X5 TROS部署yolo11报错
(ros) sunrise@ubuntu:~/rdk_model_zoo/demos/detect/YOLO11/YOLO11-Detect_YUV420SP$ ros2 launch dnn_node_example dnn_node_example.launch.py dnn_example_config_file:=config/my_workconfig.json
[INFO] [launch]: All log files can be found below /home/sunrise/.ros/log/2025-05-08-22-27-17-295741-ubuntu-10491
camera_type is usb
using usb cam
config_file_path is /opt/tros/humble/lib/hobot_usb_cam/config/usb_camera_calibration.yaml
webserver has launch
[INFO] [hobot_usb_cam-1]: process started with pid [10498]
[INFO] [hobot_codec_republish-2]: process started with pid [10500]
[INFO] [example-3]: process started with pid [10502]
[INFO] [websocket-4]: process started with pid [10504]
[hobot_codec_republish-2] [WARN] [1746714438.201390479] [hobot_codec_decoder]: Parameters:
[hobot_codec_republish-2] sub_topic: /image
[hobot_codec_republish-2] pub_topic: /hbmem_img
[hobot_codec_republish-2] out_mode: shared_mem
[hobot_codec_republish-2] in_format: jpeg
[hobot_codec_republish-2] out_format: nv12
[hobot_codec_republish-2] enc_qp: 10
[hobot_codec_republish-2] jpg_quality: 60
[hobot_codec_republish-2] dump_output: 0
[hobot_codec_republish-2] [WARN] [1746714438.207433751] [HobotCodecImpl]: platform x5
[hobot_usb_cam-1] [WARN] [1746714438.345495508] [hobot_usb_cam]: framerate: 30
[hobot_usb_cam-1] [WARN] [1746714438.346017930] [hobot_usb_cam]: pixel_format_name: mjpeg
[hobot_usb_cam-1] [WARN] [1746714438.366430438] [hobot_usb_cam]: Camera calibration file: [/opt/tros/humble/lib/hobot_usb_cam/config/usb_camera_calibration.yaml] does not exist!
[hobot_usb_cam-1] If you need calibration msg, please make sure the calibration file path is correct and the calibration file exists!
[hobot_usb_cam-1] [WARN] [1746714438.376609588] [hobot_usb_cam]: Try to open device [/dev/video0]
[hobot_usb_cam-1] [WARN] [1746714438.479188301] [hobot_usb_cam]: This devices supproted formats:
[hobot_usb_cam-1] [WARN] [1746714438.479524971] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (60 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479618764] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479667640] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479706890] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479744599] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479779432] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479815599] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479848850] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (60 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479882392] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479915601] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479947768] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.479979685] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480011810] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480044227] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480084561] [hobot_usb_cam]: Motion-JPEG: 2592 x 1944 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480120103] [hobot_usb_cam]: Motion-JPEG: 2592 x 1944 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480152311] [hobot_usb_cam]: Motion-JPEG: 2592 x 1944 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480184645] [hobot_usb_cam]: Motion-JPEG: 2592 x 1944 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480217020] [hobot_usb_cam]: Motion-JPEG: 2592 x 1944 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480248896] [hobot_usb_cam]: Motion-JPEG: 2560 x 1440 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480280188] [hobot_usb_cam]: Motion-JPEG: 2560 x 1440 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480312230] [hobot_usb_cam]: Motion-JPEG: 2560 x 1440 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480343980] [hobot_usb_cam]: Motion-JPEG: 2560 x 1440 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480375855] [hobot_usb_cam]: Motion-JPEG: 2560 x 1440 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480408022] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480439689] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480471523] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480503440] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480535315] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480567441] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480600149] [hobot_usb_cam]: Motion-JPEG: 1280 x 960 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480632316] [hobot_usb_cam]: Motion-JPEG: 1280 x 960 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480665067] [hobot_usb_cam]: Motion-JPEG: 1280 x 960 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.480697984] [hobot_usb_cam]: Motion-JPEG: 1280 x 960 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481007362] [hobot_usb_cam]: Motion-JPEG: 1280 x 960 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481048779] [hobot_usb_cam]: Motion-JPEG: 1280 x 960 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481083238] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481115738] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481147614] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481179864] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481212239] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481244448] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481276532] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (60 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481308115] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481339657] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481484784] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481525034] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481558368] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481590202] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481622119] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (60 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481654452] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481686369] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481718495] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481750412] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481781954] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481814037] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481845454] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (60 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481878080] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481910080] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481941247] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.481973039] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482005248] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482037623] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482069415] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482102874] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482134791] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482166249] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482198291] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482230083] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482261709] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482293084] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482324543] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482355376] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482387127] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482418669] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482450252] [hobot_usb_cam]: YUYV 4:2:2: 2592 x 1944 (2 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482481919] [hobot_usb_cam]: YUYV 4:2:2: 2560 x 1440 (3 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482513420] [hobot_usb_cam]: YUYV 4:2:2: 1920 x 1080 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482544587] [hobot_usb_cam]: YUYV 4:2:2: 1280 x 960 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482575670] [hobot_usb_cam]: YUYV 4:2:2: 1280 x 720 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482606754] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (60 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482638546] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482669880] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482701505] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482732339] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482763714] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482795048] [hobot_usb_cam]: YUYV 4:2:2: 320 x 240 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.482994008] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483032300] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483066509] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483099051] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483131218] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483163218] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (5 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483195760] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483227969] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (25 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483287011] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (20 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483336178] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (15 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483547181] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (10 Hz)
[hobot_usb_cam-1] [WARN] [1746714438.483595140] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (5 Hz)
[example-3] [WARN] [1746714438.494920635] [dnn_example_node]: Parameter:
[example-3] image_type: 0
[example-3] config_file: config/my_workconfig.json
[example-3] [WARN] [1746714438.495789144] [dnn_example_node]: Load [80] class types from file [config/coco.list]
[example-3] [WARN] [1746714438.495967563] [dnn_example_node]: Parameter:
[example-3] model_file_name: /home/sunrise/rdk_model_zoo/demos/detect/YOLO11/YOLO11-Detect_YUV420SP/bin_dir/yolo11n_detect_bayese_640x640_nv12/yolo11n_detect_bayese_640x640_nv12.bin
[example-3] model_name:
[example-3] [WARN] [1746714438.496066814] [dnn_example_node]: model_file_name_: /home/sunrise/rdk_model_zoo/demos/detect/YOLO11/YOLO11-Detect_YUV420SP/bin_dir/yolo11n_detect_bayese_640x640_nv12/yolo11n_detect_bayese_640x640_nv12.bin, task_num: 4
[hobot_usb_cam-1] [WARN] [1746714438.501514121] [hobot_usb_cam]: Open & Init device /dev/video0 success.
[example-3] [HBRT] set log level as 0. version = 3.15.55.0
[example-3] [DNN] Runtime version = 1.24.5_(3.15.55 HBRT)
[websocket-4] [WARN] [1746714438.549245878] [websocket]:
[websocket-4] Parameter:
[websocket-4] output_fps: 0
[example-3] [A][DNN][packed_model.cpp:247][Model](2025-05-08,22:27:18.569.570) [HorizonRT] The model builder version = 1.24.3
[example-3] [WARN] [1746714438.674219704] [dnn_example_node]: Get model name: yolo11n_detect_bayese_640x640_nv12 from load model.
[example-3] [WARN] [1746714438.674363997] [dnn_example_node]: Create ai msg publisher with topic_name: hobot_dnn_detection
[example-3] [WARN] [1746714438.684968818] [dnn_example_node]: Create img hbmem_subscription with topic_name: /hbmem_img
[example-3] [WARN] [1746714439.360289917] [dnn_example_node]: Loaned messages are only safe with const ref subscription callbacks. If you are using any other kind of subscriptions, set the ROS_DISABLE_LOANED_MESSAGES environment variable to 1 (the default).
[example-3] [WARN] [1746714439.360628088] [dnn_example_node]: Recved img encoding: nv12, h: 480, w: 640, step: 640, index: 0, stamp: 1746714438_698232000, data size: 460800, comm delay [662.3738]ms
[ERROR] [example-3]: process has died [pid 10502, exit code -11, cmd ‘/opt/tros/humble/lib/dnn_node_example/example --ros-args --log-level warn --ros-args --params-file /tmp/launch_params_7763cy9g --params-file /tmp/launch_params_v5h8gaez --params-file /tmp/launch_params_9fes5lcy --params-file /tmp/launch_params_tqf06qh_ --params-file /tmp/launch_params_dgvyoc1i’].
[hobot_codec_republish-2] [WARN] [1746714443.256444510] [hobot_codec_decoder]: Pub img fps [24.09]
[websocket-4] [ERROR] [1746714443.581390039] [websocket]: Websocket did not receive AI data! Please check whether the AI data publisher still exists by ‘ros2 topic info hobot_dnn_detection’!
[hobot_usb_cam-1] [WARN] [1746714446.575109785] [hobot_usb_cam]: Shutting down
[INFO] [hobot_codec_republish-2]: process has finished cleanly [pid 10500]
[INFO] [websocket-4]: process has finished cleanly [pid 10504]
[INFO] [hobot_usb_cam-1]: process has finished cleanly [pid 10498]
你好,严格按照RDK Model Zoo仓库最新的commit的README来操作即可,README中也有hrt_model_exec model_info --model_file 命令查看bin模型的输入输出信息。 https://github.com/D-Robotics/rdk\_model\_zoo 特别的,BPU工具链是开放的工具链,您也完全可以按照自己的想法来设计部署方案,Model Zoo只是提供部署的参考,只要自己设计的bin模型部署方案和自己设计的前后处理程序能对上,都可以来部署算法。
我也是这个问题,请问解决了吗?
暂时还没,其实解决不了也没事,我用的ros1
这个链接不是失效了吗
  1. 确保使用的是最新的系统
    目前社区对RDK X5提供的最新系统版本为3.2.3, 请烧录最新的系统后再试。
    miniBoot版本也需要保持最新, 升级方法为, 给板卡连接可访问互联网的网络, 在系统的终端命令行中, 输入 sudo srpi-config命令,1-SystemOptions,S7-UpdateMiniBoot,来升级miniboot。
  2. TROS在运行一次YOLO功能后,在当前目录的config文件夹内有若干workconfig.json文件,在这个workconfig.json文件中,有TROS使用的bin模型的路径,这些模型都是RDK板子上自带的. 您可以使用上述方法来比对自己的模型和板子上自带的能跑的模型的区别。对比的项目有:输出头的顺序,tensor type,量化与反量化类型.
