S100上TROS推理ModelZoo模型求助
我使用Yolo11训练了一个识别车辆和牌照的模型,使用S100OE搭配ModelZoo的Mapper脚本进行量化处理
使用ModelZoo中的rdk_yolo_app.py进行测试时可以正常识别
随后按照此帖修改dnnnode并重新编译后覆盖到板端
但是使用dnn_node_example修改配置文件进行测试的时候出现了大量错误的识别框而且似乎没有正确识别到相关的对象
这个截图的配置是
score_threshold:0.8
nms_threshold:0.1
nms_top_k:300
默认配置时这样:
使用https://archive.d-robotics.cc/downloads/rdk_model_zoo/rdk_s100/ultralytics_YOLO/yolo11s_detect_nashe_640x640_nv12.hbm和默认配置进行测试结果则如下:
补充下使用rdk_yolo_app.py进行测试时输出的识别结果基本都是正常的如下:
100张测试图中只有一张出现了错误:
收到问题,应该还是后处理出现的问题,可以把修改后的后处理cpp发出
// Copyright (c) 2024,D-Robotics.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//     http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#include "dnn_node/util/output_parser/detection/ptq_yolo8_output_parser.h"
#include <arm_neon.h>
#include <fstream>
#include <future>
#include <iostream>
#include <queue>
#include "dnn_node/util/output_parser/detection/nms.h"
#include "dnn_node/util/output_parser/utils.h"
#include "rapidjson/document.h"
#include "rclcpp/rclcpp.hpp"
namespace hobot {
namespace dnn_node {
namespace parser_yolov8 {
inline float fastExp(float x) {
  union {
    uint32_t i;
    float f;
  } v;
  v.i = (12102203.1616540672f * x + 1064807160.56887296f);
  return v.f;
 * Finds the greatest element in the range [first, last)
 * @tparam[in] ForwardIterator: iterator type
 * @param[in] first: fist iterator
 * @param[in] last: last iterator
 * @return Iterator to the greatest element in the range [first, last)
template <class ForwardIterator>
inline size_t argmax(ForwardIterator first, ForwardIterator last) {
  return std::distance(first, std::max_element(first, last));
#define BSWAP_32(x) static_cast<int32_t>(__builtin_bswap32(x))
#define r_int32(x, big_endian) \
  (big_endian) ? BSWAP_32((x)) : static_cast<int32_t>((x))
 * Config definition for Yolo8
struct PTQYolo8Config {
  std::vector<int> strides;
  int class_num;
  int reg_max;
  std::vector<std::string> class_names;
  std::vector<std::vector<float>> dequantize_scale;
  std::vector<int> output_order;
  std::string Str() {
    std::stringstream ss;
    ss << "strides: ";
    for (const auto &stride : strides) {
      ss << stride << " ";
    ss << "; class_num: " << class_num;
    ss << "; reg_max: " << reg_max;
    return ss.str();
PTQYolo8Config default_ptq_yolo8_config = {
    {8, 16, 32}, 80, 16, {"person",        "bicycle",      "car",
                          "motorcycle",    "airplane",     "bus",
                          "train",         "truck",        "boat",
                          "traffic light", "fire hydrant", "stop sign",
                          "parking meter", "bench",        "bird",
                          "cat",           "dog",          "horse",
                          "sheep",         "cow",          "elephant",
                          "bear",          "zebra",        "giraffe",
                          "backpack",      "umbrella",     "handbag",
                          "tie",           "suitcase",     "frisbee",
                          "skis",          "snowboard",    "sports ball",
                          "kite",          "baseball bat", "baseball glove",
                          "skateboard",    "surfboard",    "tennis racket",
                          "bottle",        "wine glass",   "cup",
                          "fork",          "knife",        "spoon",
                          "bowl",          "banana",       "apple",
                          "sandwich",      "orange",       "broccoli",
                          "carrot",        "hot dog",      "pizza",
                          "donut",         "cake",         "chair",
                          "couch",         "potted plant", "bed",
                          "dining table",  "toilet",       "tv",
                          "laptop",        "mouse",        "remote",
                          "keyboard",      "cell phone",   "microwave",
                          "oven",          "toaster",      "sink",
                          "refrigerator",  "book",         "clock",
                          "vase",          "scissors",     "teddy bear",
                          "hair drier",    "toothbrush"}};
PTQYolo8Config yolo8_config_ = default_ptq_yolo8_config;
float score_threshold_ = 0.4;
static bool is_performance_ = true;
float nms_threshold_ = 0.5;
int nms_top_k_ = 5000;
int InitClassNum(const int &class_num) {
  if (class_num > 0) {
    yolo8_config_.class_num = class_num;
  } else {
    RCLCPP_ERROR(rclcpp::get_logger("Yolo8_detection_parser"),
                 "class_num = %d is not allowed, only support class_num > 0",
                 class_num);
    return -1;
  return 0;
int InitClassNames(const std::string &cls_name_file) {
  std::ifstream fi(cls_name_file);
  if (fi) {
    yolo8_config_.class_names.clear();
    std::string line;
    while (std::getline(fi, line)) {
      yolo8_config_.class_names.push_back(line);
    int size = yolo8_config_.class_names.size();
    if (size != yolo8_config_.class_num) {
                   "class_names length %d is not equal to class_num %d",
                   size,
                   yolo8_config_.class_num);
      return -1;
  } else {
                 "can not open cls name file: %s",
                 cls_name_file.c_str());
    return -1;
  return 0;
int InitRegMax(const int &reg_max) {
  if (reg_max > 0) {
    yolo8_config_.reg_max = reg_max;
  } else {
                 "reg_max = %d is not allowed, only support class_num > 0",
                 reg_max);
    return -1;
  return 0;
int InitStrides(const std::vector<int> &strides,
                const int &model_output_count) {
  int size = strides.size();
  if (size * 2 != model_output_count) {
    RCLCPP_ERROR(rclcpp::get_logger("yolo8_detection_parser"),
                 "strides size %d is not equal to model_output_count %d",
                 size,
                 model_output_count);
    return -1;
  yolo8_config_.strides.clear();
  for (size_t i = 0; i < strides.size(); i++) {
    yolo8_config_.strides.push_back(strides[i]);
  return 0;
int LoadConfig(const rapidjson::Document &document) {
  int model_output_count = 0;
  if (document.HasMember("model_output_count")) {
    model_output_count = document["model_output_count"].GetInt();
    if (model_output_count <= 0) {
                   "model_output_count = %d <= 0 is not allowed",
      return -1;
  if (document.HasMember("class_num")) {
    int class_num = document["class_num"].GetInt();
    if (InitClassNum(class_num) < 0) {
      return -1;
  if (document.HasMember("cls_names_list")) {
    std::string cls_name_file = document["cls_names_list"].GetString();
    if (InitClassNames(cls_name_file) < 0) {
      return -1;
  if (document.HasMember("reg_max")) {
    int reg_max = document["reg_max"].GetInt();
    if (InitRegMax(reg_max) < 0) {
      return -1;
  if (document.HasMember("strides")) {
    for (size_t i = 0; i < document["strides"].Size(); i++) {
      strides.push_back(document["strides"][i].GetInt());
    if (InitStrides(strides, model_output_count) < 0) {
      return -1;
  if (document.HasMember("score_threshold")) {
    score_threshold_ = document["score_threshold"].GetFloat();
  if (document.HasMember("nms_threshold")) {
    nms_threshold_ = document["nms_threshold"].GetFloat();
  score_threshold_ = -log(1 / score_threshold_ - 1);
  if (document.HasMember("nms_top_k")) {
    nms_top_k_ = document["nms_top_k"].GetInt();
  if (document.HasMember("is_performance")) {
    is_performance_ = document["is_performance"].GetBool();
  if (document.HasMember("output_order")) {
    for (size_t i = 0; i < document["output_order"].Size(); i++) {
      yolo8_config_.output_order.push_back(
          document["output_order"][i].GetInt());
    if (InitOutputOrder(yolo8_config_.output_order, model_output_count) < 0) {
      return -1;
  } else {
    for (int i = 0; i < model_output_count; i++) {
      yolo8_config_.output_order.push_back(i);
  return 0;
int PostProcess(std::vector<std::shared_ptr<DNNTensor>> &output_tensors,
                Perception &perception);
float DequantiScale(int32_t data, bool big_endian, float &scale_value);
void SortByOrder(std::vector<std::shared_ptr<DNNTensor>> &output_tensors,
                 std::vector<int> order);
void ParseTensor(std::shared_ptr<DNNTensor> clses,
                 std::shared_ptr<DNNTensor> boxes,
                 int layer,
                 std::vector<Detection> &dets) {
  clses->CACHE_INVALIDATE();
  boxes->CACHE_INVALIDATE();
  int num_classes = yolo8_config_.class_num;
  int reg_max = yolo8_config_.reg_max;
  int stride = yolo8_config_.strides[layer];
  std::vector<float> class_pred(yolo8_config_.class_num, 0.0);
  int height, width;
  auto ret =
      hobot::dnn_node::output_parser::get_tensor_hw(boxes, &height, &width);
  if (ret != 0) {
                 "get_tensor_hw failed");
  float *cls_data = clses->GetTensorData<float>();
  float *box_data = boxes->GetTensorData<float>();
  // auto *box_scale_data =
  //     reinterpret_cast<float *>(boxes->properties.scale.scaleData);
  for (int h = 0; h < height; ++h) {
    for (int w = 0; w < width; ++w) {
      float *cur_cls_data = cls_data;
      float *cur_box_data = box_data;
      cls_data += num_classes;
      box_data += reg_max * 4;
      int id = argmax(cur_cls_data, cur_cls_data + num_classes);
      if (cur_cls_data[id] < score_threshold_) {
        continue;
      double confidence = 1 / (1 + std::exp(-cur_cls_data[id]));
      float sum, distribute_score;
      size_t box_id = 0;
      std::vector<float> decoded_boxes(4, 0);
      for (size_t i = 0; i < 4; ++i) {
        sum = 0.;
        for (int reg = 0; reg < reg_max; ++reg) {
          if (is_performance_) {
            distribute_score = fastExp(cur_box_data[box_id]);
          } else {
            distribute_score = std::exp(cur_box_data[box_id]);
          sum += distribute_score;
          decoded_boxes[i] += distribute_score * reg;
          ++box_id;
        decoded_boxes[i] /= sum;
      float xmin = (w + 0.5 - decoded_boxes[0]) * stride;
      float ymin = (h + 0.5 - decoded_boxes[1]) * stride;
      float xmax = (w + 0.5 + decoded_boxes[2]) * stride;
      float ymax = (h + 0.5 + decoded_boxes[3]) * stride;
      if (xmax <= 0 || ymax <= 0) {
        continue;
      if (xmin > xmax || ymin > ymax) {
        continue;
      Bbox bbox(xmin, ymin, xmax, ymax);
      dets.emplace_back(
          static_cast<int>(id),
          confidence,
          bbox,
          yolo8_config_.class_names[static_cast<int>(id)].c_str());
int32_t Parse(
    const std::shared_ptr<hobot::dnn_node::DnnNodeOutput> &node_output,
    std::shared_ptr<DnnParserResult> &result) {
  if (!result) {
    result = std::make_shared<DnnParserResult>();
  SortByOrder(node_output->output_tensors, yolo8_config_.output_order);
  int ret = PostProcess(node_output->output_tensors, result->perception);
  if (ret != 0) {
    RCLCPP_INFO(rclcpp::get_logger("Yolo8_detection_parser"),
                "postprocess return error, code = %d",
                ret);
  ss << "Yolo8_detection_parser parse finished, predict result: "
     << result->perception;
  RCLCPP_DEBUG(
      rclcpp::get_logger("Yolo8_detection_parser"), "%s", ss.str().c_str());
  return ret;
                Perception &perception) {
  perception.type = Perception::DET;
  std::vector<Detection> dets;
  auto ts_start = std::chrono::steady_clock::now();
  std::vector<std::future<std::shared_ptr<std::vector<Detection>>>> futs;
  auto output_size = output_tensors.size() / 2;
  for (size_t i = 0; i < output_size; i++) {
    auto fut = std::async(std::launch::async, [&output_tensors, i]() {
      std::shared_ptr<std::vector<Detection>> sp_det = nullptr;
      std::vector<Detection> _dets;
      auto start = std::chrono::steady_clock::now();
      ParseTensor(output_tensors[i * 2],
                  output_tensors[i * 2 + 1],
                  static_cast<int>(i),
                  _dets);
      int time_ms = std::chrono::duration_cast<std::chrono::milliseconds>(
                        std::chrono::steady_clock::now() - start)
                        .count();
      RCLCPP_DEBUG_STREAM(rclcpp::get_logger("yolo8_detection_parser"),
                          "parse tensor " << i << " cost [" << time_ms << "]");
      if (!_dets.empty()) {
        sp_det = std::make_shared<std::vector<Detection>>(_dets);
      return sp_det;
    futs.push_back(std::move(fut));
  for (size_t i = 0; i < futs.size(); i++) {
    if (!futs[i].valid()) {
                   "fut is not valid");
      return -1;
    futs[i].wait();
    auto det = futs[i].get();
    if (det) {
      dets.insert(dets.end(),
                  std::make_move_iterator(det->begin()),
                  std::make_move_iterator(det->end()));
  int parse_tensor_time_ms =
          std::chrono::steady_clock::now() - ts_start)
          .count();
  nms(dets, nms_threshold_, nms_top_k_, perception.det, false);
  int nms_time_ms = std::chrono::duration_cast<std::chrono::milliseconds>(
                        .count();
                      "output_tensors size: "
                          << output_tensors.size() << ", parse_tensor_time_ms ["
                          << parse_tensor_time_ms << "] nms_time_ms ["
                          << nms_time_ms << "]");
  return 0;
float DequantiScale(int32_t data, bool big_endian, float &scale_value) {
  return static_cast<float>(r_int32(data, big_endian)) * scale_value;
void SortByOrder(std::vector<std::shared_ptr<DNNTensor>> &outputs,
                 std::vector<int> order) {
  std::vector<std::shared_ptr<DNNTensor>> outputs_sorted(outputs.size());
  for (int i = 0; i < outputs.size(); i++) {
    outputs_sorted[i] = outputs[order[i]];
  outputs = outputs_sorted;
}  // namespace parser_yolov8
}  // namespace dnn_node
}  // namespace hobot
嗯,整体逻辑一致,确认一下是S100 的开发板吗 S100P和S100的模型不通用
是S100同一个板子运行的
Index of /downloads/rdk_model_zoo/rdk_s100/Ultralytics_YOLO_OE_3.5.0/Nash-e/ 用这里面的模型测试一下呢
也是不行的
11s
是4.0.4的系统吗。这边同样的修改测试正常
是404而且应该也更新到最新了啊 :sob:
就保持nms 0.7 score 0.25 会出现那种情况吗,排除相机试试本地回灌呢
现在应该不是0.25应该是0.8
本地回灌图片也是类似的
抱歉是403系统这个404是刚发布的吗 我这几天没看 :sweat_smile:
这个是必须得404才正常吗
25.10 就发布了 ,控制变量目前只能发现这个问题了
是刷了mini boot才能apt升级到最新吗 我 apt那边已经没有更新了?
是需要apt最新后更新miniboot
好我回来更新试试吧
经确认 用来试验的系统已升级到404并且所有软件包均已更新到最新
我重新拉取了所有源码并重新编译后覆盖至试验用S100
使用自带的yolov11workconfig.json时效果如下
复制此配置文件并修改为重新下载的OE3.5版yolo11s效果如下
同样的配置文件使用自行训练的模型效果如下
所有运行指令均为
ros2 launch dnn_node_example dnn_node_example.launch.py dnn_example_config_file:=config/yolov11fpworkconfig.json dnn_example_image_width:=1920 dnn_example_image_height:=1080
只是配置文件不同
此外后两个配置文件score_threshold配置为0.8
Model Zoo中的Cpp demo能否正常推理
