USB双目深度识别算法无法复现
在资料中明确写了支持USB摄像头 但是我查遍了所有的启动文件 也没发现有配置usb摄像头的文件 全是mipi的教程
日志如下 ros2 launch mipi_cam mipi_cam_dual_channel.launch.py \
mipi_image_width:=1280 mipi_image_height:=640
[INFO] [launch]: All log files can be found below /home/sunrise/.ros/log/2025-02-27-15-03-50-764148-ubuntu-10221
[INFO] [mipi_cam-1]: process started with pid [10222]
[mipi_cam-1] [WARN] [1740639832.176521181] [mipi_node]: dual_combine value: 1
[mipi_cam-1] [WARN] [1740639832.176738596] [mipi_node]: frame_ts_type value: sensor
[mipi_cam-1] [WARN] [1740639832.186656594] [mipi_factory]: board_type X5_RDK
[mipi_cam-1]
[mipi_cam-1] [WARN] [1740639832.187870880] [mipi_cam]: this board support mipi:
[mipi_cam-1] [WARN] [1740639832.188110879] [mipi_cam]: host 0
[mipi_cam-1] [WARN] [1740639832.188161629] [mipi_cam]: host 2
[mipi_cam-1] [WARN] [1740639832.188419586] [mipi_cam]: cal_file:/opt/tros/humble/lib/mipi_cam/config/calib_params.yaml
[mipi_cam-1] \u65e0\u6cd5\u6253\u5f00\u6807\u5b9a\u53c2\u6570\u6587\u4ef6\uff01
[mipi_cam-1] [ERROR] [1740639836.216758752] [mipi_cam]: [init]->cap capture init failture.
[mipi_cam-1]
[mipi_cam-1] [ERROR] [1740639836.217020959] [mipi_node]: [init]->mipinode init failure.
[mipi_cam-1]
[mipi_cam-1] [WARN] [1740639836.219054325] [mipi_cam]: cal_file:/opt/tros/humble/lib/mipi_cam/config/calib_params.yaml
[mipi_cam-1] [WARN] [1740639836.219183699] [mipi_node]: get camera calibration parameters failed
[mipi_cam-1] what(): could not create publisher: rcl node’s context is invalid, at ./src/rcl/node.c:428
[mipi_cam-1] mipi mclk is not configed.
[mipi_cam-1] Searching camera sensor on device: /proc/device-tree/soc/cam/vcon@0 mclk_is_not_configed: 1
[mipi_cam-1] i2c bus: 6 mipi rx phy: 0
[mipi_cam-1] WARN: Sensor Name: sc1330t, Expected Chip ID: 0xCA18, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: irs2875-tof, Expected Chip ID: 0x2875, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: sc230ai-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: sc132gs-1280p, Expected Chip ID: 0x132, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: sc035hgs, Expected Chip ID: 0x35, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: ov5640, Expected Chip ID: 0x5640, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: ov5647, Expected Chip ID: 0x5647, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: f37, Expected Chip ID: 0xF37, Actual Chip ID Read: 0x00
[mipi_cam-1] INFO: vp_sensor_detect_2 Support sensor index:0, sensor_name:imx219-30fps on mipi rx csi 0, i2c addr 0x10, config_file:linear_1920x1080_raw10_30fps_2lane.c
[mipi_cam-1] Searching camera sensor on device: /proc/device-tree/soc/cam/vcon@2 mclk_is_not_configed: 1
[mipi_cam-1] i2c bus: 4 mipi rx phy: 2
[mipi_cam-1] WARN: Sensor Name: imx219-30fps, Expected Chip ID: 0x219, Actual Chip ID Read: 0x00
[mipi_cam-1] WARN: Sensor Name: imx415-30fps, Expected Chip ID: 0x03, Actual Chip ID Read: 0x00
[ERROR] [mipi_cam-1]: process has died [pid 10222, exit code -6, cmd ‘/opt/tros/humble/lib/mipi_cam/mipi_cam --ros-args --log-level warn --ros-args --params-file /tmp/launch_params_l9pynmyz --params-file /tmp/launch_params_4mamlf7_ --params-file /tmp/launch_params_1q36k4wn --params-file /tmp/launch_params_5xwril69 --params-file /tmp/launch_params_ug1lht_e --params-file /tmp/launch_params_395no2at --params-file /tmp/launch_params_58kk9093 --params-file /tmp/launch_params_fwo953d8 --params-file /tmp/launch_params_jjbfhk48 --params-file /tmp/launch_params_883o1uwv --params-file /tmp/launch_params_ha5tyywp --params-file /tmp/launch_params_8r6rprz3 --params-file /tmp/launch_params_i5ptgk_u --params-file /tmp/launch_params_n5xzwoff --params-file /tmp/launch_params_hm0agcwr --params-file /tmp/launch_params_sw8_4xde’].
sunrise@ubuntu:~$
社区求助贴发帖建议-
基础信息
1. 板卡型号及板卡外观图片
3. 问题涉及的技术领域-
4. 问题描述:-
- 复现概率:必现、高、中、低,并描述大致的概率数值
- 搜索一下论坛是否有相关的案例
- 提供必要的问题日志
TROS 问题基础排查
确保您的tros软件包都是最新的:一些问题在新版本中已经被修复,在apt update确保有地瓜的apt源“archive.d-robotics.cc”后进行apt upgrade。在提问时也请使用apt list | grep tros*apt show tros*命令提供您的软件包版本。
算法工具链 问题基础排查-
你好,提问请附上您的转化环境的horizon_nn(pip list | grep horizon)包版本,Python(py38/py310/py312)版本,onnx模型,yaml配置文件,编译使用命令,hb_mapper*.log等相关文件。很多问题在一两年前就已经解决,1.0.0的Docker的环境和手册入门章节安装conda中的环境都比较古老,请参考对应的OpenExplore发布帖子,下载对应的最新的Docker和OpenExplore包。-
社区算法资源(Open Explore)-
RDK X3 算法工具链社区手册:https://developer.d-robotics.cc/api/v1/fileData/horizon\_xj3\_open\_explorer\_cn\_doc/index.html-
RDK Ultra 算法工具链社区手册:https://developer.d-robotics.cc/api/v1/fileData/horizon\_j5\_open\_explorer\_cn\_doc/index.html-
RDK X5 算法工具链社区手册:https://developer.d-robotics.cc/api/v1/fileData/x5\_doc-v126cn/index.html-
RDK X5 OpenExplore 产品发布:https://developer.d-robotics.cc/forumDetail/251934919646096384-
你好,已收到您的板卡信息,请再按照发帖规范补充以下信息,用于排查双目算法包的版本:-
你好,已收到您的问题,请先按照发帖规范补充板卡信息
rdk x5
