执行X3板子文档中的“4.2精度测试”报错
执行 exportPARALLEL_PROCESS_NUM=1
执行 sh 05_evaluate.sh
然后报错:-
[root@94daa154d42b mapper]# sh 05_evaluate.sh-
cd $(dirname $0)-
model=“./model_output/yolov2_quantized_model.onnx”-
image=“../../../01_common/data/coco/coco_val2017/images/”-
anno=“../../../01_common/data/coco/coco_val2017/annotations/instances_val2017.json”-
python3 -u ./coco_evaluate.py \-
--model=${model} \-
--image_path=${image} \-
--annotation_path=${anno}-
loading annotations into memory…-
Done (t=0.41s)-
creating index…-
index created!-
Done (t=0.77s)-
creating index…-
index created!-
Traceback (most recent call last):-
File “./coco_evaluate.py”, line 262, in -
main()-
File “./coco_evaluate.py”, line 251, in main-
yolo_config, args.process_num)-
File “./coco_evaluate.py”, line 157, in __init__-
self).__init__(model, image_path, annotation_path, yolov2_config)-
File “./coco_evaluate.py”, line 93, in __init__-
self.metric = MSCOCODetMetric(self.annotation_path, with_mask=False)-
File “/usr/local/lib/python3.6/site-packages/horizon_nn/coco_metric.py”, line 125, in __init__-
assert name in name2jsonID-
AssertionError-
Exception ignored in: <bound method MSCOCODetMetric.__del__ of <horizon_nn.coco_metric.MSCOCODetMetric object at 0x7fd3eaac0438>>-
File “/usr/local/lib/python3.6/site-packages/horizon_nn/coco_metric.py”, line 212, in __del__-
if os.path.exists(self._filename):-
AttributeError: ‘MSCOCODetMetric’ object has no attribute ‘_filename’-
错误为: assert name in name2jsonID-
解析标注文件失败: ../../../01_common/data/coco/coco_val2017/annotations/instances_val2017.json-
检查coco 版本 以及 上述路径下文件是否完整
也可自行 debug 定位:-
源码位置在: File “/usr/local/lib/python3.6/site-packages/horizon_nn/coco_metric.py”, line 125,
