J3板上加载yolov5s模型bin文件失败
系统软件版本: x3j3_lnx_db_20221121 debug
天工开物版本:horizon_xj3_open_explorer_v1.11.4_20220413
问题涉及的技术领域: (操作系统)
问题描述:调用hbDNNInitializeFromFiles接口加载yolov5s模型bin文件报错,ion alloc ion_opened[344] failed ret:-1!,但./hrt_model_exec perf工具可以验证模型性能
复现概率:(必现) 已进行的排查措施、分析及结果:
问题日志:
[BPU_PLAT]BPU Platform Version(1.3.1)!
[HBRT] set log level as 0. version = 3.13.27
[000:000] (keros_util.cpp:99): keros_authentication failed, ret = 0
[000:000] (configuration.cpp:147): Keros key init failed.
[DNN] Runtime version = 1.8.1_(3.13.27 HBRT)
[HorizonRT] The model builder version = 1.6.8
ion phys failed ret:-1!
HBMEM alloc[0x2a8d960] failed
The process open fds num : 359
hbmem buffer number = 343
# Fatal error in /home/jenkins/workspace/_ap_toolchain_horizonrtd_v1.8.1g/src/plan/hbm_exec_plan.cpp, line 191
# last system error: 12
# Check failed: one_exec_info.hbm_exec_output_internal_alloc_ != 0 (0 vs. 0)
==== C stack trace ===============================
/lib/adas/aarch64/track/libdnn.so(+0x3b3c24) [0x7fb2325c24]
/lib/adas/aarch64/track/libdnn.so(+0x12a070) [0x7fb209c070]
/lib/adas/aarch64/track/libdnn.so(+0x131f68) [0x7fb20a3f68]
/lib/adas/aarch64/track/libdnn.so(+0x134e04) [0x7fb20a6e04]
/lib/adas/aarch64/track/libdnn.so(+0xaf924) [0x7fb2021924]
/lib/adas/aarch64/track/libdnn.so(+0xb6564) [0x7fb2028564]
/lib/adas/aarch64/track/libdnn.so(+0xb8820) [0x7fb202a820]
8: hbDNNInitializeFromFiles
我们根据日志查看,分析的确是因为BPU内存不够引起的,因为BPU内存申请失败导致程序终止。考虑到[HorizonRT] The model builder version = 1.6.8这句日志出现了多次,可以初步判断为加载模型多次导致。同时起多个进程也可能导致bpu内存不够,请您排查一下这两点可能的问题原因看看。
另外系统软件的日志信息有点少,可以运行 ulimit -n 65535 调大一下数量,再运行一下看看有没有更细节的报错信息呢?
您好。看上去是bpu内存不够了,请问有同时加载好几个模型吗?
加载了1个模型文件
root@PML:/userdata/wangyajun# ulimit -n 65535
[000:002] (configuration.cpp:147): Keros key init failed.
ion alloc ion_opened[109] failed ret:-1!
HBMEM alloc[0x1b9000] failed
The process open fds num : 124
hbmem buffer number = 108
# Fatal error in /home/jenkins/workspace/_ap_toolchain_horizonrtd_v1.8.1g/src/plan/hbm_exec_plan.cpp, line 376
# Check failed: tmp_region.one_output_ptr != 0 (0 vs. 0)
/lib/adas/aarch64/track/libdnn.so(+0x3b3c24) [0x7f825a2c24]
/lib/adas/aarch64/track/libdnn.so(+0x127168) [0x7f82316168]
/lib/adas/aarch64/track/libdnn.so(+0x12726c) [0x7f8231626c]
/lib/adas/aarch64/track/libdnn.so(+0x131f68) [0x7f82320f68]
/lib/adas/aarch64/track/libdnn.so(+0x134e04) [0x7f82323e04]
/lib/adas/aarch64/track/libdnn.so(+0xaf924) [0x7f8229e924]
/lib/adas/aarch64/track/libdnn.so(+0xb6564) [0x7f822a5564]
/lib/adas/aarch64/track/libdnn.so(+0xb8820) [0x7f822a7820]
9: hbDNNInitializeFromFiles
地平线提供的YOLOv5s.onnx量化后的模型文件没有这个问题,加载模型的时候打印如下
[000:001] (configuration.cpp:147): Keros key init failed.
我现在用的模型是用yolov5 3.1版本代码,对common.py文件修改如下,对Conv层,将激活函数由默认的Hardswish替换为LeakyReLU,使训练出的模型结构和官网提供的yolov5s保持一致
对这个模型加载三次就失败了,你们提供的加载10不报错
你们了解模型占用较多的bpu内存的原因吗
您好,我们现在是在用 OE 1.16.2(虽然下的是1.16.2,但是很多文件都是前面的版本,同事说1.16.2提供的代码不完整,只给了基于前一个版本修改的部分,所以他需要一直用新版本代码覆盖上一个版本相同的部分。。。) 版本跑 yolov8s-det ,没有同时运行多个模型,也没有同时检测多个图片,跑起来后,有一段时间(时间不定)可以稳定正常运行,然后就会报这个错误,观察内存的话,进程占用内存会增加,然后继续稳定运行,长时间下来的话,占用内存是阶梯式增长。。。。
好的。您这边方便提供一下yolov5s的onnx和bin模型吗,我们这边分析一下呢。可以用百度网盘。
链接: 百度网盘-链接不存在 提取码: 4s8k
运行正常的话一般来说bpu内存都是够用的
std::vector<hbPackedDNNHandle_t> packed_dnn_handles;
packed_dnn_handles.resize(10);
int model_count = 0;
m_strModelFileName = “exp6_yolov5s_class10_best.bin”;
const char* pModelFileName = m_strModelFileName.data();
for(auto i = 0; i < 10; ++i)
HB_CHECK_RET_FALSE(hbDNNInitializeFromFiles(&packed_dnn_handles[i], &pModelFileName, 1)
, “hbDNNInitializeFromFiles failed.”);
您是想一次加载10次相同模型吗?使用需求是什么呢?加载一次就可以了。
我是想多线程去推理任务
所以本质上是想让一个模型同时能推理多张图片吗?可以编译时在yaml配置batch_size,但是在J3上这样的配置性能提升收益并不大。
j3板子上我们还跑了其他程序,类似一个L2系统,检测的对象是摄像头实时采集的图像,没办法同时推理,只用一个线程推理的话,从加载图像到出结果时间太长,显得视觉检测频率很低
