[图像算法][RDK X3]system only support 1024 funccalls at most
模型infer的时候报错:
[E][DNN][hbm_exec_plan.cpp:1105][Plan](2025-05-28,09:02:45.996.763) Subgraph [main_graph_subgraph_25] generate funccalls exceeds limit!
[E][DNN][multi_model_task.cpp:157][Task](2025-05-28,09:02:45.996.932) The model [rt_igev] genarate 2597 funccalls, but system only support 1024 funccalls at most. Funccalls can be reduced by: 1. Increase `max-time-per-fc` time at compile stage; 2. Decrease the number of batchsize at compile stage; 3. Reduce the number of roi when calling hbDNNRoiInfer
E0528 09:02:45.999325 46811 function_util.cpp:205] hbDNNWaitTaskDone failed, error code:-6000012
E0528 09:02:45.999452 46811 main.cpp:352] model inference failed, error code:-6000012
这是模型的百度网盘地址:百度网盘 请输入提取码 提取码1234
我的模型的onnx节点就有1666个,funccalls是否和模型节点数相关?
max-time-per-fc默认是0吧,batchsize 是1。我该如何改进模型让它能跑在X3上?
X5最大支持多少funccalls?
数量和模型段数有关,你这个应该就是CPU节点太多导致的。-
由于您并没有提供rdkos_info命令和工具链相关的版本信息,所以假定您使用的工具版本都是最新的了,所以限制是1024.
打开main_graph_subgraph_25的json文件显示如下内容: 是否是因为Reshape_48_output_0的单维最高是15360,超过了地平线X3最大支持的单维限制?X3单维有最大限制吗?
“summary”: {
“BPU OPs per frame (effective)”: 768,
“BPU OPs per run (effective)”: 11796480,
“BPU PE number”: 1,
“BPU core number”: 1,
“BPU march”: “BERNOULLI2”,
“DDR bytes per frame”: 3840,
“DDR bytes per run”: 58985216,
“DDR bytes per second”: 1655262259,
“DDR megabytes per frame”: 0.004,
“DDR megabytes per run”: 56.253,
“DDR megabytes per second”: 1578.6,
“FPS”: 431037.3,
“HBDK version”: “3.49.13”,
“compiling options”: “-f hbir -m /tmp/tmpydjf5ywf/main_graph_subgraph_25.hbir -o /tmp/tmpydjf5ywf/main_graph_subgraph_25.hbm --march bernoulli2 --progressbar --O3 --core-num 1 --fast --input-layout NHWC --output-layout NCHW --input-source ddr”,
“frame per run”: 15360,
“frame per second”: 431037.3,
“input features”: [
“input name”,
“input size”
“/Reshape_48_output_0_calibrated_quantized”,
“15360x1x48x8”
“interval computing unit utilization”: [
0.66,
0.623,
0.624,
0.623,
0.647,
0.664,
0.638,
0.625,
0.623,
0.627,
0.664,
0.658,
0.625,
0.624,
0.623,
0.647,
0.658,
0.645,
0.625,
0.624,
0.643,
0.64,
0.711,
0.776,
0.766,
0.792,
0.766,
0.782,
0.748,
0.789,
0.769,
0.764,
0.796,
0.761,
0.795,
0.481
“interval computing units utilization”: [
0.66,
0.623,
0.624,
0.623,
0.647,
0.664,
0.638,
0.625,
0.623,
0.627,
0.664,
0.658,
0.625,
0.624,
0.623,
0.647,
0.658,
0.645,
0.625,
0.624,
0.643,
0.64,
0.711,
0.776,
0.766,
0.792,
0.766,
0.782,
0.748,
0.789,
0.769,
0.764,
0.796,
0.761,
0.795,
0.481
“interval loading bandwidth (megabytes/s)”: [
517,
518,
517,
515,
488,
465,
493,
515,
515,
515,
485,
466,
495,
515,
515,
515,
479,
466,
501,
515,
515,
508,
462,
426,
431,
433,
433,
433,
426,
431,
426,
422,
434,
433,
436,
338
“interval number”: 36,
“interval storing bandwidth (megabytes/s)”: [
654,
722,
774,
758,
757,
755,
722,
731,
758,
749,
764,
723,
722,
766,
758,
755,
764,
722,
722,
758,
748,
764,
961,
1384,
1677,
1735,
1735,
1735,
1735,
1734,
1677,
1678,
1735,
1735,
1735,
1471
“interval time (ms)”: 1.0,
“latency (ms)”: 35.63,
“latency (ms) by segments”: [
35.635
“latency (us)”: 35635.0,
“loaded bytes per frame”: 1152,
“loaded bytes per run”: 17697536,
“model json CRC”: “7a868267”,
“model json file”: “/tmp/tmpydjf5ywf/main_graph_subgraph_25.hbir”,
“model name”: “main_graph_subgraph_25”,
“model param CRC”: “00000000”,
“multicore sync time (ms)”: 0.0,
“run per second”: 28.06,
“runtime version”: “3.15.53.0”,
“stored bytes per frame”: 2688,
“stored bytes per run”: 41287680,
“worst FPS”: 431037.3
