It looks like you’re encountering an issue with downloading the OpenExplorer® algorithm toolchain, as the page is showing a login/authorization error. The popup indicates that you need to request access from either the “地平线开发者社区” (Horizon Developer Community) or the “地瓜开发者社区” (Gourd Developer Community), depending on your origin.
Since this is a new account and the forum may require specific permissions or affiliations to access certain resources, here are some steps you can take:
Check Your Access: Ensure that you’re logged into the correct developer community (either 地平线 or 地瓜). If you’re not already registered, you may need to sign up for the appropriate community first.
Request Access: Click on the “请点击授权” (Click to authorize) button in the popup. This should redirect you to a page where you can request access or log in with your credentials.
Contact Support: If the authorization process doesn’t work, consider reaching out to the forum moderators or the OpenExplorer® support team directly. You can also post a follow-up message in this thread asking for guidance.
Verify Download Link: Sometimes, download links might be broken or region-restricted. Double-check if there’s an alternative download link provided elsewhere on the site or in the documentation.
If you need further assistance, feel free to ask! Let me know if you’d like help finding more information about the OpenExplorer® toolchain or how to get access to the developer communities.
Thank you for your patience, and I hope you resolve this issue soon!
您好,感谢您的提问!根据您提供的截图和论坛信息,我们已经定位到问题的核心:
问题总结:
您在访问 OpenExplorer® 算法工具链下载页面时,遇到“认证失败”弹窗,提示需要从“地平线开发者社区”或“地瓜开发者社区”授权登录。这通常是因为:
- 您当前未登录任何开发者社区;
- 新账号未被授权访问资源;
- 页面跳转机制要求通过特定社区入口进行身份验证。
解决方案建议:
1.
登录正确的开发者社区
请先访问以下官方链接并注册/登录:
地平线开发者社区
地瓜开发者社区(如适用) —— 有时用于特定产品线(如RDK X系列)
注意:部分工具链(如 RDK S100、X5、X3)的下载链接是独立于社区登录的,可通过 FTP 直接下载(见下方)。
2.
推荐直接使用 FTP 下载(无需登录社区)
根据论坛中其他用户的分享,OpenExplorer 工具链支持通过 FTP 直接下载,适用于已注册用户或可接受密码访问的情况:
示例命令(适用于 RDK S100):
wget -c ftp://oeftp@sdk.d-robotics.cc/oe_v3.2.0/s100-3.2.0-oe-package.tgz --ftp-password=Oeftp~123$%
示例命令(适用于 RDK X5):
wget -c ftp://x5ftp@vrftp.horizon.ai/OpenExplorer/v1.2.8_release/horizon_x5_open_explorer_v1.2.8-py310_20240926.tar.gz --ftp-password=x5ftp@123$%
密码通常是
Oeftp~123$%或x5ftp@123$%,具体取决于芯片型号。请根据您的开发板型号选择对应版本。
3.
查看官方文档获取最新版本
最新算法工具链版本为 3.7.0,可在以下路径查阅:
官方工具链文档
4.
如果仍无法下载?
请尝试以下操作:
- 清除浏览器缓存或换浏览器;
- 使用公司/学校网络(部分公网限制);
- 在论坛发帖求助,附上截图 + 芯片型号 + 浏览器类型;
- 联系地平线技术支持邮箱或客服(如有)。
特别提醒:
虽然社区登录页提示“授权”,但很多工具链资源是开放FTP下载的,尤其对已注册用户或企业客户。您可以优先尝试 FTP 方式,避免因社区跳转失败而卡住。
如果您能提供:
- 您使用的芯片型号(如 RDK S100 / X5 / X3);
- 您希望下载的具体工具包名称(如 CPU Docker / GPU Docker / 开发包);
我可以为您精准匹配对应的下载命令和校验 MD5!
感谢您的耐心阅读与配合!希望以上信息能帮助您顺利获取 OpenExplorer® 工具链。如有其他问题,欢迎随时提问!
祝您开发顺利!![]()
