大佬们,帮忙找找错误吧,这里是报错信息
[RDK_YOLO] [19:42:50.268] [INFO] Namespace(model_path=‘/home/sunrise/Desktop/yolo11n_detect_bayese_640x640_nv12.bin’, test_img=‘/home/sunrise/Desktop/images/2.jpg’, img_save_path=‘/home/sunrise/Desktop/result.jpg’, classes_num=1, reg=16, iou_thres=0.45, conf_thres=0.25)
X11 is available, using EGL for rendering.
[ERROR][utils/mem_log.c:94] [6657.68090][6857:6857][MEM_ALLOCATOR] <hb_mem_alloc_graph_buf:1144> Memory module is not found.
2025/07/10 19:42:50.637 ERROR [OpenDisplay][0159]hb_mem_alloc_graph_buf for buffer[0] failed error(-16777208)
1920 1080
[BPU_PLAT]BPU Platform Version(1.3.6)!
[A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.24.3
[RDK_YOLO] [19:42:50.861] [DEBUG] Load D-Robotics Quantize model time = 223.82 ms
[RDK_YOLO] [19:42:50.862] [INFO] → input tensors
[RDK_YOLO] [19:42:50.863] [INFO] intput[0], name=images, type=uint8, shape=(1, 3, 640, 640)
[RDK_YOLO] [19:42:50.863] [INFO] → output tensors
[RDK_YOLO] [19:42:50.863] [INFO] output[0], name=output0, type=float32, shape=(1, 80, 80, 64)
[RDK_YOLO] [19:42:50.863] [INFO] output[1], name=469, type=float32, shape=(1, 40, 40, 64)
[RDK_YOLO] [19:42:50.864] [INFO] output[2], name=477, type=float32, shape=(1, 20, 20, 64)
[RDK_YOLO] [19:42:50.864] [INFO] output[3], name=491, type=float32, shape=(1, 80, 80, 1)
[RDK_YOLO] [19:42:50.864] [INFO] output[4], name=505, type=float32, shape=(1, 40, 40, 1)
[RDK_YOLO] [19:42:50.864] [INFO] output[5], name=519, type=float32, shape=(1, 20, 20, 1)
[RDK_YOLO] [19:42:50.865] [INFO] self.s_bboxes_scale.shape=(1, 0), self.m_bboxes_scale.shape=(1, 0), self.l_bboxes_scale.shape=(1, 0)
[RDK_YOLO] [19:42:50.865] [INFO] self.weights_static.shape = (1, 1, 16)
[RDK_YOLO] [19:42:50.868] [INFO] self.s_anchor.shape = (6400, 2), self.m_anchor.shape = (1600, 2), self.l_anchor.shape = (400, 2)
[RDK_YOLO] [19:42:50.869] [INFO] iou threshol = 0.45, conf threshol = 0.25
[RDK_YOLO] [19:42:50.869] [INFO] sigmoid_inverse threshol = -1.10
[RDK_YOLO] [19:42:51.176] [DEBUG] bgr8 to nv12 time = 9.39 ms
[RDK_YOLO] [19:42:51.188] [DEBUG] forward time = 11.04 ms
[RDK_YOLO] [19:42:51.191] [DEBUG] c to numpy time = 2.46 ms
[RDK_YOLO] [19:42:51.194] [DEBUG] Post Process time = 2.79 ms
[RDK_YOLO] [19:42:51.195] [INFO] san
[RDK_YOLO] [19:42:51.195] [INFO] No objects detected.
[n2d_map(1580)] error = 0x1
2025/07/10 19:42:51.237 ERROR [SetImageFrame][0442]convertN2DBuffer(NV12) fail,ret:1
2025/07/10 19:42:51.237 ERROR [SetImageFrame][0448]convertN2DBuffer(AR24) fail,ret:1
2025/07/10 19:42:51.237 ERROR [SetImageFrame][0453]convertN2DBuffer(NV12 final) fail,ret:1
2025/07/10 19:42:51.237 ERROR [SetImageFrame][0457]convertN2DBuffer(NV12 final) fail,ret:1
[n2d_allocate(1391)] error = 0x1
[n2d_util_allocate_buffer(1618)] error = 0x1
2025/07/10 19:42:51.238 !INFO [SetImageFrame][0469]N2D init done!
Segmentation fault
