RDKX5利用TROS部署yolov11时,DNN 节点崩溃 和 MIPI 摄像头初始化异常
参考文档:YOLOv11,地瓜RDK X5开发板,TROS端到端140FPS! - 板卡使用 / RDK Model Zoo - 地瓜机器人论坛
root@ubuntu:/home/sunrise/yolo# source /opt/tros/humble/setup.bash
export CAM_TYPE=mipi
ros2 launch dnn_node_example dnn_node_example.launch.py
dnn_example_config_file:=/home/sunrise/yolo/test/test_mipi/yolov11.json
[INFO] [launch]: All log files can be found below /root/.ros/log/2025-09-11-15-01-51-078165-ubuntu-15150
camera_type is mipi
using mipi cam
webserver has launch
[INFO] [mipi_cam-1]: process started with pid [15159]
[INFO] [hobot_codec_republish-2]: process started with pid [15161]
[INFO] [example-3]: process started with pid [15163]
[INFO] [websocket-4]: process started with pid [15165]
[hobot_codec_republish-2] [WARN] [1757574111.634915123] [hobot_codec_encoder]: Parameters:
[hobot_codec_republish-2] sub_topic: /hbmem_img
[hobot_codec_republish-2] pub_topic: /image
[hobot_codec_republish-2] in_mode: shared_mem
[hobot_codec_republish-2] out_mode: ros
[hobot_codec_republish-2] in_format: nv12
[hobot_codec_republish-2] out_format: jpeg
[hobot_codec_republish-2] enc_qp: 10
[hobot_codec_republish-2] jpg_quality: 60
[hobot_codec_republish-2] dump_output: 0
[hobot_codec_republish-2] [WARN] [1757574111.640839199] [HobotCodecImpl]: platform x5
[hobot_codec_republish-2] [WARN] [1757574111.641057782] [hobot_codec_encoder]: Enabling zero-copy
[mipi_cam-1] [WARN] [1757574111.951048856] [mipi_node]: dual_combine value: 0
[mipi_cam-1] [WARN] [1757574111.951288106] [mipi_node]: frame_ts_type value: realtime
[mipi_cam-1] [WARN] [1757574111.963899049] [mipi_factory]: board_type X5_RDK
[mipi_cam-1]
[mipi_cam-1] [WARN] [1757574111.965063172] [mipi_cam]: this board support mipi:
[mipi_cam-1] [WARN] [1757574111.965307839] [mipi_cam]: host 0
[mipi_cam-1] [WARN] [1757574111.965405297] [mipi_cam]: host 2
[mipi_cam-1] [WARN] [1757574111.965709797] [mipi_cam]: Camera calibration file: /calibration.yaml is not exist!
[mipi_cam-1] If you need calibration msg, please make sure the calibration file path is correct and the calibration file exists!
[example-3] [HBRT] set log level as 0. version = 3.15.55.0
[example-3] [DNN] Runtime version = 1.24.5
(3.15.55 HBRT)
[websocket-4] [WARN] [1757574111.999863504] [websocket]:
[websocket-4] Parameter:
[websocket-4] output_fps: 0
[example-3] [A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.24.3
[mipi_cam-1] [WARN] [1757574112.512709786] [mipi_cap]: gdc bin file ���� open failed
[mipi_cam-1]
[mipi_cam-1] [WARN] [1757574113.284760080] [mipi_cam]: [init]->cap F37 init success.
[mipi_cam-1]
[mipi_cam-1] [WARN] [1757574113.285007038] [mipi_cam]: Enabling zero-copy
[hobot_codec_republish-2] [WARN] [1757574113.378847381] [hobot_codec_encoder]: Loaned messages are only safe with const ref subscription callbacks. If you are using any other kind of subscriptions, set the ROS_DISABLE_LOANED_MESSAGES environment variable to 1 (the default).
[h
TROS在运行一次YOLO功能后,在当前目录的config文件夹内有若干workconfig.json文件,在这个workconfig.json文件中,有TROS使用的bin模型的路径,这些模型都是RDK板子上自带的. 您可以使用上述方法来比对自己的模型和板子上自带的能跑的模型的区别。对比的项目有:输出头的顺序,tensor type,量化与反量化类型.
hrt_model_exec model_info --model_file 命令查看bin模型的输入输出信息
这是你最新的:
Load model to DDR cost 32.671ms.
This model file has 1 model:
[yolo11n_detect_bayese_640x640_nv12]
input[0]:
input source: HB_DNN_INPUT_FROM_PYRAMID
valid shape: (1,3,640,640,)
aligned shape: (1,3,640,640,)
aligned byte size: 614400
tensor type: HB_DNN_IMG_TYPE_NV12
quanti type: NONE
stride: (0,0,0,0,)
output[0]:
valid shape: (1,80,80,80,)
aligned shape: (1,80,80,80,)
aligned byte size: 2048000
quanti type: NONE
stride: (2048000,25600,320,4,)
output[1]:
valid shape: (1,80,80,64,)
aligned shape: (1,80,80,64,)
aligned byte size: 1638400
quanti type: NONE
output[2]:
valid shape: (1,40,40,80,)
aligned shape: (1,40,40,80,)
aligned byte size: 512000
quanti type: NONE
stride: (512000,12800,320,4,)
output[3]:
valid shape: (1,40,40,64,)
aligned shape: (1,40,40,64,)
aligned byte size: 409600
quanti type: NONE
stride: (409600,10240,256,4,)
output[4]:
valid shape: (1,20,20,80,)
aligned shape: (1,20,20,80,)
aligned byte size: 128000
quanti type: NONE
stride: (128000,6400,320,4,)
output[5]:
valid shape: (1,20,20,64,)
aligned shape: (1,20,20,64,)
aligned byte size: 102400
quanti type: NONE
stride: (102400,5120,256,4,)
这是我的:
Caomei14-yolo11_modified.bin:
root@20ee6ba3ada7:/open_explorer# hrt_model_exec model_info --model_file /data/model_output_dir14/caomei14-yolo11.bin
I0000 00:00:00.000000 14 vlog_is_on.cc:197] RAW: Set VLOG level for “*” to 3
core[0] open!
core[1] open!
Load model to DDR cost 50.359ms.
[caomei14-yolo11]
input[0]:
quanti type: NONE
stride: (0,0,0,0,)
output[0]:
valid shape: (1,80,80,3,)
aligned shape: (1,80,80,3,)
aligned byte size: 76800
quanti type: NONE
stride: (76800,960,12,4,)
output[1]:
quanti type: NONE
output[2]:
valid shape: (1,40,40,3,)
aligned shape: (1,40,40,3,)
aligned byte size: 19200
quanti type: NONE
stride: (19200,480,12,4,)
output[3]:
quanti type: NONE
output[4]:
valid shape: (1,20,20,3,)
aligned shape: (1,20,20,3,)
aligned byte size: 4800
quanti type: NONE
stride: (4800,240,12,4,)
output[5]:
quanti type: NONE
看看你的config.json,你的是3类别的模型
这个dnn节点根本就用不了在yolo11上面,你们现在也没有yolo11的tros部署检测,一用就报错excode=-11,
[ERROR] [example-3]: process has died [pid 20955, exit code -11, cmd ‘/opt/tros/humble/lib/dnn_node_example/example --ros-args --log-level warn --ros-args --params-file /tmp/launch_params_ha1qjiv2 --params-file /tmp/launch_params_bd4u1ore --params-file /tmp/launch_params_wvwdbcfq --params-file /tmp/launch_params_o07i7czg --params-file /tmp/launch_params_uhqj93yw --params-file /tmp/launch_params_jvjm96be --params-file /tmp/launch_params_dqlfaq29 --params-file /tmp/launch_params_m3zqu3n4’].
640640和640480的模型都用不了,我还以为模型问题我还训练了不同尺度的模型,本地文件灌输也灌输不了,识别输入为0,
sunrise@ubuntu:~$ ros2 launch dnn_node_example dnn_node_example_feedback.launch.py dnn_example_config_file:=/home/sunrise/caomei/caomei14-yolo11.json dnn_example_image:=/home/sunrise/caomei/10.png
[INFO] [launch]: All log files can be found below /home/sunrise/.ros/log/2000-01-01-10-25-45-551972-ubuntu-21150
[INFO] [example-1]: process started with pid [21153]
[example-1] [WARN] [0946693546.239337657] [dnn_example_node]: Parameter:
[example-1] feed_type(0:local, 1:sub): 0
[example-1] image: /home/sunrise/caomei/10.png
[example-1] image_type: 0
[example-1] dump_render_img: 1
[example-1] is_shared_mem_sub: 0
[example-1] config_file: /home/sunrise/caomei/caomei14-yolo11.json
[example-1] msg_pub_topic_name: hobot_dnn_detection
[example-1] info_msg_pub_topic_name: hobot_dnn_detection_info
[example-1] ros_img_topic_name: /image
[example-1] sharedmem_img_topic_name: /hbmem_img
[example-1] [WARN] [0946693546.240104822] [dnn_example_node]: Load [3] class types from file [/home/sunrise/caomei/caomei.list]
[example-1] [WARN] [0946693546.240240905] [dnn_example_node]: Parameter:
[example-1] model_file_name: /home/sunrise/caomei/caomei14-yolo11_modified.bin
[example-1] model_name:
[example-1] [INFO] [0946693546.240322947] [dnn]: Node init.
[example-1] [INFO] [0946693546.240349155] [dnn_example_node]: Set node para.
[example-1] [WARN] [0946693546.240391613] [dnn_example_node]: model_file_name_: /home/sunrise/caomei/caomei14-yolo11_modified.bin, task_num: 4
[example-1] [INFO] [0946693546.240439863] [dnn]: Model init.
[example-1] [BPU_PLAT]BPU Platform Version(1.3.6)!
[example-1] [HBRT] set log level as 0. version = 3.15.55.0
[example-1] [DNN] Runtime version = 1.24.5_(3.15.55 HBRT)
[example-1] [A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.24.3
[example-1] [INFO] [0946693546.402866078] [dnn]: The model input 0 width is 640 and height is 640
[example-1] [INFO] [0946693546.403038286] [dnn]:
[example-1] Model Info:
[example-1] name: caomei14-yolo11.
[example-1] [input]
[example-1] - (0) Layout: NCHW, Shape: [1, 3, 640, 640], Type: HB_DNN_IMG_TYPE_NV12.
[example-1] [output]
[example-1] - (0) Layout: NHWC, Shape: [1, 80, 80, 3], Type: HB_DNN_TENSOR_TYPE_F32.
[example-1] - (1) Layout: NHWC, Shape: [1, 80, 80, 64], Type: HB_DNN_TENSOR_TYPE_S32.
[example-1] - (2) Layout: NHWC, Shape: [1, 40, 40, 3], Type: HB_DNN_TENSOR_TYPE_F32.
[example-1] - (3) Layout: NHWC, Shape: [1, 40, 40, 64], Type: HB_DNN_TENSOR_TYPE_S32.
[example-1] - (4) Layout: NHWC, Shape: [1, 20, 20, 3], Type: HB_DNN_TENSOR_TYPE_F32.
[example-1] - (5) Layout: NHWC, Shape: [1, 20, 20, 64], Type: HB_DNN_TENSOR_TYPE_S32.
[example-1]
[example-1] [INFO] [0946693546.403096119] [dnn]: Task init.
[example-1] [INFO] [0946693546.404748033] [dnn]: Set task_num [4]
[example-1] [WARN] [0946693546.404838616] [dnn_example_node]: Get model name: caomei14-yolo11 from load model.
[example-1] [INFO] [0946693546.404963741] [dnn_example_node]: The model input width is 640 and height is 640
[example-1] [WARN] [0946693546.405025657] [dnn_example_node]: Create ai msg publisher with topic_name: hobot_dnn_detection
[example-1] [INFO] [0946693546.419074587] [dnn_example_node]: Dnn node feed with local image: /home/sunrise/caomei/10.png
[example-1] [INFO] [0946693546.613010156] [dnn_example_node]: Output from frame_id: feedback, stamp: 0.0
[ERROR] [example-1]: process has died [pid 21153, exit code -11, cmd ‘/opt/tros/humble/lib/dnn_node_example/example --ros-args --log-level info --ros-args --params-file /tmp/launch_params_jd1mw7dm --params-file /tmp/launch_params_2tz8rarc --params-file /tmp/launch_params_s1smceo4 --params-file /tmp/launch_params_96tpnf65 --params-file /tmp/launch_params_bhji8r9l’].
这问题都好几个月了不给解决吗
“model_file”: “/home/sunrise/caomei/caomei14-yolo11_modified.bin”,
“dnn_Parser”: “yolov8”,
“model_output_count”: 6,
“reg_max”: 16,
“class_num”: 3,
“cls_names_list”: “/home/sunrise/caomei/caomei.list”,
“strides”: [8, 16, 32],
“score_threshold”: 0.25,
“nms_threshold”: 0.7,
“nms_top_k”: 300
你看看TROS原版的YOLOv8跑的对应的那个bin模型的hrt_model_exec model_info xxxx的输入输出信息看看,应该不是你提供的这个
root@20ee6ba3ada7:/open_explorer# hrt_model_exec model_info --model_file /data/yolov8_640x640_nv12.bin
I0000 00:00:00.000000 40 vlog_is_on.cc:197] RAW: Set VLOG level for “*” to 3
core[0] open!
core[1] open!
[A][DNN][packed_model.cpp:247]Model [HorizonRT] The model builder version = 1.23.6
[W][DNN]bpu_model_info.cpp:491]Version Model: yolov8n_640x640_nv12. Inconsistency between the hbrt library version 3.15.55.0 and the model build version 3.15.49.0 detected, in order to ensure correct model results, it is recommended to use compilation tools and the BPU SDK from the same OpenExplorer package.
Load model to DDR cost 47.83ms.
[yolov8n_640x640_nv12]
input[0]:
quanti type: NONE
stride: (0,0,0,0,)
output[0]:
quanti type: NONE
output[1]:
quanti type: SCALE
scale data: 0.000318929,0.00032147,0.000303427,0.000281826,0.000237608,0.000196948,0.000192247,0.000155271,0.000198091,0.000214101,0.000143454,0.000127381,0.000122235,9.83469e-05,8.10663e-05,8.29722e-05,0.000302664,0.000309272,0.000280555,0.000250569,0.000223504,0.000290721,0.000195931,0.000159083,0.000185004,0.00017738,0.000118804,0.00012179,0.000118423,0.000104954,9.37726e-05,0.000122235,0.000314354,0.000319945,0.000282843,0.000243453,0.000244724,0.000179667,0.000201903,0.000133289,0.000208129,0.00018475,0.000123251,0.000120583,0.000112514,9.0469e-05,7.85886e-05,0.0001047,0.000297074,0.000273186,0.000267595,0.000225664,0.000214483,0.000301648,0.000234304,0.000173695,0.000156034,0.000156415,8.93254e-05,0.000109592,0.000106542,8.76736e-05,7.52849e-05,8.96431e-05,
quantizeAxis: 3
output[2]:
quanti type: NONE
output[3]:
quanti type: SCALE
scale data: 0.000231898,0.000221052,0.000178185,0.000175,0.000157353,0.000143408,0.000150209,0.000144097,0.000126451,0.000105533,9.24494e-05,8.53048e-05,9.22772e-05,9.12442e-05,8.67681e-05,9.78724e-05,0.000230349,0.00022329,0.00020332,0.00017061,0.000165359,0.000140051,0.000157095,0.000147196,0.000107427,0.000124815,9.03834e-05,7.26511e-05,8.08717e-05,7.97096e-05,7.42866e-05,9.11582e-05,0.000233964,0.000235341,0.000227078,0.000174655,0.000139363,0.000147971,0.000156148,0.00011965,0.000129033,0.000107169,8.014e-05,8.16894e-05,9.69255e-05,0.000106394,0.000108891,0.000122663,0.00022088,0.000211239,0.000213649,0.000175602,0.000164067,0.000149606,0.000143753,0.000119306,0.00010209,0.000156492,0.000102865,7.32967e-05,8.8834e-05,9.81306e-05,0.000100971,0.000115691,
quantizeAxis: 3
output[4]:
quanti type: NONE
output[5]:
quanti type: SCALE
scale data: 0.00026432,0.000255302,0.000239413,0.000278062,0.000228033,0.000182512,0.000184122,0.000209567,0.00022245,0.000162758,0.000213754,0.000158678,0.000157927,0.000162758,0.000150519,0.000126792,0.000250793,0.000232971,0.000260455,0.00025702,0.000219873,0.000179291,0.000224812,0.000158678,0.000194,0.000245425,0.000159108,0.00015943,0.000128295,0.000118525,9.5443e-05,6.18394e-05,0.000251008,0.000281068,0.000253155,0.000264535,0.000242204,0.000195825,0.000253799,0.000159644,0.00018176,0.000177573,0.000224597,0.000158249,0.00012486,0.000168985,0.000186914,0.000174889,0.000273983,0.000269044,0.000255732,0.000202803,0.000206668,0.000221591,0.000227388,0.000172742,0.000206131,0.000199045,0.00017242,0.000148694,0.000138172,0.000151378,0.000143326,0.000127436,
quantizeAxis: 3这是yolov8的,可是我是yolo11,我跟着你最新文档做的,你们最新文档的yolo11.bin就是我前面提供的,我不应该对比yolo11的吗,还是说你们的yolo11的dnn节点根本没做好
yolov8的节点一用就是excode=-11
请问你使用的系统版本是?能否提供一下sudo rdkos_info 命令返回的日志
请不要在问题排查清楚前下这样的结论或者质疑,这不利于问题的解决。
sunrise@ubuntu:~$ sudo rdkos_info
================ RDK System Information Collection ================
[Hardware Model]:
D-Robotics RDK X5 V1.0 (Board Id = 302)
    temperature-->
            DDR      : 48.6 (C)
            BPU      : 48.0 (C)
            CPU      : 48.0 (C)
    cpu frequency-->
                  min(M)    cur(M)  max(M)
            cpu0: 300       1200    1500
            cpu1: 300       1200    1500
            cpu2: 300       1200    1500
            cpu3: 300       1200    1500
            cpu4: 300       300     1500
            cpu5: 300       1200    1500
            cpu6: 300       1200    1500
            cpu7: 300       1200    1500
    bpu status information---->
            ddr:  266       4266    4266
            gc8000:  200    1000    1000
[RDK Kernel Version]:
Linux ubuntu 6.1.83 #1 SMP PREEMPT Tue Feb 11 00:25:16 CST 2025 aarch64 aarch64 aarch64 GNU/Linux
[RDK Miniboot Version]:
U-Boot 2022.10+ (Nov 22 2024 - 14:00:59 +0800)
到底咋解决呀,都困惑一星期了
这个bin模型输入输出头看上去没有问题。
但是rdkos_info 命令返回的信息非常不完整,建议烧录RDK X5的最新系统后再试。
