用户您好,请详细描述您所遇到的问题:-
基础信息
1. 板卡型号及板卡外观图片
RDK X5
2. 系统软件版本:3.1.1
3. 问题涉及的技术领域-
驱动树莓派官方HQ Camera imx477
4. 问题描述:-
- 复现概率:必现
官方号称支持imx477摄像头,于是我购买了树莓派官方HQ Camera,它是imx477芯片,刚好也是mipi接口的,HQ Camera的接口是宽的排线,但是树莓派官方有转接线,刚好转成这种小间距引脚的接口。RDK X5的mipi摄像头接口貌似和树莓派5的一样,我接上去,然后运行官方mipi_camera.py 例程,识别不了。摄像头照片如下:-
sunrise@ubuntu:~$ cd /app/pydev_demo/03_mipi_camera_sample/
sunrise@ubuntu:/app/pydev_demo/03_mipi_camera_sample$ sudo python3 mipi_camera.py
1920x1200
1920x1080
1680x1050
1600x1200
1600x900
1366x768
1280x1024
1280x800
1280x720
1024x768
800x600
720x576
720x480
640x480
Resolution 1920x1080 exists in the list.
[BPU_PLAT]BPU Platform Version(1.3.6)!
[A][DNN][packed_model.cpp:247][Model](2025-02-10,19:22:34.150.411) [HorizonRT] The model builder version = 1.23.5
[W][DNN]bpu_model_info.cpp:491][Version](2025-02-10,19:22:34.255.275) Model: fcos_efficientnetb0_512x512_nv12. Inconsistency between the hbrt library version 3.15.55.0 and the model build version 3.15.47.0 detected, in order to ensure correct model results, it is recommended to use compilation tools and the BPU SDK from the same OpenExplorer package.
-– model input properties —
tensor type: NV12
data type: uint8
layout: NCHW
shape: (1, 3, 512, 512)
-– model output properties —
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 64, 64, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 32, 32, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 16, 16, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 8, 8, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 4, 4, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 64, 64, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 32, 32, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 16, 16, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 8, 8, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 4, 4, 4)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 64, 64, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 32, 32, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 16, 16, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 8, 8, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 4, 4, 1)
set camera fps: -1,width: 1920,height: 1080
Camera 0:
i2c_bus: 6
mipi_host: 0
Camera 1:
i2c_bus: 4
mipi_host: 2
Camera 2:
i2c_bus: 0
mipi_host: 0
Camera 3:
i2c_bus: 0
mipi_host: 0
[INFO] board_id is 302, so skip csi test for index 1 and index 3
mipi mclk is not configed.
WARN: Sensor Name: sc035hgs, Expected Chip ID: 0x35, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx477-2016x1520-40fps, Expected Chip ID: 0x477, Actual Chip ID Read: 0x00
Searching camera sensor on device: /proc/device-tree/soc/cam/vcon@2 i2c bus: 4 mipi rx phy: 2
2025/02/10 19:22:42.479 ERROR [CamInitParam][0258]No camera sensor found, please check whether the camera connection or video_idx is correct.
2025/02/10 19:22:42.479 ERROR [OpenCamera][0410]CamInitParam failed error(-1)
X11 is available, using EGL for rendering.
2025/02/10 19:22:42.582 ERROR [GetImageFrame][0564]get chn from 512x512 failed
File “/app/pydev_demo/03_mipi_camera_sample/mipi_camera.py”, line 400, in
TypeError: a bytes-like object is required, not ‘NoneType’
