RDK X5部署yolo11n时报错返回Inlvaid parser: 0
sunrise@ubuntu:~/yolo11_ws$ ros2 launch dnn_node_example dnn_node_example.launch.py dnn_example_config_file:=./config/my_yolo11_config.json
[INFO] [launch]: All log files can be found below /home/sunrise/.ros/log/2025-06-24-17-53-03-702724-ubuntu-27831
camera_type is usb
using usb cam
config_file_path is /opt/tros/humble/lib/hobot_usb_cam/config/usb_camera_calibration.yaml
webserver has launch
[INFO] [hobot_usb_cam-1]: process started with pid [27852]
[INFO] [hobot_codec_republish-2]: process started with pid [27854]
[INFO] [example-3]: process started with pid [27856]
[INFO] [websocket-4]: process started with pid [27858]
[hobot_codec_republish-2] [WARN] [1750758784.691196910] [hobot_codec_decoder]: Parameters:
[hobot_codec_republish-2] sub_topic: /image
[hobot_codec_republish-2] pub_topic: /hbmem_img
[hobot_codec_republish-2] out_mode: shared_mem
[hobot_codec_republish-2] in_format: jpeg
[hobot_codec_republish-2] out_format: nv12
[hobot_codec_republish-2] enc_qp: 10
[hobot_codec_republish-2] jpg_quality: 60
[hobot_codec_republish-2] dump_output: 0
[hobot_codec_republish-2] [WARN] [1750758784.697060618] [HobotCodecImpl]: platform x5
[hobot_usb_cam-1] [WARN] [1750758784.862000755] [hobot_usb_cam]: framerate: 30
[hobot_usb_cam-1] [WARN] [1750758784.862601630] [hobot_usb_cam]: pixel_format_name: mjpeg
[hobot_usb_cam-1] [WARN] [1750758784.886586174] [hobot_usb_cam]: Camera calibration file: [/opt/tros/humble/lib/hobot_usb_cam/config/usb_camera_calibration.yaml] does not exist!
[hobot_usb_cam-1] If you need calibration msg, please make sure the calibration file path is correct and the calibration file exists!
[hobot_usb_cam-1] [WARN] [1750758784.898195425] [hobot_usb_cam]: Try to open device [/dev/video0]
[example-3] [WARN] [1750758785.014284558] [dnn_example_node]: Parameter:
[example-3] image_type: 0
[example-3] config_file: ./config/my_yolo11_config.json
[example-3] [WARN] [1750758785.014986017] [dnn_example_node]: Load [80] class types from file [/home/sunrise/yolo11_ws/coco.list]
[example-3] [WARN] [1750758785.015144017] [dnn_example_node]: Parameter:
[example-3] model_file_name: /home/sunrise/yolo11_ws/yolo11n_detect_bayese_640x640_nv12_modified.bin
[example-3] model_name:
[example-3] [WARN] [1750758785.015230933] [dnn_example_node]: model_file_name_: /home/sunrise/yolo11_ws/yolo11n_detect_bayese_640x640_nv12_modified.bin, task_num: 4
[example-3] [HBRT] set log level as 0. version = 3.15.55.0
[example-3] [DNN] Runtime version = 1.24.5_(3.15.55 HBRT)
[websocket-4] [WARN] [1750758785.058719561] [websocket]:
[websocket-4] Parameter:
[websocket-4] output_fps: 0
[hobot_usb_cam-1] [WARN] [1750758785.159788486] [hobot_usb_cam]: This devices supproted formats:
[hobot_usb_cam-1] [WARN] [1750758785.160064902] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160123486] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160164444] [hobot_usb_cam]: Motion-JPEG: 160 x 120 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160203444] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160240694] [hobot_usb_cam]: Motion-JPEG: 352 x 288 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160277569] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160314486] [hobot_usb_cam]: Motion-JPEG: 800 x 600 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160351402] [hobot_usb_cam]: Motion-JPEG: 1024 x 768 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160388944] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160426319] [hobot_usb_cam]: Motion-JPEG: 1280 x 1024 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160463236] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160500152] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160536902] [hobot_usb_cam]: YUYV 4:2:2: 1920 x 1080 (5 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160573944] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160610986] [hobot_usb_cam]: YUYV 4:2:2: 1280 x 720 (10 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160647736] [hobot_usb_cam]: YUYV 4:2:2: 800 x 600 (20 Hz)
[hobot_usb_cam-1] [WARN] [1750758785.160684236] [hobot_usb_cam]: YUYV 4:2:2: 960 x 540 (15 Hz)
[example-3] [A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.24.3
[hobot_usb_cam-1] [WARN] [1750758785.182726029] [hobot_usb_cam]: Open & Init device /dev/video0 success.
[example-3] [WARN] [1750758785.189630029] [dnn_example_node]: Get model name: yolo11n_detect_bayese_640x640_nv12 from load model.
[example-3] [WARN] [1750758785.189810571] [dnn_example_node]: Create ai msg publisher with topic_name: hobot_dnn_detection
[example-3] [WARN] [1750758785.217135073] [dnn_example_node]: Create img hbmem_subscription with topic_name: /hbmem_img
[example-3] [WARN] [1750758785.565690974] [dnn_example_node]: Loaned messages are only safe with const ref subscription callbacks. If you are using any other kind of subscriptions, set the ROS_DISABLE_LOANED_MESSAGES environment variable to 1 (the default).
[example-3] [WARN] [1750758785.566035932] [dnn_example_node]: Recved img encoding: nv12, h: 600, w: 800, step: 800, index: 0, stamp: 1750758784_550072000, data size: 720000, comm delay [1015.9407]ms
[example-3] [ERROR] [1750758785.586062850] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.591581225] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.596380768] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.600596268] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.605719852] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.633537145] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.664847523] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.696888650] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.732657527] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.764675071] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.796901032] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.832811868] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.864798037] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.897498581] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.932823500] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.964669461] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758785.996850422] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.032656299] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.064615718] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.097046471] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.132553932] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.164599851] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.196789728] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.232649606] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.264879817] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.296943652] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.332792905] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.364853907] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.396843326] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.432679871] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.464996040] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.497138667] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.532552003] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.564567047] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.596712966] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.632564552] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.664879554] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.696865307] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.732628559] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.764589312] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.796564189] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.832493150] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.864486902] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.896641863] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.932549991] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.964416326] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758786.996612787] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.032682998] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.064601667] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.097133794] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.132750089] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.164438758] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.196685843] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.232508721] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.264514473] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.296745976] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.332497603] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.364466356] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.396519483] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.432406611] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.464503863] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.496900866] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.533109993] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.564545162] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.596680498] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.632457959] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.664671586] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.696471589] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758787.732368758] [dnn_example_node]: Inlvaid parser: 0
[hobot_usb_cam-1] [WARN] [1750758787.750189468] [hobot_usb_cam]: Shutting down
[INFO] [hobot_codec_republish-2]: process has finished cleanly [pid 27854]
[INFO] [websocket-4]: process has finished cleanly [pid 27858]
[INFO] [hobot_usb_cam-1]: process has finished cleanly [pid 27852]
[INFO] [example-3]: process has finished cleanly [pid 27856]
sunrise@ubuntu:~/yolo11_ws$ # (在开发板上执行, 确保在 yolo11_ws 目录下)
[INFO] [launch]: All log files can be found below /home/sunrise/.ros/log/2025-06-24-17-56-10-549537-ubuntu-28282
camera_type is usb
using usb cam
[INFO] [hobot_usb_cam-1]: process started with pid [28303]
[INFO] [hobot_codec_republish-2]: process started with pid [28305]
[INFO] [example-3]: process started with pid [28307]
[INFO] [websocket-4]: process started with pid [28309]
[hobot_codec_republish-2] [WARN] [1750758971.548539938] [hobot_codec_decoder]: Parameters:
[hobot_codec_republish-2] [WARN] [1750758971.554822731] [HobotCodecImpl]: platform x5
[hobot_usb_cam-1] [WARN] [1750758971.821182472] [hobot_usb_cam]: framerate: 30
[hobot_usb_cam-1] [WARN] [1750758971.821793805] [hobot_usb_cam]: pixel_format_name: mjpeg
[hobot_usb_cam-1] [WARN] [1750758971.846241225] [hobot_usb_cam]: Camera calibration file: [/opt/tros/humble/lib/hobot_usb_cam/config/usb_camera_calibration.yaml] does not exist!
[hobot_usb_cam-1] [WARN] [1750758971.860541810] [hobot_usb_cam]: Try to open device [/dev/video0]
[example-3] [WARN] [1750758971.998790035] [dnn_example_node]: Parameter:
[example-3] [WARN] [1750758971.999510577] [dnn_example_node]: Load [80] class types from file [/home/sunrise/yolo11_ws/coco.list]
[example-3] [WARN] [1750758971.999677494] [dnn_example_node]: Parameter:
[example-3] [WARN] [1750758971.999773952] [dnn_example_node]: model_file_name_: /home/sunrise/yolo11_ws/yolo11n_detect_bayese_640x640_nv12_modified.bin, task_num: 4
[websocket-4] [WARN] [1750758972.049277375] [websocket]:
[hobot_usb_cam-1] [WARN] [1750758972.139478469] [hobot_usb_cam]: This devices supproted formats:
[hobot_usb_cam-1] [WARN] [1750758972.139768011] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.139827386] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.139866344] [hobot_usb_cam]: Motion-JPEG: 160 x 120 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.139904553] [hobot_usb_cam]: Motion-JPEG: 320 x 240 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.139941803] [hobot_usb_cam]: Motion-JPEG: 352 x 288 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.139978678] [hobot_usb_cam]: Motion-JPEG: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140015219] [hobot_usb_cam]: Motion-JPEG: 800 x 600 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140051844] [hobot_usb_cam]: Motion-JPEG: 1024 x 768 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140089011] [hobot_usb_cam]: Motion-JPEG: 1280 x 720 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140126636] [hobot_usb_cam]: Motion-JPEG: 1280 x 1024 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140163344] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140199719] [hobot_usb_cam]: Motion-JPEG: 1920 x 1080 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140236428] [hobot_usb_cam]: YUYV 4:2:2: 1920 x 1080 (5 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140273219] [hobot_usb_cam]: YUYV 4:2:2: 640 x 480 (30 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140309594] [hobot_usb_cam]: YUYV 4:2:2: 1280 x 720 (10 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140345803] [hobot_usb_cam]: YUYV 4:2:2: 800 x 600 (20 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.140381928] [hobot_usb_cam]: YUYV 4:2:2: 960 x 540 (15 Hz)
[hobot_usb_cam-1] [WARN] [1750758972.161793514] [hobot_usb_cam]: Open & Init device /dev/video0 success.
[example-3] [WARN] [1750758972.179074016] [dnn_example_node]: Get model name: yolo11n_detect_bayese_640x640_nv12 from load model.
[example-3] [WARN] [1750758972.179272099] [dnn_example_node]: Create ai msg publisher with topic_name: hobot_dnn_detection
[example-3] [WARN] [1750758972.191776309] [dnn_example_node]: Create img hbmem_subscription with topic_name: /hbmem_img
[example-3] [WARN] [1750758972.605694110] [dnn_example_node]: Loaned messages are only safe with const ref subscription callbacks. If you are using any other kind of subscriptions, set the ROS_DISABLE_LOANED_MESSAGES environment variable to 1 (the default).
[example-3] [WARN] [1750758972.606049027] [dnn_example_node]: Recved img encoding: nv12, h: 600, w: 800, step: 800, index: 0, stamp: 1750758971_582937000, data size: 720000, comm delay [1023.0884]ms
[example-3] [ERROR] [1750758972.626567488] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.631497113] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.636619697] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.641606531] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.647264490] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.651738074] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.657164658] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.690991371] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.722824791] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.754931754] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.790807466] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.822748512] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.854960474] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.890813687] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.922727066] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.954773862] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758972.993180158] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758973.022661453] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758973.054657124] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758973.090768253] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758973.122672841] [dnn_example_node]: Inlvaid parser: 0
[example-3] [ERROR] [1750758973.154869428] [dnn_example_node]: Inlvaid parser: 0
[hobot_usb_cam-1] [WARN] [1750758973.169372930] [hobot_usb_cam]: Shutting down
[INFO] [hobot_codec_republish-2]: process has finished cleanly [pid 28305]
[INFO] [websocket-4]: process has finished cleanly [pid 28309]
[INFO] [hobot_usb_cam-1]: process has finished cleanly [pid 28303]
[ERROR] [example-3]: process has died [pid 28307, exit code -7, cmd ‘/opt/tros/humble/lib/dnn_node_example/example --ros-args --log-level warn --ros-args --params-file /tmp/launch_params_qwbimkec --params-file /tmp/launch_params_k_gs6_2_ --params-file /tmp/launch_params_dlbs9i37 --params-file /tmp/launch_params_lb1rhrjd --params-file /tmp/launch_params_cik0kzcy’].
目前社区对RDK X5提供的最新系统版本为3.2.3, 请烧录最新的系统后再试。
另外,您的miniBoot版本也需要保持最新, 升级方法为, 给板卡连接可访问互联网的网络, 在系统的终端命令行中, 输入 sudo srpi-config命令,1-SystemOptions,S7-UpdateMiniBoot,来升级miniboot。
hrt_model_exec model_info --model_file 命令查看bin模型的输入输出信息。
TROS在运行一次YOLO功能后,在当前目录的config文件夹内有若干workconfig.json文件,在这个workconfig.json文件中,有TROS使用的bin模型的路径,这些模型都是RDK板子上自带的. 您可以使用上述方法来比对自己的模型和板子上自带的能跑的模型的区别。对比的项目有:输出头的顺序,tensor type,量化与反量化类型.
特别的,YOLOv8,11,12,13的parser统一使用v8的一致,并没有yolo11的parser设置。
希望这条回答可以帮助到您,祝您生活愉快。
