[root@localhost AI-EXPRESS-2.7.0]# bash deploy.sh
+ ALL_PROJECT_DIR=/opt/AI-EXPRESS-2.7.0
+ RELEASE_DIR=/opt/AI-EXPRESS-2.7.0/deploy
+ rm /opt/AI-EXPRESS-2.7.0/deploy -rf
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy
++ cat platform.tmp
+ ARCHITECTURE=x3
+ mkdir /opt/AI-EXPRESS-2.7.0/deploy/lib/
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libvioplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libsmartplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libvisualplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libwebsocketplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ ‘[’ x3 == x3 ‘]’
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libuvcplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp ‘/opt/AI-EXPRESS-2.7.0/deps/x3_prebuilt/lib/libguvc*.so’ /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/deps/x3_prebuilt/lib/libguvc*.so’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libxstream-media_codec.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp ‘/opt/AI-EXPRESS-2.7.0/build/lib/libmulti*.so’ /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/build/lib/libmulti*.so’: No such file or directory
+ cp ‘/opt/AI-EXPRESS-2.7.0/build/lib/libgdcplugin*.so’ /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/build/lib/libgdcplugin*.so’: No such file or directory
+ cp ‘/opt/AI-EXPRESS-2.7.0/source/solution_zoo/apa/gdcplugin/deps/*.so’ /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/source/solution_zoo/apa/gdcplugin/deps/*.so’: No such file or directory
+ cp ‘/opt/AI-EXPRESS-2.7.0/build/lib/libdisplayplugin*.so’ /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/build/lib/libdisplayplugin*.so’: No such file or directory
+ cp ‘/opt/AI-EXPRESS-2.7.0/source/solution_zoo/apa/displayplugin/deps/lib/*.so’ /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/source/solution_zoo/apa/displayplugin/deps/lib/*.so’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libcanplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/build/lib/libcanplugin.so’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/build/lib/libanalysisplugin.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/build/lib/libanalysisplugin.so’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/deps/bpu_predict/x3/lib/libbpu_predict.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/x3_prebuilt/lib/libhbrt_bernoulli_aarch64.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/protobuf/lib/libprotobuf.so.10 /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/opencv/lib/libopencv_world.so.3.4 /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/live555/lib/libBasicUsageEnvironment.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/live555/lib/libgroupsock.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/live555/lib/libliveMedia.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/live555/lib/libUsageEnvironment.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/uWS/lib64/libuWS.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/xwarehouse/lib/libxwarehouse.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/zeroMQ/lib/libzmq.so /opt/AI-EXPRESS-2.7.0/deps/zeroMQ/lib/libzmq.so.5 /opt/AI-EXPRESS-2.7.0/deps/zeroMQ/lib/libzmq.so.5.2.0 /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/lib/libmethod_factory.so /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/lib/vision_type.so /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/lib/xstream_internal.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xproto/python_api/package/lib/native_xproto.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/libyuv/lib/libyuv.so /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/deps/libjpeg-turbo/lib/libturbojpeg.so /opt/AI-EXPRESS-2.7.0/deps/libjpeg-turbo/lib/libturbojpeg.so.0 /opt/AI-EXPRESS-2.7.0/deps/libjpeg-turbo/lib/libturbojpeg.so.0.1.0 /opt/AI-EXPRESS-2.7.0/deploy/lib/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/run.sh /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/start_nginx.sh /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ mkdir /opt/AI-EXPRESS-2.7.0/deploy/configs/
+ ‘[’ x3 == x2 ‘]’
+ ‘[’ x3 == x3 ‘]’
+ cp /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.2610 /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.2610.hg /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.96board /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.96board.hg /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.j3dev.cam /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.j3dev.fb /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.j3dev.multi_cam_async /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.j3dev.multi_cam_sync /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.j3dev.multi_fb_sync /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.x3dev.cam /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.x3dev.fb /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.x3dev.fb_cam /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.x3dev.multi_cam_async /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_config.json.x3dev.multi_cam_sync /opt/AI-EXPRESS-2.7.0/output/vioplugin/config/vio_hg /opt/AI-EXPRESS-2.7.0/deploy/configs/ -rf
+ echo ‘copy viowrapper configs’
+ cp /opt/AI-EXPRESS-2.7.0/source/common/viowrapper/config/x3dev/hb_camera_x3.json /opt/AI-EXPRESS-2.7.0/source/common/viowrapper/config/x3dev/hb_vio_x3_1080_fb.json /opt/AI-EXPRESS-2.7.0/source/common/viowrapper/config/x3dev/hb_vio_x3_1080.json /opt/AI-EXPRESS-2.7.0/source/common/viowrapper/config/x3dev/hb_vio_x3_608.json /opt/AI-EXPRESS-2.7.0/deploy/configs/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/output/apa /opt/AI-EXPRESS-2.7.0/deploy/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/output/apa’: No such file or directory
+ cp ‘/opt/AI-EXPRESS-2.7.0/output/apa/configs/configs/*’ /opt/AI-EXPRESS-2.7.0/deploy/configs/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/output/apa/configs/configs/*’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/output/multivioplugin/bin/multivioplugin_test /opt/AI-EXPRESS-2.7.0/deploy/apa/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/output/multivioplugin/bin/multivioplugin_test’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/output/multisourceinput /opt/AI-EXPRESS-2.7.0/deploy/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/output/multisourceinput’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/output/visualplugin/config/visualplugin_body.json /opt/AI-EXPRESS-2.7.0/output/visualplugin/config/visualplugin_face.json /opt/AI-EXPRESS-2.7.0/output/visualplugin/config/visualplugin_vehicle.json /opt/AI-EXPRESS-2.7.0/deploy/configs/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xproto/plugins/websocketplugin/configs/websocketplugin_attribute.json /opt/AI-EXPRESS-2.7.0/deploy/configs/ -rf
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/models
+ cp /opt/AI-EXPRESS-2.7.0/models/x3/faceAgeGender/so/faceAgeGender.hbm /opt/AI-EXPRESS-2.7.0/models/x3/faceMask/so/faceMask.hbm /opt/AI-EXPRESS-2.7.0/models/x3/faceMultitask/so/faceMultitask.hbm /opt/AI-EXPRESS-2.7.0/models/x3/faceQuality/so/faceQuality.hbm /opt/AI-EXPRESS-2.7.0/models/x3/personMultitask/so/personMultitask.hbm /opt/AI-EXPRESS-2.7.0/deploy/models/ -rf
+ ‘[’ x3 == x3 ‘]’
+ cp /opt/AI-EXPRESS-2.7.0/models/x3/SegmentationMultitask_1024x768/so/SegmentationMultitask_1024x768.hbm /opt/AI-EXPRESS-2.7.0/deploy/models/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/models/x3/SegmentationMultitask_1024x768/so/SegmentationMultitask_1024x768.hbm’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/models/x3/personMultitask_1024x768/so/personMultitask_1024x768.hbm /opt/AI-EXPRESS-2.7.0/deploy/models/personMultitask_1024x768.hbm -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/models/x3/personMultitask_1024x768/so/personMultitask_1024x768.hbm’: No such file or directory
+ cp ‘/opt/AI-EXPRESS-2.7.0/source/solution_zoo/apa/models/*’ /opt/AI-EXPRESS-2.7.0/deploy/models/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/source/solution_zoo/apa/models/*’: No such file or directory
+ cp /opt/AI-EXPRESS-2.7.0/output/face_solution /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/output/body_solution /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/output/face_body_multisource /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/output/xwarehouse_sample /opt/AI-EXPRESS-2.7.0/deploy/ -rf
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/output/xwarehouse_sample’: No such file or directory
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/vio_config
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/bpu_config
+ cp /opt/AI-EXPRESS-2.7.0/output/face_solution/configs/bpu_config.json /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/bpu_config
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/models
+ cp -r ‘/opt/AI-EXPRESS-2.7.0/models/x3/ssd/so/*’ /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/models
cp: cannot stat ‘/opt/AI-EXPRESS-2.7.0/models/x3/ssd/so/*’: No such file or directory
+ cp -r /opt/AI-EXPRESS-2.7.0/source/solution_zoo/xstream/methods/ssd_method/config/ssd_module.json /opt/AI-EXPRESS-2.7.0/source/solution_zoo/xstream/methods/ssd_method/config/ssd_test_workflow.json /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config
+ ‘[’ x3 == x3 ‘]’
+ cp -r /opt/AI-EXPRESS-2.7.0/deploy/configs/hb_camera_x3.json /opt/AI-EXPRESS-2.7.0/deploy/configs/hb_vio_x3_1080_fb.json /opt/AI-EXPRESS-2.7.0/deploy/configs/hb_vio_x3_1080.json /opt/AI-EXPRESS-2.7.0/deploy/configs/hb_vio_x3_608.json /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/vio_config
+ cp -r /opt/AI-EXPRESS-2.7.0/deploy/configs/vio /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/config/vio_config
+ cp /opt/AI-EXPRESS-2.7.0/output/video_box /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/output/video_box/data/test.264 /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ cp -r /opt/AI-EXPRESS-2.7.0/build/bin/ssd_method_test /opt/AI-EXPRESS-2.7.0/deploy/ssd_test/
+ cp -r /opt/AI-EXPRESS-2.7.0/source/solution_zoo/xstream/methods/ssd_method/test/data /opt/AI-EXPRESS-2.7.0/deploy/ssd_test
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/python_api
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/python_api/tests
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/configs/pytest_configs
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/xstream /opt/AI-EXPRESS-2.7.0/deploy/python_api/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xproto/python_api/package/xproto /opt/AI-EXPRESS-2.7.0/deploy/python_api/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/tests/test_session.py /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/tests/test_xstream1.py /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/tests/test_xstream2.py /opt/AI-EXPRESS-2.7.0/deploy/python_api/tests/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xproto/python_api/package/tests/test_async.py /opt/AI-EXPRESS-2.7.0/deploy/python_api/tests/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/configs/a_filter.json /opt/AI-EXPRESS-2.7.0/source/common/xstream/python_api/package/configs/b_filter.json /opt/AI-EXPRESS-2.7.0/deploy/configs/pytest_configs/ -rf
+ cp /opt/AI-EXPRESS-2.7.0/webservice /opt/AI-EXPRESS-2.7.0/deploy/ -rf
+ mkdir -p /opt/AI-EXPRESS-2.7.0/deploy/vioplugin_test
+ cp -r /opt/AI-EXPRESS-2.7.0/build/bin/vioplugin_sample /opt/AI-EXPRESS-2.7.0/deploy/vioplugin_test/
[root@localhost AI-EXPRESS-2.7.0]# sudo bash deploy.sh
++ cat platform.tmp
+ ARCHITECTURE=x3
+ ‘[’ x3 == x3 ‘]’
+ ‘[’ x3 == x2 ‘]’
+ ‘[’ x3 == x3 ‘]’
+ ‘[’ x3 == x3 ‘]’
+ ‘[’ x3 == x3 ‘]’
