基于RDKX5的板卡,微雪电子的SC132gs双目摄像头。现在我基于mipi打卡摄像头的例程,只连接右边一路摄像头的mipi,可以获取到图像数据,但是我只连接左边一路摄像头的mipi,就获取不到数据。板卡上两路mipi都做了测试,都是同样的问题,如果两路都连接的话,会提示mipi超过两路,不管输入那一路都是只出右边摄像头的数据。运行i2cdetect两路都有数据,并且运行官方例程中两路mipi采集,基于ros2的,在电脑上网页端也可以看到两路数据,证明摄像头本身没有问题。
1920x1080
1680x1050
1600x900
1280x1024
1280x720
1024x768
800x600
720x576
720x480
720x400
640x480
Resolution 1920x1080 exists in the list.
[BPU_PLAT]BPU Platform Version(1.3.6)!
[A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.23.5
[W][DNN]bpu_model_info.cpp:491]Version Model: fcos_efficientnetb0_512x512_nv12. Inconsistency between the hbrt library version 3.15.55.0 and the model build version 3.15.47.0 detected, in order to ensure correct model results, it is recommended to use compilation tools and the BPU SDK from the same OpenExplorer package.
— model input properties —
tensor type: NV12
data type: uint8
layout: NCHW
shape: (1, 3, 512, 512)
— model output properties —
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 64, 64, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 32, 32, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 16, 16, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 8, 8, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 4, 4, 80)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 64, 64, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 32, 32, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 16, 16, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 8, 8, 4)
tensor type: int32
data type: int32
layout: NHWC
shape: (1, 4, 4, 4)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 64, 64, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 32, 32, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 16, 16, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 8, 8, 1)
tensor type: int32
data type: int32
layout: NCHW
shape: (1, 4, 4, 1)
set camera fps: -1,width: 1920,height: 1080
Camera 0:
i2c_bus: 6
mipi_host: 0
Camera 1:
i2c_bus: 4
mipi_host: 2
Camera 2:
i2c_bus: 0
mipi_host: 0
Camera 3:
i2c_bus: 0
mipi_host: 0
[INFO] board_id is 302, so skip csi test for index 1 and index 3
mipi mclk is not configed.
WARN: Sensor Name: sc035hgs, Expected Chip ID: 0x35, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx477-2016x1520-40fps, Expected Chip ID: 0x477, Actual Chip ID Read: 0x00
2025/07/23 15:53:04.591 ERROR [CamInitParam][0258]No camera sensor found, please check whether the camera connection or video_idx is correct.
2025/07/23 15:53:04.591 ERROR [OpenCamera][0410]CamInitParam failed error(-1)
