MIPI摄像头不能用cd /app/cdev_demo/vio2display
sunrise@ubuntu:~$ cd /app/cdev_demo/vio2display
sunrise@ubuntu:/app/cdev_demo/vio2display$ sudo make
sudo ./vicc -o /app/cdev_demo/vio2display/vio2display.o -c /app/cdev_demo/vio2display/vio2display.c
cc -O3 -o vio2display /app/cdev_demo/vio2display/vio2display.o -lspcdev
sunrise@ubuntu:/app/cdev_demo/vio2display$ sudo ./vio2display -w 1920 -h 1080
Opened DRM device: /dev/dri/card0
1920x1080
1600x1200
1600x900
1366x768
1360x768
1280x1024
1280x800
1280x768
1280x720
1152x864
1024x768
1024x600
800x600
720x576
720x480
640x480
disp_w=1920, disp_h=1080
2026/07/13 17:38:18.758 !INFO [OpenCamera][0471]hbn module
set camera fps: -1,width: 1920,height: 1080
Camera 0:
mipi_host: 0
Camera 1:
mipi_host: 2
Camera 2:
mipi_host: 0
Camera 3:
mipi_host: 0
mipi mclk is not configed.
WARN: Sensor Name: sc132gs-hdr-2lane, Expected Chip ID: 0x132, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc035hgs, Expected Chip ID: 0x31, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc035hgs_mono, Expected Chip ID: 0x31, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx586-30fps-4lane, Expected Chip ID: 0x586, Actual Chip ID Read: 0x00
WARN: Sensor Name: os08c10-30fps-2lane, Expected Chip ID: 0x53, Actual Chip ID Read: 0x00
WARN: Sensor Name: ar0233-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
WARN: Sensor Name: ar0820std-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc1336, Expected Chip ID: 0xCA3F, Actual Chip ID Read: 0x00
WARN: Sensor Name: dummy, Expected Chip ID: 0x00, Actual Chip ID Read: 0x00
WARN: Sensor Name: ar0233-30fps, Expected Chip ID: 0xA55A, Actual Chip ID Read: 0x00
WARN: Sensor Name: ov9782-200fps-2lane, Expected Chip ID: 0x9281, Actual Chip ID Read: 0x00
WARN: Sensor Name: ov9782-120fps-2lane, Expected Chip ID: 0x9281, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx477-2016x1520-21fps, Expected Chip ID: 0x477, Actual Chip ID Read: 0x00
WARN: Sensor Name: ov50h40-30fps-4lane, Expected Chip ID: 0x6C, Actual Chip ID Read: 0x00
WARN: Sensor Name: ox05b1s, Expected Chip ID: 0x58, Actual Chip ID Read: 0x00
WARN: Sensor Name: ox05b1s_2lane, Expected Chip ID: 0x58, Actual Chip ID Read: 0x00
WARN: Sensor Name: imx415-60fps-4lane, Expected Chip ID: 0x03, Actual Chip ID Read: 0x00
WARN: Sensor Name: sc850sl-30fps, Expected Chip ID: 0x9D1E, Actual Chip ID Read: 0x00
WARN: Sensor Name: shw3g-30fps, Expected Chip ID: 0xCB34, Actual Chip ID Read: 0x00
Searching camera sensor on device: /proc/device-tree/soc/cam/vcon@2 i2c bus: 4 mipi rx phy: 2
[0] INFO: Found sensor name:imx219-1920x1080-30fps on mipi rx csi 2, i2c addr 0x10, config_file:linear_1920x1080_raw10_30fps_2lane.c
2026/07/13 17:38:19.353 !INFO [CamInitParam][0341]Setting VSE channel-0: input_width:1920, input_height:1080, dst_w:1920, dst_h:1080
2026/07/13 17:38:19.353 !INFO [CamInitParam][0345]ROI: x:0, y:0, w:1920, h:1080, target_w:1920, target_h:1080
2026/07/13 17:38:19.354 !INFO [CamInitParam][0341]Setting VSE channel-1: input_width:1920, input_height:1080, dst_w:1920, dst_h:1080
2026/07/13 17:38:19.354 !INFO [CamInitParam][0345]ROI: x:0, y:0, w:1920, h:1080, target_w:1920, target_h:1080
2026/07/13 17:38:19.354 !INFO [vp_vin_init][0055]csi2 ignore mclk ex attr, because mclk is not configed at device tree.
2026/07/13 17:38:19.369 ERROR [vp_isp_init][0054] hbn_vnode_set_attr failed, ret(-10)
2026/07/13 17:38:19.370 ERROR [vp_vse_init][0050] hbn_vnode_set_attr failed, ret(-10)
2026/07/13 17:38:19.371 ERROR [OpenCamera][0532]pipeline init failed error(-10)
针对特定的问题,请参考特定领域问题的发帖模板继续提供相关信息: forum.d-robotics.cc/t/topic/28613
