尝试使用BEV和centerpoint程序,报错如下:
[INFO] [hobot_bev-1]: process started with pid [20017]
[INFO] [websocket-2]: process started with pid [20019]
[hobot_bev-1] [UCP]: log level = 3
[hobot_bev-1] [UCP]: UCP version = 3.7.3
[hobot_bev-1] [VP]: log level = 3
[hobot_bev-1] [DNN]: log level = 3
[hobot_bev-1] [HPL]: log level = 3
[hobot_bev-1] [UCPT]: log level = 6
[websocket-2] [WARN] [1750432899.136972325] [websocket]:
[websocket-2] Parameter:
[websocket-2] image_topic: /image_jpeg
[websocket-2] image_type: mjpeg
[websocket-2] only_show_image: 1
[websocket-2] output_fps: 0
[websocket-2] [INFO] [1750432899.137261141] [websocket]: Websocket using image mjpeg
[hobot_bev-1] [INFO] [1750432899.177184222] [bev_node]: BevNode init
[hobot_bev-1] [WARN] [1750432899.177522110] [bev_node]:
[hobot_bev-1] topic_name: image_jpeg
[hobot_bev-1] save_image: false
[hobot_bev-1] config_file: /opt/tros/humble/lib/hobot_bev/config/bev_gkt_mixvargenet_multitask_nuscenes/workflow_la
[hobot_bev-1] glog_level: 1
[hobot_bev-1] [WARN] [1750432899.182547313] [ai_wrapper]:
[hobot_bev-1] Set glog level in cmd line with ‘–glog_level=$num’
[hobot_bev-1] EXAMPLE_SYSTEM = 0, EXAMPLE_REPORT = 1, EXAMPLE_DETAIL = 2, EXAMPLE_DEBUG = 3
[hobot_bev-1] bin --config_file=/opt/tros/humble/lib/hobot_bev/config/bev_gkt_mixvargenet_multitask_nuscenes/workflo
–glog_level=1
[hobot_bev-1] I0000 00:00:00.000000 20017 vlog_is_on.cc:197] RAW: Set VLOG level for “*” to 1
[hobot_bev-1] I0620 23:21:39.182687 20017 ai_wrapper.cpp:85] EXAMPLE_SYSTEM
[hobot_bev-1] I0620 23:21:39.182710 20017 ai_wrapper.cpp:86] EXAMPLE_REPORT
[hobot_bev-1] I0620 23:21:39.182714 20017 ai_wrapper.cpp:92] config_fname: /opt/tros/humble/lib/hobot_bev/config/bev
t_multitask_nuscenes/workflow_latency.json
[hobot_bev-1] [BPU][[BPU_MONITOR]][281473108190720][INFO]BPULib verison(2, 1, 2)[0d3f195]!
[hobot_bev-1] [DNN] HBTL_EXT_DNN log level:6
[hobot_bev-1] [DNN]: 3.7.3_(4.2.11 HBRT)
[hobot_bev-1] malloc(): invalid size (unsorted)
[websocket-2] [ERROR] [1750432904.142624919] [websocket]: Websocket did not receive image data! Please check whether
isher still exists by ‘ros2 topic info /image_jpeg’!
[websocket-2] [ERROR] [1750432909.142438662] [websocket]: Websocket did not receive image data! Please check whether
[ERROR] [hobot_bev-1]: process has died [pid 20017, exit code -6, cmd '/opt/tros/humble/lib/hobot_bev/hobot_bev --ro
vel info --ros-args --params-file /tmp/launch_params_bwg_1xfd --params-file /tmp/launch_params_btswo435 --params-fil
arams_f4dvf1ef’].
[websocket-2] [ERROR] [1750432914.142277330] [websocket]: Websocket did not receive image data! Please check whether
[websocket-2] [ERROR] [1750432919.142100573] [websocket]: Websocket did not receive image data! Please check whether
[websocket-2] [ERROR] [1750432924.141926066] [websocket]: Websocket did not receive i
mage data! Please check whether the image publisher still exists by 'ros2 topic info
/image_jpeg’!
