[racing_obstacle_detection_yolo-1] [WARN] [1751971240.459097470] [ObstacleDetectionNode]: input fps: 0.06, out fps: 0.06, infer time ms: 17027, post process time ms: 16909
这是第一个image_utils.cpp:
// Copyright (c) 2022,Horizon Robotics.
// Licensed under the Apache License, Version 2.0 (the “License”);
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an “AS IS” BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#include “racing_obstacle_detection/image_utils.h”
#include
#include
#include
#include
#include
#include
#include “dnn/hb_sys.h”
static int32_t BGRToNv12(cv::Mat &bgr_mat, cv::Mat &img_nv12) {
auto height = bgr_mat.rows;
auto width = bgr_mat.cols;
if (height % 2 || width % 2) {
std::cerr << “input img height and width must aligned by 2!”;
return -1;
cv::Mat yuv_mat;
cv::cvtColor(bgr_mat, yuv_mat, cv::COLOR_BGR2YUV_I420);
if (yuv_mat.data == nullptr) {
std::cerr << “yuv_mat.data is null pointer” << std::endl;
return -1;
auto *yuv = yuv_mat.ptr<uint8_t>();
if (yuv == nullptr) {
std::cerr << “yuv is null pointer” << std::endl;
return -1;
img_nv12 = cv::Mat(height * 3 / 2, width, CV_8UC1);
auto *ynv12 = img_nv12.ptr<uint8_t>();
int32_t uv_height = height / 2;
int32_t uv_width = width / 2;
// copy y data
int32_t y_size = height * width;
memcpy(ynv12, yuv, y_size);
// copy uv data
uint8_t *nv12 = ynv12 + y_size;
uint8_t *u_data = yuv + y_size;
uint8_t *v_data = u_data + uv_height * uv_width;
for (int32_t i = 0; i < uv_width * uv_height; i++) {
*nv12++ = *u_data++;
*nv12++ = *v_data++;
return 0;
std::shared_ptr ImageUtils::GetNV12Pyramid(
const cv::Mat &bgr_mat, int scaled_img_height, int scaled_img_width) {
cv::Mat nv12_mat;
cv::Mat mat_tmp;
mat_tmp.create(scaled_img_height, scaled_img_width, bgr_mat.type());
cv::resize(bgr_mat, mat_tmp, mat_tmp.size(), 0, 0);
// cv::imwrite(“resized_img.jpg”, mat_tmp);
auto ret = BGRToNv12(mat_tmp, nv12_mat);
if (ret) {
std::cout << "get nv12 image failed " << std::endl;
return nullptr;
auto *y = new hbSysMem;
auto *uv = new hbSysMem;
auto w_stride = ALIGN_16(scaled_img_width);
hbSysAllocCachedMem(y, scaled_img_height * w_stride);
hbSysAllocCachedMem(uv, scaled_img_height / 2 * w_stride);
uint8_t *data = nv12_mat.data;
auto *hb_y_addr = reinterpret_cast<uint8_t *>(y->virAddr);
auto *hb_uv_addr = reinterpret_cast<uint8_t *>(uv->virAddr);
// padding y
for (int h = 0; h < scaled_img_height; ++h) {
auto *raw = hb_y_addr + h * w_stride;
for (int w = 0; w < scaled_img_width; ++w) {
*raw++ = *data++;
// padding uv
auto uv_data = nv12_mat.data + scaled_img_height * scaled_img_width;
for (int32_t h = 0; h < scaled_img_height / 2; ++h) {
auto *raw = hb_uv_addr + h * w_stride;
for (int32_t w = 0; w < scaled_img_width; ++w) {
*raw++ = *uv_data++;
hbSysFlushMem(y, HB_SYS_MEM_CACHE_CLEAN);
hbSysFlushMem(uv, HB_SYS_MEM_CACHE_CLEAN);
auto pyramid = new NV12PyramidInput;
pyramid->width = scaled_img_width;
pyramid->height = scaled_img_height;
pyramid->y_vir_addr = y->virAddr;
pyramid->y_phy_addr = y->phyAddr;
pyramid->y_stride = w_stride;
pyramid->uv_vir_addr = uv->virAddr;
pyramid->uv_phy_addr = uv->phyAddr;
pyramid->uv_stride = w_stride;
return std::shared_ptr(pyramid,
[y, uv](NV12PyramidInput *pyramid) {
// Release memory after deletion
hbSysFreeMem(y);
hbSysFreeMem(uv);
delete y;
delete uv;
delete pyramid;
这是第二个parser.cpp:
#include
#include
#include
#include
#include
#include
return -1;
cv::Mat yuv_mat;
return -1;
return -1;
// copy y data
// copy uv data
return 0;
cv::Mat nv12_mat;
cv::Mat mat_tmp;
if (ret) {
return nullptr;
// padding y
*raw++ = *data++;
// padding uv
hbSysFreeMem(y);
hbSysFreeMem(uv);
delete y;
delete uv;
delete pyramid;
第三个sample.cpp:
#include <cv_bridge/cv_bridge.h>
#include
#include “ai_msgs/msg/perception_targets.hpp”
#include “dnn_node/dnn_node.h”
#include “dnn_node/util/image_proc.h”
#include “hbm_img_msgs/msg/hbm_msg1080_p.hpp”
#include “hobot_cv/hobotcv_imgproc.h”
#include “sensor_msgs/msg/image.hpp”
#include “rapidjson/document.h”
#include “rapidjson/istreamwrapper.h”
#include “rapidjson/writer.h”
#include “racing_obstacle_detection/parser.h”
// 使用hobotcv resize nv12格式图片,固定图片宽高比
int ResizeNV12Img(const char* in_img_data,
const int& in_img_height,
const int& in_img_width,
const int& scaled_img_height,
const int& scaled_img_width,
cv::Mat& out_img,
float& ratio) {
cv::Mat src(
in_img_height * 3 / 2, in_img_width, CV_8UC1, (void*)(in_img_data));
float ratio_w =
static_cast(in_img_width) / static_cast(scaled_img_width);
float ratio_h =
static_cast(in_img_height) / static_cast(scaled_img_height);
float dst_ratio = std::max(ratio_w, ratio_h);
int resized_width, resized_height;
if (dst_ratio == ratio_w) {
resized_width = scaled_img_width;
resized_height = static_cast(in_img_height) / dst_ratio;
} else if (dst_ratio == ratio_h) {
resized_width = static_cast(in_img_width) / dst_ratio;
resized_height = scaled_img_height;
// hobot_cv要求输出宽度为16的倍数
int remain = resized_width % 16;
if (remain != 0) {
//向下取16倍数,重新计算缩放系数
resized_width -= remain;
dst_ratio = static_cast(in_img_width) / resized_width;
//高度向下取偶数
resized_height =
resized_height % 2 == 0 ? resized_height : resized_height - 1;
ratio = dst_ratio;
return hobot_cv::hobotcv_resize(
src, in_img_height, in_img_width, out_img, resized_height, resized_width);
int InitClassNames(const std::string &cls_name_file,hobot::dnn_node::racing_obstacle_detection::PTQYolo5Config &yolo5_config) {
std::ifstream fi(cls_name_file);
if (fi) {
yolo5_config.class_names.clear();
std::string line;
while (std::getline(fi, line)) {
yolo5_config.class_names.push_back(line);
int size = yolo5_config.class_names.size();
if(size != yolo5_config.class_num){
RCLCPP_ERROR(rclcpp::get_logger(“Yolo5_detection_parser”),
“class_names length %d is not equal to class_num %d”,
size, yolo5_config.class_num);
return -1;
} else {
“can not open cls name file: %s”,
cls_name_file.c_str());
return -1;
return 0;
int InitClassNum(const int &class_num,hobot::dnn_node::racing_obstacle_detection::PTQYolo5Config &yolo5_config) {
if(class_num > 0){
yolo5_config.class_num = class_num;
} else {
“class_num = %d is not allowed, only support class_num > 0”,
class_num);
return -1;
return 0;
void LoadConfig(const std::string &config_file,hobot::dnn_node::racing_obstacle_detection::PTQYolo5Config &yolo5_config) {
if (config_file.empty()) {
RCLCPP_ERROR(rclcpp::get_logger(“LoadConfig”),
“Config file [%s] is empty!”,
config_file.data());
return;
// Parsing config
std::ifstream ifs(config_file.c_str());
if (!ifs) {
“Read config file [%s] fail!”,
return;
rapidjson::IStreamWrapper isw(ifs);
rapidjson::Document document;
document.ParseStream(isw);
if (document.HasParseError()) {
“Parsing config file %s failed”,
return;
if (document.HasMember(“class_num”)){
int class_num = document[“class_num”].GetInt();
if (InitClassNum(class_num,yolo5_config) < 0) {
return;
if (document.HasMember(“cls_names_list”)) {
std::string cls_name_file = document[“cls_names_list”].GetString();
if (InitClassNames(cls_name_file,yolo5_config) < 0) {
return;
return;
struct ObstacleDetectionNodeOutput : public hobot::dnn_node::DnnNodeOutput {
// 缩放比例系数,原图和模型输入分辨率的比例。
float ratio = 0.95238;
// 继承DnnNode虚基类,创建算法推理节点
class ObstacleDetectionNode : public hobot::dnn_node::DnnNode {
public:
ObstacleDetectionNode(const std::string& node_name = “ObstacleDetectionNode”,
const rclcpp::NodeOptions& options = rclcpp::NodeOptions());
protected:
// 实现基类的纯虚接口,用于配置Node参数
int SetNodePara() override;
// 实现基类的虚接口,将解析后结构化的算法输出数据封装成ROS Msg后发布
int PostProcess(const std::shared_ptrhobot::dnn_node::DnnNodeOutput&
node_output) override;
private:
// 算法输入图片数据的宽和高
int model_input_width_ = -1;
int model_input_height_ = -1;
// 图片消息订阅者
rclcpp::Subscription<hbm_img_msgs::msg::HbmMsg1080P>::ConstSharedPtr
hbm_img_subscription_ = nullptr;
rclcpp::Subscription<sensor_msgs::msg::Image>::ConstSharedPtr
ros_img_subscription_ = nullptr;
// 算法推理结果消息发布者
rclcpp::Publisher<ai_msgs::msg::PerceptionTargets>::SharedPtr msg_publisher_ =
nullptr;
std::string sub_img_topic_ = “/hbmem_img”;
std::string config_file_ = “config/yolov5sconfig_simulation.json”;
bool is_shared_mem_sub_ = true;
hobot::dnn_node::racing_obstacle_detection::PTQYolo5Config yolo5_config_ = {
{8, 16, 32},
{{{10, 13}, {16, 30}, {33, 23}},
{{30, 61}, {62, 45}, {59, 119}},
{{116, 90}, {156, 198}, {373, 326}}},
1,
{“construction_cone”}};
// 图片消息订阅回调
void FeedHbmImg(const hbm_img_msgs::msg::HbmMsg1080P::ConstSharedPtr msg);
void FeedImg(const sensor_msgs::msg::Image::ConstSharedPtr msg);
ObstacleDetectionNode::ObstacleDetectionNode(const std::string& node_name,
const rclcpp::NodeOptions& options)
: hobot::dnn_node::DnnNode(node_name, options) {
this->declare_parameterstd::string(“sub_img_topic”, sub_img_topic_);
this->declare_parameterstd::string(“config_file”, config_file_);
this->declare_parameter(“is_shared_mem_sub”, is_shared_mem_sub_);
this->get_parameterstd::string(“sub_img_topic”, sub_img_topic_);
this->get_parameterstd::string(“config_file”, config_file_);
this->get_parameter(“is_shared_mem_sub”, is_shared_mem_sub_);
// Init中使用ObstacleDetectionNode子类实现的SetNodePara()方法进行算法推理的初始化
if (Init() != 0 ||
GetModelInputSize(0, model_input_width_, model_input_height_) < 0) {
RCLCPP_ERROR(rclcpp::get_logger(“ObstacleDetectionNode”), “Node init fail!”);
rclcpp::shutdown();
LoadConfig(config_file_,yolo5_config_);
// 创建消息订阅者,从摄像头节点订阅图像消息
if (is_shared_mem_sub_ == true){
// --修改开始–原始代码
//hbm_img_subscription_ =
// this->create_subscription<hbm_img_msgs::msg::HbmMsg1080P>(
// sub_img_topic_,
// 1,
// std::bind(&ObstacleDetectionNode::FeedHbmImg, this, std::placeholders::1));
rclcpp::QoS img_qos(10);
img_qos.reliability(rclcpp::ReliabilityPolicy::BestEffort); // 设置为BestEffort可靠性策略
hbm_img_subscription =
sub_img_topic_,
img_qos, // 使用新的QoS策略
// — 修改点结束 —
} else {
//–修改点开始—原始代码:
//ros_img_subscription =
// this->create_subscription<sensor_msgs::msg::Image>(
// sub_img_topic_,
// 1,
// std::bind(&ObstacleDetectionNode::FeedImg, this, std::placeholders::1));
// 修改为:
sub_img_topic_,
// — 修改点结束 —
// 创建消息发布者,发布算法推理消息
msg_publisher = this->create_publisher<ai_msgs::msg::PerceptionTargets>(
“/racing_obstacle_detection”, 10);
int ObstacleDetectionNode::SetNodePara() {
if (!dnn_node_para_ptr_) return -1;
// 指定算法推理使用的模型文件路径
std::ifstream ifs(config_file_.c_str());
if (!ifs) {
RCLCPP_ERROR(rclcpp::get_logger(“SetNodePara”),
config_file_.data());
return -1;
return -1;
std::string model_file;
if (document.HasMember(“model_file”)) {
model_file = document[“model_file”].GetString();
dnn_node_para_ptr_->model_file = model_file;
// 指定算法推理任务类型
// 本示例使用的人体检测算法输入为单张图片,对应的算法推理任务类型为ModelInferType
// 只有当算法输入为图片和roi(Region of
// Interest,例如目标的检测框)时,算法推理任务类型为ModelRoiInferType
dnn_node_para_ptr_->model_task_type =
hobot::dnn_node::ModelTaskType::ModelInferType;
// 指定算法推理使用的任务数量,YOLOv5算法推理耗时较长,指定使用4个任务进行推理
dnn_node_para_ptr_->task_num = 1;
// 通过bpu_core_ids参数指定算法推理使用的BPU核,使用负载均衡模式
dnn_node_para_ptr_->bpu_core_ids.push_back(HB_BPU_CORE_0);
return 0;
void ObstacleDetectionNode::FeedHbmImg(
const hbm_img_msgs::msg::HbmMsg1080P::ConstSharedPtr img_msg) {
if (!rclcpp::ok() || !img_msg) {
return;
// 1 对订阅到的图片消息进行验证,本示例只支持处理NV12格式图片数据
// 如果是其他格式图片,订阅hobot_codec解码/转码后的图片消息
if (“nv12” !=
std::string(reinterpret_cast<const char*>(img_msg->encoding.data()))) {
"Only support nv12 img encoding! Using hobot codec to process "
“%d encoding img.”,
img_msg->encoding.data());
return;
// 2 创建算法输出数据,填充消息头信息,用于推理完成后AI结果的发布
auto dnn_output = std::make_shared();
dnn_output->msg_header = std::make_shared<std_msgs::msg::Header>();
dnn_output->msg_header->set__frame_id(std::to_string(img_msg->index));
dnn_output->msg_header->set__stamp(img_msg->time_stamp);
// 3 算法前处理,即创建算法输入数据
std::shared_ptrhobot::dnn_node::NV12PyramidInput pyramid = nullptr;
if (img_msg->height != static_cast<uint32_t>(model_input_height_) ||
img_msg->width != static_cast<uint32_t>(model_input_width_)) {
// 3.1 订阅到的图片和算法输入分辨率不一致,需要做resize处理
cv::Mat out_img;
if (ResizeNV12Img(reinterpret_cast<const char*>(img_msg->data.data()),
img_msg->height,
img_msg->width,
model_input_height_,
model_input_width_,
out_img,
dnn_output->ratio) < 0) {
“Resize nv12 img fail!”);
return;
uint32_t out_img_width = out_img.cols;
uint32_t out_img_height = out_img.rows * 2 / 3;
// 3.2 根据算法输入图片分辨率,使用hobot_dnn中提供的方法创建算法输入数据
pyramid = hobot::dnn_node::ImageProc::GetNV12PyramidFromNV12Img(
reinterpret_cast<const char*>(out_img.data),
out_img_height,
out_img_width,
model_input_width_);
} else {
// 3.3
// 不需要进行resize,直接根据算法输入图片分辨率,使用hobot_dnn中提供的方法创建算法输入数据
img_msg->height,
img_msg->width,
// 3.4 校验算法输入数据
if (!pyramid) {
RCLCPP_ERROR(rclcpp::get_logger(“ObstacleDetectionNode”), “Get pym fail”);
return;
// 3.5 将算法输入数据转成dnn node推理输入的格式
auto inputs =
std::vector<std::shared_ptrhobot::dnn_node::DNNInput>{pyramid};
// 4
// 使用创建的算法输入和输出数据,以异步模式运行推理,推理结果通过PostProcess接口回调返回
if (Run(inputs, dnn_output, nullptr, true) < 0) {
RCLCPP_INFO(rclcpp::get_logger(“ObstacleDetectionNode”), “Run predict fail!”);
void ObstacleDetectionNode::FeedImg(
const sensor_msgs::msg::Image::ConstSharedPtr img_msg) {
return;
dnn_output->msg_header->set__frame_id(img_msg->header.frame_id);
dnn_output->msg_header->set__stamp(img_msg->header.stamp);
auto cv_img = cv_bridge::cvtColorForDisplay(cv_bridge::toCvShare(img_msg), “bgr8”);
pyramid = ImageUtils::GetNV12Pyramid(
cv_img->image, model_input_height_, model_input_width_);
// 3.4 校验算法输入数据
if (!pyramid) {
return;
// // 3.5 将算法输入数据转成dnn node推理输入的格式
auto inputs =
// // 4
// // 使用创建的算法输入和输出数据,以异步模式运行推理,推理结果通过PostProcess接口回调返回
if (Run(inputs, dnn_output, nullptr, false) < 0) {
// 推理结果回调,解析算法输出,通过ROS Msg发布消息
int ObstacleDetectionNode::PostProcess(
const std::shared_ptrhobot::dnn_node::DnnNodeOutput& node_output) {
if (!rclcpp::ok()) {
return 0;
// 后处理开始时间
auto tp_start = std::chrono::system_clock::now();
// 1 创建用于发布推理结果的ROS Msg
ai_msgs::msg::PerceptionTargets::UniquePtr pub_data(
new ai_msgs::msg::PerceptionTargets());
// 2 将推理输出对应图片的消息头填充到ROS Msg
pub_data->set__header(*node_output->msg_header);
// 3 使用自定义的Parse解析方法,解析算法输出的DNNTensor类型数据
// 3.1
// 创建解析输出数据,输出YoloV5Result是自定义的算法输出数据类型,results的维度等于检测出来的目标数
std::vector<std::shared_ptrhobot::dnn_node::racing_obstacle_detection::YoloV5Result>
results;
// 3.2 开始解析
if (hobot::dnn_node::racing_obstacle_detection::Parse(node_output, results, yolo5_config_) < 0) {
“Parse node_output fail!”);
return -1;
// 3.3 使用解析后的数据填充到ROS Msg
for (auto& rect : results) {
if (!rect) continue;
if (rect->xmin < 0) rect->xmin = 0;
if (rect->ymin < 0) rect->ymin = 0;
if (rect->xmax >= model_input_width_) {
rect->xmax = model_input_width_ - 1;
if (rect->ymax >= model_input_height_) {
rect->ymax = model_input_height_ - 1;
std::stringstream ss;
ss << "det rect: " << rect->xmin << " " << rect->ymin << " " << rect->xmax
<< " " << rect->ymax << ", det type: " << rect->class_name
<< ", score:" << rect->score;
RCLCPP_INFO(rclcpp::get_logger("ObstacleDetectionNode"), "%s", ss.str().c_str());
ai_msgs::msg::Roi roi;
roi.rect.set__x_offset(rect->xmin);
roi.rect.set__y_offset(rect->ymin);
roi.rect.set__width(rect->xmax - rect->xmin);
roi.rect.set__height(rect->ymax - rect->ymin);
roi.set__confidence(rect->score);
ai_msgs::msg::Target target;
target.set__type(rect->class_name);
target.rois.emplace_back(roi);
pub_data->targets.emplace_back(std::move(target));
// 4 坐标映射
auto sample_node_output =
std::dynamic_pointer_cast(node_output);
if (!sample_node_output) {
“Cast dnn node output fail!”);
return -1;
if (sample_node_output->ratio != 1.0) {
// 前处理有对图片进行resize,需要将坐标映射到对应的订阅图片分辨率
for (auto& target : pub_data->targets) {
for (auto& roi : target.rois) {
roi.rect.x_offset *= sample_node_output->ratio;
roi.rect.y_offset *= sample_node_output->ratio;
roi.rect.width *= sample_node_output->ratio;
roi.rect.height *= sample_node_output->ratio;
// 5 将算法推理输出帧率填充到ROS Msg
if (node_output->rt_stat) {
pub_data->set__fps(round(node_output->rt_stat->output_fps));
// 如果算法推理统计有更新,输出算法输入和输出的帧率统计、推理耗时
if (node_output->rt_stat->fps_updated) {
// 后处理结束时间
auto tp_now = std::chrono::system_clock::now();
auto interval = std::chrono::duration_caststd::chrono::milliseconds(
tp_now - tp_start)
.count();
RCLCPP_WARN(rclcpp::get_logger(“ObstacleDetectionNode”),
"input fps: %.2f, out fps: %.2f, infer time ms: %d, "
“post process time ms: %d”,
node_output->rt_stat->input_fps,
node_output->rt_stat->output_fps,
node_output->rt_stat->infer_time_ms,
interval);
// 6 发布ROS Msg
msg_publisher_->publish(std::move(pub_data));
return 0;
int main(int argc, char** argv) {
rclcpp::init(argc, argv);
rclcpp::spin(std::make_shared());
rclcpp::shutdown();
return 0;
如何操作可以提高或者解决我的问题,求大老个思路,bpu加速方面吗?还是像素调低?
