地平线deeplabv3+ 参考算法如何实现resize和argmax算子的BPU加速?
1. 前言
为了保证模型输出的精度,地平线的实例分割参考算法deeplabv3+在部署时,将模型尾部的resize和argmax放在了CPU的后处理代码中进行计算,但是这样也带来了一些问题,比如会占用比较大的CPU资源,尤其是大尺寸特征图的argmax计算。事实上,地平线J5的BPU也是支持resize和argmax算子的,本帖将介绍将resize和argmax计算融入到deeplabv3+模型中进行BPU加速的教程。
2. 代码修改流程
2.1 环境部署
首先访问地平线开发者社区的OpenExplorer算法工具链版本发布帖,获取GPU docker和OE开发包,然后参考用户手册环境部署章节完成环境的部署。
2.2 代码修改流程
Step1:-
在Docker环境下,进入到/usr/loacal/lib/python3.8/dist-packages/hat/models/task_modules/deeplab/head.py目录下,修改Deeplabv3plusHead类的代码,如下所示:
def __init__(
        self,
        in_channels: int,
        c1_index: int,
        c1_in_channels: int,
        feat_channels: int,
        num_classes: int,
        dilations: List[int],
        num_repeats: List[int],
        argmax_output: Optional[bool] = False,
        dequant_output: Optional[bool] = True,
        int8_output: Optional[bool] = True,
        bn_kwargs: Optional[Dict] = None,
        dropout_ratio: Optional[float] = 0.1,
        upsample_output_scale: Optional[int] = None,
        upsample_decode_scale: Optional[int] = 4,
        bias=True,
        #定义resize2算子,
        #将Deeplabv3plusHead输出上采样8倍至1024x2048
        self.resize2 = hnn.Interpolate(
               #resize到原图尺寸
                scale_factor=8,
                align_corners=None,
                recompute_scale_factor=True,
    def forward(self, inputs):
        x = inputs[-1]
        c1_input = inputs[self.c1_index]
        x = self.aspp(x)
        x = self.seg_convs([c1_input, x])
        if self.dropout is not None:
            x = self.dropout(x)
        seg_pred1 = self.cls_seg(x)
        #增加argmax输出分支
        seg_pred = self.resize2(seg_pred1)
        seg_pred = seg_pred.argmax(dim=1,keepdim=True)
        seg_pred1 = self.dequant(seg_pred1)
        return seg_pred,seg_pred1
Step2:-
在Docker环境下,进入到/usr/loacal/lib/python3.8/dist-packages/hat/models/structures/encoder_decoder.py 目录下,修改_post_process函数的代码,如下所示:
    @fx_wrap()
    def _post_process(self, gts, preds, features):
        if self.training:
            #改动1:
            target = self.target(gts, preds[1])
            decode_loss = self.loss(**target)
            aux_losses = OrderedDict()
            if self.auxiliary_heads is not None:
                features = [
                    i.as_subclass(torch.Tensor)
                    if isinstance(i, QTensor)
                    else i
                    for i in features
                for head, target_mod, loss in zip(
                    self.auxiliary_heads,
                    self.auxiliary_target,
                    self.auxiliary_loss,
                    preds = head(features)
                    target = target_mod(gts, preds)
                    aux_loss = loss(**target)
                    aux_losses.update(aux_loss)
            return {**decode_loss, **aux_losses}
            #改动2:
            #因为已经在self.decode_head里做了resize和argmax,
            #所以注释掉self.decode
            # if self.decode is not None:
            #   preds = self.decode(preds)
            preds=preds[0]
            if self.with_target is False:
                return preds
            return preds, target
    def forward(self, data: dict):
        image = data["img"]
        gts = data.get("gt_seg", None)
        features = self.backbone(image)
        if self.neck is not None:
            features = self.neck(features)
        preds= self.decode_head(features)
        print("decode_head out in enc-dec:",preds[0].shape,preds[1].shape)
        return self._post_process(gts, preds, features)
Step3:-
进入到OE开发包的ddk/samples/ai_toolchain/horizon_model_train_sample/scripts/configs/segmentation目录下,-
修改config文件中的model和deploy_model字段,如下所示:
model = dict(
    type="EncoderDecoder",
    backbone=dict(
        type="efficientnet",
        bn_kwargs=bn_kwargs,
        model_type="b0",
        num_classes=1000,
        include_top=False,
        activation="relu",
        use_se_block=False,
        blocks_args=SEG_BLOCKS_ARGS,
    decode_head=dict(
        type="Deeplabv3plusHead",
        in_channels=320,
        feat_channels=128,
        num_classes=19,
        c1_index=2,
        dilations=[1, 2, 4, 4],
        num_repeats=[1, 1, 1, 2],
        c1_in_channels=40,
        argmax_output=False,
        dequant_output=True,
        #设置conv输出为int8
        #部署模型尾部由conv改为了resize和argmax,conv不再支持int32高精度输出
        int8_output=True,
        dropout_ratio=0.1,
        upsample_decode_scale=4,
        upsample_output_scale=None,
deploy_model = dict(
    backbone=dict(
        model_type="b0",
        num_classes=1000,
        include_top=False,
        activation="relu",
        use_se_block=False,
    decode_head=dict(
        in_channels=320,
        feat_channels=128,
        num_classes=19,
        c1_index=2,
        c1_in_channels=40,
        #修改conv输出为int8
        int8_output=True,
        dropout_ratio=0.1,
Step4:-
修改config文件中的update_val_metric函数:
def update_val_metric(metrics, batch, model_outs):
    # Convert one hot to index
    target: Tensor = batch["gt_seg"]
    preds= model_outs
    #resize&argmax后的模型输出shape:1x1x1024x2048,
    #target shape:1x1024x2048
    #所以这里增加了unsqueeze操作
    for metric in metrics:
        metric.update(target.unsqueeze(1), preds)
至此,代码修改完成。-
然后,我们按照地平线的算法工具链用户手册完成deeplabv3+参考算法的训练和编译后,生成的板端部署hbm模型中的resize和argmax算子就可以实现在BPU上的加速了。
你好,大佬,按照这个思路修改的,qat精度比float精度掉了5个点
