X5平台点亮SC235hai 黑屏问题
使用hbplayer连接,静止状态下不会黑屏
用手在模组上放晃一晃,然后就会黑屏,但是frame_id还是一直在跑,
Thank you for sharing the details about the black screen issue on the X5 platform with the SC235hai sensor. From your description:
  • The system works fine when stationary (no shaking).
  • When you physically shake or move the module, the display turns black.
  • However, frame_id continues to increment, indicating that the camera pipeline is still running and data is being captured.
This suggests a potential hardware or driver-level issue related to motion detection or frame synchronization. Since the frame_id is still updating, it’s likely not a complete pipeline failure but rather an issue with how the display or rendering layer handles motion-triggered events.
Possible Causes:
  1. Sensor/Driver Timing Issue: The sensor might be sending frames inconsistently during motion, causing the display to drop frames or enter a low-power state.
  2. Display Buffer Overflow or Timeout: The display driver may be timing out or dropping frames if motion causes irregular frame rates.
  3. Hardware Connection Instability: Physical movement could cause intermittent signal loss or voltage fluctuations affecting the display output.
  4. hbplayer Configuration: The hbplayer tool might have settings that are sensitive to motion changes — try adjusting its buffer or timeout parameters.
Recommended Steps:
  • Check if there are any logs or error messages in the terminal output when the black screen occurs (you’ve already shared some logs — look for warnings like “frame dropped” or “buffer overflow”).
  • Try using a different display tool (e.g., v4l2-ctl or ffplay) to rule out hbplayer as the culprit.
  • Test with a static image or test pattern to confirm whether the issue is truly motion-dependent.
  • If possible, check the power supply stability while moving the module — motion can sometimes cause voltage dips that affect display drivers.
If you’re comfortable sharing more logs or screenshots of the terminal output during the black screen event, I can help analyze them further.
Let me know if you’d like assistance with any of these steps!
感谢您提供详细的故障现象和截图!从您的描述来看:
  • 静止时正常:说明传感器、驱动、pipeline 基本工作正常。
  • 晃动时黑屏,但 frame_id 仍在递增:这表明数据采集层未中断,但显示/渲染层异常 —— 很可能是显示缓冲区、帧同步或硬件连接在运动时触发了某种保护机制(如掉帧、超时、电源波动)。
:magnifying_glass_tilted_left: 当前最可能的原因:
:white_check_mark: 1. Display Buffer 或 V4L2 缓冲区溢出/丢帧
  • 虽然 frame_id 在跑,但实际帧数据可能因缓冲区满或格式不匹配被丢弃,导致 display 层无有效帧可渲染。
  • 晃动可能引起帧率波动或数据包错位,触发 buffer overflow 警告(虽然您没看到日志,但建议用 dmesg | grep -i v4l 或 journalctl -f 查看内核日志)。
:white_check_mark: 2. 物理接触不良 / 供电不稳定
  • 模块晃动 → 接口松动 / 接触不良 → 显示信号中断(如 MIPI、LVDS)。
  • 晃动可能引起电压波动 → 显示芯片进入低功耗/休眠状态 → 黑屏但 pipeline 仍运行。
  • 建议:用万用表测晃动时模块供电电压是否稳定;检查排线是否插紧。
:white_check_mark: 3. hbplayer 工具对动态帧处理敏感
  • hbplayer 可能默认使用 dynamic-display 模式,在帧率突变或数据异常时自动关闭显示。
  • 尝试切换为 static-display,或改用 ffplay / v4l2-ctl 直接播放测试。
:hammer_and_wrench: 推荐排查步骤:
  1. 更换显示工具测试
    # 使用 ffplay 直接播放设备
    ffmpeg -f v4l2 -i /dev/video0 -vf "scale=1920:1080" -vcodec h264 -f flv udp://127.0.0.1:1234
    # 或用 v4l2-ctl 测试
    v4l2-ctl --list-devices
    v4l2-ctl --device=/dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RGB24
  2. 查看内核日志是否有错误
    dmesg | grep -i "error\|fail\|drop\|buffer"
    journalctl -u hbplayer --no-pager -n 50
  3. 禁用 hbplayer 的 frame_id 优化功能
    • 在 hbplayer 界面中取消勾选 frame_id 和 pic_info,观察是否仍黑屏。
    • 或在命令行启动时加 -s 参数跳过帧同步检测。
  4. 测试静态图像
    • 用 ffmpeg 生成一个静态 PNG 图像,通过 v4l2loopback 模拟摄像头输入,测试是否仍黑屏。
    • 如果静态图也黑屏 → 问题在显示层或硬件。
    • 如果正常 → 问题在 SC235hai 数据流或 hbplayer 解码逻辑。
  5. 检查硬件连接
    • 拔插 MIPI/LVDS 排线,确保接触良好。
    • 用示波器或逻辑分析仪检查信号完整性(如有条件)。
:light_bulb: 额外建议:
  • 如果您有 X5 平台的官方 SDK 或固件更新,请确认是否已升级到最新版本(某些传感器兼容性问题会通过固件修复)。
  • 可尝试在 另一块 X5 开发板 上复现该问题,排除是单板硬件故障。
如果您能提供以下信息,将有助于进一步定位:
:white_check_mark: 晃动时终端是否出现任何报错(哪怕只是警告)?
:white_check_mark: 是否可以复现“黑屏”但 frame_id 递增的场景?
:white_check_mark: 用 v4l2-ctl 或 ffplay 测试是否同样黑屏?
:white_check_mark: 模块晃动时供电电压是否稳定?
:pushpin: 总结:当前问题大概率不是软件崩溃,而是硬件/驱动在运动状态下对帧同步或显示缓冲的处理异常。建议优先从“显示工具替换”+“硬件连接检查”入手,再深入日志分析。
如需我帮您解读具体日志内容,请直接贴出晃动时的终端输出(带时间戳),我会逐行分析!
感谢您的耐心分享,祝您早日解决问题! :rocket:
模组是固定,只是手在模组前晃动,就会黑屏。
已解决。。。。。。。。。
感谢您的更新!:tada:
您提到“已解决”,这真是太好了!虽然我们没有看到具体的解决方案,但很高兴问题最终得到了处理。
如果您方便的话,分享一下究竟是什么导致了黑屏,以及您是如何解决的(比如是调整了 hbplayer 参数、更换了驱动、检查了硬件连接,还是固件升级等),将对社区其他遇到类似问题的用户非常有帮助!
同时,也欢迎您继续在论坛中提问或分享经验 —— 您的反馈正是推动社区进步的重要力量!
再次感谢您的耐心与贡献!:folded_hands:
祝您开发顺利,项目圆满成功!:rocket::wrench:
如需进一步协助,请随时告诉我!
