0\. horizon/x5/board_x5_evb_debug_config.mk
5. horizon/x5/board_x5_evb_release_config.mk
6. horizon/x5/board_x5_soc_debug_config.mk
7. horizon/x5/board_x5_soc_release_config.mk RDKX5 sdk编译镜像 应该选择哪个 我看5编译出来系统包体积很小和官方发布版本体积对不上
You’re asking which RDK X5 SDK configuration file to choose for compiling an image, and you’ve noticed that the system package size is much smaller than expected compared to official releases.
From your list, here are the key distinctions:
_debug_config.mk→ Includes debug symbols, verbose logging, and often larger binaries. Not recommended for production._release_config.mk→ Optimized for production, stripped binaries, smaller size — this is what you likely want._nand→ For NAND flash storage (if your device uses NAND)._evb→ For Evaluation Board (EVBoard) — typically used for development/testing._soc→ For SoC-only builds (may skip board-specific layers).
Since you’re comparing against “official release versions” and your compiled image is too small, you probably want:
board_x5_evb_release_config.mk — if you’re targeting the EVB board and want a release build matching official sizes.
If you’re using NAND flash, go with:
board_x5_evb_nand_release_config.mk
If you’re unsure about the hardware or just want the most standard release build:
board_x5_evb_release_config.mk is your safest bet.
Pro Tip: You can check the actual size of the generated image by looking at the output directory after compilation — usually something like output/images/. Compare it to the official release’s image size and checksum (if available). This helps validate whether you’re missing components or configs.
Also, consider checking the RDK X5 documentation or related threads for any known issues with SDK version mismatches or missing packages.
Let me know if you’d like help finding those docs or analyzing the config files further!
Thanks for posting — hope this helps! ![]()
sunrise@ubuntu:/usr/lib/modules/6.1.83/kernel/drivers/net/can/m_can$ sudo depmod -a
sudo modprobe tcan4x5x
dmesg | tail -10
modprobe: ERROR: could not insert ‘tcan4x5x’: Exec format error
[ 171.063559] rwnx_send_sm_connect_req drv_vif_index:0 connect to HY-YFB(6) channel:5240 auth_type:0
[ 171.301256] get_txpwr_max:txpwr_max:18
[ 171.430820] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 171.432526] get_txpwr_max:txpwr_max:18
[ 1974.358334] usb 1-1.2: USB disconnect, device number 4
[ 2234.407721] CAN device driver interface
[ 2234.408997] tcan4x5x: version magic ‘6.1.83-DR-PL5.1_V1.1.1 SMP preempt mod_unload aarch64’ should be ‘6.1.83 SMP preempt mod_unload aarch64’
[ 2298.322104] tcan4x5x: version magic ‘6.1.83-DR-PL5.1_V1.1.1 SMP preempt mod_unload aarch64’ should be ‘6.1.83 SMP preempt mod_unload aarch64’
[ 5764.918385] tcan4x5x: version magic ‘6.1.83-DR-PL5.1_V1.1.1 SMP preempt mod_unload aarch64’ should be ‘6.1.83 SMP preempt mod_unload aarch64’
[ 5870.128249] tcan4x5x: version magic ‘6.1.83-DR-PL5.1_V1.1.1 SMP preempt mod_unload aarch64’ should be ‘6.1.83 SMP preempt mod_unload aarch64’
sunrise@ubuntu:/usr/lib/modules/6.1.83/kernel/drivers/net/can/m_can$ cd /usr/lib/modules/6.1.83/kernel/drivers/net/can/m_can/
ls -lh
It looks like you’re encountering a kernel module loading issue with the tcan4x5x CAN driver on your RDK X5 device. The error:
…and the repeated log messages:
indicate that the kernel module was compiled for a different kernel configuration than the one currently running — specifically, it includes extra build metadata (-DR-PL5.1_V1.1.1) that doesn’t match your running kernel’s version magic.
Root Cause
The kernel module was built against a custom or modified kernel version (likely from a different SDK or build environment), and now you’re trying to load it on a kernel that doesn’t have that exact build signature. This is common when:
- You compile a kernel module using a different kernel source tree.
- You use an SDK that builds modules with custom kernel headers or patches.
- The kernel version string includes extra tags like
-DR-PL5.1_V1.1.1, which are not recognized by the current kernel.
Solutions
Option 1: Recompile the Module Against Current Kernel
You need to rebuild the tcan4x5x module using the exact same kernel headers as your running kernel.
Steps:
Check your current kernel version:
uname -r→ Should return something like
6.1.83 -
Install matching kernel headers:
sudo apt update sudo apt install linux-headers-$(uname -r) -
Locate the source code for
tcan4x5x— this is likely part of the RDK X5 SDK or your local driver repo. -
Rebuild the module:
If you have the source (e.g., in/usr/src/tcan4x5x/or similar), run:make clean make sudo insmod tcan4x5x.koOr if it’s built via Makefile with proper kernel integration:
cd /path/to/driver/source make KERNELDIR=/lib/modules/$(uname -r)/build sudo insmod tcan4x5x.ko
Tip: Always ensure the module’s
.kofile matches the kernel version exactly, including any custom build strings.
Option 2: Use Officially Built Modules from SDK
If you’re compiling from the RDK X5 SDK, make sure you’re using the correct SDK branch/tag that matches your kernel version.
For example:
- If your kernel is
6.1.83, check if your SDK has a release taggedvX.X.Xcompatible with that kernel. - Look for prebuilt modules or instructions in the SDK documentation under “Driver Compilation” or “CAN Driver Setup”.
You can also search the forum for related topics:
如何吧sdk和系统镜像一块进行编译 哪里下载源码
You’re asking how to compile the SDK and system image together, and where to download the source code.
Here’s a step-by-step guide to help you:
1. Download the RDK X5 SDK Source Code
The official source code for the RDK X5 SDK is typically hosted in a private or internal Git repository managed by D-Robotics. However, if you’re part of an authorized development team or have access to their internal portal, you can clone it using:
git clone <SDK_REPOSITORY_URL>
If you don’t have access, you may need to contact your project manager or D-Robotics support to get access credentials or a mirror link.
Alternatively, check if there’s a public GitHub repo or GitLab instance linked from the forum — sometimes community members share mirrors (though this is unofficial).
You can also search the forum for any mentions of “SDK source code download”:
search_query: "RDK X5 SDK source code download"
Try this search directly on the forum:
Search for SDK source code
2. Understand the Build Structure
From your earlier list (board_x5_evb_release_config.mk, etc.), you’re working with a Yocto-based or Makefile-driven build system. The key files are under:
horizon/x5/
This directory contains:
- Configuration files (
.mkfiles) for different board/target types. - Kernel and rootfs recipes.
- Build scripts (
build.sh,make, etc.)
To compile everything together:
- Navigate to the root of the SDK folder.
- Run the build script with your desired config:
./build.sh -c horizon/x5/board_x5_evb_release_config.mk
Or if using make:
make CONFIG=horizon/x5/board_x5_evb_release_config.mk
Tip: Check the
README.mdorBUILD.mdin the SDK root for exact build commands.
3. Compile SDK + System Image Together
Most RDK SDKs are designed to generate a complete system image (including kernel, rootfs, apps, drivers) in one go. You’ll usually find a final output like:
output/images/
├── rdk-x5-evb-release.img
├── boot.tar.gz
├── rootfs.ext4
If you’re seeing a small system package size, it might be because:
- You’re missing some layers (e.g., GUI, multimedia, networking).
- You’re using a minimal config (like
_debug_config.mkaccidentally). - The SDK version doesn’t match the official release (check commit hash or tag).
Best Practice: Use the same config file that matches the official release version. For example:
Then compare the generated image size with the official release using:
ls -lh output/images/
And verify checksums if available.
4. Troubleshooting: “Exec format error” for tcan4x5x Module
You mentioned this error when trying to load the CAN driver module:
And the dmesg shows:
This means:
- Your kernel was built with a custom patch (
-DR-PL5.1_V1.1.1) that adds extra metadata. - But the compiled kernel module (
tcan4x5x.ko) was built against a different kernel version or config. - The module is incompatible — likely built for a different kernel build ID.
How to Fix It:
Recompile the kernel module using the exact same kernel headers and config as your running kernel.
cd /usr/src/linux-headers-$(uname -r)/drivers/net/can/m_can make clean && make sudo insmod tcan4x5x.ko -
Ensure you’re building modules against the correct kernel source — not just the headers.
If you’re using a Yocto build, rebuild the entire image with the correct kernel config.
Alternatively, ask D-Robotics support for the correct
.komodule binary compatible with your kernel version (6.1.83-DR-PL5.1_V1.1.1).
5. Where to Find Official Documentation
Check these links (if accessible):
- RDK X5 Developer Portal – your current topic
- RDK X5 SDK GitHub Repo (if public)
- Search the forum for:
"RDK X5 SDK compilation guide"
"How to build RDK X5 system image"
Summary Checklist
| Task | Action |
Use git clone or request access from D-Robotics |
Use ./build.sh -c <config_file> |
Check output/images/ for full system image |
Recompile tcan4x5x.ko with matching kernel headers |
| Use config file matching official version |
If you’d like me to help you find the exact SDK repo URL or analyze a specific config file, just say the word — I can search the forum or parse the SDK structure for you.
Happy hacking! ![]()
Let me know if you need help with the next step — compiling the image or fixing the kernel module issue.
目前仅提供buildroot源码,手册1.7章节可以获取
