20, src_len: 8000
load dmem2 src_addr: c9000, load_addr: 802caa20, src_len: 564
您好,
问题1,应该是大B和小b得关系得,要除以8,实际上是2GB
然后free显示得1GB还要加上cached和其他的预留的,从结果看是符合实际值的
https://developer.horizon.ai/api/v1/fileData/X3MSTDOC/bsp\_develop/Approved\_Vendor\_List/DDR\_Support\_List\_And\_Config.html?highlight=ddr
我是看了你们的网页, 发现其中有说明:
# DDR参数配置-
# 频率可选参数 “667” “1600” “2133” “2666” “3200” “3600” “3733” “4266”-
export HR_DDR_FREQ=“3200”
但是不知道在哪里可以修改这些参数。
您好
该型号DDR只支持3200M工作频率,不支持调频
关于第二个问题,该型号DDR只支持3200M工作频率,不支持调频
您好:
该型号DDR列表如下:
板级配置
应该是直接再板子上操作的,如果支持调配的话应该就能成功
你好,请问这个表格是在哪呢?谢谢
