[2.514s] DEBUG:colcon:Command line arguments: [‘/usr/bin/colcon’, ‘build’, ‘–packages-select’, ‘dnn_node_sample’]
[2.515s] DEBUG:colcon:Parsed command line arguments: Namespace(allow_overriding=, ament_cmake_args=None, base_paths=[‘.’], build_base=‘build’, catkin_cmake_args=None, catkin_skip_building_tests=False, cmake_args=None, cmake_clean_cache=False, cmake_clean_first=False, cmake_force_configure=False, cmake_target=None, cmake_target_skip_unavailable=False, continue_on_error=False, event_handlers=None, executor=‘parallel’, ignore_user_meta=False, install_base=‘install’, log_base=None, log_level=None, main=<bound method BuildVerb.main of <colcon_core.verb.build.BuildVerb object at 0x7f9cc2f7f0>>, merge_install=False, metas=[‘./colcon.meta’], packages_above=None, packages_above_and_dependencies=None, packages_above_depth=None, packages_end=None, packages_ignore=None, packages_ignore_regex=None, packages_select=[‘dnn_node_sample’], packages_select_build_failed=False, packages_select_by_dep=None, packages_select_regex=None, packages_select_test_failures=False, packages_skip=None, packages_skip_build_finished=False, packages_skip_by_dep=None, packages_skip_regex=None, packages_skip_test_passed=False, packages_skip_up_to=None, packages_start=None, packages_up_to=None, packages_up_to_regex=None, parallel_workers=4, paths=None, symlink_install=False, test_result_base=None, verb_extension=<colcon_core.verb.build.BuildVerb object at 0x7f9cc2f7f0>, verb_name=‘build’, verb_parser=<colcon_defaults.argument_parser.defaults.DefaultArgumentsDecorator object at 0x7f9cc2fd60>)
[2.724s] Level 1:colcon.colcon_core.package_discovery:discover_packages(colcon_meta) check parameters
[2.725s] Level 1:colcon.colcon_core.package_discovery:discover_packages(recursive) check parameters
[2.725s] Level 1:colcon.colcon_core.package_discovery:discover_packages(ignore) check parameters
[2.726s] Level 1:colcon.colcon_core.package_discovery:discover_packages(path) check parameters
[2.726s] Level 1:colcon.colcon_core.package_discovery:discover_packages(colcon_meta) discover
[2.726s] Level 1:colcon.colcon_core.package_discovery:discover_packages(recursive) discover
[2.726s] INFO:colcon.colcon_core.package_discovery:Crawling recursively for packages in ‘/app/hobot_dnn/dnn_node_sample’
[2.727s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extensions [‘ignore’, ‘ignore_ament_install’]
[2.728s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extension ‘ignore’
[2.729s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extension ‘ignore_ament_install’
[2.729s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extensions [‘colcon_pkg’]
[2.730s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extension ‘colcon_pkg’
[2.730s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extensions [‘colcon_meta’]
[2.730s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extension ‘colcon_meta’
[2.731s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extensions [‘ros’]
[2.731s] Level 1:colcon.colcon_core.package_identification:_identify(.) by extension ‘ros’
[2.995s] DEBUG:colcon.colcon_core.package_identification:Package ‘.’ with type ‘ros.ament_cmake’ and name ‘dnn_node_sample’
[2.995s] Level 1:colcon.colcon_core.package_discovery:discover_packages(recursive) using defaults
[2.996s] Level 1:colcon.colcon_core.package_discovery:discover_packages(ignore) discover
[2.996s] Level 1:colcon.colcon_core.package_discovery:discover_packages(ignore) using defaults
[2.996s] Level 1:colcon.colcon_core.package_discovery:discover_packages(path) discover
[2.996s] Level 1:colcon.colcon_core.package_discovery:discover_packages(path) using defaults
[3.162s] Level 1:colcon.colcon_core.package_discovery:discover_packages(prefix_path) check parameters
[3.163s] Level 1:colcon.colcon_core.package_discovery:discover_packages(prefix_path) discover
[3.239s] DEBUG:colcon.colcon_installed_package_information.package_discovery:Found 364 installed packages in /opt/tros
[3.269s] DEBUG:colcon.colcon_installed_package_information.package_discovery:Found 17 installed packages in /userdata/dev_ws/install
[3.272s] Level 1:colcon.colcon_core.package_discovery:discover_packages(prefix_path) using defaults
[3.644s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘cmake_args’ from command line to ‘None’
[3.644s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘cmake_target’ from command line to ‘None’
[3.645s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘cmake_target_skip_unavailable’ from command line to ‘False’
[3.645s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘cmake_clean_cache’ from command line to ‘False’
[3.645s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘cmake_clean_first’ from command line to ‘False’
[3.645s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘cmake_force_configure’ from command line to ‘False’
[3.645s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘ament_cmake_args’ from command line to ‘None’
[3.645s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘catkin_cmake_args’ from command line to ‘None’
[3.646s] Level 5:colcon.colcon_core.verb:set package ‘dnn_node_sample’ build argument ‘catkin_skip_building_tests’ from command line to ‘False’
[3.646s] DEBUG:colcon.colcon_core.verb:Building package ‘dnn_node_sample’ with the following arguments: {‘ament_cmake_args’: None, ‘build_base’: ‘/app/hobot_dnn/dnn_node_sample/build/dnn_node_sample’, ‘catkin_cmake_args’: None, ‘catkin_skip_building_tests’: False, ‘cmake_args’: None, ‘cmake_clean_cache’: False, ‘cmake_clean_first’: False, ‘cmake_force_configure’: False, ‘cmake_target’: None, ‘cmake_target_skip_unavailable’: False, ‘install_base’: ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample’, ‘merge_install’: False, ‘path’: ‘/app/hobot_dnn/dnn_node_sample’, ‘symlink_install’: False, ‘test_result_base’: None}
[3.652s] INFO:colcon.colcon_core.executor:Executing jobs using ‘parallel’ executor
[3.680s] DEBUG:colcon.colcon_parallel_executor.executor.parallel:run_until_complete
[3.681s] INFO:colcon.colcon_ros.task.ament_cmake.build:Building ROS package in ‘/app/hobot_dnn/dnn_node_sample’ with build type ‘ament_cmake’
[3.682s] INFO:colcon.colcon_cmake.task.cmake.build:Building CMake package in ‘/app/hobot_dnn/dnn_node_sample’
[3.720s] INFO:colcon.colcon_core.plugin_system:Skipping extension ‘colcon_core.shell.bat’: Not used on non-Windows systems
[3.721s] INFO:colcon.colcon_core.shell:Skip shell extension ‘powershell’ for command environment: Not usable outside of PowerShell
[3.721s] DEBUG:colcon.colcon_core.shell:Skip shell extension ‘dsv’ for command environment
[3.838s] DEBUG:colcon.colcon_core.event_handler.log_command:Invoking command in ‘/app/hobot_dnn/dnn_node_sample/build/dnn_node_sample’: CMAKE_PREFIX_PATH=${CMAKE_PREFIX_PATH}:/userdata/dev_ws/install/originbot_linefollower:/userdata/dev_ws/install/originbot_demo /usr/bin/cmake --build /app/hobot_dnn/dnn_node_sample/build/dnn_node_sample – -j4 -l4
[4.197s] DEBUG:colcon.colcon_core.event_handler.log_command:Invoked command in ‘/app/hobot_dnn/dnn_node_sample/build/dnn_node_sample’ returned ‘0’: CMAKE_PREFIX_PATH=${CMAKE_PREFIX_PATH}:/userdata/dev_ws/install/originbot_linefollower:/userdata/dev_ws/install/originbot_demo /usr/bin/cmake --build /app/hobot_dnn/dnn_node_sample/build/dnn_node_sample – -j4 -l4
[4.380s] DEBUG:colcon.colcon_core.event_handler.log_command:Invoking command in ‘/app/hobot_dnn/dnn_node_sample/build/dnn_node_sample’: CMAKE_PREFIX_PATH=${CMAKE_PREFIX_PATH}:/userdata/dev_ws/install/originbot_linefollower:/userdata/dev_ws/install/originbot_demo /usr/bin/cmake --install /app/hobot_dnn/dnn_node_sample/build/dnn_node_sample
[4.448s] Level 1:colcon.colcon_core.environment:create_environment_scripts_only(dnn_node_sample)
[4.464s] DEBUG:colcon.colcon_core.event_handler.log_command:Invoked command in ‘/app/hobot_dnn/dnn_node_sample/build/dnn_node_sample’ returned ‘0’: CMAKE_PREFIX_PATH=${CMAKE_PREFIX_PATH}:/userdata/dev_ws/install/originbot_linefollower:/userdata/dev_ws/install/originbot_demo /usr/bin/cmake --install /app/hobot_dnn/dnn_node_sample/build/dnn_node_sample
[4.500s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample’ for CMake module files
[4.505s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample’ for CMake config files
[4.506s] Level 1:colcon.colcon_core.shell:create_environment_hook(‘dnn_node_sample’, ‘cmake_prefix_path’)
[4.520s] INFO:colcon.colcon_core.shell:Creating environment hook ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/hook/cmake_prefix_path.ps1’
[4.525s] INFO:colcon.colcon_core.shell:Creating environment descriptor ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/hook/cmake_prefix_path.dsv’
[4.530s] INFO:colcon.colcon_core.shell:Creating environment hook ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/hook/cmake_prefix_path.sh’
[4.538s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/lib’
[4.540s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/bin’
[4.541s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/lib/pkgconfig/dnn_node_sample.pc’
[4.542s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/lib/python3.8/site-packages’
[4.544s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/bin’
[4.560s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.ps1’
[4.568s] INFO:colcon.colcon_core.shell:Creating package descriptor ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.dsv’
[4.573s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.sh’
[4.580s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.bash’
[4.587s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.zsh’
[4.594s] Level 1:colcon.colcon_core.environment:create_file_with_runtime_dependencies(/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/colcon-core/packages/dnn_node_sample)
[4.717s] Level 1:colcon.colcon_core.environment:create_environment_scripts_only(dnn_node_sample)
[4.738s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample’ for CMake module files
[4.743s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample’ for CMake config files
[4.744s] Level 1:colcon.colcon_core.shell:create_environment_hook(‘dnn_node_sample’, ‘cmake_prefix_path’)
[4.759s] INFO:colcon.colcon_core.shell:Creating environment hook ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/hook/cmake_prefix_path.ps1’
[4.762s] INFO:colcon.colcon_core.shell:Creating environment descriptor ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/hook/cmake_prefix_path.dsv’
[4.765s] INFO:colcon.colcon_core.shell:Creating environment hook ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/hook/cmake_prefix_path.sh’
[4.769s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/lib’
[4.769s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/bin’
[4.770s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/lib/pkgconfig/dnn_node_sample.pc’
[4.771s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/lib/python3.8/site-packages’
[4.773s] Level 1:colcon.colcon_core.environment:checking ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/bin’
[4.785s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.ps1’
[4.788s] INFO:colcon.colcon_core.shell:Creating package descriptor ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.dsv’
[4.793s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.sh’
[4.796s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.bash’
[4.800s] INFO:colcon.colcon_core.shell:Creating package script ‘/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/dnn_node_sample/package.zsh’
[4.803s] Level 1:colcon.colcon_core.environment:create_file_with_runtime_dependencies(/app/hobot_dnn/dnn_node_sample/install/dnn_node_sample/share/colcon-core/packages/dnn_node_sample)
[4.805s] DEBUG:colcon.colcon_parallel_executor.executor.parallel:closing loop
[4.806s] DEBUG:colcon.colcon_parallel_executor.executor.parallel:loop closed
[4.807s] DEBUG:colcon.colcon_parallel_executor.executor.parallel:run_until_complete finished with ‘0’
[4.808s] DEBUG:colcon.colcon_core.event_reactor:joining thread
[4.844s] INFO:colcon.colcon_core.plugin_system:Skipping extension ‘colcon_notification.desktop_notification.notify_send’: Could not find ‘notify-send’
[4.844s] INFO:colcon.colcon_core.plugin_system:Skipping extension ‘colcon_notification.desktop_notification.terminal_notifier’: Not used on non-Darwin systems
[4.845s] INFO:colcon.colcon_core.plugin_system:Skipping extension ‘colcon_notification.desktop_notification.win32’: Not used on non-Windows systems
[4.845s] INFO:colcon.colcon_notification.desktop_notification:Sending desktop notification using ‘notify2’
[4.848s] DEBUG:colcon.colcon_notification.desktop_notification.notify2:Failed to initialize notify2: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Notifications was not provided by any .service files
[4.849s] DEBUG:colcon.colcon_core.event_reactor:joined thread
[4.861s] INFO:colcon.colcon_core.shell:Creating prefix script ‘/app/hobot_dnn/dnn_node_sample/install/local_setup.ps1’
[4.869s] INFO:colcon.colcon_core.shell:Creating prefix util module ‘/app/hobot_dnn/dnn_node_sample/install/_local_setup_util_ps1.py’
[4.880s] INFO:colcon.colcon_core.shell:Creating prefix chain script ‘/app/hobot_dnn/dnn_node_sample/install/setup.ps1’
[4.893s] INFO:colcon.colcon_core.shell:Creating prefix script ‘/app/hobot_dnn/dnn_node_sample/install/local_setup.sh’
[4.897s] INFO:colcon.colcon_core.shell:Creating prefix util module ‘/app/hobot_dnn/dnn_node_sample/install/_local_setup_util_sh.py’
[4.900s] INFO:colcon.colcon_core.shell:Creating prefix chain script ‘/app/hobot_dnn/dnn_node_sample/install/setup.sh’
[4.914s] INFO:colcon.colcon_core.shell:Creating prefix script ‘/app/hobot_dnn/dnn_node_sample/install/local_setup.bash’
[4.917s] INFO:colcon.colcon_core.shell:Creating prefix chain script ‘/app/hobot_dnn/dnn_node_sample/install/setup.bash’
[4.930s] INFO:colcon.colcon_core.shell:Creating prefix script ‘/app/hobot_dnn/dnn_node_sample/install/local_setup.zsh’
[4.934s] INFO:colcon.colcon_core.shell:Creating prefix chain script ‘/app/hobot_dnn/dnn_node_sample/install/setup.zsh’
