C++代码,模型部署问题
1.芯片型号:XJ3
2.天工开物开发包OpenExplorer版本:horizon_xj3_open_explorer_v1.12.7_20220520
3.问题定位:板端部署
4.问题具体描述
报错信息:
[HBRT] set log level as 0. version = 3.13.31
ioctl read error, ret = -1 error = 5
keros_i2c_read failed
ioctl write error, ret = -1 error = 5
keros_i2c_write failed
[DNN] (/home/users/daofu.zhang/release-sdk/horizonrtd/src/util/keros_util.cpp: 98) keros_authentication failed, ret = 0
[DNN] (/home/users/daofu.zhang/release-sdk/horizonrtd/src/util/configuration.cpp: 159) Keros key init failed.
[DNN] Runtime version = 1.9.3_(3.13.31 HBRT)
input_memSize = 1057
output_memSize = 0
[DNN] (/home/users/daofu.zhang/release-sdk/horizonrtd/src/hb_sys.cpp: 58) The alloced memory size should be greater than 0
hbSysAllocCachedMem failed, error code:-6000129output_memSize size = 0
hbSysAllocCachedMem failed, error code:-6000129output_memSize size = -1630512184
[DNN] (/home/users/daofu.zhang/release-sdk/horizonrtd/src/hb_sys.cpp: 62) The alloced memory size should be less than 2^31 - 4096
hbSysAllocCachedMem failed, error code:-6000129ModelInit success!
使用C++代码推理时,hbDNNGetInputTensorProperties接口返回的alignedByteSize不正确是什么原因导致的。
从报错信息看,是分配的内存不满足大于0的要求。
建议1:使用hrt_model_exec工具能否正常推理模型?
建议2:看到你使用的OE与docker版本都比较老旧,建议更新OE与docker的版本进行再次尝试~获取链接:https://developer.horizon.cc/forumDetail/136488103547258769,X3建议使用OE2.6.2,J3建议使用OE1.16.2c
代码参照ddk\samples\ai_toolchain\horizon_runtime_sample\code\00_quick_start\src\run_mobileNetV1_224x224.cc文件,如下:-
hbPackedDNNHandle_t packed_dnn_handle;
hbDNNHandle_t dnn_handle;
const char** model_name_list;
int model_count = 0;
// Step1: get model handle
HB_CHECK_SUCCESS(
hbDNNInitializeFromFiles(&packed_dnn_handle, &modelFile, 1),
“hbDNNInitializeFromFiles failed”);
HB_CHECK_SUCCESS(hbDNNGetModelNameList(
&model_name_list, &model_count, packed_dnn_handle),
“hbDNNGetModelNameList failed”);
HB_CHECK_SUCCESS(
hbDNNGetModelHandle(&dnn_handle, packed_dnn_handle, model_name_list[0]),
“hbDNNGetModelHandle failed”);
std::vector input_tensors;
std::vector output_tensors;
int input_count = 0;
int output_count = 0;
// Step2: prepare input and output tensor
HB_CHECK_SUCCESS(hbDNNGetInputCount(&input_count, dnn_handle),
“hbDNNGetInputCount failed”);
HB_CHECK_SUCCESS(hbDNNGetOutputCount(&output_count, dnn_handle),
input_tensors.resize(input_count);
output_tensors.resize(output_count);
PrepareTensor(input_tensors.data(), output_tensors.data(), dnn_handle);
int PrepareTensor(hbDNNTensor* input_tensor, hbDNNTensor* output_tensor, hbDNNHandle_t dnn_handle) {
hbDNNGetInputCount(&input_count, dnn_handle);
hbDNNGetOutputCount(&output_count, dnn_handle);
/** Tips:
* For input memory size:
* * input_memSize = input[i].properties.alignedByteSize
* For output memory size:
* * output_memSize = output[i].properties.alignedByteSize
hbDNNTensor* input = input_tensor;
HB_CHECK_SUCCESS(
hbDNNGetInputTensorProperties(&input[i].properties, dnn_handle, i),
“hbDNNGetInputTensorProperties failed”);
int input_memSize = input[i].properties.alignedByteSize;
printf(“input_memSize = %d\n”, input_memSize);
HB_CHECK_SUCCESS(hbSysAllocCachedMem(&input[i].sysMem[0], input_memSize),
“hbSysAllocCachedMem failed”);
/** Tips:
* For input tensor, aligned shape should always be equal to the real
* shape of the user’s data. If you are going to set your input data with
* padding, this step is not necessary.
input[i].properties.alignedShape = input[i].properties.validShape;
hbDNNTensor* output = output_tensor;
HB_CHECK_SUCCESS(
hbDNNGetOutputTensorProperties(&output[i].properties, dnn_handle, i),
“hbDNNGetOutputTensorProperties failed”);
int output_memSize = output[i].properties.alignedByteSize;
printf(“output_memSize size = %d\n”, output_memSize);
HB_CHECK_SUCCESS(hbSysAllocCachedMem(&output[i].sysMem[0], output_memSize),
return 0;
使用的OE包和编译环境如上图
关于该示例,欢迎参考教程:https://developer.horizon.cc/forumDetail/174216099150358528,以及对应视频:https://www.bilibili.com/video/BV1Xh411P73Z/?p=11&vd\_source=fceccd8a9a5f97cd8f38261a3c288567
我把例程中run_mobileNetV1_224x224.cc文件中后处理部分注释掉,导入自己转换后的模型文件是可以正常推理的,但是我将相同的代码复制出来到自己的工程内就不行,请问有可能是什么原因?
编译环境是相同的。
这个到自己的工程里,变量就很多了,建议认真比对一下代码层面的差异(还有就是,希望考虑一下我上面提的两条建议哈)
好的,谢谢,我再去检查一下。
