操作过程参考了vio2display示例:
vio2display输出的日志,提示“No camera sensor found, please check whether the camera connection or video_idx is correct”:
./vio2display -h 1080 -w 1280
Opened DRM device: /dev/dri/card0
1024x600
832x624
800x600
720x576
720x480
720x400
640x480
disp_w=1024, disp_h=600
2026/01/12 12:50:32.185 !INFO [OpenCamera][0447]hbn module
set camera fps: -1,width: 1280,height: 1080
Camera 0:
mipi_host: 0
Camera 1:
mipi_host: 2
Camera 2:
mipi_host: 0
Camera 3:
mipi_host: 0
mipi mclk is not configed.
WARN: Sensor Name: sc230ai-10fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x132
WARN: Sensor Name: sc230ai-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x132
WARN: Sensor Name: sc132gs-hdr-2lane, Expected Chip ID: 0x132, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc035hgs, Expected Chip ID: 0x31, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc035hgs_mono, Expected Chip ID: 0x31, Actual Chip ID Read: 0x32
WARN: Sensor Name: sc231ai-30fps, Expected Chip ID: 0xCB6A, Actual Chip ID Read: 0x132
WARN: Sensor Name: imx586-30fps-4lane, Expected Chip ID: 0x586, Actual Chip ID Read: 0x00
WARN: Sensor Name: os08c10-30fps-2lane, Expected Chip ID: 0x53, Actual Chip ID Read: 0x00
WARN: Sensor Name: ar0233-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
WARN: Sensor Name: ar0820std-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc1336, Expected Chip ID: 0xCA3F, Actual Chip ID Read: 0x00
WARN: Sensor Name: dummy, Expected Chip ID: 0x00, Actual Chip ID Read: 0x00
WARN: Sensor Name: ar0233-30fps, Expected Chip ID: 0xA55A, Actual Chip ID Read: 0x00
WARN: Sensor Name: ov9782-200fps-2lane, Expected Chip ID: 0x9281, Actual Chip ID Read: 0x00
WARN: Sensor Name: ov9782-120fps-2lane, Expected Chip ID: 0x9281, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx477-2016x1520-21fps, Expected Chip ID: 0x477, Actual Chip ID Read: 0x00
WARN: Sensor Name: ov50h40-30fps-4lane, Expected Chip ID: 0x6C, Actual Chip ID Read: 0x00
WARN: Sensor Name: ox05b1s, Expected Chip ID: 0x58, Actual Chip ID Read: 0x00
WARN: Sensor Name: ox05b1s_2lane, Expected Chip ID: 0x58, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx415-60fps-4lane, Expected Chip ID: 0x03, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc850sl-30fps, Expected Chip ID: 0x9D1E, Actual Chip ID Read: 0x00
WARN: Sensor Name: shw3g-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
2026/01/12 12:50:32.477 ERROR [CamInitParam][0283]No camera sensor found, please check whether the camera connection or video_idx is correct.
2026/01/12 12:50:32.477 ERROR [OpenCamera][0495]CamInitParam failed error(-1)
[Error] sp_open_camera failed!
软件环境:
# cat /etc/version
3.4.1
root@ubuntu:~# dpkg --status hobot-spdev
Package: hobot-spdev
Status: install ok installed
Installed-Size: 1057
Maintainer: developer@d-robotics.cc
Architecture: arm64
Version: 3.0.8-20251208164547
Depends: hobot-multimedia, hobot-camera, hobot-dnn
Description: Python and C/C++ Development Interface
Git Commit: 19e6f00fe0c792be14fdda6bef9360cde113ff3d
接线:
尝试过的排障:
- 尝试根据提示“No camera sensor found, please check whether the camera connection or video_idx is correct”,修改video_idx的值,无果。
- 跑TROS的示例“5.2.1 数据采集”、“双目深度算法”,都是正常能出图的,跑出来的深度数据也正常,说明硬件和接线没问题
- i2cdetect看着也没什么问题:
root@ubuntu:/app/cdev_demo/vio2display# i2cdetect -r -y 4
00: -- -- -- -- -- -- -- --
30: -- -- -- 33 -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@ubuntu:/app/cdev_demo/vio2display# i2cdetect -r -y 6
30: -- -- 32 -- -- -- -- -- -- -- -- -- -- -- -- --
请帮忙排障,万分感谢!
