RDK工作人员,-
您好,之前在技术交流群,说是量产的时候可以把BPU的使用率跑到80到90,但是我现在只是用了两个线程,他基本上就是90以上,还有100,我还使用了下面的指令让CPU BPU达到最佳的状态
# CPU: 1.8Ghz
sudo bash -c "echo 1 > /sys/devices/system/cpu/cpufreq/boost"
# Performance Mode
# BPU: 1.2GHz
echo 1200000000 > /sys/kernel/debug/clk/bpu_mclk_2x_clk/clk_rate
请问量产的时候可以这样吗?我是做摄像头算法的,这样可以一直跑吗?-
谢谢~
1. 板卡型号及板卡外观图片
RDKX5
2. 系统软件版本: 提供 sudo cat /etc/version
命令和 sudo rdkos_info
命令的返回结果
root@ubuntu:~/cqy/RDK_Test# sudo cat /etc/version
3.1.0
root@ubuntu:~/cqy/RDK_Test# sudo rdkos_info
================ RDK System Information Collection ================
[Hardware Model]:
D-Robotics RDK X5 V1.0 (Board Id = 302)
[CPU And BPU Status]:
temperature-->
DDR : 66.5 (C)
BPU : 66.5 (C)
CPU : 66.5 (C)
cpu frequency-->
min(M) cur(M) max(M)
cpu0: 300 1800 1800
cpu1: 300 1800 1800
cpu2: 300 1800 1800
cpu3: 300 1800 1800
cpu4: 300 1800 1800
cpu5: 300 1800 1800
cpu6: 300 1800 1800
cpu7: 300 1800 1800
bpu status information---->
min(M) cur(M) max(M) ratio
bpu0: 500 1200 1000 0
ddr: 266 4266 4266
gc8000: 200 1000 1000
[Total Memory]: 6.9Gi
[Used Memory]: 1.5Gi
[Free Memory]: 1.9Gi
[ION Memory Size]: 128MB
[ION Reserved Memory Size]: 320MB
[ION Carveout Memory Size]: 320MB
[RDK OS Version]:
3.1.0
[RDK Kernel Version]:
Linux ubuntu 6.1.83 #2 SMP PREEMPT Fri Nov 22 11:51:26 CST 2024 aarch64 aarch64 aarch64 GNU/Linux
[RDK Miniboot Version]:
U-Boot 2022.10-g505104e8-dirty (Sep 26 2024 - 15:01:37 +0800)
[RDK Packages List]:
hobot-audio-config/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-boot/unknown 3.0.2-20250211004929 arm64 [upgradable from: 3.0.2-20241122121958]
hobot-camera/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-configs/unknown 3.0.1-20250115152435 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-display/unknown,now 3.0.0-20241018162911 arm64 [installed]
hobot-dnn/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20240919231504]
hobot-dtb/unknown 3.0.2-20250115150713 arm64 [upgradable from: 3.0.2-20241122121958]
hobot-io-samples/unknown 3.0.0-20250115150941 arm64 [upgradable from: 3.0.0-20240919231504]
hobot-io/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-kernel-headers/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-miniboot/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122142025]
hobot-models-basic/unknown,now 1.1.3 arm64 [installed]
hobot-multimedia-dev/unknown 3.0.2-20250110154647 arm64 [upgradable from: 3.0.2-20241122121958]
hobot-multimedia-samples/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-multimedia/unknown 3.0.2-20250110154647 arm64 [upgradable from: 3.0.2-20241122121958]
hobot-sp-samples/unknown 3.0.1-20250115150853 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-spdev/unknown 3.0.4-20250110154647 arm64 [upgradable from: 3.0.4-20241122121958]
hobot-utils/unknown 3.0.1-20250110154647 arm64 [upgradable from: 3.0.1-20241122121958]
hobot-wifi/unknown,now 3.0.0-20240919231504 arm64 [installed]
tros-humble-ai-msgs/unknown 2.0.1-jammy.20241225.032050 arm64 [upgradable from: 2.0.1-jammy.20241120.052137]
tros-humble-audio-control/unknown 2.0.1-jammy.20241225.031153 arm64
tros-humble-audio-msg/unknown 2.0.0-jammy.20241225.030541 arm64 [upgradable from: 2.0.0-jammy.20241120.051443]
tros-humble-audio-tracking/unknown 2.1.0-jammy.20241225.032437 arm64
tros-humble-base/unknown 2.3.2-jammy.20241225.041806 arm64 [upgradable from: 2.3.1-jammy.20241120.053851]
tros-humble-body-tracking/unknown 2.1.1-jammy.20241225.040923 arm64 [upgradable from: 2.1.1-jammy.20241120.070103]
tros-humble-chatbot/unknown 0.1.0-20240822101628 arm64
tros-humble-clip-encode-image/unknown 0.2.0-jammy.20241225.032737 arm64 [upgradable from: 0.2.0-jammy.20241120.052639]
tros-humble-clip-encode-text/unknown 0.2.0-jammy.20241225.024337 arm64 [upgradable from: 0.2.0-jammy.20241120.045801]
tros-humble-clip-manage/unknown 0.2.0-jammy.20241225.024351 arm64 [upgradable from: 0.2.0-jammy.20241120.045819]
tros-humble-clip-msgs/unknown 0.2.0-jammy.20241225.024229 arm64 [upgradable from: 0.2.0-jammy.20241120.045654]
tros-humble-dnn-benchmark-example/unknown 2.4.0-jammy.20241225.023457 arm64 [upgradable from: 2.4.0-jammy.20241120.045119]
tros-humble-dnn-node-example/unknown 2.4.1-jammy.20241225.035700 arm64 [upgradable from: 2.4.1-jammy.20241120.120344]
tros-humble-dnn-node-sample/unknown 2.3.2-jammy.20241225.035939 arm64 [upgradable from: 2.3.2-jammy.20241120.065131]
tros-humble-dnn-node/unknown 2.4.2-jammy.20241225.023147 arm64 [upgradable from: 2.4.1-jammy.20241120.115729]
tros-humble-elevation-net/unknown 2.2.1-jammy.20241225.034317 arm64 [upgradable from: 2.2.1-jammy.20241120.063514]
tros-humble-face-age-detection/unknown 2.3.1-jammy.20241225.033025 arm64 [upgradable from: 2.3.1-jammy.20241120.052928]
tros-humble-face-landmarks-detection/unknown 2.3.1-jammy.20241225.033459 arm64 [upgradable from: 2.3.1-jammy.20241120.053402]
tros-humble-first-node/unknown 0.0.0-20240822101706 arm64
tros-humble-gesture-control/unknown 2.1.0-jammy.20241225.041130 arm64 [upgradable from: 2.1.0-jammy.20241120.070312]
tros-humble-hand-gesture-detection/unknown 2.4.1-jammy.20241225.040702 arm64 [upgradable from: 2.4.1-jammy.20241120.065842]
tros-humble-hand-lmk-detection/unknown 2.4.1-jammy.20241225.040439 arm64 [upgradable from: 2.4.1-jammy.20241120.065619]
tros-humble-hbm-img-msgs/unknown 2.0.0-jammy.20241225.031409 arm64 [upgradable from: 2.0.0-jammy.20241120.051644]
tros-humble-hobot-arm/unknown 2.0.0-20240822101204 arm64
tros-humble-hobot-audio/unknown 2.3.2-jammy.20241225.030656 arm64
tros-humble-hobot-cartographer/unknown 0.0.1-20240822101611 arm64
tros-humble-hobot-chatbot/unknown 2.0.1-jammy.20241225.035416 arm64
tros-humble-hobot-codec/unknown 2.3.2-jammy.20241225.035052 arm64 [upgradable from: 2.3.1-jammy.20241120.064245]
tros-humble-hobot-cv/unknown 2.3.0-jammy.20241225.025952 arm64 [upgradable from: 2.3.0-jammy.20241120.051029]
tros-humble-hobot-dosod/unknown 0.1.0-jammy.20250108.034233 arm64
tros-humble-hobot-falldown-detection/unknown 2.0.0-jammy.20241225.040324 arm64 [upgradable from: 2.0.0-jammy.20241120.065505]
tros-humble-hobot-hdmi/unknown,unknown 2.4.2-jammy.20241127.083620 arm64 [upgradable from: 2.4.2-jammy.20241120.064045]
tros-humble-hobot-image-publisher/unknown 2.2.1-jammy.20241225.035542 arm64 [upgradable from: 2.2.1-jammy.20241120.064734]
tros-humble-hobot-llm/unknown 2.2.0-jammy.20241225.023654 arm64
tros-humble-hobot-mot/unknown 2.0.2-jammy.20241225.024808 arm64 [upgradable from: 2.0.2-jammy.20241120.050235]
tros-humble-hobot-rtsp-client/unknown 1.0.1-jammy.20241225.031516 arm64 [upgradable from: 1.0.0-jammy.20241121.093457]
tros-humble-hobot-shm/unknown 0.0.1-jammy.20241225.030528 arm64 [upgradable from: 0.0.1-jammy.20241120.051430]
tros-humble-hobot-stereo-usb-cam/unknown 2.1.0-jammy.20240816.141027 arm64
tros-humble-hobot-stereonet-render/unknown 2.0.1-jammy.20240816.143408 arm64
tros-humble-hobot-stereonet-utils/unknown 2.3.1-jammy.20241225.024524 arm64 [upgradable from: 2.3.1-jammy.20241120.045952]
tros-humble-hobot-stereonet/unknown 2.2.0-jammy.20241225.024928 arm64 [upgradable from: 2.2.0-jammy.20241120.073723]
tros-humble-hobot-tts/unknown 2.0.5-jammy.20241225.030359 arm64
tros-humble-hobot-usb-cam/unknown 2.3.0-jammy.20241225.031650 arm64 [upgradable from: 2.3.0-jammy.20241120.051751]
tros-humble-hobot-vio/unknown 2.1.1-jammy.20241225.023850 arm64 [upgradable from: 2.1.1-jammy.20241120.045315]
tros-humble-hobot-visualization/unknown 2.0.3-jammy.20241225.035430 arm64 [upgradable from: 2.0.3-jammy.20241120.064621]
tros-humble-hobot-yolo-world/unknown 0.4.1-jammy.20241225.041535 arm64 [upgradable from: 0.4.1-jammy.20241120.070712]
tros-humble-hobot-zed-cam/unknown 2.3.1-jammy.20241225.060928 arm64
tros-humble-img-msgs/unknown 2.0.0-jammy.20241225.031324 arm64 [upgradable from: 2.0.0-jammy.20241120.051559]
tros-humble-imu-sensor/unknown 2.0.1-jammy.20241225.030258 arm64 [upgradable from: 2.0.1-jammy.20241120.051328]
tros-humble-ldlidar-ros2/unknown 1.0.0-20240822101535 arm64
tros-humble-line-follower-model/unknown 2.0.0-jammy.20240821.150053 arm64
tros-humble-mipi-cam/unknown 2.3.6-jammy.20250109.065921 arm64 [upgradable from: 2.3.4-jammy.20241122.075936]
tros-humble-mono-mobilesam/unknown 0.2.0-jammy.20241225.034034 arm64 [upgradable from: 0.2.0-jammy.20241120.063228]
tros-humble-mono-pwcnet/unknown 0.1.0-jammy.20241225.033248 arm64 [upgradable from: 0.1.0-jammy.20241120.053152]
tros-humble-mono2d-body-detection/unknown 2.4.1-jammy.20241225.040107 arm64 [upgradable from: 2.4.1-jammy.20241120.065259]
tros-humble-mono2d-trash-detection/unknown 2.4.0-jammy.20241225.035918 arm64 [upgradable from: 2.4.0-jammy.20241120.065109]
tros-humble-mono3d-indoor-detection/unknown 2.2.1-jammy.20241225.041312 arm64 [upgradable from: 2.2.1-jammy.20241120.070452]
tros-humble-orb-slam3-example-ros2/unknown 2.3.1-jammy.20241122.161842 arm64
tros-humble-orb-slam3/unknown 2.3.0-jammy.20241120.074512 arm64
tros-humble-originbot-base/unknown 0.0.0-20240822101336 arm64
tros-humble-originbot-msgs/unknown 0.0.0-20240822101300 arm64
tros-humble-parking-perception/unknown,now 2.1.0-jammy.20240816.144347 arm64 [installed]
tros-humble-parking-search/unknown 2.1.0-jammy.20241225.032300 arm64 [upgradable from: 2.1.0-jammy.20241120.052349]
tros-humble-performance-test/unknown 2.1.0-jammy.20241127.065446 arm64
tros-humble-racing-control/unknown 2.0.0-20240822101647 arm64
tros-humble-racing-image-collect/unknown 0.0.0-20240822101240 arm64
tros-humble-racing-light-detection-cv/unknown 0.0.0-20240822101554 arm64
tros-humble-recorder-node/unknown 2.1.0-jammy.20241225.024033 arm64
tros-humble-ros-workspace/unknown,now 1.0.3-jammy.20240410.033708 arm64 [installed]
tros-humble-serial/unknown 1.2.1-20240822101317 arm64
tros-humble-sllidar-ros2/unknown 1.0.1-20240822101516 arm64
tros-humble-trigger-node-example/unknown 2.1.0-jammy.20241225.032624 arm64
tros-humble-trigger-node/unknown 2.1.0-jammy.20241225.024119 arm64
tros-humble-tros-lowpass-filter/unknown 0.0.1-jammy.20241225.033734 arm64 [upgradable from: 0.0.1-jammy.20241120.053636]
tros-humble-tros-perception-fusion-msgs/unknown 0.0.1-jammy.20241225.024840 arm64 [upgradable from: 0.0.1-jammy.20241120.050307]
tros-humble-tros-perception-fusion/unknown 0.0.1-jammy.20241225.033858 arm64 [upgradable from: 0.0.1-jammy.20241120.063041]
tros-humble-websocket/unknown 2.3.2-jammy.20241225.034606 arm64 [upgradable from: 2.3.1-jammy.20241120.063803]
tros-humble-yahboom-sunrise-robot-lib/unknown 0.0.0-20240822101356 arm64
tros-humble-yahboomcar-base-node/unknown 0.0.0-20240822101438 arm64
tros-humble-yahboomcar-bringup/unknown 0.0.0-20240822101457 arm64
tros-humble-yahboomcar-description/unknown 0.0.0-20240822101414 arm64
tros-humble-ydlidar-ros2-driver/unknown 1.0.1-20240822090807 arm64
tros-humble/unknown 2.3.2-jammy.20250108.090123 arm64 [upgradable from: 2.3.1-jammy.20241120.121144]
[RDK Kernel Module List]:
Module Size Used by
bnep 28672 2
vs_drm 110592 1
vs_x5_syscon_bridge 16384 0
vio_n2d 266240 1 vs_drm
galcore 368640 0
snd_soc_hobot_sound_duplex_host 24576 0
snd_soc_simple_card_utils 28672 1 snd_soc_hobot_sound_duplex_host
es8311 45056 0
designware_i2s 24576 2
rtc_hpu3501 20480 1
usb_f_rndis 40960 2
u_ether 28672 1 usb_f_rndis
libcomposite 69632 10 usb_f_rndis
leds_gpio 16384 0
bpu_hw_io_x5 24576 0
bpu_cores 28672 1 bpu_hw_io_x5
bpu_framework 73728 2 bpu_hw_io_x5,bpu_cores
hobot_jpu 69632 0
hobot_vpu 122880 0
hobot_lpwm 45056 0
hobot_codec_vnode 32768 0
hobot_isi_sensor 32768 0
hobot_gdc 36864 0
hobot_deserial 45056 0
vs_vse_nat 57344 0
vs_dw_crc 16384 2 hobot_gdc,vs_vse_nat
vs_isp_nat 77824 1 vs_vse_nat
hobot_mipidbg 28672 0
hobot_mipicsi 126976 1 hobot_mipidbg
hobot_camsys 36864 2 hobot_mipicsi,hobot_gdc
hobot_mipiphy 49152 2 hobot_mipidbg,hobot_mipicsi
hobot_sensor 163840 1 hobot_isi_sensor
vs_sif_nat 57344 0
vs_ops_nat 16384 3 vs_isp_nat,vs_sif_nat,vs_vse_nat
vs_cam_pulse 16384 1 vs_sif_nat
hobot_vin_vcon 45056 0
hobot_vin_vnode 45056 4 hobot_mipicsi,vs_sif_nat,hobot_vin_vcon,hobot_lpwm
hobot_osd 73728 0
hobot_vio_common 114688 14 hobot_isi_sensor,vio_n2d,hobot_deserial,hobot_camsys,vs_isp_nat,hobot_vin_vnode,hobot_gdc,hobot_osd,hobot_codec_vnode,vs_sif_nat,hobot_vin_vcon,vs_vse_nat,hobot_sensor,hobot_lpwm
vs_csi_wrapper 16384 0
vs_cam_ctrl 16384 4 vs_isp_nat,hobot_gdc,vs_sif_nat,vs_vse_nat
vs_isc 28672 13 vs_isp_nat,vs_sif_nat,vs_vse_nat
binfmt_misc 24576 1
input_leds 16384 0
led_class 20480 2 leds_gpio,input_leds
joydev 28672 0
aic8800_fdrv 430080 0
cfg80211 389120 1 aic8800_fdrv
aic8800_bsp 81920 1 aic8800_fdrv
sii902x 24576 0
i2c_mux 16384 1 sii902x
drm_kms_helper 172032 3 sii902x,vs_x5_syscon_bridge,vs_drm
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
snd_soc_es8326 45056 1
tcan4x5x 16384 0
m_can 32768 1 tcan4x5x
can_dev 40960 1 m_can
spidev 24576 0
evdev 24576 2
sch_fq_codel 20480 6
goodix_ts 32768 0
panel_waveshare_dsi 16384 0
ft5406 20480 0
panel_wh_cm480 16384 0
uvcvideo 106496 0
videobuf2_vmalloc 20480 1 uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 32768 1 uvcvideo
videobuf2_common 53248 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
hci_uart 49152 1
btrtl 28672 1 hci_uart
btbcm 20480 0
bluetooth 790528 29 btrtl,hci_uart,btbcm,bnep
rfkill 32768 5 bluetooth,cfg80211
fuse 131072 1
[Kernel Log]:
Feb 12 11:12:51 ubuntu kernel: [433964.744297] usb 1-1.3: Product: USB 2.0 Hub
Feb 12 11:12:51 ubuntu kernel: [433964.780917] hub 1-1.3:1.0: USB hub found
Feb 12 11:12:51 ubuntu kernel: [433964.781582] hub 1-1.3:1.0: 4 ports detected
Feb 12 11:12:52 ubuntu kernel: [433965.094086] usb 1-1.3.2: new full-speed USB device number 13 using xhci-hcd
Feb 12 11:12:52 ubuntu kernel: [433965.226520] usb 1-1.3.2: New USB device found, idVendor=3554, idProduct=fc03, bcdDevice= 7.92
Feb 12 11:12:52 ubuntu kernel: [433965.226542] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 12 11:12:52 ubuntu kernel: [433965.226549] usb 1-1.3.2: Product: 2.4G Receiver
Feb 12 11:12:52 ubuntu kernel: [433965.226554] usb 1-1.3.2: Manufacturer: CX
Feb 12 11:12:52 ubuntu kernel: [433965.294624] input: CX 2.4G Receiver as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:3554:FC03.000D/input/input37
Feb 12 11:12:52 ubuntu kernel: [433965.365621] hid-generic 0003:3554:FC03.000D: input,hidraw0: USB HID v1.11 Keyboard [CX 2.4G Receiver] on usb-xhci-hcd.2.auto-1.3.2/input0
Feb 12 11:12:52 ubuntu kernel: [433965.369302] input: CX 2.4G Receiver Mouse as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.1/0003:3554:FC03.000E/input/input38
Feb 12 11:12:52 ubuntu kernel: [433965.370110] input: CX 2.4G Receiver as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.1/0003:3554:FC03.000E/input/input39
Feb 12 11:12:52 ubuntu kernel: [433965.370645] input: CX 2.4G Receiver Consumer Control as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.1/0003:3554:FC03.000E/input/input40
Feb 12 11:12:52 ubuntu kernel: [433965.444273] input: CX 2.4G Receiver System Control as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.1/0003:3554:FC03.000E/input/input41
Feb 12 11:12:52 ubuntu kernel: [433965.445935] hid-generic 0003:3554:FC03.000E: input,hiddev96,hidraw1: USB HID v1.11 Mouse [CX 2.4G Receiver] on usb-xhci-hcd.2.auto-1.3.2/input1
Feb 12 11:12:52 ubuntu kernel: [433965.554119] usb 1-1.3.3: new full-speed USB device number 14 using xhci-hcd
Feb 12 11:12:52 ubuntu kernel: [433965.706104] usb 1-1.3.3: New USB device found, idVendor=25a7, idProduct=fa61, bcdDevice= 6.91
Feb 12 11:12:52 ubuntu kernel: [433965.706125] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 12 11:12:52 ubuntu kernel: [433965.706131] usb 1-1.3.3: Product: 2.4G Receiver
Feb 12 11:12:52 ubuntu kernel: [433965.706137] usb 1-1.3.3: Manufacturer: Compx
Feb 12 11:12:52 ubuntu kernel: [433965.774345] input: Compx 2.4G Receiver as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:25A7:FA61.000F/input/input43
Feb 12 11:12:52 ubuntu kernel: [433965.854614] hid-generic 0003:25A7:FA61.000F: input,hidraw2: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-xhci-hcd.2.auto-1.3.3/input0
Feb 12 11:12:52 ubuntu kernel: [433965.857995] input: Compx 2.4G Receiver Mouse as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.1/0003:25A7:FA61.0010/input/input44
Feb 12 11:12:52 ubuntu kernel: [433965.858247] input: Compx 2.4G Receiver as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.1/0003:25A7:FA61.0010/input/input45
Feb 12 11:12:52 ubuntu kernel: [433965.858459] input: Compx 2.4G Receiver Consumer Control as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.1/0003:25A7:FA61.0010/input/input46
Feb 12 11:12:52 ubuntu kernel: [433965.924376] input: Compx 2.4G Receiver System Control as /devices/platform/soc/35000000.hsio_apb/35100000.usb3/35100000.usb/xhci-hcd.2.auto/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.1/0003:25A7:FA61.0010/input/input47
Feb 12 11:12:52 ubuntu kernel: [433965.924681] hid-generic 0003:25A7:FA61.0010: input,hiddev97,hidraw3: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-xhci-hcd.2.auto-1.3.3/input1
Feb 12 11:13:10 ubuntu kernel: [433983.627525] usb 1-1.3: USB disconnect, device number 12
Feb 12 11:13:10 ubuntu kernel: [433983.627546] usb 1-1.3.2: USB disconnect, device number 13
Feb 12 11:13:11 ubuntu kernel: [433984.459400] usb 1-1.3.3: USB disconnect, device number 14
[System Log]:
Feb 12 19:50:51 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 19:50:51 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 20:00:51 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 20:00:51 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 20:00:51 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 20:10:51 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 20:10:51 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 20:10:51 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 20:20:24 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 20:20:24 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 20:20:24 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 20:30:29 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 20:30:29 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 20:30:29 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 20:33:51 ubuntu systemd[1]: Started Run anacron jobs.
Feb 12 20:33:51 ubuntu anacron[134527]: Anacron 2.3 started on 2025-02-12
Feb 12 20:33:51 ubuntu anacron[134527]: Normal exit (0 jobs run)
Feb 12 20:33:51 ubuntu systemd[1]: anacron.service: Deactivated successfully.
Feb 12 20:40:51 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 20:40:51 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 20:40:51 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 20:50:16 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 20:50:16 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 20:50:16 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 21:00:51 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 21:00:51 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 21:00:51 ubuntu systemd[1]: Finished system activity accounting tool.
Feb 12 21:10:51 ubuntu systemd[1]: Starting system activity accounting tool...
Feb 12 21:10:51 ubuntu systemd[1]: sysstat-collect.service: Deactivated successfully.
Feb 12 21:10:51 ubuntu systemd[1]: Finished system activity accounting tool.
[Journal Log]:
Feb 12 21:15:55 ubuntu sudo[514025]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Feb 12 21:15:55 ubuntu sudo[514025]: root : TTY=pts/5 ; PWD=/root/cqy/RDK_Test ; USER=root ; COMMAND=/usr/bin/rdkos_info
Feb 12 21:15:50 ubuntu sudo[513185]: pam_unix(sudo:session): session closed for user root
Feb 12 21:15:50 ubuntu sudo[513185]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Feb 12 21:15:50 ubuntu sudo[513185]: root : TTY=pts/5 ; PWD=/root/cqy/RDK_Test ; USER=root ; COMMAND=/usr/bin/cat /etc/version
3. 问题涉及的技术领域-
算法工具链 (OpenExplore)
4. 问题描述:-
- 复现概率:必现、高
- 搜索一下论坛是否有相关的案例
- 提供必要的问题日志
