x3 交叉编译环境搭建,报错mkdosfs: unable to open /dev/loop3p1: No such file or directory
  1. 系统软件版本: 不涉及
  2. 问题涉及的技术领域:交叉编译环境docker 环境, docker 中安装ubuntu 20.04
  3. 问题描述:
  4. 按照官网指导搭建交叉编译环境时报错
  5. https://developer.horizon.cc/documents_rdk/linux_development/environment_build
  6. 执行步骤如下
  7. cd rdk-gen
  8. sudo ./pack_image.sh
  9. 执行上述命令是报错:mkdosfs: unable to open /dev/loop3p1: No such file or directory
  10. 求助上述问题如何解决?
  11. 复现概率:必现
  12. 提供必要的问题日志:
  13. (Reading database … 152094 files and directories currently installed.)
  14. Preparing to unpack …/tros-xrrobot-msgs_2.0.0-20230901172822_arm64.deb …
  15. Unpacking tros-xrrobot-msgs (2.0.0-20230901172822) …
  16. Setting up tros-xrrobot-msgs (2.0.0-20230901172822) …
  17. ###### Installed tros-xrrobot-msgs_2.0.0-20230901172822_arm64.deb ######
  18. ###### Installing tros-xrrobot_2.0.0-20230901172816_arm64.deb ######
  19. Selecting previously unselected package tros-xrrobot.
  20. (Reading database … 152217 files and directories currently installed.)
  21. Preparing to unpack …/tros-xrrobot_2.0.0-20230901172816_arm64.deb …
  22. Unpacking tros-xrrobot (2.0.0-20230901172816) …
  23. Setting up tros-xrrobot (2.0.0-20230901172816) …
  24. ###### Installed tros-xrrobot_2.0.0-20230901172816_arm64.deb ######
  25. ###### Installing tros_2.1.3-20240307165139_arm64.deb ######
  26. Selecting previously unselected package tros.
  27. (Reading database … 152248 files and directories currently installed.)
  28. Preparing to unpack …/tros_2.1.3-20240307165139_arm64.deb …
  29. Unpacking tros (2.1.3-20240307165139) …
  30. Setting up tros (2.1.3-20240307165139) …
  31. ###### Installed tros_2.1.3-20240307165139_arm64.deb ######
  32. Install hobot packages is finished
  33. Creating loop device…
  34. mkdosfs: unable to open /dev/loop3p1: No such file or directory
  35. root@CP:/home/x3/rdk-gen#
  36. 软件上是否有做自定义修改:无
您好,我看您另一个帖子的问题已经解决了,请问这个问题是否也有解决?
我在RDK X5 上也遇到类似的问题.请问如何解决呢?
Setting up tros-humble-websocket (2.3.2-jammy.20250425.113230) …
[INFO] Installed tros-humble-websocket_2.3.2-jammy.20250425.113230_arm64.deb
[INFO] Installing tros-humble_2.3.3-jammy.20250428.105957_arm64.deb
Selecting previously unselected package tros-humble.
(Reading database … 180333 files and directories currently installed.)
Preparing to unpack …/tros-humble_2.3.3-jammy.20250428.105957_arm64.deb …
Unpacking tros-humble (2.3.3-jammy.20250428.105957) …
Setting up tros-humble (2.3.3-jammy.20250428.105957) …
[INFO] Installed tros-humble_2.3.3-jammy.20250428.105957_arm64.deb
mkdosfs: unable to open /dev/loop0p1: No such file or directory
root@6506b0d0499d:~/D-Robotics/x5#
