想在旭日X3上使用pyqt,使用pip命令安装失败,求教!!
使用官方提供的桌面系统,只修改了pip源,但是在执行【pip3 install pyqt5】时,无法正常安装,提示一下问题:
Looking in indexes: Simple Index
Collecting pyqt5
Downloading https://pypi.tuna.tsinghua.edu.cn/packages/5c/46/b4b6eae1e24d9432905ef1d4e7c28b6610e28252527cdc38f2a75997d8b5/PyQt5-5.15.9.tar.gz (3.2 MB)
|████████████████████████████████| 3.2 MB 1.2 MB/s
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing wheel metadata … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/tmp6ryn0sez prepare_metadata_for_build_wheel /tmp/tmpgbvk7uun
cwd: /tmp/pip-install-pqp3k53v/pyqt5
Complete output (31 lines):
File “/tmp/tmp6ryn0sez”, line 126, in prepare_metadata_for_build_wheel
hook = backend.prepare_metadata_for_build_wheel
AttributeError: module ‘sipbuild.api’ has no attribute ‘prepare_metadata_for_build_wheel’
During handling of the above exception, another exception occurred:
File “/tmp/tmp6ryn0sez”, line 280, in
main()
File “/tmp/tmp6ryn0sez”, line 263, in main
json_out[‘return_val’] = hook(**hook_input[‘kwargs’])
File “/tmp/tmp6ryn0sez”, line 130, in prepare_metadata_for_build_wheel
return _get_wheel_metadata_from_wheel(backend, metadata_directory,
File “/tmp/tmp6ryn0sez”, line 159, in _get_wheel_metadata_from_wheel
whl_basename = backend.build_wheel(metadata_directory, config_settings)
File “/tmp/pip-build-env-2nbkdrcc/overlay/lib/python3.8/site-packages/sipbuild/api.py”, line 46, in build_wheel
project = AbstractProject.bootstrap(‘wheel’,
File “/tmp/pip-build-env-2nbkdrcc/overlay/lib/python3.8/site-packages/sipbuild/abstract_project.py”, line 87, in bootstrap
project.setup(pyproject, tool, tool_description)
File “/tmp/pip-build-env-2nbkdrcc/overlay/lib/python3.8/site-packages/sipbuild/project.py”, line 586, in setup
self.apply_user_defaults(tool)
File “/tmp/pip-install-pqp3k53v/pyqt5/project.py”, line 68, in apply_user_defaults
super().apply_user_defaults(tool)
File “/tmp/pip-build-env-2nbkdrcc/overlay/lib/python3.8/site-packages/pyqtbuild/project.py”, line 70, in apply_user_defaults
File “/tmp/pip-build-env-2nbkdrcc/overlay/lib/python3.8/site-packages/sipbuild/project.py”, line 237, in apply_user_defaults
self.builder.apply_user_defaults(tool)
File “/tmp/pip-build-env-2nbkdrcc/overlay/lib/python3.8/site-packages/pyqtbuild/builder.py”, line 69, in apply_user_defaults
raise PyProjectOptionException(‘qmake’,
sipbuild.pyproject.PyProjectOptionException
ERROR: Command errored out with exit status 1: /usr/bin/python3 /tmp/tmp6ryn0sez prepare_metadata_for_build_wheel /tmp/tmpgbvk7uun Check the logs for full command output.
请问大佬们怎么解决? 或者推荐一下其他安装pyqt的方法,万分感谢!!
查看系统的python版文为3.8.10,也对应下载了一个安装包,使用【pip3 install PyQt5-5.14.1-5.14.1-cp35.cp36.cp37.cp38-abi3-manylinux2014_x86_64.whl】进行安装,提示【ERROR: PyQt5-5.14.1-5.14.1-cp35.cp36.cp37.cp38-abi3-manylinux2014_x86_64.whl is not a supported wheel on this platform.】,这个版本应该时能用的呀
你好,X86的软件无法在arm端使用的,需要使用arm端的源才可以 x86_64.whl
好的,我去找一下,感谢
